hallo
I try to add nvtracker in deepstream_test3_app but have Display problem
label in every object only display “obj”,multi stream display same error
Delete nvtracker and display ok
* Copyright (c) 2018 NVIDIA Corporation. All rights reserved.
* NVIDIA Corporation and its licensors retain all intellectual property
* and proprietary rights in and to this software, related documentation
* and any modifications thereto. Any use, reproduction, disclosure or
* distribution of this software and related documentation without an express
* license agreement from NVIDIA Corporation is strictly prohibited.
#include <gst/gst.h>
#include <glib.h>
#include <math.h>
#include <string.h>
#include <sys/time.h>
#include "gstnvdsmeta.h"
#include "gstnvstreammeta.h"
#include "gst-nvmessage.h"
#define MAX_DISPLAY_LEN 64
#define PGIE_CLASS_ID_CAR 0
#define PGIE_CLASS_ID_BICYCLE 1
#define PGIE_CLASS_ID_PERSON 2
#define PGIE_CLASS_ID_ROADSIGN 3
#define MUXER_OUTPUT_WIDTH 1920
#define MUXER_OUTPUT_HEIGHT 1080
#define MUXER_BATCH_TIMEOUT_USEC 4000000
#define TILED_OUTPUT_WIDTH 1920
#define TILED_OUTPUT_HEIGHT 1080
#define GST_CAPS_FEATURES_NVMM "memory:NVMM"
gchar pgie_classes_str[4][32] = {"Car", "Bicycle", "Person", "Roadsign"};
#define FPS_PRINT_INTERVAL 300
static struct timeval start_time = { };
static guint probe_counter = 0;
static GstPadProbeReturn
tiler_src_pad_buffer_probe(GstPad * pad, GstPadProbeInfo * info,
gpointer u_data)
GstMeta *gst_meta = NULL;
NvDsMeta *nvdsmeta = NULL;
gpointer state = NULL;
static GQuark _nvdsmeta_quark = 0;
GstBuffer *buf = (GstBuffer *) info->data;
NvDsFrameMeta *frame_meta = NULL;
guint num_rects = 0, rect_index = 0;
NvDsObjectParams *obj_meta = NULL;
NvOSD_TextParams *txt_params = NULL;
GstNvStreamMeta *streammeta = NULL;
NvOSD_RectParams *rect_params = NULL;
guint tracking_id = 0;
if (!_nvdsmeta_quark)
_nvdsmeta_quark = g_quark_from_static_string (NVDS_META_STRING);
if (probe_counter == 0) {
gettimeofday (&start_time, NULL);
} else if (probe_counter == FPS_PRINT_INTERVAL) {
struct timeval cur_time;
gettimeofday (&cur_time, NULL);
g_print ("FPS for the last %d batches: %.2f\n", FPS_PRINT_INTERVAL,
FPS_PRINT_INTERVAL / ((cur_time.tv_sec - start_time.tv_sec) +
(cur_time.tv_usec - start_time.tv_usec) / 1e6));
probe_counter = 0;
start_time = cur_time;
probe_counter++;
streammeta = gst_buffer_get_nvstream_meta (buf);
while ((gst_meta = gst_buffer_iterate_meta (buf, &state))) {
if (gst_meta_api_type_has_tag (gst_meta->info->api, _nvdsmeta_quark)) {
nvdsmeta = (NvDsMeta *) gst_meta;
/* We are interested only in intercepting Meta of type
* "NVDS_META_FRAME_INFO" as they are from our infer elements. */
if (nvdsmeta->meta_type == NVDS_META_FRAME_INFO) {
guint car_count = 0;
guint bicycle_count = 0;
guint person_count = 0;
guint roadsign_count = 0;
frame_meta = (NvDsFrameMeta *) nvdsmeta->meta_data;
if (frame_meta == NULL) {
g_print ("NvDS Meta contained NULL meta \n");
return GST_PAD_PROBE_OK;
/* We reset the num_strings here as we plan to iterate through the
* the detected objects and form our own strings.
