I added the original code (deepstream_pose_estimation_app.cpp
), refering to DeepStream SDK FAQ - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums .
However, the FPS is 0.000233. It seems to be too slow, is this normal?
$ sudo ./deepstream-pose-estimation-app ../../../../samples/streams/couple.h264 output/
Now playing: ../../../../samples/streams/couple.h264
Opening in BLOCKING MODE
0:00:04.241684344 9064 0x559b13ff80 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1701> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream_pose_estimation_fps/pose_estimation.onnx_b1_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input.1 3x224x224
1 OUTPUT kFLOAT 262 18x56x56
2 OUTPUT kFLOAT 264 42x56x56
0:00:04.241860246 9064 0x559b13ff80 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1805> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream_pose_estimation_fps/pose_estimation.onnx_b1_gpu0_fp16.engine
0:00:04.275769467 9064 0x559b13ff80 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:deepstream_pose_estimation_config.txt sucessfully
Running...
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 0
End of Stream
Returned, stopping playback
Deleting pipeline
Average fps 0.000233
↓deepstream_pose_estimation_app.cpp (edited)
// Copyright 2020 - NVIDIA Corporation
// SPDX-License-Identifier: MIT
#include "post_process.cpp"
#include <gst/gst.h>
#include <glib.h>
#include <stdio.h>
#include "gstnvdsmeta.h"
#include "nvdsgstutils.h"
#include "nvbufsurface.h"
#include <vector>
#include <array>
#include <queue>
#include <cmath>
#include <string>
#define EPS 1e-6
#define MAX_DISPLAY_LEN 64
/* The muxer output resolution must be set if the input streams will be of
* different resolution. The muxer will scale all the input frames to this
* resolution. */
#define MUXER_OUTPUT_WIDTH 1920
#define MUXER_OUTPUT_HEIGHT 1080
/* Muxer batch formation timeout, for e.g. 40 millisec. Should ideally be set
* based on the fastest source's framerate. */
#define MUXER_BATCH_TIMEOUT_USEC 4000000
template <class T>
using Vec1D = std::vector<T>;
template <class T>
using Vec2D = std::vector<Vec1D<T>>;
template <class T>
using Vec3D = std::vector<Vec2D<T>>;
gint frame_number = 0;
typedef struct _perf_measure{
GstClockTime pre_time;
GstClockTime total_time;
guint count;
}perf_measure;
/*Method to parse information returned from the model*/
std::tuple<Vec2D<int>, Vec3D<float>>
parse_objects_from_tensor_meta(NvDsInferTensorMeta *tensor_meta)
Vec1D<int> counts;
Vec3D<int> peaks;
float threshold = 0.1;
int window_size = 5;
int max_num_parts = 2;
int num_integral_samples = 7;
float link_threshold = 0.1;
int max_num_objects = 100;
void *cmap_data = tensor_meta->out_buf_ptrs_host[0];
NvDsInferDims &cmap_dims = tensor_meta->output_layers_info[0].inferDims;
void *paf_data = tensor_meta->out_buf_ptrs_host[1];
NvDsInferDims &paf_dims = tensor_meta->output_layers_info[1].inferDims;
/* Finding peaks within a given window */
find_peaks(counts, peaks, cmap_data, cmap_dims, threshold, window_size, max_num_parts);
/* Non-Maximum Suppression */
Vec3D<float> refined_peaks = refine_peaks(counts, peaks, cmap_data, cmap_dims, window_size);
/* Create a Bipartite graph to assign detected body-parts to a unique person in the frame */
Vec3D<float> score_graph = paf_score_graph(paf_data, paf_dims, topology, counts, refined_peaks, num_integral_samples);
/* Assign weights to all edges in the bipartite graph generated */
Vec3D<int> connections = assignment(score_graph, topology, counts, link_threshold, max_num_parts);
