Tiler_rows and tiler_columns do not change correctly for runtime_source_add_delete
• Hardware Platform (Jetson / GPU) 2080Ti
• DeepStream Version 6.0.0
• TensorRT Version 8.2.0
• NVIDIA GPU Driver Version (valid for GPU only) 470.182
• Issue Type( questions, new requirements, bugs) questions, bugs
I cloned runtime_source_add_delete repository and I want to do some changes to it. It’s necessary to have accurate number of rows and columns after deleting or adding a stream.
I’m checking number of rows and columns after deleting or adding each streams.
The changed program and output is brought here.
Program:
main.c (24.1 KB)
Output
output (8.3 KB)
 * Copyright (c) 2020-2021, NVIDIA CORPORATION.  All rights reserved.
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 *     http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
#include <stdlib.h>
#include <gst/gst.h>
#include <glib.h>
#include <math.h>
#include <gmodule.h>
#include <string.h>
#include <sys/time.h>
#include "gstnvdsmeta.h"
#include "gst-nvmessage.h"
#include "nvdsmeta.h"
#include <cuda_runtime_api.h>
#define MAX_DISPLAY_LEN 64
#define PGIE_CLASS_ID_VEHICLE 0
#define PGIE_CLASS_ID_PERSON 2
#define SET_GPU_ID(object, gpu_id) g_object_set (G_OBJECT (object), "gpu-id", gpu_id, NULL);
#define SET_MEMORY(object, mem_id) g_object_set (G_OBJECT (object), "nvbuf-memory-type", mem_id, NULL);
GMainLoop *loop = NULL;
/* The muxer output resolution must be set if the input streams will be of
 * different resolution. The muxer will scale all the input frames to this
 * resolution. */
#define MUXER_OUTPUT_WIDTH 1280
#define MUXER_OUTPUT_HEIGHT 720
#define TILED_OUTPUT_WIDTH 1280
#define TILED_OUTPUT_HEIGHT 720
#define GPU_ID 0
#define MAX_NUM_SOURCES 4
#define PGIE_CONFIG_FILE "../../dstest_pgie_config.txt"
#define TRACKER_CONFIG_FILE "../../dstest_tracker_config.txt"
#define SGIE1_CONFIG_FILE "../../dstest_sgie1_config.txt"
#define SGIE2_CONFIG_FILE "../../dstest_sgie2_config.txt"
#define SGIE3_CONFIG_FILE "../../dstest_sgie3_config.txt"
#define CONFIG_GPU_ID "gpu-id"
#define CONFIG_GROUP_TRACKER "tracker"
#define CONFIG_GROUP_TRACKER_WIDTH "tracker-width"
#define CONFIG_GROUP_TRACKER_HEIGHT "tracker-height"
#define CONFIG_GROUP_TRACKER_LL_CONFIG_FILE "ll-config-file"
#define CONFIG_GROUP_TRACKER_LL_LIB_FILE "ll-lib-file"
#define CONFIG_GROUP_TRACKER_ENABLE_BATCH_PROCESS "enable-batch-process"
#define MUXER_BATCH_TIMEOUT_USEC 40000
gint g_num_sources = 0;
guint  num_sources = 0;
gint g_source_id_list[MAX_NUM_SOURCES];
gboolean g_eos_list[MAX_NUM_SOURCES];
gboolean g_source_enabled[MAX_NUM_SOURCES];
GstElement **g_source_bin_list = NULL;
GMutex eos_lock;
gboolean g_run_forever = FALSE;
/* Assuming Resnet 10 model packaged in DS SDK */
gchar pgie_classes_str[4][32] = { "Vehicle", "TwoWheeler", "Person",
  "Roadsign"
GstElement *pipeline = NULL, *streammux = NULL, *sink = NULL, *pgie = NULL,
    *sgie1 = NULL, *sgie2 = NULL, *sgie3 = NULL,
    *nvvideoconvert = NULL, *nvosd = NULL, *tiler = NULL, *tracker = NULL, *queue = NULL;
gchar *uri = NULL;
guint tiler_rows, tiler_columns;
static gboolean add_sources (gpointer data);
static void
decodebin_child_added (GstChildProxy * child_proxy, GObject * object,
    gchar * name, gpointer user_data)
  g_print ("decodebin child added %s\n", name);
  if (g_strrstr (name, "decodebin") == name) {
    g_signal_connect (G_OBJECT (object), "child-added",
        G_CALLBACK (decodebin_child_added), user_data);
  int current_device = -1;
  cudaGetDevice(&current_device);
  struct cudaDeviceProp prop;
  cudaGetDeviceProperties(&prop, current_device);
  if (g_strrstr (name, "nvv4l2decoder") == name) {
    if(prop.integrated) {
      g_object_set (object, "enable-max-performance", TRUE, NULL);
