Enable Perf measurement(FPS) for deepstream-test3-app not working
Hi all !
I am working with enable Perf measurement(FPS) in deepstream-test3-app.
I follow Enable Perf measurement(FPS) for deepstream sample apps, make file success but just print
**PERF:
How can i fix it? Thank so much
This is code i modified:
 * Copyright (c) 2018-2020, NVIDIA CORPORATION. All rights reserved.
 * Permission is hereby granted, free of charge, to any person obtaining a
 * copy of this software and associated documentation files (the "Software"),
 * to deal in the Software without restriction, including without limitation
 * the rights to use, copy, modify, merge, publish, distribute, sublicense,
 * and/or sell copies of the Software, and to permit persons to whom the
 * Software is furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
 * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
 * DEALINGS IN THE SOFTWARE.
#include <gst/gst.h>
#include <glib.h>
#include <stdio.h>
#include <math.h>
#include <string.h>
#include <sys/time.h>
#include <cuda_runtime_api.h>
#include "gstnvdsmeta.h"
#include "deepstream_perf.h"
//#include "gstnvstreammeta.h"
#ifndef PLATFORM_TEGRA
#include "gst-nvmessage.h"
#endif
#define MAX_DISPLAY_LEN 64
#define PGIE_CLASS_ID_VEHICLE 0
#define PGIE_CLASS_ID_PERSON 2
/* By default, OSD process-mode is set to CPU_MODE. To change mode, set as:
 * 1: GPU mode (for Tesla only)
 * 2: HW mode (For Jetson only)
#define OSD_PROCESS_MODE 0
/* By default, OSD will not display text. To display text, change this to 1 */
#define OSD_DISPLAY_TEXT 0
/* The muxer output resolution must be set if the input streams will be of
 * different resolution. The muxer will scale all the input frames to this
 * resolution. */
#define MUXER_OUTPUT_WIDTH 1920
#define MUXER_OUTPUT_HEIGHT 1080
/* Muxer batch formation timeout, for e.g. 40 millisec. Should ideally be set
 * based on the fastest source's framerate. */
#define MUXER_BATCH_TIMEOUT_USEC 40000
#define MAX_STREAMS 64
typedef struct
  /** identifies the stream ID */
  guint32 stream_index;
  gdouble fps[MAX_STREAMS];
  gdouble fps_avg[MAX_STREAMS];
  guint32 num_instances;
  guint header_print_cnt;
  GMutex fps_lock;
  gpointer context;
  /** Test specific info */
  guint32 set_batch_size;
}DemoPerfCtx;
#define TILED_OUTPUT_WIDTH 1280
#define TILED_OUTPUT_HEIGHT 720
/* NVIDIA Decoder source pad memory feature. This feature signifies that source
 * pads having this capability will push GstBuffers containing cuda buffers. */
#define GST_CAPS_FEATURES_NVMM "memory:NVMM"
gchar pgie_classes_str[4][32] = { "Vehicle", "TwoWheeler", "Person",
  "RoadSign"
#define FPS_PRINT_INTERVAL 300
//static struct timeval start_time = { };
//static guint probe_counter = 0;
 * callback function to print the performance numbers of each stream.
