Jetson Nano 2G.
• DeepStream Version
DeepStream 6 installed by .deb.
4.6, SD card image downloaded at Nov 2021.
• TensorRT Version
questions.
I’m trying to get a python app that achieve:
- Receive sources as multiple rtsp input streams or .mp4 files.
- Detect objects in sources.
- Output to a rstp stream(start a rtsp server).
- Output to local tiler osd.
- Output analytics data to kafka server.
I can run through all existing python app source code samples.
I basically followed the existing samples, and trying to combined several of them, after some work and run the app, can see very limited detection results printed out(Kafka server received nothing) then stuck.
I believe I must have some mis-config when constructing the pipeline since it’s not that clear(what the purpose, what the sequence) for me.
The terminal console show some objects detected:
eow@nano2gforcam:/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/deepstream-test51-on-test4$ python3 deepstream_test_51.py -i file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264 -p /opt/nvidia/deepstream/deepstream/lib/libnvds_kafka_proto.so --conn-str=“dev-iot.xxx.xxx;9092” --topic=“test” -s 0
Creating PipelineCreating streamux
Creating source_bin 0
source-bin-02 is created
Creating PgieCreating tiler
Creating nvvidconv
Creating nvosd
Creating nvvideoconvert - postosd
Creating caps
Creating H264 Encoder
Creating H264 rtppay
Creating EGLSinkAdding elements to Pipeline
Starting pipeline
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
Using winsys: x11
Opening in BLOCKING MODE
0:00:06.768180520 17203 0x302c40f0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1161> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.0/sources/deepstream_python_apps/apps/deepstream-test51-on-test4/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:09.770505297 17203 0x302c40f0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.0/sources/deepstream_python_apps/apps/deepstream-test51-on-test4/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:09.770682957 17203 0x302c40f0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.0/sources/deepstream_python_apps/apps/deepstream-test51-on-test4/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:09.770716499 17203 0x302c40f0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
WARNING: INT8 not supported by platform. Trying FP16 mode.
WARNING: [TRT]: Detected invalid timing cache, setup a local cache instead
ERROR: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine opened error
0:01:35.610217620 17203 0x302c40f0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1942> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x400:01:35.854824664 17203 0x302c40f0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dstest51_pgie_config.txt sucessfully
Decodebin child added: sourceDecodebin child added: decodebin0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: nvv4l2decoder0
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
In cb_newpadgstname= video/x-raw
features= <Gst.CapsFeatures object at 0x7f7a8920a8 (GstCapsFeatures at 0x7ed0037120)>
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
Frame Number = 0 Vehicle Count = 6 Person Count = 3
Frame Number = 0 Vehicle Count = 7 Person Count = 3
H264: Profile = 66, Level = 0
NVMEDIA_ENC: bBlitMode is set to TRUE
The app’s source code:
#!/usr/bin/env python3
import sys
sys.path.append('../')
import gi
gi.require_version("Gst", "1.0")
gi.require_version("GstRtspServer", "1.0")
from gi.repository import GObject, Gst, GstRtspServer, GLib
import sys
import math
from optparse import OptionParser
from common.is_aarch_64 import is_aarch64
from common.bus_call import bus_call
from common.utils import long_to_uint64
import pyds
import argparse
MAX_DISPLAY_LEN = 64
MAX_TIME_STAMP_LEN = 32
PGIE_CLASS_ID_VEHICLE = 0
PGIE_CLASS_ID_BICYCLE = 1
PGIE_CLASS_ID_PERSON = 2
PGIE_CLASS_ID_ROADSIGN = 3
MUXER_OUTPUT_WIDTH = 1920
MUXER_OUTPUT_HEIGHT = 1080
MUXER_BATCH_TIMEOUT_USEC = 4000000
TILED_OUTPUT_WIDTH = 1280
TILED_OUTPUT_HEIGHT = 720
input_file = None
schema_type = 0
proto_lib = None
conn_str = "localhost;2181;testTopic"
cfg_file = None
topic = None
no_display = False
PGIE_CONFIG_FILE = "dstest51_pgie_config.txt"
MSCONV_CONFIG_FILE = "dstest51_msgconv_config.txt"
pgie_classes_str = ["Vehicle", "TwoWheeler", "Person", "Roadsign"]
def create_source_bin(index, uri):
# print(" source bin")
# Create a source GstBin to abstract this bin's content from the rest of the
# pipeline
bin_name = "source-bin-%02d" % index
print(" " + bin_name + " is created")
nbin = Gst.Bin.new(bin_name)
if not nbin:
sys.stderr.write(" Unable to create source bin \n")