      g_object_set (object, "bufapi-version", TRUE, NULL);
      g_object_set (object, "drop-frame-interval", 0, NULL);
      g_object_set (object, "num-extra-surfaces", 0, NULL);
    } else {
      g_object_set (object, "gpu-id", GPU_ID, NULL);
static gchar *
get_absolute_file_path (gchar *cfg_file_path, gchar *file_path)
  gchar abs_cfg_path[PATH_MAX + 1];
  gchar *abs_file_path;
  gchar *delim;
  if (file_path && file_path[0] == '/') {
    return file_path;
  if (!realpath (cfg_file_path, abs_cfg_path)) {
    g_free (file_path);
    return NULL;
  /* Return absolute path of config file if file_path is NULL. */
  if (!file_path) {
    abs_file_path = g_strdup (abs_cfg_path);
    return abs_file_path;
  delim = g_strrstr (abs_cfg_path, "/");
  *(delim + 1) = '\0';
  abs_file_path = g_strconcat (abs_cfg_path, file_path, NULL);
  g_free (file_path);
static GstPadProbeReturn
eos_probe_cb(GstPad* pad, GstPadProbeInfo* info, gpointer u_data)
    if (GST_EVENT_TYPE(GST_PAD_PROBE_INFO_DATA(info)) != GST_EVENT_EOS)
        return GST_PAD_PROBE_OK;
    return GST_PAD_PROBE_DROP;
static void
cb_newpad (GstElement * decodebin, GstPad * pad, gpointer data)
  GstCaps *caps = gst_pad_query_caps (pad, NULL);
  const GstStructure *str = gst_caps_get_structure (caps, 0);
  const gchar *name = gst_structure_get_name (str);
  g_print ("decodebin new pad %s\n", name);
  if (!strncmp (name, "video", 5)) {
    gint source_id = (*(gint *) data);
    gchar pad_name[16] = { 0 };
    GstPad *sinkpad = NULL;
    g_snprintf (pad_name, 15, "sink_%u", source_id);
    sinkpad = gst_element_get_request_pad (streammux, pad_name);
    if (gst_pad_link (pad, sinkpad) != GST_PAD_LINK_OK) {
      g_print ("Failed to link decodebin to pipeline\n");
    } else {
      g_print ("Decodebin linked to pipeline\n");
    gst_object_unref (sinkpad);
    gst_pad_add_probe(pad, GST_PAD_PROBE_TYPE_EVENT_DOWNSTREAM,
                      eos_probe_cb, pipeline, NULL);
static GstElement *
create_uridecode_bin (guint index, gchar * filename)
  GstElement *bin = NULL;
  gchar bin_name[16] = { };
  g_print ("creating uridecodebin for [%s]\n", filename);
  g_source_id_list[index] = index;
  g_snprintf (bin_name, 15, "source-bin-%02d", index);
  bin = gst_element_factory_make ("uridecodebin", bin_name);
  g_object_set (G_OBJECT (bin), "uri", filename, NULL);
  g_signal_connect (G_OBJECT (bin), "pad-added",
      G_CALLBACK (cb_newpad), &g_source_id_list[index]);
  g_signal_connect (G_OBJECT (bin), "child-added",
      G_CALLBACK (decodebin_child_added), &g_source_id_list[index]);
  g_source_enabled[index] = TRUE;
  return bin;
static void
stop_release_source (gint source_id)
  GstStateChangeReturn state_return;
  gchar pad_name[16];
  state_return =
      gst_element_set_state (g_source_bin_list[source_id], GST_STATE_NULL);
  switch (state_return) {
    case GST_STATE_CHANGE_SUCCESS:
      g_print ("STATE CHANGE SUCCESS\n\n");
      sinkpad = gst_element_get_static_pad (streammux, pad_name);
      gst_pad_send_event (sinkpad, gst_event_new_eos ());
      gst_pad_send_event (sinkpad, gst_event_new_flush_stop (FALSE));
      gst_element_release_request_pad (streammux, sinkpad);
      g_print ("STATE CHANGE SUCCESS %p\n\n", sinkpad);
      gst_bin_remove (GST_BIN (pipeline), g_source_bin_list[source_id]);
      source_id--;
      g_num_sources--;
      break;
    case GST_STATE_CHANGE_FAILURE:
      g_print ("STATE CHANGE FAILURE\n\n");
      break;
    case GST_STATE_CHANGE_ASYNC:
      g_print ("STATE CHANGE ASYNC\n\n");
      g_print ("STATE CHANGE ASYNC %p\n\n", sinkpad);
      source_id--;
      g_num_sources--;
      break;
    case GST_STATE_CHANGE_NO_PREROLL:
      g_print ("STATE CHANGE NO PREROLL\n\n");
      break;
    default:
      break;
  g_object_get (G_OBJECT (tiler), "rows", &tiler_rows, NULL);
