How to change input h264 to RTSP in deepstream-test2 app
Hi all,
TX2
• DeepStream Version
5.1
4.5.1
• TensorRT Version
7.1
How to change the input source for the sample app deepstream-test2 located in /opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-test2 from h264 elementary stream to RTSP/Webcam or any other video file?
The sample app that I’m trying to edit and use is
“/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-test2” with both primary detector and secondary classifiers and tracking
I want to know how can I add a new rtsp source or webcam input instead of the currently available h264 elementary stream input.
You need to modify the code. Before modify the code, please make sure you are already familiar with gstreamer basic knowledge and coding skills. https://gstreamer.freedesktop.org/ There is sample code of setup uridecodebin and rtspsrc sources in deepstream-app sample.
@Fiona.Chen
Thanks for letting know.
Can you please mention the part of the code so that it would be easy to find as there are three files deepstream_app.c , deepstream_app_main.c and deepstream_app_config_parser.c
There is no function referring the uridecodebin or the rtspsrc ? Can you help?
Please refer to /opt/nvidia/deepstream/deepstream/sources/apps/apps-common/src/deepstream_source_bin.c
Hi @Fiona.Chen,
 * Copyright (c) 2018-2020, NVIDIA CORPORATION. All rights reserved.
 * Permission is hereby granted, free of charge, to any person obtaining a
 * copy of this software and associated documentation files (the "Software"),
 * to deal in the Software without restriction, including without limitation
 * the rights to use, copy, modify, merge, publish, distribute, sublicense,
 * and/or sell copies of the Software, and to permit persons to whom the
 * Software is furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
 * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
 * DEALINGS IN THE SOFTWARE.
#include <gst/gst.h>
#include <glib.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <cuda_runtime_api.h>
#include "gstnvdsmeta.h"
#define PGIE_CONFIG_FILE  "/opt/nvidia/deepstream/deepstream-5.1/samples/configs/tlt_pretrained_models/config_infer_primary_facedetectir.txt"
#define SGIE1_CONFIG_FILE "/opt/nvidia/deepstream/deepstream-5.1/samples/configs/tlt_pretrained_models/config_infer_age_classifier.txt"
#define SGIE2_CONFIG_FILE "/opt/nvidia/deepstream/deepstream-5.1/samples/configs/tlt_pretrained_models/config_infer_emotion_classifier.txt"
#define SGIE3_CONFIG_FILE "/opt/nvidia/deepstream/deepstream-5.1/samples/configs/tlt_pretrained_models/config_infer_gender_classifier.txt"
// #define PGIE_CONFIG_FILE  "dstest2_pgie_config.txt"
// #define SGIE1_CONFIG_FILE "dstest2_sgie1_config.txt"
// #define SGIE2_CONFIG_FILE "dstest2_sgie2_config.txt"
// #define SGIE3_CONFIG_FILE "dstest2_sgie3_config.txt"
#define MAX_DISPLAY_LEN 64
#define TRACKER_CONFIG_FILE "dstest2_tracker_config.txt"
#define MAX_TRACKING_ID_LEN 16
#define PGIE_CLASS_ID_FACE 0
// #define PGIE_CLASS_ID_VEHICLE 0
// #define PGIE_CLASS_ID_PERSON 2
/* The muxer output resolution must be set if the input streams will be of
 * different resolution. The muxer will scale all the input frames to this
 * resolution. */
#define MUXER_OUTPUT_WIDTH 1920
#define MUXER_OUTPUT_HEIGHT 1080
/* Muxer batch formation timeout, for e.g. 40 millisec. Should ideally be set
 * based on the fastest source's framerate. */
#define MUXER_BATCH_TIMEOUT_USEC 40000
gint frame_number = 0;
/* These are the strings of the labels for the respective models */
gchar sgie1_classes_str[8][32] = { "0-2", "4-6", "8-13", "15-20", "25-32",
  "38-43", "48-53", "60" };
gchar sgie2_classes_str[7][32] =
    { "neutral", "anger", "disgust", "fear", "happy",
  "sadness", "surprise" };
gchar sgie3_classes_str[2][32] = { "male", "female" };
// gchar sgie1_classes_str[12][32] = { "black", "blue", "brown", "gold", "green",
//   "grey", "maroon", "orange", "red", "silver", "white", "yellow"
// gchar sgie2_classes_str[20][32] =
//     { "Acura", "Audi", "BMW", "Chevrolet", "Chrysler",
