• Hardware Platform (Jetson / GPU) GTX1070
• DeepStream Version 5.0
• TensorRT Version 7.0
• NVIDIA GPU Driver Version (valid for GPU only) 440.82
I am trying to restart the pipeline after consuming a video file. I referenced the code in a old thread. But the program stoped after the location of the source was changed
The full code is below
#include <gst/gst.h>
#include <glib.h>
#include <stdio.h>
#include "gstnvdsmeta.h"
#define MAX_DISPLAY_LEN 64
#define PGIE_CLASS_ID_VEHICLE 0
#define PGIE_CLASS_ID_PERSON 2
/* The muxer output resolution must be set if the input streams will be of
* different resolution. The muxer will scale all the input frames to this
* resolution. */
#define MUXER_OUTPUT_WIDTH 1920
#define MUXER_OUTPUT_HEIGHT 1080
/* Muxer batch formation timeout, for e.g. 40 millisec. Should ideally be set
* based on the fastest source's framerate. */
#define MUXER_BATCH_TIMEOUT_USEC 40000
GMainLoop *loop = NULL;
GstElement *pipeline = NULL;
gint frame_number = 0;
gchar pgie_classes_str[4][32] = { "Vehicle", "TwoWheeler", "Person",
"Roadsign"
flag = TRUE;
static gboolean source_switch_thread(gpointer* data)
g_print("debug \n");
GstElement* source = gst_bin_get_by_name(GST_BIN(pipeline), "file-source");
GstElement* h264parser = gst_bin_get_by_name(GST_BIN(pipeline), "h264-parser");
GstElement* sink = gst_bin_get_by_name(GST_BIN(pipeline), "nvvideo-renderer");
gst_element_set_state(pipeline, GST_STATE_PAUSED);
GstStateChangeReturn ret = GST_STATE_CHANGE_FAILURE;
ret = gst_element_set_state(source, GST_STATE_NULL);
if (ret == GST_STATE_CHANGE_FAILURE)
g_print("Unable to set state change for source element \n");
g_main_loop_quit(loop);
if (flag)
g_object_set(G_OBJECT(source), "location", "./sample_720p_2.h264", NULL);
flag = FALSE;
else
g_object_set(G_OBJECT(source), "location", "./sample_720p.h264", NULL);
flag = TRUE;
gst_pad_activate_mode(gst_element_get_static_pad(h264parser, "sink"), GST_PAD_MODE_PUSH, TRUE);
gst_element_sync_state_with_parent(h264parser);
gst_element_sync_state_with_parent(source);
gst_element_sync_state_with_parent(sink);
frame_number = 0;
gst_element_set_state(pipeline, GST_STATE_PLAYING);
return FALSE;
static GstPadProbeReturn eos_probe_cb(GstPad* pad, GstPadProbeInfo* info, gpointer u_data)
if (GST_EVENT_TYPE(GST_PAD_PROBE_INFO_DATA(info)) != GST_EVENT_EOS) { return GST_PAD_PROBE_OK; }
gst_element_seek((GstElement*) u_data, 1.0, GST_FORMAT_TIME,
(GstSeekFlags)(GST_SEEK_FLAG_FLUSH), GST_SEEK_TYPE_SET, 0, GST_SEEK_TYPE_NONE,
GST_CLOCK_TIME_NONE);
g_idle_add((GSourceFunc) source_switch_thread, u_data);
return GST_PAD_PROBE_DROP;
/* osd_sink_pad_buffer_probe will extract metadata received on OSD sink pad
* and update params for drawing rectangle, object information etc. */
osd_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
gpointer u_data)
GstBuffer *buf = (GstBuffer *) info->data;
guint num_rects = 0;
NvDsObjectMeta *obj_meta = NULL;
guint vehicle_count = 0;
guint person_count = 0;
NvDsMetaList * l_frame = NULL;
NvDsMetaList * l_obj = NULL;
NvDsDisplayMeta *display_meta = NULL;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
int offset = 0;
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
l_obj = l_obj->next) {
obj_meta = (NvDsObjectMeta *) (l_obj->data);
if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
vehicle_count++;
num_rects++;
if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) {
person_count++;
num_rects++;
display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