# Source element for reading from the uri.
# We will use decodebin and let it figure out the container format of the
# stream and the codec and plug the appropriate demux and decode plugins.
uri_decode_bin = Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
if not uri_decode_bin:
sys.stderr.write(" Unable to create uri decode bin \n")
# We set the input uri to the source element
uri_decode_bin.set_property("uri", uri)
# Connect to the "pad-added" signal of the decodebin which generates a
# callback once a new pad for raw data has beed created by the decodebin
uri_decode_bin.connect("pad-added", cb_newpad, nbin)
uri_decode_bin.connect("child-added", decodebin_child_added, nbin)
# We need to create a ghost pad for the source bin which will act as a proxy
# for the video decoder src pad. The ghost pad will not have a target right
# now. Once the decode bin creates the video decoder and generates the
# cb_newpad callback, we will set the ghost pad target to the video decoder
# src pad.
Gst.Bin.add(nbin, uri_decode_bin)
bin_pad = nbin.add_pad(
Gst.GhostPad.new_no_target(
"src", Gst.PadDirection.SRC))
if not bin_pad:
sys.stderr.write(" Failed to add ghost pad in source bin \n")
return None
return nbin
def decodebin_child_added(child_proxy, Object, name, user_data):
print("Decodebin child added:", name, "\n")
if name.find("decodebin") != -1:
Object.connect("child-added", decodebin_child_added, user_data)
def cb_newpad(decodebin, decoder_src_pad, data):
print("In cb_newpad\n")
caps = decoder_src_pad.get_current_caps()
gststruct = caps.get_structure(0)
gstname = gststruct.get_name()
source_bin = data
features = caps.get_features(0)
# Need to check if the pad created by the decodebin is for video and not
# audio.
print("gstname=", gstname)
if gstname.find("video") != -1:
# Link the decodebin pad only if decodebin has picked nvidia
# decoder plugin nvdec_*. We do this by checking if the pad caps contain
# NVMM memory features.
print("features=", features)
if features.contains("memory:NVMM"):
# Get the source bin ghost pad
bin_ghost_pad = source_bin.get_static_pad("src")
if not bin_ghost_pad.set_target(decoder_src_pad):
sys.stderr.write(
"Failed to link decoder src pad to source bin ghost pad\n"
else:
sys.stderr.write(
" Error: Decodebin did not pick nvidia decoder plugin.\n")
# Callback function for deep-copying an NvDsEventMsgMeta struct
def meta_copy_func(data, user_data):
# Cast data to pyds.NvDsUserMeta
user_meta = pyds.NvDsUserMeta.cast(data)
src_meta_data = user_meta.user_meta_data
# Cast src_meta_data to pyds.NvDsEventMsgMeta
srcmeta = pyds.NvDsEventMsgMeta.cast(src_meta_data)
# Duplicate the memory contents of srcmeta to dstmeta
# First use pyds.get_ptr() to get the C address of srcmeta, then
# use pyds.memdup() to allocate dstmeta and copy srcmeta into it.
# pyds.memdup returns C address of the allocated duplicate.
dstmeta_ptr = pyds.memdup(pyds.get_ptr(srcmeta),
sys.getsizeof(pyds.NvDsEventMsgMeta))
# Cast the duplicated memory to pyds.NvDsEventMsgMeta
dstmeta = pyds.NvDsEventMsgMeta.cast(dstmeta_ptr)
# Duplicate contents of ts field. Note that reading srcmeat.ts
# returns its C address. This allows to memory operations to be
# performed on it.
dstmeta.ts = pyds.memdup(srcmeta.ts, MAX_TIME_STAMP_LEN + 1)