//   "Dodge", "Ford", "GMC", "Honda", "Hyundai", "Infiniti", "Jeep", "Kia",
//       "Lexus", "Mazda", "Mercedes", "Nissan",
//   "Subaru", "Toyota", "Volkswagen"
// gchar sgie3_classes_str[6][32] = { "coupe", "largevehicle", "sedan", "suv",
//   "truck", "van"
gchar pgie_classes_str[1][32] =
    { "face" };
// gchar pgie_classes_str[4][32] =
//     { "Vehicle", "TwoWheeler", "Person", "RoadSign" };
/* gie_unique_id is one of the properties in the above dstest2_sgiex_config.txt
 * files. These should be unique and known when we want to parse the Metadata
 * respective to the sgie labels. Ideally these should be read from the config
 * files but for brevity we ensure they are same. */
guint sgie1_unique_id = 2;
guint sgie2_unique_id = 3;
guint sgie3_unique_id = 4;
/* This is the buffer probe function that we have registered on the sink pad
 * of the OSD element. All the infer elements in the pipeline shall attach
 * their metadata to the GstBuffer, here we will iterate & process the metadata
 * forex: class ids to strings, counting of class_id objects etc. */
static GstPadProbeReturn
osd_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
    gpointer u_data)
    GstBuffer *buf = (GstBuffer *) info->data;
    guint num_rects = 0;
    NvDsObjectMeta *obj_meta = NULL;
    // guint vehicle_count = 0;
    // guint person_count = 0;
    guint face_count = 0;
    NvDsMetaList * l_frame = NULL;
    NvDsMetaList * l_obj = NULL;
    NvDsDisplayMeta *display_meta = NULL;
    NvDsClassifierMetaList *l_classifier = NULL;
    NvDsClassifierMeta *class_meta = NULL;
    NvDsLabelInfoList *l_label = NULL;
    NvDsLabelInfo *label_info = NULL;
    NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
    for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
      l_frame = l_frame->next) {
        NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
        int offset = 0;
        for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
                l_obj = l_obj->next) {
            obj_meta = (NvDsObjectMeta *) (l_obj->data);
            if (obj_meta->class_id == PGIE_CLASS_ID_FACE) {
                face_count++;
                num_rects++;
            // if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
            //     vehicle_count++;
            //     num_rects++;
// New ***
                int id = obj_meta->object_id;
                for(l_classifier = obj_meta->classifier_meta_list; l_classifier != NULL;
                l_classifier = l_classifier->next) {
                  class_meta = (NvDsClassifierMeta *)(l_classifier->data);
                  for(l_label = class_meta->label_info_list; l_label != NULL;
                  l_label = l_label->next) {
                    label_info = (NvDsLabelInfo *) (l_label->data);
                    g_print("%d", id);
                    g_print("-------");
                    g_print ("%s\n", label_info->result_label);
        //     if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) {
        //         person_count++;
        //         num_rects++;
        //         obj_meta->text_params.font_params.font_size = 24;
        display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
        NvOSD_TextParams *txt_params  = &display_meta->text_params[0];
        display_meta->num_labels = 1;
        txt_params->display_text = g_malloc0 (MAX_DISPLAY_LEN);
        // offset = snprintf(txt_params->display_text, MAX_DISPLAY_LEN, "Person = %d ", person_count);
        offset = snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN, "Face = %d ", face_count);
        /* Now set the offsets where the string should appear */
        txt_params->x_offset = 10;
        txt_params->y_offset = 12;
        /* Font , font-color and font-size */
        txt_params->font_params.font_name = "Serif";
        txt_params->font_params.font_size = 10;
        txt_params->font_params.font_color.red = 1.0;
        txt_params->font_params.font_color.green = 1.0;
        txt_params->font_params.font_color.blue = 1.0;
