The new nvstreammux cannot go back to PLAYING state after EOS
Continuing the discussion from The new nvstreammux cannot go back to PLAYING state after EOS:
• DeepStream Version
• TensorRT Version
is there a working solution for this problem? thanks
The problem has been fixed in DeepStream 6.2
 * Copyright (c) 2020-2021, NVIDIA CORPORATION.  All rights reserved.
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 *     http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
#include <stdio.h>
#include <stdlib.h>
#include <gst/gst.h>
#include <glib.h>
#include <math.h>
#include <gmodule.h>
#include <string.h>
#include <sys/time.h>
#include "gstnvdsmeta.h"
#include "gst-nvmessage.h"
#include "nvdsmeta.h"
#include <cuda_runtime_api.h>
#define MAX_DISPLAY_LEN 64
#define PGIE_CLASS_ID_VEHICLE 0
#define PGIE_CLASS_ID_PERSON 2
#define SET_GPU_ID(object, gpu_id) g_object_set(G_OBJECT(object), "gpu-id", gpu_id, NULL);
#define SET_MEMORY(object, mem_id) g_object_set(G_OBJECT(object), "nvbuf-memory-type", mem_id, NULL);
GMainLoop *loop = NULL;
/* The muxer output resolution must be set if the input streams will be of
 * different resolution. The muxer will scale all the input frames to this
 * resolution. */
#define MUXER_OUTPUT_WIDTH 1920
#define MUXER_OUTPUT_HEIGHT 1080
#define TILED_OUTPUT_WIDTH 1280
#define TILED_OUTPUT_HEIGHT 720
#define GPU_ID 0
#define MAX_NUM_SOURCES 1
#define PGIE_CONFIG_FILE "dstest_pgie_config.txt"
#define TRACKER_CONFIG_FILE "dstest_tracker_config.txt"
#define SGIE1_CONFIG_FILE "dstest_sgie1_config.txt"
#define SGIE2_CONFIG_FILE "dstest_sgie2_config.txt"
#define SGIE3_CONFIG_FILE "dstest_sgie3_config.txt"
#define CONFIG_GPU_ID "gpu-id"
#define CONFIG_GROUP_TRACKER "tracker"
#define CONFIG_GROUP_TRACKER_WIDTH "tracker-width"
#define CONFIG_GROUP_TRACKER_HEIGHT "tracker-height"
#define CONFIG_GROUP_TRACKER_LL_CONFIG_FILE "ll-config-file"
#define CONFIG_GROUP_TRACKER_LL_LIB_FILE "ll-lib-file"
#define CONFIG_GROUP_TRACKER_ENABLE_BATCH_PROCESS "enable-batch-process"
gint g_num_sources = 0;
gint g_source_id_list[MAX_NUM_SOURCES];
gboolean g_eos_list[MAX_NUM_SOURCES];
gboolean g_source_enabled[MAX_NUM_SOURCES];
GstElement **g_source_bin_list = NULL;
GMutex eos_lock;
gboolean g_run_forever = FALSE;
/* Assuming Resnet 10 model packaged in DS SDK */
gchar pgie_classes_str[4][32] = {"Vehicle", "TwoWheeler", "Person",
                                 "Roadsign"};
GstElement *pipeline = NULL, *streammux = NULL, *sink = NULL, *pgie = NULL,
           *sgie1 = NULL, *sgie2 = NULL, *sgie3 = NULL,
           *nvvideoconvert = NULL, *nvosd = NULL, *tiler = NULL, *tracker = NULL, *queue = NULL;
gchar *uri = NULL;
static gboolean add_sources(gpointer data);
static gboolean delete_sources(gpointer data);
static void
decodebin_child_added(GstChildProxy *child_proxy, GObject *object,
                      gchar *name, gpointer user_data)
  g_print("decodebin child added %s\n", name);
  if (g_strrstr(name, "decodebin") == name)
    g_signal_connect(G_OBJECT(object), "child-added",
                     G_CALLBACK(decodebin_child_added), user_data);
  int current_device = -1;
  cudaGetDevice(&current_device);
  struct cudaDeviceProp prop;
  cudaGetDeviceProperties(&prop, current_device);
  if (g_strrstr(name, "nvv4l2decoder") == name)
    if (prop.integrated)
      g_object_set(object, "enable-max-performance", TRUE, NULL);
      g_object_set(object, "bufapi-version", TRUE, NULL);
      g_object_set(object, "drop-frame-interval", 0, NULL);