# Copy the sensorStr. This field is a string property. The getter (read)
# returns its C address. The setter (write) takes string as input,
# allocates a string buffer and copies the input string into it.
# pyds.get_string() takes C address of a string and returns the reference
# to a string object and the assignment inside the binder copies content.
dstmeta.sensorStr = pyds.get_string(srcmeta.sensorStr)
if srcmeta.objSignature.size > 0:
dstmeta.objSignature.signature = pyds.memdup(
srcmeta.objSignature.signature, srcmeta.objSignature.size)
dstmeta.objSignature.size = srcmeta.objSignature.size
if srcmeta.extMsgSize > 0:
if srcmeta.objType == pyds.NvDsObjectType.NVDS_OBJECT_TYPE_VEHICLE:
srcobj = pyds.NvDsVehicleObject.cast(srcmeta.extMsg)
obj = pyds.alloc_nvds_vehicle_object()
obj.type = pyds.get_string(srcobj.type)
obj.make = pyds.get_string(srcobj.make)
obj.model = pyds.get_string(srcobj.model)
obj.color = pyds.get_string(srcobj.color)
obj.license = pyds.get_string(srcobj.license)
obj.region = pyds.get_string(srcobj.region)
dstmeta.extMsg = obj
dstmeta.extMsgSize = sys.getsizeof(pyds.NvDsVehicleObject)
if srcmeta.objType == pyds.NvDsObjectType.NVDS_OBJECT_TYPE_PERSON:
srcobj = pyds.NvDsPersonObject.cast(srcmeta.extMsg)
obj = pyds.alloc_nvds_person_object()
obj.age = srcobj.age
obj.gender = pyds.get_string(srcobj.gender)
obj.cap = pyds.get_string(srcobj.cap)
obj.hair = pyds.get_string(srcobj.hair)
obj.apparel = pyds.get_string(srcobj.apparel)
return dstmeta
# Callback function for freeing an NvDsEventMsgMeta instance
def meta_free_func(data, user_data):
srcmeta = pyds.NvDsEventMsgMeta.cast(user_meta.user_meta_data)
# pyds.free_buffer takes C address of a buffer and frees the memory
# It's a NOP if the address is NULL
pyds.free_buffer(srcmeta.ts)
pyds.free_buffer(srcmeta.sensorStr)
pyds.free_buffer(srcmeta.objSignature.signature)
srcmeta.objSignature.size = 0
pyds.free_buffer(obj.type)
pyds.free_buffer(obj.color)
pyds.free_buffer(obj.make)
pyds.free_buffer(obj.model)
pyds.free_buffer(obj.license)
pyds.free_buffer(obj.region)
pyds.free_buffer(obj.gender)
pyds.free_buffer(obj.cap)
pyds.free_buffer(obj.hair)
pyds.free_buffer(obj.apparel)
pyds.free_gbuffer(srcmeta.extMsg)
srcmeta.extMsgSize = 0
def generate_vehicle_meta(data):
obj = pyds.NvDsVehicleObject.cast(data)
obj.type = "sedan"
obj.color = "blue"
obj.make = "Bugatti"
obj.model = "M"
obj.license = "XX1234"
obj.region = "CA"
return obj
def generate_person_meta(data):
obj = pyds.NvDsPersonObject.cast(data)
obj.age = 45
obj.cap = "none"
obj.hair = "black"
obj.gender = "male"
obj.apparel = "formal"
return obj
def generate_event_msg_meta(data, class_id):
meta = pyds.NvDsEventMsgMeta.cast(data)
meta.sensorId = 0
meta.placeId = 0
meta.moduleId = 0
meta.sensorStr = "sensor-0"
meta.ts = pyds.alloc_buffer(MAX_TIME_STAMP_LEN + 1)
pyds.generate_ts_rfc3339(meta.ts, MAX_TIME_STAMP_LEN)
# This demonstrates how to attach custom objects.
# Any custom object as per requirement can be generated and attached
# like NvDsVehicleObject / NvDsPersonObject. Then that object should
# be handled in payload generator library (nvmsgconv.cpp) accordingly.
if class_id == PGIE_CLASS_ID_VEHICLE:
meta.type = pyds.NvDsEventType.NVDS_EVENT_MOVING
meta.objType = pyds.NvDsObjectType.NVDS_OBJECT_TYPE_VEHICLE
meta.objClassId = PGIE_CLASS_ID_VEHICLE
obj = generate_vehicle_meta(obj)
meta.extMsg = obj
if class_id == PGIE_CLASS_ID_PERSON:
meta.type = pyds.NvDsEventType.NVDS_EVENT_ENTRY
meta.objType = pyds.NvDsObjectType.NVDS_OBJECT_TYPE_PERSON
meta.objClassId = PGIE_CLASS_ID_PERSON
obj = generate_person_meta(obj)
meta.extMsg = obj
meta.extMsgSize = sys.getsizeof(pyds.NvDsPersonObject)
