[DS4.0.1] DCF tracker not working with pgie output tensor data processed result !!!
For one of our requirements, we directly processed tensor output as demonstrated in deepstream-infer-tensor-meta-test.
Now after adding tracker, we are facing issues with DCF tracker, The detections are not at all consumed by DCF tracker. KLT tracker is working fine, so it seems its something very specific with DCF tracker internal implementation.
I am sharing modified “deepstream-test2” in which I am able to reproduce the issue
 * Copyright (c) 2018-2019, NVIDIA CORPORATION. All rights reserved.
 * Permission is hereby granted, free of charge, to any person obtaining a
 * copy of this software and associated documentation files (the "Software"),
 * to deal in the Software without restriction, including without limitation
 * the rights to use, copy, modify, merge, publish, distribute, sublicense,
 * and/or sell copies of the Software, and to permit persons to whom the
 * Software is furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
 * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
 * DEALINGS IN THE SOFTWARE.
#include <gst/gst.h>
#include <glib.h>
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <iostream>
#include "cuda_runtime_api.h"
#include <opencv2/objdetect/objdetect.hpp>
#include "gstnvdsmeta.h"
#include "gstnvdsinfer.h"
#include "nvdsinfer_custom_impl.h"
#define PGIE_CONFIG_FILE  "dstest2_pgie_config.txt"
#define SGIE1_CONFIG_FILE "dstest2_sgie1_config.txt"
#define SGIE2_CONFIG_FILE "dstest2_sgie2_config.txt"
#define SGIE3_CONFIG_FILE "dstest2_sgie3_config.txt"
#define MAX_DISPLAY_LEN 64
#define TRACKER_CONFIG_FILE "dstest2_tracker_config.txt"
#define MAX_TRACKING_ID_LEN 16
#define PGIE_CLASS_ID_VEHICLE 0
#define PGIE_CLASS_ID_PERSON 2
/* The muxer output resolution must be set if the input streams will be of
 * different resolution. The muxer will scale all the input frames to this
 * resolution. */
#define MUXER_OUTPUT_WIDTH 1920
#define MUXER_OUTPUT_HEIGHT 1080
/* Muxer batch formation timeout, for e.g. 40 millisec. Should ideally be set
 * based on the fastest source's framerate. */
#define MUXER_BATCH_TIMEOUT_USEC 4000000
#define PGIE_NET_WIDTH 640
#define PGIE_NET_HEIGHT 368
#define PGIE_DETECTED_CLASS_NUM 4
gint frame_number = 0;
/* These are the strings of the labels for the respective models */
gchar sgie1_classes_str[12][32] = { "black", "blue", "brown", "gold", "green",
  "grey", "maroon", "orange", "red", "silver", "white", "yellow"
gchar sgie2_classes_str[20][32] =
    { "Acura", "Audi", "BMW", "Chevrolet", "Chrysler",
  "Dodge", "Ford", "GMC", "Honda", "Hyundai", "Infiniti", "Jeep", "Kia",
      "Lexus", "Mazda", "Mercedes", "Nissan",
  "Subaru", "Toyota", "Volkswagen"
gchar sgie3_classes_str[6][32] = { "coupe", "largevehicle", "sedan", "suv",
  "truck", "van"
gchar pgie_classes_str[4][32] =
    { "Vehicle", "TwoWheeler", "Person", "RoadSign" };
/* gie_unique_id is one of the properties in the above dstest2_sgiex_config.txt
 * files. These should be unique and known when we want to parse the Metadata
 * respective to the sgie labels. Ideally these should be read from the config
 * files but for brevity we ensure they are same. */
guint sgie1_unique_id = 2;
guint sgie2_unique_id = 3;
guint sgie3_unique_id = 4;
extern "C"
    bool NvDsInferParseCustomResnet (std::vector < NvDsInferLayerInfo >
    const &outputLayersInfo, NvDsInferNetworkInfo const &networkInfo,
    NvDsInferParseDetectionParams const &detectionParams,
    std::vector < NvDsInferObjectDetectionInfo > &objectList);
/* This is the buffer probe function that we have registered on the src pad
 * of the PGIE's next queue element. PGIE element in the pipeline shall attach
 * its NvDsInferTensorMeta to each frame metadata on GstBuffer, here we will
 * iterate & parse the tensor data to get detection bounding boxes. The result
 * would be attached as object-meta(NvDsObjectMeta) into the same frame metadata.