        txt_params->font_params.font_color.alpha = 1.0;
        /* Text background color */
        txt_params->set_bg_clr = 1;
        txt_params->text_bg_clr.red = 0.0;
        txt_params->text_bg_clr.green = 0.0;
        txt_params->text_bg_clr.blue = 0.0;
        txt_params->text_bg_clr.alpha = 1.0;
        nvds_add_display_meta_to_frame(frame_meta, display_meta);
    g_print ("Frame Number = %d Number of objects = %d "
            "Face Count = %d \n",
            frame_number, num_rects, face_count);
    // g_print ("Frame Number = %d Number of objects = %d "
    //         "Vehicle Count = %d Person Count = %d\n",
    //         frame_number, num_rects, vehicle_count, person_count);
    frame_number++;
    return GST_PAD_PROBE_OK;
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
  GMainLoop *loop = (GMainLoop *) data;
  switch (GST_MESSAGE_TYPE (msg)) {
    case GST_MESSAGE_EOS:
      g_print ("End of stream\n");
      g_main_loop_quit (loop);
      break;
    case GST_MESSAGE_ERROR:{
      gchar *debug;
      GError *error;
      gst_message_parse_error (msg, &error, &debug);
      g_printerr ("ERROR from element %s: %s\n",
          GST_OBJECT_NAME (msg->src), error->message);
      if (debug)
        g_printerr ("Error details: %s\n", debug);
      g_free (debug);
      g_error_free (error);
      break;
    default:
      break;
  return TRUE;
/* Tracker config parsing */
#define CHECK_ERROR(error) \
    if (error) { \
        g_printerr ("Error while parsing config file: %s\n", error->message); \
        goto done; \
#define CONFIG_GROUP_TRACKER "tracker"
#define CONFIG_GROUP_TRACKER_WIDTH "tracker-width"
#define CONFIG_GROUP_TRACKER_HEIGHT "tracker-height"
#define CONFIG_GROUP_TRACKER_LL_CONFIG_FILE "ll-config-file"
#define CONFIG_GROUP_TRACKER_LL_LIB_FILE "ll-lib-file"
#define CONFIG_GROUP_TRACKER_ENABLE_BATCH_PROCESS "enable-batch-process"
#define CONFIG_GPU_ID "gpu-id"
static gchar *
get_absolute_file_path (gchar *cfg_file_path, gchar *file_path)
  gchar abs_cfg_path[PATH_MAX + 1];
  gchar *abs_file_path;
  gchar *delim;
  if (file_path && file_path[0] == '/') {
    return file_path;
  if (!realpath (cfg_file_path, abs_cfg_path)) {
    g_free (file_path);
    return NULL;
  // Return absolute path of config file if file_path is NULL.
  if (!file_path) {
    abs_file_path = g_strdup (abs_cfg_path);
    return abs_file_path;
  delim = g_strrstr (abs_cfg_path, "/");
  *(delim + 1) = '\0';
  abs_file_path = g_strconcat (abs_cfg_path, file_path, NULL);
  g_free (file_path);
static gboolean
set_tracker_properties (GstElement *nvtracker)
  gboolean ret = FALSE;
  GError *error = NULL;
  gchar **keys = NULL;
  gchar **key = NULL;
  GKeyFile *key_file = g_key_file_new ();
  if (!g_key_file_load_from_file (key_file, TRACKER_CONFIG_FILE, G_KEY_FILE_NONE,
          &error)) {
    g_printerr ("Failed to load config file: %s\n", error->message);
    return FALSE;
  keys = g_key_file_get_keys (key_file, CONFIG_GROUP_TRACKER, NULL, &error);
  CHECK_ERROR (error);
  for (key = keys; *key; key++) {
    if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_WIDTH)) {
      gint width =
          g_key_file_get_integer (key_file, CONFIG_GROUP_TRACKER,
          CONFIG_GROUP_TRACKER_WIDTH, &error);
      g_object_set (G_OBJECT (nvtracker), "tracker-width", width, NULL);
    } else if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_HEIGHT)) {
      gint height =
          CONFIG_GROUP_TRACKER_HEIGHT, &error);
      g_object_set (G_OBJECT (nvtracker), "tracker-height", height, NULL);
    } else if (!g_strcmp0 (*key, CONFIG_GPU_ID)) {
      guint gpu_id =
          CONFIG_GPU_ID, &error);
      g_object_set (G_OBJECT (nvtracker), "gpu_id", gpu_id, NULL);
    } else if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_LL_CONFIG_FILE)) {
      char* ll_config_file = get_absolute_file_path (TRACKER_CONFIG_FILE,
                g_key_file_get_string (key_file,
                    CONFIG_GROUP_TRACKER_LL_CONFIG_FILE, &error));
      g_object_set (G_OBJECT (nvtracker), "ll-config-file", ll_config_file, NULL);