return meta
# osd_sink_pad_buffer_probe will extract metadata received on OSD sink pad
# and update params for drawing rectangle, object information etc.
# IMPORTANT NOTE:
# a) probe() callbacks are synchronous and thus holds the buffer
# (info.get_buffer()) from traversing the pipeline until user return.
# b) loops inside probe() callback could be costly in python.
# So users shall optimize according to their use-case.
def osd_sink_pad_buffer_probe(pad, info, u_data):
frame_number = 0
# Intiallizing object counter with 0.
obj_counter = {
PGIE_CLASS_ID_VEHICLE: 0,
PGIE_CLASS_ID_PERSON: 0,
PGIE_CLASS_ID_BICYCLE: 0,
PGIE_CLASS_ID_ROADSIGN: 0
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
# Retrieve batch metadata from the gst_buffer
# Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
# C address of gst_buffer as input, which is obtained with hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
if not batch_meta:
return Gst.PadProbeReturn.OK
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.NvDsFrameMeta.cast()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
except StopIteration:
continue
is_first_object = True
# Short example of attribute access for frame_meta:
# print("Frame Number is ", frame_meta.frame_num)
# print("Source id is ", frame_meta.source_id)
# print("Batch id is ", frame_meta.batch_id)
# print("Source Frame Width ", frame_meta.source_frame_width)
# print("Source Frame Height ", frame_meta.source_frame_height)
# print("Num object meta ", frame_meta.num_obj_meta)
frame_number = frame_meta.frame_num
l_obj = frame_meta.obj_meta_list
while l_obj is not None:
try:
obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
continue
# Update the object text display
txt_params = obj_meta.text_params
# Set display_text. Any existing display_text string will be
# freed by the bindings module.
txt_params.display_text = pgie_classes_str[obj_meta.class_id]
obj_counter[obj_meta.class_id] += 1
# Font , font-color and font-size
txt_params.font_params.font_name = "Serif"
txt_params.font_params.font_size = 10
# set(red, green, blue, alpha); set to White
txt_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
# Text background color
txt_params.set_bg_clr = 1
# set(red, green, blue, alpha); set to Black
txt_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
# Ideally NVDS_EVENT_MSG_META should be attached to buffer by the
# component implementing detection / recognition logic.
# Here it demonstrates how to use / attach that meta data.
if is_first_object and (frame_number % 30) == 0:
# Frequency of messages to be send will be based on use case.
# Here message is being sent for first object every 30 frames.
# Allocating an NvDsEventMsgMeta instance and getting
# reference to it. The underlying memory is not manged by
# Python so that downstream plugins can access it. Otherwise
# the garbage collector will free it when this probe exits.
msg_meta = pyds.alloc_nvds_event_msg_meta()
msg_meta.bbox.top = obj_meta.rect_params.top
msg_meta.bbox.left = obj_meta.rect_params.left
msg_meta.bbox.width = obj_meta.rect_params.width
msg_meta.bbox.height = obj_meta.rect_params.height
msg_meta.frameId = frame_number
msg_meta.trackingId = long_to_uint64(obj_meta.object_id)
msg_meta.confidence = obj_meta.confidence
msg_meta = generate_event_msg_meta(msg_meta, obj_meta.class_id)
user_event_meta = pyds.nvds_acquire_user_meta_from_pool(
batch_meta)
if user_event_meta:
user_event_meta.user_meta_data = msg_meta
user_event_meta.base_meta.meta_type = pyds.NvDsMetaType.NVDS_EVENT_MSG_META
# Setting callbacks in the event msg meta. The bindings
# layer will wrap these callables in C functions.
# Currently only one set of callbacks is supported.
pyds.user_copyfunc(user_event_meta, meta_copy_func)
pyds.user_releasefunc(user_event_meta, meta_free_func)
pyds.nvds_add_user_meta_to_frame(frame_meta,
user_event_meta)
else:
print("Error in attaching event meta to buffer\n")
is_first_object = False
try:
l_obj = l_obj.next
break
try:
l_frame = l_frame.next
break
print("Frame Number =", frame_number, "Vehicle Count =",
obj_counter[PGIE_CLASS_ID_VEHICLE], "Person Count =",
obj_counter[PGIE_CLASS_ID_PERSON])
def main(args):
GObject.threads_init()
Gst.init(None)
# registering callbacks
pyds.register_user_copyfunc(meta_copy_func)
pyds.register_user_releasefunc(meta_free_func)
print("Creating Pipeline \n ")
pipeline = Gst.Pipeline()
if not pipeline:
sys.stderr.write(" Unable to create Pipeline \n")
# print("Creating Source \n ")
# source = Gst.ElementFactory.make("filesrc", "file-source")
# if not source:
# sys.stderr.write(" Unable to create Source \n")
# print("Creating H264Parser \n")
# h264parser = Gst.ElementFactory.make("h264parse", "h264-parser")
# if not h264parser:
# sys.stderr.write(" Unable to create h264 parser \n")
# print("Creating Decoder \n")
# decoder = Gst.ElementFactory.make("nvv4l2decoder", "nvv4l2-decoder")
# if not decoder:
# sys.stderr.write(" Unable to create Nvv4l2 Decoder \n")
print("Creating streamux \n ")
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
if not streammux:
sys.stderr.write(" Unable to create NvStreamMux \n")
pipeline.add(streammux)
number_sources = 0
for i in range(len(args)):
uri_name = args[i]
if uri_name.find("rtsp://") == 0:
is_live = True
elif uri_name.find("file://") == 0:
pass
else:
continue
print("Creating source_bin", number_sources, " ")
source_bin = create_source_bin(i, uri_name)
if not source_bin:
sys.stderr.write("Unable to create source bin \n")
pipeline.add(source_bin)
padname = "sink_%u" % i
sinkpad = streammux.get_request_pad(padname)
if not sinkpad:
sys.stderr.write("Unable to create sink pad bin \n")
srcpad = source_bin.get_static_pad("src")
if not srcpad:
sys.stderr.write("Unable to create src pad bin \n")
srcpad.link(sinkpad)
number_sources += 1
print("Creating Pgie \n ")
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
if not pgie:
sys.stderr.write(" Unable to create pgie \n")
print("Creating tiler \n ")
tiler = Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
if not tiler:
sys.stderr.write(" Unable to create tiler \n")
print("Creating nvvidconv \n ")
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
if not nvvidconv:
sys.stderr.write(" Unable to create nvvidconv \n")
print("Creating nvosd \n ")
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
if not nvosd:
sys.stderr.write(" Unable to create nvosd \n")
print("Creating nvvideoconvert - postosd\n ")
nvvidconv_postosd = Gst.ElementFactory.make(
"nvvideoconvert", "convertor_postosd")
if not nvvidconv_postosd:
sys.stderr.write(" Unable to create nvvidconv_postosd \n")
# Create a caps filter
print("Creating caps\n ")
caps = Gst.ElementFactory.make("capsfilter", "filter")
caps.set_property(
"caps", Gst.Caps.from_string("video/x-raw(memory:NVMM), format=I420")
# Make the encoder
if codec == "H264":
encoder = Gst.ElementFactory.make("nvv4l2h264enc", "encoder")
print("Creating H264 Encoder")
elif codec == "H265":
encoder = Gst.ElementFactory.make("nvv4l2h265enc", "encoder")
print("Creating H265 Encoder")
if not encoder:
sys.stderr.write(" Unable to create encoder")
encoder.set_property("bitrate", bitrate)
if is_aarch64():
encoder.set_property("preset-level", 1)
encoder.set_property("insert-sps-pps", 1)
encoder.set_property("bufapi-version", 1)
# Make the payload-encode video into RTP packets
if codec == "H264":
rtppay = Gst.ElementFactory.make("rtph264pay", "rtppay")