static GstPadProbeReturn
pgie_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
  static guint use_device_mem = 0;
  static NvDsInferNetworkInfo networkInfo
  PGIE_NET_WIDTH, PGIE_NET_HEIGHT, 3};
  static NvDsInferParseDetectionParams detectionParams
    4,
  0.2, 0.2, 0.2, 0.2}};
  static float groupThreshold = 1;
  static float groupEps = 0.2;
  NvDsBatchMeta *batch_meta =
      gst_buffer_get_nvds_batch_meta (GST_BUFFER (info->data));
  /* Iterate each frame metadata in batch */
  for (NvDsMetaList * l_frame = batch_meta->frame_meta_list; l_frame != NULL;
      l_frame = l_frame->next) {
    NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) l_frame->data;
    /* Iterate user metadata in frames to search PGIE's tensor metadata */
    for (NvDsMetaList * l_user = frame_meta->frame_user_meta_list;
        l_user != NULL; l_user = l_user->next) {
      NvDsUserMeta *user_meta = (NvDsUserMeta *) l_user->data;
      if (user_meta->base_meta.meta_type != NVDSINFER_TENSOR_OUTPUT_META)
        continue;
      /* convert to tensor metadata */
      NvDsInferTensorMeta *meta =
          (NvDsInferTensorMeta *) user_meta->user_meta_data;
      for (unsigned int i = 0; i < meta->num_output_layers; i++) {
        NvDsInferLayerInfo *info = &meta->output_layers_info[i];
        info->buffer = meta->out_buf_ptrs_host[i];
        if (use_device_mem) {
          cudaMemcpy (meta->out_buf_ptrs_host[i], meta->out_buf_ptrs_dev[i],
              info->dims.numElements * 4, cudaMemcpyDeviceToHost);
      /* Parse output tensor and fill detection results into objectList. */
          outputLayersInfo (meta->output_layers_info,
          meta->output_layers_info + meta->num_output_layers);
      std::vector < NvDsInferObjectDetectionInfo > objectList;
      NvDsInferParseCustomResnet (outputLayersInfo, networkInfo,
          detectionParams, objectList);
      /* Seperate detection rectangles per class for grouping. */
      std::vector < std::vector <
          cv::Rect >> objectListClasses (PGIE_DETECTED_CLASS_NUM);
    for (auto & obj:objectList) {
        objectListClasses[obj.classId].emplace_back (obj.left, obj.top,
            obj.width, obj.height);
      for (uint32_t c = 0; c < objectListClasses.size (); ++c) {
        auto & objlist = objectListClasses[c];
        if (objlist.empty ())
          continue;
        /* Merge and cluster similar detection results */
        cv::groupRectangles (objlist, groupThreshold, groupEps);
      std::cout<<"Nuber of detections of class :"<< c <<"is:"<<objlist.size() <<std::endl;
        /* Iterate final rectangules and attach result into frame's obj_meta_list. */
      for (const auto & rect:objlist) {
          NvDsObjectMeta *obj_meta =
              nvds_acquire_obj_meta_from_pool (batch_meta);
          obj_meta->unique_component_id = meta->unique_id;
          obj_meta->confidence = 0.0;
          /* This is an untracked object. Set tracking_id to -1. */
          obj_meta->object_id = UNTRACKED_OBJECT_ID;
          obj_meta->class_id = c;
          NvOSD_RectParams & rect_params = obj_meta->rect_params;
          NvOSD_TextParams & text_params = obj_meta->text_params;
          /* Assign bounding box coordinates. */
          rect_params.left = rect.x * MUXER_OUTPUT_WIDTH / PGIE_NET_WIDTH;
          rect_params.top = rect.y * MUXER_OUTPUT_HEIGHT / PGIE_NET_HEIGHT;
          rect_params.width = rect.width * MUXER_OUTPUT_WIDTH / PGIE_NET_WIDTH;
          rect_params.height =
              rect.height * MUXER_OUTPUT_HEIGHT / PGIE_NET_HEIGHT;
          /* Border of width 3. */
          rect_params.border_width = 3;
          rect_params.has_bg_color = 0;
          rect_params.border_color = (NvOSD_ColorParams) {
          1, 0, 0, 1};
          /* display_text requires heap allocated memory. */
          text_params.display_text = g_strdup (pgie_classes_str[c]);
          /* Display text above the left top corner of the object. */
          text_params.x_offset = rect_params.left;
          text_params.y_offset = rect_params.top - 10;
          /* Set black background for the text. */
          text_params.set_bg_clr = 1;
          text_params.text_bg_clr = (NvOSD_ColorParams) {
          0, 0, 0, 1};
          /* Font face, size and color. */
          text_params.font_params.font_name = (gchar *) "Serif";
          text_params.font_params.font_size = 11;
          text_params.font_params.font_color = (NvOSD_ColorParams) {