static void
perf_cb (gpointer context, NvDsAppPerfStruct * str)
  DemoPerfCtx *thCtx = (DemoPerfCtx *) context;
  g_mutex_lock(&thCtx->fps_lock);
  /** str->num_instances is == num_sources */
  guint32 numf = str->num_instances;
  guint32 i;
  for (i = 0; i < numf; i++) {
    thCtx->fps[i] = str->fps[i];
    thCtx->fps_avg[i] = str->fps_avg[i];
  thCtx->context = thCtx;
  g_print ("**PERF: ");
    g_print ("%.2f (%.2f)\t", thCtx->fps[i], thCtx->fps_avg[i]);
  g_print ("\n");
  g_mutex_unlock(&thCtx->fps_lock);
/* tiler_sink_pad_buffer_probe  will extract metadata received on OSD sink pad
 * and update params for drawing rectangle, object information etc. */
static GstPadProbeReturn
tiler_src_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
    gpointer u_data)
    GstBuffer *buf = (GstBuffer *) info->data;
    guint num_rects = 0;
    NvDsObjectMeta *obj_meta = NULL;
    guint vehicle_count = 0;
    guint person_count = 0;
    NvDsMetaList * l_frame = NULL;
    NvDsMetaList * l_obj = NULL;
    //NvDsDisplayMeta *display_meta = NULL;
    NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
    for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
      l_frame = l_frame->next) {
        NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
        //int offset = 0;
        for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
                l_obj = l_obj->next) {
            obj_meta = (NvDsObjectMeta *) (l_obj->data);
            if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
                vehicle_count++;
                num_rects++;
            if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) {
                person_count++;
                num_rects++;
          g_print ("Frame Number = %d Number of objects = %d "
            "Vehicle Count = %d Person Count = %d\n",
            frame_meta->frame_num, num_rects, vehicle_count, person_count);
#if 0
        display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
        NvOSD_TextParams *txt_params  = &display_meta->text_params;
        txt_params->display_text = g_malloc0 (MAX_DISPLAY_LEN);
        offset = snprintf(txt_params->display_text, MAX_DISPLAY_LEN, "Person = %d ", person_count);
        offset = snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN, "Vehicle = %d ", vehicle_count);
        /* Now set the offsets where the string should appear */
        txt_params->x_offset = 10;
        txt_params->y_offset = 12;
        /* Font , font-color and font-size */
        txt_params->font_params.font_name = "Serif";
        txt_params->font_params.font_size = 10;
        txt_params->font_params.font_color.red = 1.0;
        txt_params->font_params.font_color.green = 1.0;
        txt_params->font_params.font_color.blue = 1.0;
        txt_params->font_params.font_color.alpha = 1.0;
        /* Text background color */
        txt_params->set_bg_clr = 1;
        txt_params->text_bg_clr.red = 0.0;
        txt_params->text_bg_clr.green = 0.0;
        txt_params->text_bg_clr.blue = 0.0;
        txt_params->text_bg_clr.alpha = 1.0;
        nvds_add_display_meta_to_frame(frame_meta, display_meta);
#endif
    return GST_PAD_PROBE_OK;
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
  GMainLoop *loop = (GMainLoop *) data;
  switch (GST_MESSAGE_TYPE (msg)) {
    case GST_MESSAGE_EOS:
      g_print ("End of stream\n");
      g_main_loop_quit (loop);
      break;
    case GST_MESSAGE_WARNING:
      gchar *debug;
      GError *error;
      gst_message_parse_warning (msg, &error, &debug);
      g_printerr ("WARNING from element %s: %s\n",
          GST_OBJECT_NAME (msg->src), error->message);
      g_free (debug);
      g_printerr ("Warning: %s\n", error->message);
      g_error_free (error);
      break;
    case GST_MESSAGE_ERROR:
      gchar *debug;
      GError *error;
      gst_message_parse_error (msg, &error, &debug);
      g_printerr ("ERROR from element %s: %s\n",
      if (debug)
        g_printerr ("Error details: %s\n", debug);
      g_free (debug);
      break;
    case GST_MESSAGE_ELEMENT:
      if (gst_nvmessage_is_stream_eos (msg)) {
        guint stream_id;
        if (gst_nvmessage_parse_stream_eos (msg, &stream_id)) {
          g_print ("Got EOS from stream %d\n", stream_id);
      break;
#endif
    default:
      break;
  return TRUE;
static void
cb_newpad (GstElement * decodebin, GstPad * decoder_src_pad, gpointer data)
  g_print ("In cb_newpad\n");
  GstCaps *caps = gst_pad_get_current_caps (decoder_src_pad);
  const GstStructure *str = gst_caps_get_structure (caps, 0);
  const gchar *name = gst_structure_get_name (str);
  GstElement *source_bin = (GstElement *) data;
  GstCapsFeatures *features = gst_caps_get_features (caps, 0);
  /* Need to check if the pad created by the decodebin is for video and not
   * audio. */
  if (!strncmp (name, "video", 5)) {
    /* Link the decodebin pad only if decodebin has picked nvidia
     * decoder plugin nvdec_*. We do this by checking if the pad caps contain
     * NVMM memory features. */
    if (gst_caps_features_contains (features, GST_CAPS_FEATURES_NVMM)) {
      /* Get the source bin ghost pad */
      GstPad *bin_ghost_pad = gst_element_get_static_pad (source_bin, "src");
      if (!gst_ghost_pad_set_target (GST_GHOST_PAD (bin_ghost_pad),
              decoder_src_pad)) {
        g_printerr ("Failed to link decoder src pad to source bin ghost pad\n");
      gst_object_unref (bin_ghost_pad);
    } else {
      g_printerr ("Error: Decodebin did not pick nvidia decoder plugin.\n");
static void
decodebin_child_added (GstChildProxy * child_proxy, GObject * object,
    gchar * name, gpointer user_data)
  g_print ("Decodebin child added: %s\n", name);
  if (g_strrstr (name, "decodebin") == name) {
    g_signal_connect (G_OBJECT (object), "child-added",
        G_CALLBACK (decodebin_child_added), user_data);
static GstElement *
create_source_bin (guint index, gchar * uri)
  GstElement *bin = NULL, *uri_decode_bin = NULL;
  gchar bin_name[16] = { };
  g_snprintf (bin_name, 15, "source-bin-%02d", index);
  /* Create a source GstBin to abstract this bin's content from the rest of the
   * pipeline */
  bin = gst_bin_new (bin_name);
  /* Source element for reading from the uri.