      g_object_set(object, "num-extra-surfaces", 0, NULL);
    else
      g_object_set(object, "gpu-id", GPU_ID, NULL);
static gchar *
get_absolute_file_path(gchar *cfg_file_path, gchar *file_path)
  gchar abs_cfg_path[PATH_MAX + 1];
  gchar *abs_file_path;
  gchar *delim;
  if (file_path && file_path[0] == '/')
    return file_path;
  if (!realpath(cfg_file_path, abs_cfg_path))
    g_free(file_path);
    return NULL;
  /* Return absolute path of config file if file_path is NULL. */
  if (!file_path)
    abs_file_path = g_strdup(abs_cfg_path);
    return abs_file_path;
  delim = g_strrstr(abs_cfg_path, "/");
  *(delim + 1) = '\0';
  abs_file_path = g_strconcat(abs_cfg_path, file_path, NULL);
  g_free(file_path);
static gboolean source_switch_thread(gpointer *data)
  //	gst_element_set_state(pipeline, GST_STATE_PAUSED);
  //	gboolean ret=delete_sources((gpointer) g_source_bin_list);
  // add_sources((gpointer) g_source_bin_list);
  delete_sources((gpointer)g_source_bin_list);
  add_sources((gpointer)g_source_bin_list);
  gst_element_set_state(pipeline, GST_STATE_PLAYING);
  return true;
static GstPadProbeReturn
eos_probe_cb(GstPad *pad, GstPadProbeInfo *info, gpointer u_data)
  if (GST_EVENT_TYPE(GST_PAD_PROBE_INFO_DATA(info)) != GST_EVENT_EOS)
    return GST_PAD_PROBE_OK;
  g_idle_add((GSourceFunc)source_switch_thread, u_data);
  return GST_PAD_PROBE_DROP;
static void
cb_newpad(GstElement *decodebin, GstPad *pad, gpointer data)
  GstCaps *caps = gst_pad_query_caps(pad, NULL);
  const GstStructure *str = gst_caps_get_structure(caps, 0);
  const gchar *name = gst_structure_get_name(str);
  g_print("decodebin new pad %s\n", name);
  if (!strncmp(name, "video", 5))
    gint source_id = (*(gint *)data);
    gchar pad_name[16] = {0};
    GstPad *sinkpad = NULL;
    g_snprintf(pad_name, 15, "sink_%u", source_id);
    sinkpad = gst_element_get_request_pad(streammux, pad_name);
    if (gst_pad_link(pad, sinkpad) != GST_PAD_LINK_OK)
      g_print("Failed to link decodebin to pipeline\n");
    else
      g_print("Decodebin linked to pipeline\n");
    gst_object_unref(sinkpad);
    //    gst_pad_add_probe(pad, GST_PAD_PROBE_TYPE_EVENT_DOWNSTREAM,eos_probe_cb, pipeline, NULL);
static GstElement *
create_uridecode_bin(guint index, gchar *filename)
  GstElement *bin = NULL;
  gchar bin_name[16] = {};
  g_print("creating uridecodebin for [%s]\n", filename);
  g_source_id_list[index] = index;
  g_snprintf(bin_name, 15, "source-bin-%02d", index);
  bin = gst_element_factory_make("uridecodebin", bin_name);
  g_object_set(G_OBJECT(bin), "uri", filename, NULL);
  g_signal_connect(G_OBJECT(bin), "pad-added",
                   G_CALLBACK(cb_newpad), &g_source_id_list[index]);
  g_signal_connect(G_OBJECT(bin), "child-added",
                   G_CALLBACK(decodebin_child_added), &g_source_id_list[index]);
  g_source_enabled[index] = TRUE;
  return bin;
static void
stop_release_source(gint source_id)
  GstStateChangeReturn state_return;
  gchar pad_name[16];
  state_return =
      gst_element_set_state(g_source_bin_list[source_id], GST_STATE_NULL);
  switch (state_return)
  case GST_STATE_CHANGE_SUCCESS:
    g_print("stop_release_source STATE CHANGE SUCCESS\n\n");
    sinkpad = gst_element_get_static_pad(streammux, pad_name);
    gst_pad_send_event(sinkpad, gst_event_new_eos());
    gst_pad_send_event(sinkpad, gst_event_new_flush_stop(FALSE));
    gst_element_release_request_pad(streammux, sinkpad);
    g_print("stop_release_source STATE CHANGE SUCCESS %p\n\n", sinkpad);