/* Connecting all the Body Parts and Forming a Human Skeleton */
Vec2D<int> objects = connect_parts(connections, topology, counts, max_num_objects);
return {objects, refined_peaks};
/* MetaData to handle drawing onto the on-screen-display */
static void
create_display_meta(Vec2D<int> &objects, Vec3D<float> &normalized_peaks, NvDsFrameMeta *frame_meta, int frame_width, int frame_height)
int K = topology.size();
int count = objects.size();
NvDsBatchMeta *bmeta = frame_meta->base_meta.batch_meta;
NvDsDisplayMeta *dmeta = nvds_acquire_display_meta_from_pool(bmeta);
nvds_add_display_meta_to_frame(frame_meta, dmeta);
for (auto &object : objects)
int C = object.size();
for (int j = 0; j < C; j++)
int k = object[j];
if (k >= 0)
auto &peak = normalized_peaks[j][k];
int x = peak[1] * MUXER_OUTPUT_WIDTH;
int y = peak[0] * MUXER_OUTPUT_HEIGHT;
if (dmeta->num_circles == MAX_ELEMENTS_IN_DISPLAY_META)
NvOSD_CircleParams &cparams = dmeta->circle_params[dmeta->num_circles];
cparams.xc = x;
cparams.yc = y;
cparams.radius = 8;
cparams.circle_color = NvOSD_ColorParams{244, 67, 54, 1};
cparams.has_bg_color = 1;
cparams.bg_color = NvOSD_ColorParams{0, 255, 0, 1};
dmeta->num_circles++;
for (int k = 0; k < K; k++)
int c_a = topology[k][2];
int c_b = topology[k][3];
if (object[c_a] >= 0 && object[c_b] >= 0)
auto &peak0 = normalized_peaks[c_a][object[c_a]];
auto &peak1 = normalized_peaks[c_b][object[c_b]];
int x0 = peak0[1] * MUXER_OUTPUT_WIDTH;
int y0 = peak0[0] * MUXER_OUTPUT_HEIGHT;
int x1 = peak1[1] * MUXER_OUTPUT_WIDTH;
int y1 = peak1[0] * MUXER_OUTPUT_HEIGHT;
if (dmeta->num_lines == MAX_ELEMENTS_IN_DISPLAY_META)
NvOSD_LineParams &lparams = dmeta->line_params[dmeta->num_lines];
lparams.x1 = x0;
lparams.x2 = x1;
lparams.y1 = y0;
lparams.y2 = y1;
lparams.line_width = 3;
lparams.line_color = NvOSD_ColorParams{0, 255, 0, 1};
dmeta->num_lines++;
/* pgie_src_pad_buffer_probe will extract metadata received from pgie
* and update params for drawing rectangle, object information etc. */
static GstPadProbeReturn
pgie_src_pad_buffer_probe(GstPad *pad, GstPadProbeInfo *info,
gpointer u_data)
gchar *msg = NULL;
GstBuffer *buf = (GstBuffer *)info->data;
NvDsMetaList *l_frame = NULL;
NvDsMetaList *l_obj = NULL;
NvDsMetaList *l_user = NULL;
GstClockTime now;
perf_measure * perf = (perf_measure *)(u_data);
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta(buf);
now = g_get_monotonic_time();
if (perf->pre_time == GST_CLOCK_TIME_NONE) {
perf->pre_time = now;
perf->total_time = GST_CLOCK_TIME_NONE;
} else {
if (perf->total_time == GST_CLOCK_TIME_NONE) {
perf->total_time = (now - perf->pre_time);
else {
perf->total_time += (now - perf->pre_time);
perf->count++;
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next)
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *)(l_frame->data);
for (l_user = frame_meta->frame_user_meta_list; l_user != NULL;
l_user = l_user->next)
NvDsUserMeta *user_meta = (NvDsUserMeta *)l_user->data;
if (user_meta->base_meta.meta_type == NVDSINFER_TENSOR_OUTPUT_META)
NvDsInferTensorMeta *tensor_meta =
(NvDsInferTensorMeta *)user_meta->user_meta_data;
Vec2D<int> objects;
Vec3D<float> normalized_peaks;
tie(objects, normalized_peaks) = parse_objects_from_tensor_meta(tensor_meta);
create_display_meta(objects, normalized_peaks, frame_meta, frame_meta->source_frame_width, frame_meta->source_frame_height);
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
l_obj = l_obj->next)