  g_object_get (G_OBJECT (tiler), "columns", &tiler_columns, NULL);
  g_print ("stop_release_source tiler_rows %d \n", tiler_rows);
  g_print ("stop_release_source tiler_columns %d \n", tiler_columns);
static gboolean
delete_sources (gpointer data)
  gint source_id;
  g_mutex_lock (&eos_lock);
  for (source_id = 0; source_id < MAX_NUM_SOURCES; source_id++) {
    if (g_eos_list[source_id] == TRUE && g_source_enabled[source_id] == TRUE) {
      g_source_enabled[source_id] = FALSE;
      stop_release_source (source_id);
  g_mutex_unlock (&eos_lock);
  if (g_num_sources == 0) {
    if (g_run_forever==FALSE){
      g_main_loop_quit (loop);
      g_print ("All sources Stopped quitting\n");
    else {
      g_timeout_add_seconds (15, add_sources, (gpointer) g_source_bin_list);
    return FALSE;
  do {
    source_id = rand () % MAX_NUM_SOURCES;
  } while (!g_source_enabled[source_id]);
  g_print ("Calling Stop %d \n", source_id);
  g_print ("delete_sources tiler_rows %d \n", tiler_rows);
  g_print ("delete_sources tiler_columns %d \n", tiler_columns);
    else {
    return FALSE;
  return TRUE;
static gboolean
  gint source_id = g_num_sources;
  GstElement *source_bin;
  do {
    /* Generating random source id between 0 - MAX_NUM_SOURCES - 1,
     * which has not been enabled
  } while (g_source_enabled[source_id]);
  g_source_enabled[source_id] = TRUE;
  g_print ("Calling Start %d \n", source_id);
  source_bin = create_uridecode_bin (source_id, uri);
  if (!source_bin) {
    g_printerr ("Failed to create source bin. Exiting.\n");
    return -1;
  g_source_bin_list[source_id] = source_bin;
  gst_bin_add (GST_BIN (pipeline), source_bin);
  state_return =
      gst_element_set_state (g_source_bin_list[source_id], GST_STATE_PLAYING);
      source_id++;
      break;
      break;
      state_return =
          gst_element_get_state (g_source_bin_list[source_id], NULL, NULL,
          GST_CLOCK_TIME_NONE);
      source_id++;
      break;
      break;
    default:
      break;
  g_num_sources++;
  g_print ("add_sources tiler_rows %d \n", tiler_rows);
  g_print ("add_sources tiler_columns %d \n", tiler_columns);
  g_print ("add_sources g_num_sources %d \n", g_num_sources);
  if (g_num_sources == MAX_NUM_SOURCES) {
    /* We have reached MAX_NUM_SOURCES to be added, no stop calling this function
     * and enable calling delete sources
    g_timeout_add_seconds (5, delete_sources, (gpointer) g_source_bin_list);
    return FALSE;
  return TRUE;
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
  GMainLoop *loop = (GMainLoop *) data;
  switch (GST_MESSAGE_TYPE (msg)) {
    case GST_MESSAGE_EOS:
        g_print ("End of stream\n");
      break;
    case GST_MESSAGE_WARNING:
      gchar *debug;
      GError *error;
      gst_message_parse_warning (msg, &error, &debug);
      g_printerr ("WARNING from element %s: %s\n",
          GST_OBJECT_NAME (msg->src), error->message);
      g_free (debug);
      g_printerr ("Warning: %s\n", error->message);
      g_error_free (error);
      break;
    case GST_MESSAGE_ERROR:
      gchar *debug;
      GError *error;
      gst_message_parse_error (msg, &error, &debug);
      g_printerr ("ERROR from element %s: %s\n",
      if (debug)
        g_printerr ("Error details: %s\n", debug);
      g_free (debug);
      break;
    case GST_MESSAGE_ELEMENT:
      if (gst_nvmessage_is_stream_eos (msg)) {
        guint stream_id;
        if (gst_nvmessage_parse_stream_eos (msg, &stream_id)) {
          g_print ("Got EOS from stream %d\n", stream_id);
          g_eos_list[stream_id] = TRUE;
      break;
    default:
      break;
  return TRUE;
/* Tracker config parsing */
#define CHECK_ERROR(error) \
    if (error) { \
        g_printerr ("Error while parsing config file: %s\n", error->message); \