          1, 1, 1, 1};
          nvds_add_obj_meta_to_frame (frame_meta, obj_meta, NULL);
  use_device_mem = 1 - use_device_mem;
  return GST_PAD_PROBE_OK;
/* This is the buffer probe function that we have registered on the sink pad
 * of the OSD element. All the infer elements in the pipeline shall attach
 * their metadata to the GstBuffer, here we will iterate & process the metadata
 * forex: class ids to strings, counting of class_id objects etc. */
osd_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
    gpointer u_data)
    GstBuffer *buf = (GstBuffer *) info->data;
    guint num_rects = 0;
    NvDsObjectMeta *obj_meta = NULL;
    guint vehicle_count = 0;
    guint person_count = 0;
    NvDsMetaList * l_frame = NULL;
    NvDsMetaList * l_obj = NULL;
    NvDsDisplayMeta *display_meta = NULL;
    NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
    for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
        NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
        int offset = 0;
        for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
                l_obj = l_obj->next) {
            obj_meta = (NvDsObjectMeta *) (l_obj->data);
            if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
                vehicle_count++;
                num_rects++;
            if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) {
                person_count++;
                num_rects++;
        display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
        NvOSD_TextParams *txt_params  = &display_meta->text_params[0];
        display_meta->num_labels = 1;
        txt_params->display_text = (gchar *) g_malloc0 (MAX_DISPLAY_LEN);
        offset = snprintf(txt_params->display_text, MAX_DISPLAY_LEN, "Person = %d ", person_count);
        offset = snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN, "Vehicle = %d ", vehicle_count);
        /* Now set the offsets where the string should appear */
        txt_params->x_offset = 10;
        txt_params->y_offset = 12;
        /* Font , font-color and font-size */
        txt_params->font_params.font_name = "Serif";
        txt_params->font_params.font_size = 10;
        txt_params->font_params.font_color.red = 1.0;
        txt_params->font_params.font_color.green = 1.0;
        txt_params->font_params.font_color.blue = 1.0;
        txt_params->font_params.font_color.alpha = 1.0;
        /* Text background color */
        txt_params->set_bg_clr = 1;
        txt_params->text_bg_clr.red = 0.0;
        txt_params->text_bg_clr.green = 0.0;
        txt_params->text_bg_clr.blue = 0.0;
        txt_params->text_bg_clr.alpha = 1.0;
        nvds_add_display_meta_to_frame(frame_meta, display_meta);
    g_print ("Frame Number = %d Number of objects = %d "
            "Vehicle Count = %d Person Count = %d\n",
            frame_number, num_rects, vehicle_count, person_count);
    frame_number++;
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
  GMainLoop *loop = (GMainLoop *) data;
  switch (GST_MESSAGE_TYPE (msg)) {
    case GST_MESSAGE_EOS:
      g_print ("End of stream\n");
      g_main_loop_quit (loop);
      break;
    case GST_MESSAGE_ERROR:{
      gchar *debug;
      GError *error;
      gst_message_parse_error (msg, &error, &debug);
      g_printerr ("ERROR from element %s: %s\n",
          GST_OBJECT_NAME (msg->src), error->message);
      if (debug)
        g_printerr ("Error details: %s\n", debug);
      g_free (debug);
      g_error_free (error);
      break;
    default:
      break;
  return TRUE;
/* Tracker config parsing */
#define CHECK_ERROR(error) \
    if (error) { \
        g_printerr ("Error while parsing config file: %s\n", error->message); \
        goto done; \
#define CONFIG_GROUP_TRACKER "tracker"
#define CONFIG_GROUP_TRACKER_WIDTH "tracker-width"
#define CONFIG_GROUP_TRACKER_HEIGHT "tracker-height"
#define CONFIG_GROUP_TRACKER_LL_CONFIG_FILE "ll-config-file"
#define CONFIG_GROUP_TRACKER_LL_LIB_FILE "ll-lib-file"
#define CONFIG_GROUP_TRACKER_ENABLE_BATCH_PROCESS "enable-batch-process"
#define CONFIG_GPU_ID "gpu-id"
static gchar *
get_absolute_file_path (gchar *cfg_file_path, gchar *file_path)
  gchar abs_cfg_path[PATH_MAX + 1];
  gchar *abs_file_path;
  gchar *delim;
  if (file_path && file_path[0] == '/') {
    return file_path;
  if (!realpath (cfg_file_path, abs_cfg_path)) {
    g_free (file_path);
    return NULL;
  // Return absolute path of config file if file_path is NULL.