* The pipeline generated strings shall be discarded.
frame_meta->num_strings = 0;
num_rects = frame_meta->num_rects;
/* This means we have num_rects in frame_meta->obj_params,
* now lets iterate through them */
for (rect_index = 0; rect_index < num_rects; rect_index++) {
/* Now using above information we need to form a text that should
* be displayed on top of the bounding box, so lets form it here. */
obj_meta = (NvDsObjectParams *) & frame_meta->obj_params[rect_index];
txt_params = &(obj_meta->text_params);
rect_params = &(obj_meta->rect_params);
if (txt_params->display_text)
g_free (txt_params->display_text);
/* 添加跟踪物体ID 若是pipline中没有添加nvtracker则所有id都显示-1 */
tracking_id = obj_meta->tracking_id;
txt_params->display_text = g_malloc0 (MAX_DISPLAY_LEN);
g_snprintf (txt_params->display_text, MAX_DISPLAY_LEN, "%s %d",
pgie_classes_str[obj_meta->class_id], tracking_id);
/* Now set the offsets where the string should appear */
txt_params->x_offset = obj_meta->rect_params.left;
txt_params->y_offset = obj_meta->rect_params.top - 25;
/* Font , font-color and font-size */
txt_params->font_params.font_name = "Arial";
txt_params->font_params.font_size = 12;
txt_params->font_params.font_color.red = 1.0;
txt_params->font_params.font_color.green = 1.0;
txt_params->font_params.font_color.blue = 1.0;
txt_params->font_params.font_color.alpha = 1.0;
/* Text background color */
txt_params->set_bg_clr = 1;
txt_params->text_bg_clr.red = 0.0;
txt_params->text_bg_clr.green = 0.0;
txt_params->text_bg_clr.blue = 0.5;
txt_params->text_bg_clr.alpha = 1.0;
if (obj_meta->class_id == PGIE_CLASS_ID_CAR)
car_count++;
/* 根据每个ID设置不同颜色 */
rect_params->border_color.red = 1.0;
rect_params->border_color.green = 0.0;
rect_params->border_color.blue = 0.0;
rect_params->border_color.alpha = 1.0;
if (obj_meta->class_id == PGIE_CLASS_ID_BICYCLE)
bicycle_count++;
rect_params->border_color.red = 0.0;
rect_params->border_color.green = 1.0;
if (obj_meta->class_id == PGIE_CLASS_ID_PERSON)
person_count++;
rect_params->border_color.blue = 1.0;
if (obj_meta->class_id == PGIE_CLASS_ID_ROADSIGN)
roadsign_count++;
rect_params->border_color.red = 0.7;
rect_params->border_color.green = 0.5;
rect_params->border_color.blue = 0.3;
frame_meta->num_strings++;
/* Enable this print by setting environment variable GST_DEBUG=4
* before running the app. */
/*g_print("Source %d Frame Number = %lu Count: car = %d bicycle = %d "
"Person = %d roadsign = %d\n", frame_meta->stream_id,
streammeta->stream_frame_num[frame_meta->batch_id],
car_count, bicycle_count, person_count, roadsign_count);*/
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
GMainLoop *loop = (GMainLoop *) data;
switch (GST_MESSAGE_TYPE (msg)) {
case GST_MESSAGE_EOS:
g_print ("End of stream\n");
g_main_loop_quit (loop);
break;
case GST_MESSAGE_WARNING:
gchar *debug;
GError *error;
gst_message_parse_warning (msg, &error, &debug);
g_printerr ("WARNING from element %s: %s\n",
GST_OBJECT_NAME (msg->src), error->message);
g_free (debug);
g_printerr ("Warning: %s\n", error->message);
g_error_free (error);
break;
case GST_MESSAGE_ERROR:
gchar *debug;
GError *error;
gst_message_parse_error (msg, &error, &debug);
g_printerr ("ERROR from element %s: %s\n",
if (debug)
g_printerr ("Error details: %s\n", debug);
g_free (debug);
break;
case GST_MESSAGE_ELEMENT:
if (gst_nvmessage_is_stream_eos (msg)) {
guint stream_id;
if (gst_nvmessage_parse_stream_eos (msg, &stream_id)) {
g_print ("Got EOS from stream %d\n", stream_id);
break;
default:
break;
return TRUE;
static void
cb_newpad (GstElement * decodebin, GstPad * decoder_src_pad, gpointer data)
GstCaps *caps = gst_pad_query_caps (decoder_src_pad, NULL);
const GstStructure *str = gst_caps_get_structure (caps, 0);
const gchar *name = gst_structure_get_name (str);
GstElement *source_bin = (GstElement *) data;
GstCapsFeatures *features = gst_caps_get_features (caps, 0);
/* Need to check if the pad created by the decodebin is for video and not
* audio. */
if (!strncmp (name, "video", 5)) {
/* Link the decodebin pad only if decodebin has picked nvidia
* decoder plugin nvdec_*. We do this by checking if the pad caps contain
* NVMM memory features. */
if (gst_caps_features_contains (features, GST_CAPS_FEATURES_NVMM)) {
/* Get the source bin ghost pad */
GstPad *bin_ghost_pad = gst_element_get_static_pad (source_bin, "src");
if (!gst_ghost_pad_set_target (GST_GHOST_PAD (bin_ghost_pad),
decoder_src_pad)) {
g_printerr ("Failed to link decoder src pad to source bin ghost pad\n");
gst_object_unref (bin_ghost_pad);
} else {
g_printerr ("Error: Decodebin did not pick nvidia decoder plugin.\n");
static GstElement *
create_source_bin (guint index, gchar * uri)
GstElement *bin = NULL, *uri_decode_bin = NULL;
gchar bin_name[16] = { };
g_snprintf (bin_name, 15, "source-bin-%02d", index);
/* Create a source GstBin to abstract this bin's content from the rest of the
* pipeline */
bin = gst_bin_new (bin_name);
/* Source element for reading from the uri.