        goto done; \
static gboolean
set_tracker_properties (GstElement *nvtracker)
  gboolean ret = FALSE;
  GError *error = NULL;
  gchar **keys = NULL;
  gchar **key = NULL;
  GKeyFile *key_file = g_key_file_new ();
  if (!g_key_file_load_from_file (key_file, TRACKER_CONFIG_FILE, G_KEY_FILE_NONE,
          &error)) {
    g_printerr ("Failed to load config file: %s\n", error->message);
    return FALSE;
  keys = g_key_file_get_keys (key_file, CONFIG_GROUP_TRACKER, NULL, &error);
  CHECK_ERROR (error);
  for (key = keys; *key; key++) {
    if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_WIDTH)) {
      gint width =
          g_key_file_get_integer (key_file, CONFIG_GROUP_TRACKER,
          CONFIG_GROUP_TRACKER_WIDTH, &error);
      g_object_set (G_OBJECT (nvtracker), "tracker-width", width, NULL);
    } else if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_HEIGHT)) {
      gint height =
          CONFIG_GROUP_TRACKER_HEIGHT, &error);
      g_object_set (G_OBJECT (nvtracker), "tracker-height", height, NULL);
    } else if (!g_strcmp0 (*key, CONFIG_GPU_ID)) {
      guint gpu_id =
          CONFIG_GPU_ID, &error);
      g_object_set (G_OBJECT (nvtracker), "gpu_id", gpu_id, NULL);
    } else if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_LL_CONFIG_FILE)) {
      char* ll_config_file = get_absolute_file_path (TRACKER_CONFIG_FILE,
                g_key_file_get_string (key_file,
                    CONFIG_GROUP_TRACKER_LL_CONFIG_FILE, &error));
      g_object_set (G_OBJECT (nvtracker), "ll-config-file", ll_config_file, NULL);
    } else if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_LL_LIB_FILE)) {
      char* ll_lib_file = get_absolute_file_path (TRACKER_CONFIG_FILE,
                    CONFIG_GROUP_TRACKER_LL_LIB_FILE, &error));
      g_object_set (G_OBJECT (nvtracker), "ll-lib-file", ll_lib_file, NULL);
    } else if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_ENABLE_BATCH_PROCESS)) {
      gboolean enable_batch_process =
          CONFIG_GROUP_TRACKER_ENABLE_BATCH_PROCESS, &error);
      g_object_set (G_OBJECT (nvtracker), "enable_batch_process",
                    enable_batch_process, NULL);
    } else {
      g_printerr ("Unknown key '%s' for group [%s]", *key,
          CONFIG_GROUP_TRACKER);
  ret = TRUE;
done:
  if (error) {
  if (keys) {
    g_strfreev (keys);
  if (!ret) {
    g_printerr ("%s failed", __func__);
  return ret;
int
main (int argc, char *argv[])
  GstBus *bus = NULL;
  guint bus_watch_id;
  guint i;
  guint pgie_batch_size;
  gboolean sync = TRUE;
  gboolean display = TRUE;
  /* Check input arguments */
  if ((argc != 5)) {
    g_printerr ("Usage: %s <uri> <run forever> <sink> <sync>\n", argv[0]);
    g_printerr ("     : <run forever> 0 or 1 \n");
    g_printerr ("     : <sink> filesink (generates test.mkv) or nveglglessink (dGPU) or nv3dsink (Jetson)\n");
    g_printerr ("     : <sync> 0 or 1 \n\n");
    g_printerr ("example: %s file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 0 filesink 1\n", argv[0]);
    return -1;
  if (!strcmp(argv[3],"filesink")){
    display = FALSE;
  else if  (!strcmp(argv[3],"nveglglessink") || !strcmp(argv[3],"nv3dsink") ){
    display = TRUE;
  else {
    g_printerr ("Error: set correct sink: filesink, nveglglessink or nv3dsink\n");
    return -1;
  num_sources = 1;
  g_run_forever = atoi(argv[2]);
  sync = atoi(argv[4]);
  /* Standard GStreamer initialization */
  gst_init (&argc, &argv);
  loop = g_main_loop_new (NULL, FALSE);
  g_mutex_init (&eos_lock);
  /* Create gstreamer elements */
  /* Create Pipeline element that will form a connection of other elements */
  pipeline = gst_pipeline_new ("dstest-pipeline");
  /* Use nvinfer to run inferencing on decoder's output,