    } else if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_LL_LIB_FILE)) {
      char* ll_lib_file = get_absolute_file_path (TRACKER_CONFIG_FILE,
                    CONFIG_GROUP_TRACKER_LL_LIB_FILE, &error));
      g_object_set (G_OBJECT (nvtracker), "ll-lib-file", ll_lib_file, NULL);
    } else if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_ENABLE_BATCH_PROCESS)) {
      gboolean enable_batch_process =
          CONFIG_GROUP_TRACKER_ENABLE_BATCH_PROCESS, &error);
      g_object_set (G_OBJECT (nvtracker), "enable_batch_process",
                    enable_batch_process, NULL);
    } else {
      g_printerr ("Unknown key '%s' for group [%s]", *key,
          CONFIG_GROUP_TRACKER);
  ret = TRUE;
done:
  if (error) {
  if (keys) {
    g_strfreev (keys);
  if (!ret) {
    g_printerr ("%s failed", __func__);
  return ret;
int
main (int argc, char *argv[])
  GMainLoop *loop = NULL;
  GstElement *pipeline = NULL, *source = NULL, *h264parser = NULL,
      *decoder = NULL, *streammux = NULL, *sink = NULL, *pgie = NULL, *nvvidconv = NULL,
      *nvosd = NULL, *sgie1 = NULL, *sgie2 = NULL, *sgie3 = NULL, *nvtracker = NULL;
  g_print ("With tracker\n");
  GstElement *transform = NULL;
  GstBus *bus = NULL;
  guint bus_watch_id = 0;
  GstPad *osd_sink_pad = NULL;
  int current_device = -1;
  cudaGetDevice(&current_device);
  struct cudaDeviceProp prop;
  cudaGetDeviceProperties(&prop, current_device);
  /* Check input arguments */
  if (argc != 2) {
    g_printerr ("Usage: %s <elementary H264 filename>\n", argv[0]);
    return -1;
  /* Standard GStreamer initialization */
  gst_init (&argc, &argv);
  loop = g_main_loop_new (NULL, FALSE);
  /* Create gstreamer elements */
  /* Create Pipeline element that will be a container of other elements */
  pipeline = gst_pipeline_new ("dstest2-pipeline");
  /* Source element for reading from the file */
  source = gst_element_factory_make ("filesrc", "file-source");
  /* Since the data format in the input file is elementary h264 stream,
   * we need a h264parser */
  h264parser = gst_element_factory_make ("h264parse", "h264-parser");
  /* Use nvdec_h264 for hardware accelerated decode on GPU */
  decoder = gst_element_factory_make ("nvv4l2decoder", "nvv4l2-decoder");
  /* Create nvstreammux instance to form batches from one or more sources. */
  streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
  if (!pipeline || !streammux) {
    g_printerr ("One element could not be created. Exiting.\n");
    return -1;
  /* Use nvinfer to run inferencing on decoder's output,
   * behaviour of inferencing is set through config file */
  pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
  /* We need to have a tracker to track the identified objects */
  nvtracker = gst_element_factory_make ("nvtracker", "tracker");
  /* We need three secondary gies so lets create 3 more instances of
     nvinfer */
  sgie1 = gst_element_factory_make ("nvinfer", "secondary1-nvinference-engine");
  sgie2 = gst_element_factory_make ("nvinfer", "secondary2-nvinference-engine");
  sgie3 = gst_element_factory_make ("nvinfer", "secondary3-nvinference-engine");
  /* Use convertor to convert from NV12 to RGBA as required by nvosd */
  nvvidconv = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter");
  /* Create OSD to draw on the converted RGBA buffer */
  nvosd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
  /* Finally render the osd output */
  if(prop.integrated) {
    transform = gst_element_factory_make ("nvegltransform", "nvegl-transform");
  sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
  if (!source || !h264parser || !decoder || !pgie ||
      !nvtracker || !sgie1 || !sgie2 || !sgie3 || !nvvidconv || !nvosd || !sink) {
    return -1;
  if(!transform && prop.integrated) {
      g_printerr ("One tegra element could not be created. Exiting.\n");
      return -1;
  /* Set the input filename to the source element */
  g_object_set (G_OBJECT (source), "location", argv[1], NULL);
  g_object_set (G_OBJECT (streammux), "batch-size", 1, NULL);