  if (!file_path) {
    abs_file_path = g_strdup (abs_cfg_path);
    return abs_file_path;
  delim = g_strrstr (abs_cfg_path, "/");
  *(delim + 1) = '\0';
  abs_file_path = g_strconcat (abs_cfg_path, file_path, NULL);
  g_free (file_path);
static gboolean
set_tracker_properties (GstElement *nvtracker)
  gboolean ret = FALSE;
  GError *error = NULL;
  gchar **keys = NULL;
  gchar **key = NULL;
  GKeyFile *key_file = g_key_file_new ();
  if (!g_key_file_load_from_file (key_file, TRACKER_CONFIG_FILE, G_KEY_FILE_NONE,
          &error)) {
    g_printerr ("Failed to load config file: %s\n", error->message);
    return FALSE;
  keys = g_key_file_get_keys (key_file, CONFIG_GROUP_TRACKER, NULL, &error);
  CHECK_ERROR (error);
  for (key = keys; *key; key++) {
    if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_WIDTH)) {
      gint width =
          g_key_file_get_integer (key_file, CONFIG_GROUP_TRACKER,
          CONFIG_GROUP_TRACKER_WIDTH, &error);
      g_object_set (G_OBJECT (nvtracker), "tracker-width", width, NULL);
    } else if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_HEIGHT)) {
      gint height =
          CONFIG_GROUP_TRACKER_HEIGHT, &error);
      g_object_set (G_OBJECT (nvtracker), "tracker-height", height, NULL);
    } else if (!g_strcmp0 (*key, CONFIG_GPU_ID)) {
      guint gpu_id =
          CONFIG_GPU_ID, &error);
      g_object_set (G_OBJECT (nvtracker), "gpu_id", gpu_id, NULL);
    } else if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_LL_CONFIG_FILE)) {
      char* ll_config_file = get_absolute_file_path (TRACKER_CONFIG_FILE,
                g_key_file_get_string (key_file,
                    CONFIG_GROUP_TRACKER_LL_CONFIG_FILE, &error));
      g_object_set (G_OBJECT (nvtracker), "ll-config-file", ll_config_file, NULL);
    } else if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_LL_LIB_FILE)) {
      char* ll_lib_file = get_absolute_file_path (TRACKER_CONFIG_FILE,
                    CONFIG_GROUP_TRACKER_LL_LIB_FILE, &error));
      g_object_set (G_OBJECT (nvtracker), "ll-lib-file", ll_lib_file, NULL);
    } else if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_ENABLE_BATCH_PROCESS)) {
      gboolean enable_batch_process =
          CONFIG_GROUP_TRACKER_ENABLE_BATCH_PROCESS, &error);
      g_object_set (G_OBJECT (nvtracker), "enable_batch_process",
                    enable_batch_process, NULL);
    } else {
      g_printerr ("Unknown key '%s' for group [%s]", *key,
          CONFIG_GROUP_TRACKER);
  ret = TRUE;
done:
  if (error) {
  if (keys) {
    g_strfreev (keys);
  if (!ret) {
    g_printerr ("%s failed", __func__);
  return ret;
int
main (int argc, char *argv[])
  GMainLoop *loop = NULL;
  GstElement *pipeline = NULL, *source = NULL, *h264parser = NULL, *queue=NULL,
      *decoder = NULL, *streammux = NULL, *sink = NULL, *pgie = NULL, *nvvidconv = NULL,
      *nvosd = NULL, *sgie1 = NULL, *sgie2 = NULL, *sgie3 = NULL, *nvtracker = NULL;
  g_print ("With tracker\n");
#ifdef PLATFORM_TEGRA
  GstElement *transform = NULL;
#endif
  GstBus *bus = NULL;
  guint bus_watch_id = 0;
  GstPad *osd_sink_pad = NULL,*queue_src_pad = NULL;
  /* Check input arguments */
  if (argc != 2) {
    g_printerr ("Usage: %s <elementary H264 filename>\n", argv[0]);
    return -1;
  /* Standard GStreamer initialization */
  gst_init (&argc, &argv);
  loop = g_main_loop_new (NULL, FALSE);
  /* Create gstreamer elements */
  /* Create Pipeline element that will be a container of other elements */