print("Creating H264 rtppay")
rtppay = Gst.ElementFactory.make("rtph265pay", "rtppay")
print("Creating H265 rtppay")
if not rtppay:
sys.stderr.write(" Unable to create rtppay")
# Make the UDP sink
updsink_port_num = 5400
sink = Gst.ElementFactory.make("udpsink", "udpsink")
if not sink:
sys.stderr.write(" Unable to create udpsink")
sink.set_property("host", "224.224.255.255")
sink.set_property("port", updsink_port_num)
sink.set_property("async", False)
sink.set_property("sync", 1)
streammux.set_property("width", 1920)
streammux.set_property("height", 1080)
streammux.set_property("batch-size", 1)
streammux.set_property("batched-push-timeout", 4000000)
if gie == "nvinfer":
pgie.set_property("config-file-path", "dstest51_pgie_config.txt")
else:
pgie.set_property("config-file-path", "dstest51_pgie_inferserver_config.txt")
pgie_batch_size = pgie.get_property("batch-size")
if pgie_batch_size != number_sources:
print(
"WARNING: Overriding infer-config batch-size ",
pgie_batch_size,
" with number of user input real sources count ",
number_sources,
" \n",
pgie.set_property("batch-size", number_sources)
# print("Adding elements to Pipeline \n")
tiler_rows = int(math.sqrt(number_sources))
tiler_columns = int(math.ceil((1.0 * number_sources) / tiler_rows))
tiler.set_property("rows", tiler_rows)
tiler.set_property("columns", tiler_columns)
tiler.set_property("width", TILED_OUTPUT_WIDTH)
tiler.set_property("height", TILED_OUTPUT_HEIGHT)
sink.set_property("qos", 0)
msgconv = Gst.ElementFactory.make("nvmsgconv", "nvmsg-converter")
if not msgconv:
sys.stderr.write(" Unable to create msgconv \n")
msgbroker = Gst.ElementFactory.make("nvmsgbroker", "nvmsg-broker")
if not msgbroker:
sys.stderr.write(" Unable to create msgbroker \n")
tee = Gst.ElementFactory.make("tee", "nvsink-tee")
if not tee:
sys.stderr.write(" Unable to create tee \n")
queue1 = Gst.ElementFactory.make("queue", "nvtee-que1")
if not queue1:
sys.stderr.write(" Unable to create queue1 \n")
queue2 = Gst.ElementFactory.make("queue", "nvtee-que2")
if not queue2:
sys.stderr.write(" Unable to create queue2 \n")
if no_display:
print("Creating FakeSink \n")
sink = Gst.ElementFactory.make("fakesink", "fakesink")
if not sink:
sys.stderr.write(" Unable to create fakesink \n")
else:
if is_aarch64():
transform = Gst.ElementFactory.make("nvegltransform",
"nvegl-transform")
print("Creating EGLSink \n")
sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
if not sink:
sys.stderr.write(" Unable to create egl sink \n")
# print("Playing file %s " % input_file)
# source.set_property('location', input_file)
streammux.set_property('width', 1920)
streammux.set_property('height', 1080)
streammux.set_property('batch-size', 1)
streammux.set_property('batched-push-timeout', 4000000)
pgie.set_property('config-file-path', PGIE_CONFIG_FILE)
msgconv.set_property('config', MSCONV_CONFIG_FILE)
msgconv.set_property('payload-type', schema_type)
msgbroker.set_property('proto-lib', proto_lib)
msgbroker.set_property('conn-str', conn_str)
if cfg_file is not None:
msgbroker.set_property('config', cfg_file)
if topic is not None:
msgbroker.set_property('topic', topic)
msgbroker.set_property('sync', False)
# pipeline.add(source)
# pipeline.add(h264parser)
# pipeline.add(decoder)
# pipeline.add(streammux)
pipeline.add(pgie)
pipeline.add(tiler)
pipeline.add(nvvidconv)
pipeline.add(nvosd)
pipeline.add(nvvidconv_postosd)
pipeline.add(caps)
pipeline.add(encoder)
pipeline.add(rtppay)
pipeline.add(tee)
pipeline.add(queue1)
pipeline.add(queue2)
pipeline.add(msgconv)
pipeline.add(msgbroker)
pipeline.add(sink)
if is_aarch64() and not no_display:
pipeline.add(transform)
# print("Linking elements in the Pipeline \n")
# source.link(h264parser)
# h264parser.link(decoder)
sinkpad = streammux.get_request_pad("sink_0")
if not sinkpad:
sys.stderr.write(" Unable to get the sink pad of streammux \n")
# srcpad = decoder.get_static_pad("src")
# if not srcpad:
# sys.stderr.write(" Unable to get source pad of decoder \n")
# srcpad.link(sinkpad)
streammux.link(pgie)