  g_object_set (G_OBJECT (streammux), "width", MUXER_OUTPUT_WIDTH, "height",
      MUXER_OUTPUT_HEIGHT,
      "batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
  /* Set all the necessary properties of the nvinfer element,
   * the necessary ones are : */
  g_object_set (G_OBJECT (pgie), "config-file-path", PGIE_CONFIG_FILE, NULL);
  g_object_set (G_OBJECT (sgie1), "config-file-path", SGIE1_CONFIG_FILE, NULL);
  g_object_set (G_OBJECT (sgie2), "config-file-path", SGIE2_CONFIG_FILE, NULL);
  g_object_set (G_OBJECT (sgie3), "config-file-path", SGIE3_CONFIG_FILE, NULL);
  /* Set necessary properties of the tracker element. */
  if (!set_tracker_properties(nvtracker)) {
    g_printerr ("Failed to set tracker properties. Exiting.\n");
    return -1;
  /* we add a message handler */
  bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
  bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
  gst_object_unref (bus);
  /* Set up the pipeline */
  /* we add all elements into the pipeline */
  /* decoder | pgie1 | nvtracker | sgie1 | sgie2 | sgie3 | etc.. */
    gst_bin_add_many (GST_BIN (pipeline),
        source, h264parser, decoder, streammux, pgie, nvtracker, sgie1, sgie2, sgie3,
        nvvidconv, nvosd, transform, sink, NULL);
  else {
        nvvidconv, nvosd, sink, NULL);
  GstPad *sinkpad, *srcpad;
  gchar pad_name_sink[16] = "sink_0";
  gchar pad_name_src[16] = "src";
  sinkpad = gst_element_get_request_pad (streammux, pad_name_sink);
  if (!sinkpad) {
    g_printerr ("Streammux request sink pad failed. Exiting.\n");
    return -1;
  srcpad = gst_element_get_static_pad (decoder, pad_name_src);
  if (!srcpad) {
    g_printerr ("Decoder request src pad failed. Exiting.\n");
    return -1;
  if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
      g_printerr ("Failed to link decoder to stream muxer. Exiting.\n");
      return -1;
  gst_object_unref (sinkpad);
  gst_object_unref (srcpad);
  /* Link the elements together */
  if (!gst_element_link_many (source, h264parser, decoder, NULL)) {
    g_printerr ("Elements could not be linked: 1. Exiting.\n");
    return -1;
    if (!gst_element_link_many (streammux, pgie, nvtracker, sgie1,
        sgie2, sgie3, nvvidconv, nvosd, transform, sink, NULL)) {
      g_printerr ("Elements could not be linked. Exiting.\n");
      return -1;
  else {
        sgie2, sgie3, nvvidconv, nvosd, sink, NULL)) {
      return -1;
  /* Lets add probe to get informed of the meta data generated, we add probe to
   * the sink pad of the osd element, since by that time, the buffer would have
   * had got all the metadata. */
  osd_sink_pad = gst_element_get_static_pad (nvosd, "sink");
  if (!osd_sink_pad)
    g_print ("Unable to get sink pad\n");
  else
    gst_pad_add_probe (osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
        osd_sink_pad_buffer_probe, NULL, NULL);
  gst_object_unref (osd_sink_pad);
  /* Set the pipeline to "playing" state */
  g_print ("Now playing: %s\n", argv[1]);
  gst_element_set_state (pipeline, GST_STATE_PLAYING);
  /* Iterate */
  g_print ("Running...\n");
  g_main_loop_run (loop);
  /* Out of the main loop, clean up nicely */
  g_print ("Returned, stopping playback\n");
  gst_element_set_state (pipeline, GST_STATE_NULL);
  g_print ("Deleting pipeline\n");
  gst_object_unref (GST_OBJECT (pipeline));
  g_source_remove (bus_watch_id);
  g_main_loop_unref (loop);
  return 0;
The above mentioned is the modified deepstream_test2.c which provides the metadata while run on the h264 video stream. The only issue here is I want to change the input as multiple sources (rtsp/webcam/ mp4videofile) as in deepstream-app. I’m not able to get the point where I should change the code. I have gone through the forums of earlier posts regarding this but there is no solutions. Can you please help me modify it?
For multiple sources, please refer to deepstream-test3 sample code. Please make sure you are already familiar with gstreamer basic knowledge and coding skills.https://gstreamer.freedesktop.org/