  pipeline = gst_pipeline_new ("dstest2-pipeline");
  /* Source element for reading from the file */
  source = gst_element_factory_make ("filesrc", "file-source");
  /* Since the data format in the input file is elementary h264 stream,
   * we need a h264parser */
  h264parser = gst_element_factory_make ("h264parse", "h264-parser");
  /* Use nvdec_h264 for hardware accelerated decode on GPU */
  decoder = gst_element_factory_make ("nvv4l2decoder", "nvv4l2-decoder");
  /* Create nvstreammux instance to form batches from one or more sources. */
  streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
  if (!pipeline || !streammux) {
    g_printerr ("One element could not be created. Exiting.\n");
    return -1;
  /* Use nvinfer to run inferencing on decoder's output,
   * behaviour of inferencing is set through config file */
  pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
  queue = gst_element_factory_make ("queue", NULL);
  /* We need to have a tracker to track the identified objects */
  nvtracker = gst_element_factory_make ("nvtracker", "tracker");
  /* We need three secondary gies so lets create 3 more instances of
     nvinfer */
  sgie1 = gst_element_factory_make ("nvinfer", "secondary1-nvinference-engine");
  sgie2 = gst_element_factory_make ("nvinfer", "secondary2-nvinference-engine");
  sgie3 = gst_element_factory_make ("nvinfer", "secondary3-nvinference-engine");
  /* Use convertor to convert from NV12 to RGBA as required by nvosd */
  nvvidconv = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter");
  /* Create OSD to draw on the converted RGBA buffer */
  nvosd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
  /* Finally render the osd output */
  transform = gst_element_factory_make ("nvegltransform", "nvegl-transform");
#endif
  sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
  if (!source || !h264parser || !decoder || !pgie ||
      !nvtracker || !sgie1 || !sgie2 || !sgie3 || !nvvidconv || !nvosd || !sink) {
    return -1;
  if(!transform) {
    g_printerr ("One tegra element could not be created. Exiting.\n");
    return -1;
#endif
  /* Set the input filename to the source element */
  g_object_set (G_OBJECT (source), "location", argv[1], NULL);
  g_object_set (G_OBJECT (streammux), "width", MUXER_OUTPUT_WIDTH, "height",
      MUXER_OUTPUT_HEIGHT, "batch-size", 1,
      "batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
  /* Set all the necessary properties of the nvinfer element,
   * the necessary ones are : */
  g_object_set (G_OBJECT (pgie), "config-file-path", PGIE_CONFIG_FILE, NULL);
  g_object_set (G_OBJECT (sgie1), "config-file-path", SGIE1_CONFIG_FILE, NULL);
  g_object_set (G_OBJECT (sgie2), "config-file-path", SGIE2_CONFIG_FILE, NULL);
  g_object_set (G_OBJECT (sgie3), "config-file-path", SGIE3_CONFIG_FILE, NULL);
  /* Set necessary properties of the tracker element. */
  if (!set_tracker_properties(nvtracker)) {
    g_printerr ("Failed to set tracker properties. Exiting.\n");
    return -1;
  /* we add a message handler */
  bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
  bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
  gst_object_unref (bus);
  /* Set up the pipeline */
  /* we add all elements into the pipeline */
  /* decoder | pgie1 | nvtracker | sgie1 | sgie2 | sgie3 | etc.. */
  gst_bin_add_many (GST_BIN (pipeline),
      source, h264parser, decoder, streammux, pgie, nvtracker, sgie1, sgie2, sgie3,
      nvvidconv, nvosd, transform, sink, NULL);
#else