NvOSD_TextParams *txt_params = &display_meta->text_params[0];
display_meta->num_labels = 1;
txt_params->display_text = g_malloc0 (MAX_DISPLAY_LEN);
offset = snprintf(txt_params->display_text, MAX_DISPLAY_LEN, "Person = %d ", person_count);
offset = snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN, "Vehicle = %d ", vehicle_count);
/* Now set the offsets where the string should appear */
txt_params->x_offset = 10;
txt_params->y_offset = 12;
/* Font , font-color and font-size */
txt_params->font_params.font_name = "Serif";
txt_params->font_params.font_size = 10;
txt_params->font_params.font_color.red = 1.0;
txt_params->font_params.font_color.green = 1.0;
txt_params->font_params.font_color.blue = 1.0;
txt_params->font_params.font_color.alpha = 1.0;
/* Text background color */
txt_params->set_bg_clr = 1;
txt_params->text_bg_clr.red = 0.0;
txt_params->text_bg_clr.green = 0.0;
txt_params->text_bg_clr.blue = 0.0;
txt_params->text_bg_clr.alpha = 1.0;
nvds_add_display_meta_to_frame(frame_meta, display_meta);
g_print ("Frame Number = %d Number of objects = %d "
"Vehicle Count = %d Person Count = %d\n",
frame_number, num_rects, vehicle_count, person_count);
frame_number++;
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
switch (GST_MESSAGE_TYPE (msg)) {
case GST_MESSAGE_EOS:
g_print ("End of stream\n");
g_main_loop_quit (loop);
break;
case GST_MESSAGE_ERROR:{
gchar *debug;
GError *error;
gst_message_parse_error (msg, &error, &debug);
g_printerr ("ERROR from element %s: %s\n",
GST_OBJECT_NAME (msg->src), error->message);
if (debug)
g_printerr ("Error details: %s\n", debug);
g_free (debug);
g_error_free (error);
break;
default:
break;
return TRUE;
int
main (int argc, char *argv[])
GstElement *source = NULL, *h264parser = NULL,
*decoder = NULL, *streammux = NULL, *sink = NULL, *pgie = NULL, *nvvidconv = NULL,
*nvosd = NULL;
#ifdef PLATFORM_TEGRA
GstElement *transform = NULL;
#endif
GstBus *bus = NULL;
guint bus_watch_id;
GstPad *osd_sink_pad = NULL;
GstPad *osd_src_pad = NULL;
/* Check input arguments */
if (argc != 2) {
g_printerr ("Usage: %s <H264 filename>\n", argv[0]);
return -1;
/* Standard GStreamer initialization */
gst_init (&argc, &argv);
loop = g_main_loop_new (NULL, FALSE);
/* Create gstreamer elements */
/* Create Pipeline element that will form a connection of other elements */
pipeline = gst_pipeline_new ("dstest1-pipeline");
/* Source element for reading from the file */
source = gst_element_factory_make ("filesrc", "file-source");
/* Since the data format in the input file is elementary h264 stream,
* we need a h264parser */
h264parser = gst_element_factory_make ("h264parse", "h264-parser");
/* Use nvdec_h264 for hardware accelerated decode on GPU */
decoder = gst_element_factory_make ("nvv4l2decoder", "nvv4l2-decoder");
/* Create nvstreammux instance to form batches from one or more sources. */
streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
if (!pipeline || !streammux) {
g_printerr ("One element could not be created. Exiting.\n");
return -1;
/* Use nvinfer to run inferencing on decoder's output,
* behaviour of inferencing is set through config file */
pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
/* Use convertor to convert from NV12 to RGBA as required by nvosd */
nvvidconv = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter");
/* Create OSD to draw on the converted RGBA buffer */
nvosd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
/* Finally render the osd output */
transform = gst_element_factory_make ("nvegltransform", "nvegl-transform");