   * We will use decodebin and let it figure out the container format of the
   * stream and the codec and plug the appropriate demux and decode plugins. */
  uri_decode_bin = gst_element_factory_make ("uridecodebin", "uri-decode-bin");
  if (!bin || !uri_decode_bin) {
    g_printerr ("One element in source bin could not be created.\n");
    return NULL;
  /* We set the input uri to the source element */
  g_object_set (G_OBJECT (uri_decode_bin), "uri", uri, NULL);
  /* Connect to the "pad-added" signal of the decodebin which generates a
   * callback once a new pad for raw data has beed created by the decodebin */
  g_signal_connect (G_OBJECT (uri_decode_bin), "pad-added",
      G_CALLBACK (cb_newpad), bin);
  g_signal_connect (G_OBJECT (uri_decode_bin), "child-added",
      G_CALLBACK (decodebin_child_added), bin);
  gst_bin_add (GST_BIN (bin), uri_decode_bin);
  /* We need to create a ghost pad for the source bin which will act as a proxy
   * for the video decoder src pad. The ghost pad will not have a target right
   * now. Once the decode bin creates the video decoder and generates the
   * cb_newpad callback, we will set the ghost pad target to the video decoder
   * src pad. */
  if (!gst_element_add_pad (bin, gst_ghost_pad_new_no_target ("src",
              GST_PAD_SRC))) {
    g_printerr ("Failed to add ghost pad in source bin\n");
    return NULL;
  return bin;
int
main (int argc, char *argv[])
  GMainLoop *loop = NULL;
  GstElement *pipeline = NULL, *streammux = NULL, *sink = NULL, *pgie = NULL,
      *queue1, *queue2, *queue3, *queue4, *queue5, *nvvidconv = NULL,
      *nvosd = NULL, *tiler = NULL;
  GstElement *transform = NULL;
  GstBus *bus = NULL;
  guint bus_watch_id;
  GstPad *tiler_src_pad = NULL;
  guint i, num_sources;
  guint tiler_rows, tiler_columns;
  guint pgie_batch_size;
  int current_device = -1;
  cudaGetDevice(&current_device);
  struct cudaDeviceProp prop;
  cudaGetDeviceProperties(&prop, current_device);
  /* Check input arguments */
  if (argc < 2) {
    g_printerr ("Usage: %s <uri1> [uri2] ... [uriN] \n", argv[0]);
    return -1;
  num_sources = argc - 1;
  /* Standard GStreamer initialization */
  gst_init (&argc, &argv);
  loop = g_main_loop_new (NULL, FALSE);
  /* Create gstreamer elements */
  /* Create Pipeline element that will form a connection of other elements */
  pipeline = gst_pipeline_new ("dstest3-pipeline");
  /* Create nvstreammux instance to form batches from one or more sources. */
  streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
  if (!pipeline || !streammux) {
    g_printerr ("One element could not be created. Exiting.\n");
    return -1;
  gst_bin_add (GST_BIN (pipeline), streammux);
  for (i = 0; i < num_sources; i++) {
    GstPad *sinkpad, *srcpad;
    gchar pad_name[16] = { };
    GstElement *source_bin = create_source_bin (i, argv[i + 1]);
    if (!source_bin) {
      g_printerr ("Failed to create source bin. Exiting.\n");
      return -1;
    gst_bin_add (GST_BIN (pipeline), source_bin);
    g_snprintf (pad_name, 15, "sink_%u", i);
    sinkpad = gst_element_get_request_pad (streammux, pad_name);
    if (!sinkpad) {
      g_printerr ("Streammux request sink pad failed. Exiting.\n");
      return -1;
    srcpad = gst_element_get_static_pad (source_bin, "src");
    if (!srcpad) {
      g_printerr ("Failed to get src pad of source bin. Exiting.\n");
      return -1;
    if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
      g_printerr ("Failed to link source bin to stream muxer. Exiting.\n");
      return -1;
    gst_object_unref (srcpad);