      source, h264parser, decoder, streammux, pgie, queue, nvtracker, sgie1, sgie2, sgie3,
      nvvidconv, nvosd, sink, NULL);
#endif
  GstPad *sinkpad, *srcpad;
  gchar pad_name_sink[16] = "sink_0";
  gchar pad_name_src[16] = "src";
  sinkpad = gst_element_get_request_pad (streammux, pad_name_sink);
  if (!sinkpad) {
    g_printerr ("Streammux request sink pad failed. Exiting.\n");
    return -1;
  srcpad = gst_element_get_static_pad (decoder, pad_name_src);
  if (!srcpad) {
    g_printerr ("Decoder request src pad failed. Exiting.\n");
    return -1;
  if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
      g_printerr ("Failed to link decoder to stream muxer. Exiting.\n");
      return -1;
  gst_object_unref (sinkpad);
  gst_object_unref (srcpad);
  /* Link the elements together */
  if (!gst_element_link_many (source, h264parser, decoder, NULL)) {
    g_printerr ("Elements could not be linked: 1. Exiting.\n");
    return -1;
  if (!gst_element_link_many (streammux, pgie, queue, nvtracker, sgie1,
      sgie2, sgie3, nvvidconv, nvosd, transform, sink, NULL)) {
    g_printerr ("Elements could not be linked. Exiting.\n");
    return -1;
#else
      sgie2, sgie3, nvvidconv, nvosd, sink, NULL)) {
    return -1;
#endif
  /* Lets add probe to get informed of the meta data generated, we add probe to
   * the sink pad of the osd element, since by that time, the buffer would have
   * had got all the metadata. */
  osd_sink_pad = gst_element_get_static_pad (nvosd, "sink");
  if (!osd_sink_pad)
    g_print ("Unable to get sink pad\n");
  else
    gst_pad_add_probe (osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
        osd_sink_pad_buffer_probe, NULL, NULL);
  /* Add probe to get informed of the meta data generated, we add probe to
   * the source pad of PGIE's next queue element, since by that time, PGIE's
   * buffer would have had got tensor metadata. */
  queue_src_pad = gst_element_get_static_pad (queue, "src");
  gst_pad_add_probe (queue_src_pad, GST_PAD_PROBE_TYPE_BUFFER,
      pgie_pad_buffer_probe, NULL, NULL);
  /* Set the pipeline to "playing" state */
  g_print ("Now playing: %s\n", argv[1]);
  gst_element_set_state (pipeline, GST_STATE_PLAYING);
  /* Iterate */
  g_print ("Running...\n");
  g_main_loop_run (loop);
  /* Out of the main loop, clean up nicely */
  g_print ("Returned, stopping playback\n");
  gst_element_set_state (pipeline, GST_STATE_NULL);
  g_print ("Deleting pipeline\n");
  gst_object_unref (GST_OBJECT (pipeline));
  g_source_remove (bus_watch_id);
  g_main_loop_unref (loop);
  return 0;
Please let me know your input on this !!!
Regards
Pallab Sarkar
There is a knwon issue on NvDCF, which might cause jitters effect.
Are you facing the similar issue?
If yes, please check this comment for the workaround:
https://devtalk.nvidia.com/default/topic/1065481/deepstream-sdk/nvdcf-jitter/post/5400989/#5400989
Hi AastaLLL,
My issue is entirely different. Also, I tried that workaround you mentioned but it doesn’t solve the problem.
I have already shared the modified “deepstream-test2” which will reproduce my issue. Can you please try it in your setup ??
Regards
Pallab Sarkar
Thanks for the check.
We are going to reproduce this issue and will update more information with you later.
It looks like there are some extra libraries used in your sample, which make it cannot be compiled with original Makefile.
Would you mind to share your customized Makefile with us directly.
Hi
I have DM you the make file
Regards
Could you share your environment and Deepstream version with us?