NvDsObjectMeta *obj_meta = (NvDsObjectMeta *)l_obj->data;
for (l_user = obj_meta->obj_user_meta_list; l_user != NULL;
Vec2D<int> objects;
return GST_PAD_PROBE_OK;
/* osd_sink_pad_buffer_probe will extract metadata received from OSD
osd_sink_pad_buffer_probe(GstPad *pad, GstPadProbeInfo *info,
gpointer u_data)
guint num_rects = 0;
NvDsObjectMeta *obj_meta = NULL;
NvDsDisplayMeta *display_meta = NULL;
int offset = 0;
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL; l_obj = l_obj->next)
obj_meta = (NvDsObjectMeta *)(l_obj->data);
display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
/* Parameters to draw text onto the On-Screen-Display */
NvOSD_TextParams *txt_params = &display_meta->text_params[0];
display_meta->num_labels = 1;
txt_params->display_text = (char *)g_malloc0(MAX_DISPLAY_LEN);
offset = snprintf(txt_params->display_text, MAX_DISPLAY_LEN, "Frame Number = %d", frame_number);
offset = snprintf(txt_params->display_text + offset, MAX_DISPLAY_LEN, "");
txt_params->x_offset = 10;
txt_params->y_offset = 12;
txt_params->font_params.font_name = "Mono";
txt_params->font_params.font_size = 10;
txt_params->font_params.font_color.red = 1.0;
txt_params->font_params.font_color.green = 1.0;
txt_params->font_params.font_color.blue = 1.0;
txt_params->font_params.font_color.alpha = 1.0;
txt_params->set_bg_clr = 1;
txt_params->text_bg_clr.red = 0.0;
txt_params->text_bg_clr.green = 0.0;
txt_params->text_bg_clr.blue = 0.0;
txt_params->text_bg_clr.alpha = 1.0;
nvds_add_display_meta_to_frame(frame_meta, display_meta);
frame_number++;
static gboolean
bus_call(GstBus *bus, GstMessage *msg, gpointer data)
GMainLoop *loop = (GMainLoop *)data;
switch (GST_MESSAGE_TYPE(msg))
case GST_MESSAGE_EOS:
g_print("End of Stream\n");
g_main_loop_quit(loop);
break;
case GST_MESSAGE_ERROR:
gchar *debug;
GError *error;
gst_message_parse_error(msg, &error, &debug);
g_printerr("ERROR from element %s: %s\n",
GST_OBJECT_NAME(msg->src), error->message);
if (debug)
g_printerr("Error details: %s\n", debug);
g_free(debug);
g_error_free(error);
break;
default:
break;
return TRUE;
gboolean
link_element_to_tee_src_pad(GstElement *tee, GstElement *sinkelem)
gboolean ret = FALSE;
GstPad *tee_src_pad = NULL;
GstPad *sinkpad = NULL;
GstPadTemplate *padtemplate = NULL;
padtemplate = (GstPadTemplate *)gst_element_class_get_pad_template(GST_ELEMENT_GET_CLASS(tee), "src_%u");
tee_src_pad = gst_element_request_pad(tee, padtemplate, NULL, NULL);
if (!tee_src_pad)
g_printerr("Failed to get src pad from tee");
goto done;
sinkpad = gst_element_get_static_pad(sinkelem, "sink");
if (!sinkpad)
g_printerr("Failed to get sink pad from '%s'",
GST_ELEMENT_NAME(sinkelem));
goto done;
if (gst_pad_link(tee_src_pad, sinkpad) != GST_PAD_LINK_OK)
g_printerr("Failed to link '%s' and '%s'", GST_ELEMENT_NAME(tee),
goto done;
ret = TRUE;
done:
if (tee_src_pad)
gst_object_unref(tee_src_pad);
if (sinkpad)
gst_object_unref(sinkpad);
return ret;
int main(int argc, char *argv[])
GMainLoop *loop = NULL;
GstCaps *caps = NULL;
GstElement *pipeline = NULL, *source = NULL, *h264parser = NULL,
*decoder = NULL, *streammux = NULL, *sink = NULL, *pgie = NULL, *nvvidconv = NULL, *nvosd = NULL,
*nvvideoconvert = NULL, *tee = NULL, *h264encoder = NULL, *cap_filter = NULL, *filesink = NULL, *queue = NULL, *qtmux = NULL, *h264parser1 = NULL, *nvsink = NULL;
/* Add a transform element for Jetson*/
#ifdef PLATFORM_TEGRA
GstElement *transform = NULL;
#endif
GstBus *bus = NULL;
guint bus_watch_id;
GstPad *osd_sink_pad = NULL;
/* Check input arguments */