    gst_bin_remove(GST_BIN(pipeline), g_source_bin_list[source_id]);
    source_id--;
    g_num_sources--;
    break;
  case GST_STATE_CHANGE_FAILURE:
    g_print("STATE CHANGE FAILURE\n\n");
    break;
  case GST_STATE_CHANGE_ASYNC:
    g_print("stop_release_source STATE CHANGE ASYNC\n\n");
    g_print("stop_release_source STATE CHANGE ASYNC %p\n\n", sinkpad);
    source_id--;
    g_num_sources--;
    break;
  case GST_STATE_CHANGE_NO_PREROLL:
    g_print("STATE CHANGE NO PREROLL\n\n");
    break;
  default:
    break;
static gboolean
  gint source_id=0;
  g_print("Calling Stop %d \n", source_id);
  stop_release_source(source_id);
  return TRUE;
static gboolean
  gint source_id = 0;
  GstElement *source_bin;
  g_print("Calling Start %d \n", source_id);
  source_bin = create_uridecode_bin(source_id, uri);
  if (!source_bin)
    g_printerr("Failed to create source bin. Exiting.\n");
    return -1;
  g_source_bin_list[source_id] = source_bin;
  gst_bin_add(GST_BIN(pipeline), source_bin);
  state_return =
      gst_element_set_state(g_source_bin_list[source_id], GST_STATE_PLAYING);
    g_print("STATE CHANGE SUCCESS\n\n");
    break;
    break;
    g_print("STATE CHANGE ASYNC\n\n");
    state_return =
        gst_element_get_state(g_source_bin_list[source_id], NULL, NULL,
                              GST_CLOCK_TIME_NONE);
    break;
    break;
  default:
    break;
  return TRUE;
static gboolean
bus_call(GstBus *bus, GstMessage *msg, gpointer data)
  GMainLoop *loop = (GMainLoop *)data;
  switch (GST_MESSAGE_TYPE(msg))
  case GST_MESSAGE_EOS:
    /*if (g_run_forever==FALSE){
      g_print ("End of stream\n");
      g_main_loop_quit (loop);
    gst_element_set_state(streammux, GST_STATE_PAUSED);
    delete_sources((gpointer)g_source_bin_list);//delete old soure_bin
    //uri = "file:///work/111b6042-1fae-11ee-b19a-00044ba5a7f2_1_DNWM00015.mp4";
    add_sources((gpointer)g_source_bin_list);// add new create source_bin
    gst_element_set_state(streammux, GST_STATE_PLAYING);
    break;
  case GST_MESSAGE_WARNING:
    gchar *debug;
    GError *error;
    gst_message_parse_warning(msg, &error, &debug);
    g_printerr("WARNING from element %s: %s\n",
               GST_OBJECT_NAME(msg->src), error->message);
    g_free(debug);
    g_printerr("Warning: %s\n", error->message);
    g_error_free(error);
    break;
  case GST_MESSAGE_ERROR:
    gchar *debug;
    GError *error;
    gst_message_parse_error(msg, &error, &debug);
    g_printerr("ERROR from element %s: %s\n",
    if (debug)
      g_printerr("Error details: %s\n", debug);
    g_free(debug);
    g_main_loop_quit(loop);
    break;
  case GST_MESSAGE_ELEMENT:
    if (gst_nvmessage_is_stream_eos(msg))
      guint stream_id;
      if (gst_nvmessage_parse_stream_eos(msg, &stream_id))
        g_print("Got EOS from stream %d\n", stream_id);
        g_mutex_lock(&eos_lock);
        g_eos_list[stream_id] = TRUE;
        g_mutex_unlock(&eos_lock);
    break;
  default:
    break;
  return TRUE;
/* Tracker config parsing */
#define CHECK_ERROR(error)                                               \
  if (error)                                                             \
    g_printerr("Error while parsing config file: %s\n", error->message); \
    goto done;                                                           \
static gboolean
set_tracker_properties(GstElement *nvtracker)
  gboolean ret = FALSE;
  GError *error = NULL;
  gchar **keys = NULL;
  gchar **key = NULL;
  GKeyFile *key_file = g_key_file_new();
  if (!g_key_file_load_from_file(key_file, TRACKER_CONFIG_FILE, G_KEY_FILE_NONE,