    gst_object_unref (sinkpad);
  /* Use nvinfer to infer on batched frame. */
  pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
  /* Add queue elements between every two elements */
  queue1 = gst_element_factory_make ("queue", "queue1");
  queue2 = gst_element_factory_make ("queue", "queue2");
  queue3 = gst_element_factory_make ("queue", "queue3");
  queue4 = gst_element_factory_make ("queue", "queue4");
  queue5 = gst_element_factory_make ("queue", "queue5");
  /* Use nvtiler to composite the batched frames into a 2D tiled array based
   * on the source of the frames. */
  tiler = gst_element_factory_make ("nvmultistreamtiler", "nvtiler");
  /* Use convertor to convert from NV12 to RGBA as required by nvosd */
  nvvidconv = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter");
  /* Create OSD to draw on the converted RGBA buffer */
  nvosd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
  /* Finally render the osd output */
  if(prop.integrated) {
    transform = gst_element_factory_make ("nvegltransform", "nvegl-transform");
  sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
  if (!pgie || !tiler || !nvvidconv || !nvosd || !sink) {
    return -1;
  if(!transform && prop.integrated) {
    g_printerr ("One tegra element could not be created. Exiting.\n");
    return -1;
  g_object_set (G_OBJECT (streammux), "batch-size", num_sources, NULL);
  g_object_set (G_OBJECT (streammux), "width", MUXER_OUTPUT_WIDTH, "height",
      MUXER_OUTPUT_HEIGHT,
      "batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
  /* Configure the nvinfer element using the nvinfer config file. */
  g_object_set (G_OBJECT (pgie),
      "config-file-path", "dstest3_pgie_config.txt", NULL);
  /* Override the batch-size set in the config file with the number of sources. */
  g_object_get (G_OBJECT (pgie), "batch-size", &pgie_batch_size, NULL);
  if (pgie_batch_size != num_sources) {
    g_printerr
        ("WARNING: Overriding infer-config batch-size (%d) with number of sources (%d)\n",
        pgie_batch_size, num_sources);
    g_object_set (G_OBJECT (pgie), "batch-size", num_sources, NULL);
  tiler_rows = (guint) sqrt (num_sources);
  tiler_columns = (guint) ceil (1.0 * num_sources / tiler_rows);
  /* we set the tiler properties here */
  g_object_set (G_OBJECT (tiler), "rows", tiler_rows, "columns", tiler_columns,
      "width", TILED_OUTPUT_WIDTH, "height", TILED_OUTPUT_HEIGHT, NULL);
  g_object_set (G_OBJECT (nvosd), "process-mode", OSD_PROCESS_MODE,
      "display-text", OSD_DISPLAY_TEXT, NULL);
  g_object_set (G_OBJECT (sink), "qos", 0, NULL);
  /* we add a message handler */
  bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
  bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
  gst_object_unref (bus);
  /* Set up the pipeline */
  /* we add all elements into the pipeline */
    gst_bin_add_many (GST_BIN (pipeline), queue1, pgie, queue2, tiler, queue3,
        nvvidconv, queue4, nvosd, queue5, transform, sink, NULL);
    /* we link the elements together
    * nvstreammux -> nvinfer -> nvtiler -> nvvidconv -> nvosd -> video-renderer */
    if (!gst_element_link_many (streammux, queue1, pgie, queue2, tiler, queue3,
          nvvidconv, queue4, nvosd, queue5, transform, sink, NULL)) {
      g_printerr ("Elements could not be linked. Exiting.\n");
      return -1;
  else {
      nvvidconv, queue4, nvosd, queue5, sink, NULL);
          nvvidconv, queue4, nvosd, queue5, sink, NULL)) {
      return -1;
  /* Lets add probe to get informed of the meta data generated, we add probe to