if (argc != 3)
g_printerr("Usage: %s <filename> <output-path>\n", argv[0]);
return -1;
/* Standard GStreamer initialization */
gst_init(&argc, &argv);
loop = g_main_loop_new(NULL, FALSE);
/* Create gstreamer elements */
/* Create Pipeline element that will form a connection of other elements */
pipeline = gst_pipeline_new("deepstream-tensorrt-openpose-pipeline");
/* Source element for reading from the file */
source = gst_element_factory_make("filesrc", "file-source");
/* Since the data format in the input file is elementary h264 stream,
* we need a h264parser */
h264parser = gst_element_factory_make("h264parse", "h264-parser");
h264parser1 = gst_element_factory_make("h264parse", "h264-parser1");
/* Use nvdec_h264 for hardware accelerated decode on GPU */
decoder = gst_element_factory_make("nvv4l2decoder", "nvv4l2-decoder");
/* Create nvstreammux instance to form batches from one or more sources. */
streammux = gst_element_factory_make("nvstreammux", "stream-muxer");
if (!pipeline || !streammux)
g_printerr("One element could not be created. Exiting.\n");
return -1;
/* Use nvinfer to run inferencing on decoder's output,
* behaviour of inferencing is set through config file */
pgie = gst_element_factory_make("nvinfer", "primary-nvinference-engine");
/* Use convertor to convert from NV12 to RGBA as required by nvosd */
nvvidconv = gst_element_factory_make("nvvideoconvert", "nvvideo-converter");
queue = gst_element_factory_make("queue", "queue");
filesink = gst_element_factory_make("filesink", "filesink");
/* Set output file location */
char *output_path = argv[2];
strcat(output_path,"Pose_Estimation.mp4");
g_object_set(G_OBJECT(filesink), "location", output_path, NULL);
nvvideoconvert = gst_element_factory_make("nvvideoconvert", "nvvideo-converter1");
tee = gst_element_factory_make("tee", "TEE");
h264encoder = gst_element_factory_make("nvv4l2h264enc", "video-encoder");
cap_filter = gst_element_factory_make("capsfilter", "enc_caps_filter");
caps = gst_caps_from_string("video/x-raw(memory:NVMM), format=I420");
g_object_set(G_OBJECT(cap_filter), "caps", caps, NULL);
qtmux = gst_element_factory_make("qtmux", "muxer");
/* Create OSD to draw on the converted RGBA buffer */
nvosd = gst_element_factory_make("nvdsosd", "nv-onscreendisplay");
/* Finally render the osd output */
transform = gst_element_factory_make("nvegltransform", "nvegl-transform");
#endif
nvsink = gst_element_factory_make("nveglglessink", "nvvideo-renderer");
sink = gst_element_factory_make("fpsdisplaysink", "fps-display");
g_object_set(G_OBJECT(sink), "text-overlay", FALSE, "video-sink", nvsink, "sync", FALSE, NULL);
if (!source || !h264parser || !decoder || !pgie || !nvvidconv || !nvosd || !sink || !cap_filter || !tee || !nvvideoconvert ||
!h264encoder || !filesink || !queue || !qtmux || !h264parser1)
return -1;
if (!transform)
g_printerr("One tegra element could not be created. Exiting.\n");
return -1;
#endif
perf_measure perf_measure;
int src_cnt = 1; // the source number, set to 1 temporarily
perf_measure.pre_time = GST_CLOCK_TIME_NONE;
perf_measure.total_time = GST_CLOCK_TIME_NONE;
perf_measure.count = 0;
/* we set the input filename to the source element */
g_object_set(G_OBJECT(source), "location", argv[1], NULL);
g_object_set(G_OBJECT(streammux), "width", MUXER_OUTPUT_WIDTH, "height",
MUXER_OUTPUT_HEIGHT, "batch-size", 1,
"batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
/* Set all the necessary properties of the nvinfer element,
* the necessary ones are : */