                                 &error))
    g_printerr("Failed to load config file: %s\n", error->message);
    return FALSE;
  keys = g_key_file_get_keys(key_file, CONFIG_GROUP_TRACKER, NULL, &error);
  CHECK_ERROR(error);
  for (key = keys; *key; key++)
    if (!g_strcmp0(*key, CONFIG_GROUP_TRACKER_WIDTH))
      gint width =
          g_key_file_get_integer(key_file, CONFIG_GROUP_TRACKER,
                                 CONFIG_GROUP_TRACKER_WIDTH, &error);
      CHECK_ERROR(error);
      g_object_set(G_OBJECT(nvtracker), "tracker-width", width, NULL);
    else if (!g_strcmp0(*key, CONFIG_GROUP_TRACKER_HEIGHT))
      gint height =
                                 CONFIG_GROUP_TRACKER_HEIGHT, &error);
      CHECK_ERROR(error);
      g_object_set(G_OBJECT(nvtracker), "tracker-height", height, NULL);
    else if (!g_strcmp0(*key, CONFIG_GPU_ID))
      guint gpu_id =
                                 CONFIG_GPU_ID, &error);
      CHECK_ERROR(error);
      g_object_set(G_OBJECT(nvtracker), "gpu_id", gpu_id, NULL);
    else if (!g_strcmp0(*key, CONFIG_GROUP_TRACKER_LL_CONFIG_FILE))
      char *ll_config_file = get_absolute_file_path(TRACKER_CONFIG_FILE,
                                                    g_key_file_get_string(key_file,
        CONFIG_GROUP_TRACKER_LL_CONFIG_FILE, &error));
      CHECK_ERROR(error);
      g_object_set(G_OBJECT(nvtracker), "ll-config-file", ll_config_file, NULL);
    else if (!g_strcmp0(*key, CONFIG_GROUP_TRACKER_LL_LIB_FILE))
      char *ll_lib_file = get_absolute_file_path(TRACKER_CONFIG_FILE,
        CONFIG_GROUP_TRACKER_LL_LIB_FILE, &error));
      CHECK_ERROR(error);
      g_object_set(G_OBJECT(nvtracker), "ll-lib-file", ll_lib_file, NULL);
    else if (!g_strcmp0(*key, CONFIG_GROUP_TRACKER_ENABLE_BATCH_PROCESS))
      gboolean enable_batch_process =
                                 CONFIG_GROUP_TRACKER_ENABLE_BATCH_PROCESS, &error);
      CHECK_ERROR(error);
      g_object_set(G_OBJECT(nvtracker), "enable_batch_process",
                   enable_batch_process, NULL);
    else
      g_printerr("Unknown key '%s' for group [%s]", *key,
                 CONFIG_GROUP_TRACKER);
  ret = TRUE;
done:
  if (error)
  if (keys)
    g_strfreev(keys);
  if (!ret)
    g_printerr("%s failed", __func__);
  return ret;
int main(int argc, char *argv[])
  GstBus *bus = NULL;
  guint bus_watch_id;
  guint i, num_sources;
  guint tiler_rows, tiler_columns;
  guint pgie_batch_size;
  gboolean sync = TRUE;
  gboolean display = TRUE;
  /* Check input arguments */
  if ((argc != 5))
    g_printerr("Usage: %s <uri> <run forever> <sink> <sync>\n", argv[0]);
    g_printerr("     : <run forever> 0 or 1 \n");
    g_printerr("     : <sink> filesink (generates test.mkv) or nveglglessink (dGPU) or nv3dsink (Jetson)\n");
    g_printerr("     : <sync> 0 or 1 \n\n");
    g_printerr("example: %s file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 0 filesink 1\n", argv[0]);
    return -1;
  if (!strcmp(argv[3], "filesink"))
    display = FALSE;
  else if (!strcmp(argv[3], "nveglglessink") || !strcmp(argv[3], "nv3dsink"))
    display = TRUE;
  else
    g_printerr("Error: set correct sink: filesink, nveglglessink or nv3dsink\n");
    return -1;
  num_sources = 1;
  g_run_forever = atoi(argv[2]);
  sync = atoi(argv[4]);
  /* Standard GStreamer initialization */
  gst_init(&argc, &argv);
  loop = g_main_loop_new(NULL, FALSE);
  g_mutex_init(&eos_lock);
  /* Create gstreamer elements */
  /* Create Pipeline element that will form a connection of other elements */