pgie.link(nvvidconv)
nvvidconv.link(tiler)
tiler.link(nvosd)
nvosd.link(tee)
queue1.link(msgconv)
msgconv.link(msgbroker)
queue2.link(nvvidconv_postosd)
nvvidconv_postosd.link(caps)
caps.link(encoder)
encoder.link(rtppay)
rtppay.link(sink)
sink_pad = queue1.get_static_pad("sink")
tee_msg_pad = tee.get_request_pad('src_%u')
tee_render_pad = tee.get_request_pad("src_%u")
if not tee_msg_pad or not tee_render_pad:
sys.stderr.write("Unable to get request pads\n")
tee_msg_pad.link(sink_pad)
sink_pad = queue2.get_static_pad("sink")
tee_render_pad.link(sink_pad)
# create an event loop and feed gstreamer bus messages to it
loop = GObject.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect("message", bus_call, loop)
osdsinkpad = nvosd.get_static_pad("sink")
if not osdsinkpad:
sys.stderr.write(" Unable to get sink pad of nvosd \n")
osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
print("Starting pipeline \n")
# Start streaming
rtsp_port_num = 8554
server = GstRtspServer.RTSPServer.new()
server.props.service = "%d" % rtsp_port_num
server.attach(None)
factory = GstRtspServer.RTSPMediaFactory.new()
factory.set_launch(
'( udpsrc name=pay0 port=%d buffer-size=524288 caps="application/x-rtp, media=video, clock-rate=90000, encoding-name=(string)%s, payload=96 " )'
% (updsink_port_num, codec)
factory.set_shared(True)
server.get_mount_points().add_factory("/ds-test", factory)
print(
"\n *** DeepStream: Launched RTSP Streaming at rtsp://localhost:%d/ds-test ***\n\n"
% rtsp_port_num
# start play back and listed to events
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
# cleanup
pyds.unset_callback_funcs()
pipeline.set_state(Gst.State.NULL)
# Parse and validate input arguments
def parse_args():
parser = OptionParser()
parser.add_option("-c", "--cfg-file", dest="cfg_file",
help="Set the adaptor config file. Optional if "
"connection string has relevant details.",
metavar="FILE")
parser.add_option("-i", "--input",
help="Path to input .mp4 file(H264 encoded) or input RTSP stream", default=["a"])
parser.add_option("-p", "--proto-lib", dest="proto_lib",
help="Absolute path of adaptor library", metavar="PATH")
parser.add_option("", "--conn-str", dest="conn_str",
help="Connection string of backend server. Optional if "
"it is part of config file.", metavar="STR")
parser.add_option("-s", "--schema-type", dest="schema_type", default="0",
help="Type of message schema (0=Full, 1=minimal), "
"default=0")
parser.add_option("-t", "--topic", dest="topic",
help="Name of message topic. Optional if it is part of "
"connection string or config file.", metavar="TOPIC")
parser.add_option("-d", "--no-display", action="store_true",
dest="no_display", default=False,
help="Disable display")
parser.add_option("-e", "--codec", default="H264",
help="Output RTSP Streaming Codec H264/H265 , default=H264", choices=['H264', 'H265'])
parser.add_option("-b", "--bitrate", default=4000000,
help="Set the encoding bitrate for output RTSP streaming", type=int)
(options, args) = parser.parse_args()
global cfg_file
global input
global proto_lib
global conn_str
global topic
global schema_type
global no_display
global codec
global bitrate
global stream_path
global gie
gie = "nvinfer"
cfg_file = options.cfg_file
input = options.input
proto_lib = options.proto_lib
conn_str = options.conn_str
topic = options.topic
no_display = options.no_display
if not (proto_lib and input):
print("Usage: python3 deepstream_test_51.py -i <H264 filename> -p "
"<Proto adaptor library> --conn-str=<Connection string>")
return 1
codec = options.codec
bitrate = options.bitrate
stream_path = options.input
schema_type = 0 if options.schema_type == "0" else 1
return stream_path
if __name__ == '__main__':
ret = parse_args()
# If argument parsing fails, returns failure (non-zero)
if ret == 1:
sys.exit(1)
sys.exit(main(sys.argv))
question 1: How to make the rtsp server listen all IP addresses?
question 2: What is the cause of the stuck?