g_object_set(G_OBJECT(pgie), "output-tensor-meta", TRUE,
"config-file-path", "deepstream_pose_estimation_config.txt", NULL);
/* we add a message handler */
bus = gst_pipeline_get_bus(GST_PIPELINE(pipeline));
bus_watch_id = gst_bus_add_watch(bus, bus_call, loop);
gst_object_unref(bus);
/* Set up the pipeline */
/* we add all elements into the pipeline */
gst_bin_add_many(GST_BIN(pipeline),
source, h264parser, decoder, streammux, pgie,
nvvidconv, nvosd, transform, /*sink,*/
tee, nvvideoconvert, h264encoder, cap_filter, filesink, queue, h264parser1, qtmux, NULL);
#else
nvvidconv, nvosd, /*sink,*/
#endif
GstPad *sinkpad, *srcpad;
gchar pad_name_sink[16] = "sink_0";
gchar pad_name_src[16] = "src";
sinkpad = gst_element_get_request_pad(streammux, pad_name_sink);
if (!sinkpad)
g_printerr("Streammux request sink pad failed. Exiting.\n");
return -1;
srcpad = gst_element_get_static_pad(decoder, pad_name_src);
if (!srcpad)
g_printerr("Decoder request src pad failed. Exiting.\n");
return -1;
if (gst_pad_link(srcpad, sinkpad) != GST_PAD_LINK_OK)
g_printerr("Failed to link decoder to stream muxer. Exiting.\n");
return -1;
gst_object_unref(srcpad);
if (!gst_element_link_many(source, h264parser, decoder, NULL))
g_printerr("Elements could not be linked: 1. Exiting.\n");
return -1;
#if 0
if (!gst_element_link_many (streammux, pgie,
nvvidconv, nvosd, transform, sink, NULL)) {
g_printerr ("Elements could not be linked: 2. Exiting.\n");
return -1;
#else
if (!gst_element_link_many (streammux, pgie, nvvidconv, nvosd, sink, NULL)) {
return -1;
#endif
#else
if (!gst_element_link_many(streammux, pgie,
nvvidconv, nvosd, tee, NULL))
g_printerr("Elements could not be linked: 2. Exiting.\n");
return -1;
#else
if (!gst_element_link_many(streammux, pgie, nvvidconv, nvosd, tee, NULL))
return -1;
#endif
#if 0
if (!link_element_to_tee_src_pad(tee, queue)) {
g_printerr ("Could not link tee to sink\n");
return -1;
if (!gst_element_link_many (queue, sink, NULL)) {
return -1;
#else
g_printerr("Could not link tee to nvvideoconvert\n");
return -1;
if (!gst_element_link_many(queue, nvvideoconvert, cap_filter, h264encoder,
h264parser1, qtmux, filesink, NULL))
g_printerr("Elements could not be linked\n");
return -1;
#endif
#endif
GstPad *pgie_src_pad = gst_element_get_static_pad(pgie, "src");
if (!pgie_src_pad)
g_print("Unable to get pgie src pad\n");
else
gst_pad_add_probe(pgie_src_pad, GST_PAD_PROBE_TYPE_BUFFER,
pgie_src_pad_buffer_probe, (gpointer)sink, NULL);
/* Lets add probe to get informed of the meta data generated, we add probe to
* the sink pad of the osd element, since by that time, the buffer would have
* had got all the metadata. */
osd_sink_pad = gst_element_get_static_pad(nvosd, "sink");
if (!osd_sink_pad)
g_print("Unable to get sink pad\n");
else
gst_pad_add_probe(osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
osd_sink_pad_buffer_probe, &perf_measure, NULL);
/* Set the pipeline to "playing" state */
g_print("Now playing: %s\n", argv[1]);
gst_element_set_state(pipeline, GST_STATE_PLAYING);
/* Wait till pipeline encounters an error or EOS */
g_print("Running...\n");
g_main_loop_run(loop);
/* Out of the main loop, clean up nicely */
g_print("Returned, stopping playback\n");
gst_element_set_state(pipeline, GST_STATE_NULL);
g_print("Deleting pipeline\n");
g_print ("Average fps %f\n",((perf_measure.count-1)*src_cnt*1000000.0)/perf_measure.total_time);
gst_object_unref(GST_OBJECT(pipeline));
g_source_remove(bus_watch_id);
g_main_loop_unref(loop);
return 0;