  pipeline = gst_pipeline_new("dstest-pipeline");
  /* Use nvinfer to run inferencing on decoder's output,
   * behaviour of inferencing is set through config file */
  streammux = gst_element_factory_make("nvstreammux", "stream-muxer");
  g_object_set(G_OBJECT(streammux), "batched-push-timeout", 25000, NULL);
  g_object_set(G_OBJECT(streammux), "batch-size", 30, NULL);
  g_object_set(G_OBJECT(streammux), "drop-pipeline-eos", g_run_forever, NULL);
  SET_GPU_ID(streammux, GPU_ID);
  if (!pipeline || !streammux)
    g_printerr("One element could not be created. Exiting.\n");
    return -1;
  gst_bin_add(GST_BIN(pipeline), streammux);
  g_object_set(G_OBJECT(streammux), "live-source", 1, NULL);
  g_source_bin_list = g_malloc0(sizeof(GstElement *) * MAX_NUM_SOURCES);
  uri = g_strdup(argv[1]);
  for (i = 0; i < /*num_sources */ 1; i++)
    GstElement *source_bin = create_uridecode_bin(i, argv[i + 1]);
    if (!source_bin)
      return -1;
    g_source_bin_list[i] = source_bin;
  g_num_sources = num_sources;
  pgie = gst_element_factory_make("nvinfer", "primary-nvinference-engine");
  /* Use nvtiler to stitch o/p from upstream components */
  tiler = gst_element_factory_make("nvmultistreamtiler", "nvtiler");
  /* Use convertor to convert from NV12 to RGBA as required by nvosd */
  nvvideoconvert =
      gst_element_factory_make("nvvideoconvert", "nvvideo-converter");
  /* Create OSD to draw on the converted RGBA buffer */
  nvosd = gst_element_factory_make("nvdsosd", "nv-onscreendisplay");
  tracker = gst_element_factory_make("nvtracker", "nvtracker");
  sgie1 = gst_element_factory_make("nvinfer", "secondary-nvinference-engine1");
  sgie2 = gst_element_factory_make("nvinfer", "secondary-nvinference-engine2");
  sgie3 = gst_element_factory_make("nvinfer", "secondary-nvinference-engine3");
  queue = gst_element_factory_make("queue", "queue");
  if (display)
    /* Finally render the osd output */
      sink = gst_element_factory_make("nv3dsink", "nv3dsink");
    else
      sink = gst_element_factory_make("nveglglessink", "nveglglessink");
  else
    sink = gst_element_factory_make("nvvideoencfilesinkbin", "sink");
    g_object_set(G_OBJECT(sink), "container", 2, "output-file", "test.mkv", NULL);
  if (!pgie || !sgie1 || !sgie2 || !sgie3 || !tiler || !nvvideoconvert || !nvosd || !sink || !tracker)
    return -1;
  g_object_set(G_OBJECT(streammux), "width", MUXER_OUTPUT_WIDTH, "height",
               MUXER_OUTPUT_HEIGHT, NULL);
  /* Set all the necessary properties of the nvinfer element,
   * the necessary ones are : */
  g_object_set(G_OBJECT(pgie), "config-file-path", PGIE_CONFIG_FILE, NULL);
  g_object_set(G_OBJECT(sgie1), "config-file-path", SGIE1_CONFIG_FILE, NULL);
  g_object_set(G_OBJECT(sgie2), "config-file-path", SGIE2_CONFIG_FILE, NULL);
  g_object_set(G_OBJECT(sgie3), "config-file-path", SGIE3_CONFIG_FILE, NULL);
  /* Set necessary properties of the tracker element. */
  if (!set_tracker_properties(tracker))
    g_printerr("Failed to set tracker properties. Exiting.\n");
    return -1;
  g_object_get(G_OBJECT(pgie), "batch-size", &pgie_batch_size, NULL);
  if (pgie_batch_size < MAX_NUM_SOURCES)
    g_printerr("WARNING: Overriding infer-config batch-size (%d) with number of sources (%d)\n",
               pgie_batch_size, num_sources);
    g_object_set(G_OBJECT(pgie), "batch-size", MAX_NUM_SOURCES, NULL);
  /* Set GPU ID of elements */
  SET_GPU_ID(pgie, GPU_ID);
  SET_GPU_ID(sgie1, GPU_ID);
  SET_GPU_ID(sgie2, GPU_ID);