* We will use decodebin and let it figure out the container format of the
* stream and the codec and plug the appropriate demux and decode plugins. */
uri_decode_bin = gst_element_factory_make ("uridecodebin", "uri-decode-bin");
if (!bin || !uri_decode_bin) {
g_printerr ("One element in source bin could not be created.\n");
return NULL;
/* We set the input uri to the source element */
g_object_set (G_OBJECT (uri_decode_bin), "uri", uri, NULL);
/* Connect to the "pad-added" signal of the decodebin which generates a
* callback once a new pad for raw data has beed created by the decodebin */
g_signal_connect (G_OBJECT (uri_decode_bin), "pad-added",
G_CALLBACK (cb_newpad), bin);
gst_bin_add (GST_BIN (bin), uri_decode_bin);
/* We need to create a ghost pad for the source bin which will act as a proxy
* for the video decoder src pad. The ghost pad will not have a target right
* now. Once the decode bin creates the video decoder and generates the
* cb_newpad callback, we will set the ghost pad target to the video decoder
* src pad. */
if (!gst_element_add_pad (bin, gst_ghost_pad_new_no_target ("src",
GST_PAD_SRC))) {
g_printerr ("Failed to add ghost pad in source bin\n");
return NULL;
return bin;
int
main (int argc, char *argv[])
GMainLoop *loop = NULL;
GstElement *pipeline = NULL, *streammux = NULL, *sink = NULL, *pgie = NULL,
*nvvidconv = NULL, *nvosd = NULL, *tiler = NULL;
GstBus *bus = NULL;
guint bus_watch_id;
GstPad *tiler_src_pad = NULL;
guint i, num_sources;
guint tiler_rows, tiler_columns;
guint pgie_batch_size;
GstElement *nvtracker = NULL,
*nvvidconv1 = NULL,
*filter3 = NULL,
*videoconvert = NULL,
*filter4 = NULL,
*x264enc = NULL,
*qtmux = NULL;
GstCaps *caps3 = NULL, *caps4 = NULL;
/* Check input arguments */
if (argc < 2) {
g_printerr ("Usage: %s <uri1> [uri2] ... [uriN] \n", argv[0]);
return -1;
num_sources = argc - 1;
/* Standard GStreamer initialization */
gst_init (&argc, &argv);
loop = g_main_loop_new (NULL, FALSE);
/* Create gstreamer elements */
/* Create Pipeline element that will form a connection of other elements */
pipeline = gst_pipeline_new ("dstest3-pipeline");
/* Create nvstreammux instance to form batches from one or more sources. */
streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
if (!pipeline || !streammux) {
g_printerr ("One element could not be created. Exiting.\n");
return -1;
gst_bin_add (GST_BIN (pipeline), streammux);
for (i = 0; i < num_sources; i++) {
GstPad *sinkpad, *srcpad;
gchar pad_name[16] = { };
GstElement *source_bin = create_source_bin (i, argv[i + 1]);
if (!source_bin) {
g_printerr ("Failed to create source bin. Exiting.\n");
return -1;
gst_bin_add (GST_BIN (pipeline), source_bin);
g_snprintf (pad_name, 15, "sink_%u", i);
sinkpad = gst_element_get_request_pad (streammux, pad_name);
if (!sinkpad) {
g_printerr ("Streammux request sink pad failed. Exiting.\n");
return -1;
srcpad = gst_element_get_static_pad (source_bin, "src");
if (!srcpad) {
g_printerr ("Failed to get src pad of source bin. Exiting.\n");
return -1;
if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
g_printerr ("Failed to link source bin to stream muxer. Exiting.\n");
return -1;
gst_object_unref (srcpad);
gst_object_unref (sinkpad);
/* Use nvinfer to infer on batched frame. */
pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
/* 我们需要一个跟踪器跟踪被识别的物体。 */
nvtracker = gst_element_factory_make ("nvtracker", "tracker");
/* Use nvtiler to composite the batched frames into a 2D tiled array based
* on the source of the frames. */
tiler = gst_element_factory_make ("nvmultistreamtiler", "nvtiler");
/* Use convertor to convert from NV12 to RGBA as required by nvosd */