   * behaviour of inferencing is set through config file */
  streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
  g_object_set (G_OBJECT (streammux), "batched-push-timeout", 25000, NULL);
//  g_object_set (G_OBJECT (streammux), "batch-size", 30, NULL);
  g_object_set (G_OBJECT (streammux), "batch-size", num_sources, NULL);
  g_object_set (G_OBJECT (streammux), "enable-padding",1,NULL);
//  g_object_set (G_OBJECT (streammux), "drop-pipeline-eos", g_run_forever, NULL);
  SET_GPU_ID (streammux, GPU_ID);
  if (!pipeline || !streammux) {
    g_printerr ("One element could not be created. Exiting.\n");
    return -1;
  gst_bin_add (GST_BIN (pipeline), streammux);
  g_object_set (G_OBJECT (streammux), "live-source", 1, NULL);
  g_object_set (G_OBJECT (streammux), "width", MUXER_OUTPUT_WIDTH, "height",
                MUXER_OUTPUT_HEIGHT,
                "batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
  g_source_bin_list = g_malloc0 (sizeof (GstElement *) * MAX_NUM_SOURCES);
  uri = g_strdup (argv[1]);
  for (i = 0; i < /*num_sources */ 1; i++) {
    GstElement *source_bin = create_uridecode_bin (i, argv[i + 1]);
    if (!source_bin) {
      return -1;
    g_source_bin_list[i] = source_bin;
  g_num_sources = num_sources;
  pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
  /* Use nvtiler to stitch o/p from upstream components */
  tiler = gst_element_factory_make ("nvmultistreamtiler", "nvtiler");
  /* Use convertor to convert from NV12 to RGBA as required by nvosd */
  nvvideoconvert =
      gst_element_factory_make ("nvvideoconvert", "nvvideo-converter");
  /* Create OSD to draw on the converted RGBA buffer */
  nvosd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
  tracker = gst_element_factory_make ("nvtracker", "nvtracker");
  sgie1 = gst_element_factory_make ("nvinfer", "secondary-nvinference-engine1");
  sgie2 = gst_element_factory_make ("nvinfer", "secondary-nvinference-engine2");
  sgie3 = gst_element_factory_make ("nvinfer", "secondary-nvinference-engine3");
  queue = gst_element_factory_make ("queue", "queue");
  if (display){
  /* Finally render the osd output */
    if (prop.integrated) {
      sink = gst_element_factory_make ("nv3dsink", "nv3dsink");
    } else {
      sink = gst_element_factory_make ("nveglglessink", "nveglglessink");
  else {
    sink = gst_element_factory_make ("nvvideoencfilesinkbin","sink");
    g_object_set (G_OBJECT(sink), "container", 2, "output-file", "test.mkv", NULL);
  if (!pgie || !sgie1 || !sgie2 || !sgie3 || !tiler || !nvvideoconvert || !nvosd
      || !sink || !tracker) {
    return -1;
      MUXER_OUTPUT_HEIGHT, NULL);
  /* Set all the necessary properties of the nvinfer element,
   * the necessary ones are : */
  g_object_set (G_OBJECT (pgie), "config-file-path", PGIE_CONFIG_FILE, NULL);
  g_object_set (G_OBJECT (sgie1), "config-file-path", SGIE1_CONFIG_FILE, NULL);
  g_object_set (G_OBJECT (sgie2), "config-file-path", SGIE2_CONFIG_FILE, NULL);
  g_object_set (G_OBJECT (sgie3), "config-file-path", SGIE3_CONFIG_FILE, NULL);
  /* Set necessary properties of the tracker element. */
  if (!set_tracker_properties(tracker)) {
    g_printerr ("Failed to set tracker properties. Exiting.\n");
    return -1;
  g_object_get (G_OBJECT (pgie), "batch-size", &pgie_batch_size, NULL);
  if (pgie_batch_size < MAX_NUM_SOURCES) {
    g_printerr
        ("WARNING: Overriding infer-config batch-size (%d) with number of sources (%d)\n",
        pgie_batch_size, num_sources);
    g_object_set (G_OBJECT (pgie), "batch-size", MAX_NUM_SOURCES, NULL);
  /* Set GPU ID of elements */
  SET_GPU_ID (pgie, GPU_ID);
  SET_GPU_ID (sgie1, GPU_ID);
  SET_GPU_ID (sgie2, GPU_ID);
  SET_GPU_ID (sgie3, GPU_ID);
  tiler_rows = (guint) sqrt (num_sources);