  SET_GPU_ID(sgie3, GPU_ID);
  tiler_rows = (guint)sqrt(num_sources);
  tiler_columns = (guint)ceil(1.0 * num_sources / tiler_rows);
  /* we set the osd properties here */
  g_object_set(G_OBJECT(tiler), "rows", tiler_rows, "columns", tiler_columns,
               "width", TILED_OUTPUT_WIDTH, "height", TILED_OUTPUT_HEIGHT, NULL);
  SET_GPU_ID(tiler, GPU_ID);
  SET_GPU_ID(nvvideoconvert, GPU_ID);
  SET_GPU_ID(nvosd, GPU_ID);
  if (!prop.integrated)
    SET_GPU_ID(sink, GPU_ID);
  /* we add a message handler */
  bus = gst_pipeline_get_bus(GST_PIPELINE(pipeline));
  bus_watch_id = gst_bus_add_watch(bus, bus_call, loop);
  gst_object_unref(bus);
  /* Set up the pipeline */
  /* we add all elements into the pipeline */
  gst_bin_add_many(GST_BIN(pipeline), pgie, tracker, sgie1, sgie2, sgie3,
                   tiler, nvvideoconvert, nvosd, queue, sink, NULL);
  /* we link the elements together */
  /* file-source -> h264-parser -> nvh264-decoder ->
   * nvinfer -> nvvideoconvert -> nvosd -> video-renderer */
  if (!gst_element_link_many(streammux, pgie, tracker, sgie1, sgie2, sgie3, queue,
                             tiler, nvvideoconvert, nvosd, sink, NULL))
    g_printerr("Elements could not be linked. Exiting.\n");
    return -1;
  g_object_set(G_OBJECT(sink), "sync", sync, "qos", FALSE, NULL);
  /* Set the pipeline to "playing" state */
  g_print("Now playing: %s\n", argv[1]);
  if (gst_element_set_state(pipeline,
                            GST_STATE_PLAYING) == GST_STATE_CHANGE_FAILURE)
    g_printerr("Failed to set pipeline to playing. Exiting.\n");
    return -1;
  GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS(GST_BIN(pipeline), GST_DEBUG_GRAPH_SHOW_ALL, "ds-app-playing");
  /* Wait till pipeline encounters an error or EOS */
  g_print("Running...\n");
  // g_timeout_add_seconds (15, add_sources, (gpointer) g_source_bin_list);
  g_main_loop_run(loop);
  /* Out of the main loop, clean up nicely */
  g_print("Returned, stopping playback\n");
  gst_element_set_state(pipeline, GST_STATE_NULL);
  g_print("Deleting pipeline\n");
  gst_object_unref(GST_OBJECT(pipeline));
  g_source_remove(bus_watch_id);
  g_main_loop_unref(loop);
  g_free(g_source_bin_list);
  g_free(uri);
  g_mutex_clear(&eos_lock);
  return 0;
@Fiona.Chen
In deepstream6.2 docker I changed the runtime delete add source code , after receive EOS, delete the old source bin and add new create bin in bus_call, why it does not continue to process the video?
Calling Stop 0
nvstreammux: Successfully handled EOS for source_id=0
stop_release_source STATE CHANGE SUCCESS 0x7f0aa8022a50
Calling Start 0
creating uridecodebin for [file:///work/111b6042-1fae-11ee-b19a-00044ba5a7f2_1_DNWM00015.mp4]
decodebin child added source
decodebin child added decodebin337
STATE CHANGE ASYNC
decodebin child added qtdemux337
decodebin child added multiqueue337
decodebin child added h264parse337
decodebin child added capsfilter337
decodebin child added nvv4l2decoder337
decodebin new pad video/x-raw
WARNING from element stream-muxer: No Sources found at the input of muxer. Waiting for sources.
Warning: No Sources found at the input of muxer. Waiting for sources.
When the EOS event is received in bus callback, the whole pipeline already got the EOS event. It is no use to change the state to “PAUSE”. You need to change the whole pipeline to “NULL” state. The whole pipeline should start from the beginning.
States (gstreamer.freedesktop.org)
It has nothing to do with DeepStream. Please consult GStreamer community.