   * the sink pad of the osd element, since by that time, the buffer would have
   * had got all the metadata. */
  tiler_src_pad = gst_element_get_static_pad (pgie, "src");
  if (!tiler_src_pad)
    g_print ("Unable to get src pad\n");
  else
    gst_pad_add_probe (tiler_src_pad, GST_PAD_PROBE_TYPE_BUFFER,
        tiler_src_pad_buffer_probe, NULL, NULL);
  gst_object_unref (tiler_src_pad);
  GstPad *tiler_pad =  gst_element_get_static_pad (tiler, "sink");
  if (!tiler_pad)
    g_print ("Unable to get tiler_pad pad\n");
  else {
    NvDsAppPerfStructInt *str =  (NvDsAppPerfStructInt *)g_malloc0(sizeof(NvDsAppPerfStructInt));
    DemoPerfCtx *perf_ctx = (DemoPerfCtx *)g_malloc0(sizeof(DemoPerfCtx));
    g_mutex_init(&perf_ctx->fps_lock);
    str->context = perf_ctx;
    enable_perf_measurement (str, tiler_pad, argc-2, 1, 0, perf_cb);
  gst_object_unref (tiler_pad);
  /* Set the pipeline to "playing" state */
  g_print ("Now playing:");
    g_print (" %s,", argv[i + 1]);
  g_print ("\n");
  gst_element_set_state (pipeline, GST_STATE_PLAYING);
  /* Wait till pipeline encounters an error or EOS */
  g_print ("Running...\n");
  g_main_loop_run (loop);
  /* Out of the main loop, clean up nicely */
  g_print ("Returned, stopping playback\n");
  gst_element_set_state (pipeline, GST_STATE_NULL);
  g_print ("Deleting pipeline\n");
  gst_object_unref (GST_OBJECT (pipeline));
  g_source_remove (bus_watch_id);
  g_main_loop_unref (loop);
  return 0;
Makefile:
# Copyright (c) 2019-2020, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
CUDA_VER?=10.2
ifeq ($(CUDA_VER),)
  $(error "CUDA_VER is not set")
endif
APP:= deepstream-test3-app
TARGET_DEVICE = $(shell gcc -dumpmachine | cut -f1 -d -)
NVDS_VERSION:=6.0
LIB_INSTALL_DIR?=/opt/nvidia/deepstream/deepstream-$(NVDS_VERSION)/lib/
APP_INSTALL_DIR?=/opt/nvidia/deepstream/deepstream-$(NVDS_VERSION)/bin/
ifeq ($(TARGET_DEVICE),aarch64)
  CFLAGS:= -DPLATFORM_TEGRA
endif
SRCS:= $(wildcard *.c)
SRCS+= $(wildcard ../../apps-common/src/deepstream_perf.c)
INCS:= $(wildcard *.h)
PKGS:= gstreamer-1.0
OBJS:= $(SRCS:.c=.o)
CFLAGS+= -I../../../includes \
		-I../../apps-common/includes \
		-I /usr/local/cuda-$(CUDA_VER)/include
CFLAGS+= $(shell pkg-config --cflags $(PKGS))
LIBS:= $(shell pkg-config --libs $(PKGS))
LIBS+= -L/usr/local/cuda-$(CUDA_VER)/lib64/ -lcudart -lnvdsgst_helper -lm \
		-L$(LIB_INSTALL_DIR) -lnvdsgst_meta -lnvds_meta \
		-lcuda -Wl,-rpath,$(LIB_INSTALL_DIR)
all: $(APP)
%.o: %.c $(INCS) Makefile
	$(CC) -c -o $@ $(CFLAGS) $<
$(APP): $(OBJS) Makefile
	$(CC) -o $(APP) $(OBJS) $(LIBS)
install: $(APP)
	cp -rv $(APP) $(APP_INSTALL_DIR)
clean:
	rm -rf $(OBJS) $(APP)
And log:
Frame Number = 99 Number of objects = 16 Vehicle Count = 11 Person Count = 5
Frame Number = 100 Number of objects = 17 Vehicle Count = 11 Person Count = 6
Frame Number = 101 Number of objects = 16 Vehicle Count = 10 Person Count = 6
Frame Number = 102 Number of objects = 15 Vehicle Count = 11 Person Count = 4
**PERF:
Frame Number = 103 Number of objects = 18 Vehicle Count = 14 Person Count = 4
Frame Number = 104 Number of objects = 19 Vehicle Count = 14 Person Count = 5
Frame Number = 105 Number of objects = 16 Vehicle Count = 12 Person Count = 4
• Hardware Platform Jetson NX
• DeepStream 6.0
• JetPack 4.6
What’s your command like?
i run with command:
./deepstream-test3-app file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_1080p_h264.mp4
Could you try to set the third parameter of enable_perf_measurement to the number of sources?
it working
I change the third parameter from argc-2 to num_sources
Thank you