  tiler_columns = (guint) ceil (1.0 * num_sources / tiler_rows);
  /* we set the osd properties here */
  g_object_set (G_OBJECT (tiler), "rows", tiler_rows, "columns", tiler_columns,
      "width", TILED_OUTPUT_WIDTH, "height", TILED_OUTPUT_HEIGHT, NULL);
  SET_GPU_ID (tiler, GPU_ID);
  SET_GPU_ID (nvvideoconvert, GPU_ID);
  SET_GPU_ID (nvosd, GPU_ID);
  if(!prop.integrated) {
    SET_GPU_ID (sink, GPU_ID);
  /* we add a message handler */
  bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
  bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
  gst_object_unref (bus);
  /* Set up the pipeline */
  /* we add all elements into the pipeline */
  gst_bin_add_many (GST_BIN (pipeline), pgie, tracker, sgie1, sgie2, sgie3,
      tiler, nvvideoconvert, nvosd, queue, sink, NULL);
  /* we link the elements together */
  /* file-source -> h264-parser -> nvh264-decoder ->
   * nvinfer -> nvvideoconvert -> nvosd -> video-renderer */
  if (!gst_element_link_many (streammux, pgie, tracker, sgie1, sgie2, sgie3,queue,
          tiler, nvvideoconvert, nvosd, sink, NULL)) {
    g_printerr ("Elements could not be linked. Exiting.\n");
    return -1;
  g_object_set (G_OBJECT (sink), "sync", sync, "qos", FALSE, NULL);
  gst_element_set_state (pipeline, GST_STATE_PAUSED);
  /* Set the pipeline to "playing" state */
  g_print ("Now playing: %s\n", argv[1]);
  if (gst_element_set_state (pipeline,
          GST_STATE_PLAYING) == GST_STATE_CHANGE_FAILURE) {
    g_printerr ("Failed to set pipeline to playing. Exiting.\n");
    return -1;
  //GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS (GST_BIN (pipeline), GST_DEBUG_GRAPH_SHOW_ALL, "ds-app-playing");
  /* Wait till pipeline encounters an error or EOS */
  g_print ("Running...\n");
  g_print ("main tiler_rows %d \n", tiler_rows);
  g_print ("main tiler_columns %d \n", tiler_columns);
  g_main_loop_run (loop);
  /* Out of the main loop, clean up nicely */
  g_print ("Returned, stopping playback\n");
  gst_element_set_state (pipeline, GST_STATE_NULL);
  g_print ("Deleting pipeline\n");
  gst_object_unref (GST_OBJECT (pipeline));
  g_source_remove (bus_watch_id);
  g_main_loop_unref (loop);
  g_free (g_source_bin_list);
  g_free (uri);
  g_mutex_clear (&eos_lock);
  return 0;
creating uridecodebin for [file:///home/USER/Videos/3.mp4]
0:00:01.286317969 18872 0x55c9cab94b50 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<secondary-nvinference-engine3> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 4]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:01.295255479 18872 0x55c9cab94b50 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<secondary-nvinference-engine3> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 4]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:01.296496117 18872 0x55c9cab94b50 INFO                 nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary-nvinference-engine3> [UID 4]: Load new model:../../dstest_sgie3_config.txt sucessfully
0:00:01.561658892 18872 0x55c9cab94b50 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<secondary-nvinference-engine2> NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 3]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:01.570931257 18872 0x55c9cab94b50 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<secondary-nvinference-engine2> NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 3]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:01.571943644 18872 0x55c9cab94b50 INFO                 nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary-nvinference-engine2> [UID 3]: Load new model:../../dstest_sgie2_config.txt sucessfully