#endif
sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
//sink = gst_element_factory_make ("filesink", "filesink");
if (!source || !h264parser || !decoder || !pgie
|| !nvvidconv || !nvosd || !sink) {
return -1;
if(!transform) {
g_printerr ("One tegra element could not be created. Exiting.\n");
return -1;
#endif
/* we set the input filename to the source element */
g_object_set (G_OBJECT (source), "location", argv[1], NULL);
g_object_set (G_OBJECT (streammux), "batch-size", 1, NULL);
g_object_set (G_OBJECT (streammux), "width", MUXER_OUTPUT_WIDTH, "height",
MUXER_OUTPUT_HEIGHT,
"batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
//g_object_set (G_OBJECT (sink), "location", "test1.mp4", NULL);
/* Set all the necessary properties of the nvinfer element,
* the necessary ones are : */
g_object_set (G_OBJECT (pgie),
"config-file-path", "dstest1_pgie_config.txt", NULL);
/* we add a message handler */
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
gst_object_unref (bus);
/* Set up the pipeline */
/* we add all elements into the pipeline */
gst_bin_add_many (GST_BIN (pipeline),
source, h264parser, decoder, streammux, pgie,
nvvidconv, nvosd, transform, sink, NULL);
#else
nvvidconv, nvosd, sink, NULL);
#endif
GstPad *sinkpad, *srcpad;
gchar pad_name_sink[16] = "sink_0";
gchar pad_name_src[16] = "src";
sinkpad = gst_element_get_request_pad (streammux, pad_name_sink);
if (!sinkpad) {
g_printerr ("Streammux request sink pad failed. Exiting.\n");
return -1;
srcpad = gst_element_get_static_pad (decoder, pad_name_src);
if (!srcpad) {
g_printerr ("Decoder request src pad failed. Exiting.\n");
return -1;
if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
g_printerr ("Failed to link decoder to stream muxer. Exiting.\n");
return -1;
gst_object_unref (sinkpad);
gst_object_unref (srcpad);
/* we link the elements together */
/* file-source -> h264-parser -> nvh264-decoder ->
* nvinfer -> nvvidconv -> nvosd -> video-renderer */
if (!gst_element_link_many (source, h264parser, decoder, NULL)) {
g_printerr ("Elements could not be linked: 1. Exiting.\n");
return -1;
if (!gst_element_link_many (streammux, pgie,
nvvidconv, nvosd, transform, sink, NULL)) {
g_printerr ("Elements could not be linked: 2. Exiting.\n");
return -1;
#else
nvvidconv, nvosd, sink, NULL)) {
return -1;
#endif
/* Lets add probe to get informed of the meta data generated, we add probe to
* the sink pad of the osd element, since by that time, the buffer would have
* had got all the metadata. */
osd_sink_pad = gst_element_get_static_pad (nvosd, "sink");
if (!osd_sink_pad)
g_print ("Unable to get sink pad\n");
else
gst_pad_add_probe (osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
osd_sink_pad_buffer_probe, NULL, NULL);
osd_src_pad = gst_element_get_static_pad(nvosd, "src");
if (!osd_src_pad)
g_print("Unable to get OSD src pad \n");
else
gst_pad_add_probe(osd_src_pad, GST_PAD_PROBE_TYPE_EVENT_DOWNSTREAM,
eos_probe_cb, pipeline, NULL);
/* Set the pipeline to "playing" state */
g_print ("Now playing: %s\n", argv[1]);
gst_element_set_state (pipeline, GST_STATE_PLAYING);
/* Wait till pipeline encounters an error or EOS */
g_print ("Running...\n");
g_main_loop_run (loop);
/* Out of the main loop, clean up nicely */
g_print ("Returned, stopping playback\n");
gst_element_set_state (pipeline, GST_STATE_NULL);
g_print ("Deleting pipeline\n");
gst_object_unref (GST_OBJECT (pipeline));
g_source_remove (bus_watch_id);
g_main_loop_unref (loop);
return 0;