nvvidconv = gst_element_factory_make ("nvvidconv", "nvvideo-converter");
/* Create OSD to draw on the converted RGBA buffer */
nvosd = gst_element_factory_make ("nvosd", "nv-onscreendisplay");
nvvidconv1 = gst_element_factory_make ("nvvidconv", "nvvideo-converter1");
videoconvert = gst_element_factory_make ("videoconvert", "converter");
x264enc = gst_element_factory_make ("x264enc", "h264 encoder");
qtmux = gst_element_factory_make ("qtmux", "muxer");
/* Finally render the osd output */
sink = gst_element_factory_make ("filesink", "filesink");
filter3 = gst_element_factory_make ("capsfilter", "filter3");
filter4 = gst_element_factory_make ("capsfilter", "filter4");
if (!pgie || !tiler || !nvvidconv || !nvosd || !sink) {
return -1;
if (!nvtracker || !nvvidconv1 || !x264enc || !qtmux || !filter3 || !filter4) {
return -1;
g_object_set (G_OBJECT (sink), "location", "out.mp4", NULL);
g_object_set (G_OBJECT (streammux), "width", MUXER_OUTPUT_WIDTH, "height",
MUXER_OUTPUT_HEIGHT, "batch-size", num_sources,
"batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
/* Configure the nvinfer element using the nvinfer config file. */
g_object_set (G_OBJECT (pgie),
"config-file-path", "dstest3_pgie_config.txt", NULL);
/* Override the batch-size set in the config file with the number of sources. */
g_object_get (G_OBJECT (pgie), "batch-size", &pgie_batch_size, NULL);
if (pgie_batch_size != num_sources) {
g_printerr
("WARNING: Overriding infer-config batch-size (%d) with number of sources (%d)\n",
pgie_batch_size, num_sources);
g_object_set (G_OBJECT (pgie), "batch-size", num_sources, NULL);
tiler_rows = (guint) sqrt (num_sources);
tiler_columns = (guint) ceil (1.0 * num_sources / tiler_rows);
/* we set the tiler properties here */
g_object_set (G_OBJECT (tiler), "rows", tiler_rows, "columns", tiler_columns,
"width", TILED_OUTPUT_WIDTH, "height", TILED_OUTPUT_HEIGHT, NULL);
/* we set the osd properties here */
g_object_set (G_OBJECT (nvosd), "font-size", 15, NULL);
/* we add a message handler */
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
gst_object_unref (bus);
/* Set up the pipeline */
/* we add all elements into the pipeline */
gst_bin_add_many (GST_BIN (pipeline), pgie, nvtracker, tiler, nvvidconv, nvosd, nvvidconv1, filter3,
videoconvert, filter4,
x264enc, qtmux, sink,
NULL);
/* we link the elements together
* nvstreammux -> nvinfer -> nvtiler -> nvvidconv -> nvosd -> video-renderer */
if (!gst_element_link_many (streammux, pgie, nvtracker, tiler, nvvidconv, nvosd, nvvidconv1, filter3,
NULL)) {
g_printerr ("Elements could not be linked. Exiting.\n");
return -1;
/* Lets add probe to get informed of the meta data generated, we add probe to
* the sink pad of the osd element, since by that time, the buffer would have
* had got all the metadata. */
tiler_src_pad = gst_element_get_static_pad (pgie, "src");
if (!tiler_src_pad)
g_print ("Unable to get src pad\n");
else
gst_pad_add_probe (tiler_src_pad, GST_PAD_PROBE_TYPE_BUFFER,
tiler_src_pad_buffer_probe, NULL, NULL);
/* Set the pipeline to "playing" state */
g_print ("Now playing:");
g_print (" %s,", argv[i + 1]);
g_print ("\n");
gst_element_set_state (pipeline, GST_STATE_PLAYING);
/* Wait till pipeline encounters an error or EOS */
g_print ("Running...\n");
g_main_loop_run (loop);
/* Out of the main loop, clean up nicely */
g_print ("Returned, stopping playback\n");
gst_element_set_state (pipeline, GST_STATE_NULL);
g_print ("Deleting pipeline\n");
gst_object_unref (GST_OBJECT (pipeline));
g_source_remove (bus_watch_id);
g_main_loop_unref (loop);
return 0;
Difference.html (13.7 KB)