0:00:01.836941297 18872 0x55c9cab94b50 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<secondary-nvinference-engine1> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 2]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:01.846602873 18872 0x55c9cab94b50 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<secondary-nvinference-engine1> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 2]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:01.847866617 18872 0x55c9cab94b50 INFO                 nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary-nvinference-engine1> [UID 2]: Load new model:../../dstest_sgie1_config.txt sucessfully
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 2
0   INPUT  kFLOAT input_1         3x224x224
1   OUTPUT kFLOAT predictions/Softmax 6x1x1
1   OUTPUT kFLOAT predictions/Softmax 20x1x1
1   OUTPUT kFLOAT predictions/Softmax 12x1x1
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
~~ CLOG[include/modules/NvMultiObjectTracker/NvTrackerParams.hpp, getConfigRoot() @line 54]: [NvTrackerParams::getConfigRoot()] !!![WARNING] Invalid low-level config file caused an exception, but will go ahead with the default config values
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is OFF
[NvMultiObjectTracker] Initialized
0:00:02.115678158 18872 0x55c9cab94b50 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
0:00:02.125307741 18872 0x55c9cab94b50 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
0:00:02.156172618 18872 0x55c9cab94b50 INFO                 nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:../../dstest_pgie_config.txt sucessfully
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0   INPUT  kFLOAT input_1         3x368x640
1   OUTPUT kFLOAT conv2d_bbox     16x23x40
2   OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
decodebin child added source
decodebin child added decodebin0
Now playing: file:///home/USER/Videos/3.mp4
Running...
main tiler_rows 1
main tiler_columns 1
decodebin child added qtdemux0
decodebin child added multiqueue0
decodebin child added h264parse0
decodebin child added capsfilter0
decodebin child added nvv4l2decoder0
decodebin new pad video/x-raw
Calling Start 3
decodebin child added decodebin1
STATE CHANGE ASYNC
decodebin child added qtdemux1
decodebin child added multiqueue1
decodebin child added h264parse1
decodebin child added capsfilter1
decodebin child added nvv4l2decoder1
add_sources tiler_rows 1
add_sources tiler_columns 1
add_sources g_num_sources 2
Calling Start 2
decodebin child added decodebin2
STATE CHANGE ASYNC
decodebin child added qtdemux2
decodebin child added multiqueue2
decodebin child added h264parse2
decodebin child added capsfilter2
decodebin child added nvv4l2decoder2
add_sources tiler_rows 2
add_sources tiler_columns 2
add_sources g_num_sources 3
Calling Start 1
decodebin child added decodebin3
STATE CHANGE ASYNC
decodebin child added qtdemux3
decodebin child added multiqueue3
decodebin child added h264parse3
decodebin child added capsfilter3
decodebin child added nvv4l2decoder3
add_sources g_num_sources 4
Calling Stop 3
STATE CHANGE SUCCESS 0x7f6d90008f40
stop_release_source tiler_rows 2
stop_release_source tiler_columns 2
delete_sources tiler_rows 2
delete_sources tiler_columns 2
Calling Stop 1
STATE CHANGE SUCCESS 0x7f6d64008810
Calling Stop 2
STATE CHANGE SUCCESS 0x7f6d74020090
Calling Stop 0
STATE CHANGE SUCCESS 0x7f6de007bd50
main tiler_rows 2
main tiler_columns 2
[NvMultiObjectTracker] De-initialized
Deleting pipeline
The rows and columns cannot decrease dynamically now.
By adding a stream they change but not correctly.When deleting a stream it will not change.
main tiler_rows 1
Calling Stop 3
Calling Stop 1
Calling Stop 2
Calling Stop 0
main tiler_rows 2
Deleting pipeline
Sorry, my previous answer was a bit ambiguous. The Gst-nvmultistreamtiler cannot support decrease the rows and columns dynamically now.