We try to reproduce this issue in our environment but the pipeline is broken due to incompatibility.
nvidia@xavier:~/topic_1067129/deepstream-test2$ ./deepstream-test2-app /opt/nvidia/deepstream/deepstream-4.0/samples/streams/sample_720p.h264
With tracker
Unknown key 'gie-mode' for group [property]
(deepstream-test2-app:9458): GStreamer-WARNING **: 17:47:15.480: Trying to link elements primary-nvinference-engine and queue0 that don't share a common ancestor: queue0 hasn't been added to a bin or pipeline, and primary-nvinference-engine is in dstest2-pipeline
(deepstream-test2-app:9458): GStreamer-WARNING **: 17:47:15.481: Trying to link elements primary-nvinference-engine and queue0 that don't share a common ancestor: queue0 hasn't been added to a bin or pipeline, and primary-nvinference-engine is in dstest2-pipeline
Our environment is JetPack4.2.3 with Deepstream4.0.1.
Hi
Code and makefile shared was from my Tesla Environment.
Now I have DM you latest code and makefile and pgie config file from Jetson Nano .
Regards
Pallab Sarkar
Thanks for your sharing. We can compile and execute your application in our environment.
However, we could not see too much difference between DCF and KLT tracker.
Would you mind to point out more specifically your issue?
Here attached the video of DCF and KLT.
DCF: https://drive.google.com/open?id=1J7IhMIckU6f7mBa59K7aluIChyVBGjQY
KLT: https://drive.google.com/open?id=1zpr21PmEwggBx3YUqnO-s-yL0OVGmst1
Thanks for your update.
We are at a critical milestone. If you need any more support from our side to speed up the solution please let me know!!
Regards
Pallab Sarkar
Sorry that I have updated the comment.
Would you mind to answer the question in comment#9?
Did you shared these videos from the code i shared ?
Because ran again in my code and able to reproduce the issue
Please see the attached videos.
KLT: https://drive.google.com/open?id=1v7gPEGp5TapVunaq1TDZUweXPG9dV8oF
DCF: https://drive.google.com/open?id=1FD06mYF5aoR4Y6g7n0G8o0npAf1ttPEI
I will also share the entire enviroment of code as a zip in DM!
Specifically nvDCF tracker doesn’t work(no tracking results) if we directly process tensor output as demonstrated in deepstream-infer-tensor-meta-test
Regards
Pallab Sarkar
We can output the bounding box correctly with your source.
The only difference we made is the TensorRT engine path.
It looks like the shared config links to a FP16 engine but using a IN8 network mode(=1).
Could you update the engine file path to see if helps?
I also share our source via PM.
Thanks for your reply
I have corrected the network_mode to fp16 as needed by Nano, But it doesn’t solve the problem.
I have compared your code with mine and below is the major difference why you are not able to reproduce the issue is that in your primary gie config you have not added below
## 0=Detector, 1=Classifier, 2=Segmentation, 100=Other
network-type=100
# Enable tensor metadata output
output-tensor-meta=1
This will enable tensor meta processing and then only issue will reproduce!!!
Enable this is dstest2_pgie_config.txt(AS SHARED by my code) and then test KLT and DCF , KLT will work but DCF will not work.
Regards
Pallab Sarkar
Thanks for checking this with us.
We can reproduce this issue in our environment right now.
It looks like the bounding box can output correctly with following update:
network-type=0
May I know why you need to set the network-type=100 since it’s expected to 0 for pgie file.
We feedback this issue to our internal team. Will share more information with you once we got any news.
THansk.
To keep network-type=100 and output-tensor-meta=1 is the configuration suggested to get output as a tensor in Deepstream SDk example in “deepstream-infer-tensor-meta-test”
From the Readme of deepstream-infer-tensor-meta-test I can see network-type= 100 is not mandatory
To enable output layers' tensor data, we need set property or attribute
    "output-tensor-meta=true".
In the sample code, We also set attribute "network-type=100" in config file but
this is not mandatory. "output-tensor-meta" will work with nvinfer configured
as detector/classifier as well.
But my proprietory code {NOt the one which i shared with you } only works when network-type=100 and output-tensor-meta=1
If I keep network-type=0 and output-tensor-meta=1 I get below error in my code
Creating LL OSD context new
0:00:04.033092473 21347   0x5589bd1400 ERROR                nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:parseBoundingBox(): Could not find output coverage layer for parsing objects
0:00:04.033239352 21347   0x5589bd1400 ERROR                nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:fillDetectionOutput(): Failed to parse bboxes
./runarm.sh: line 1: 21347 Segment
How the tracker KLT and DCF have different behavior with network-type=100 and output-tensor-meta=1
Regards
Thanks for the update.
This issue is checking by our internal team.
We will update here once we got any feedback. Stay tuned.
Is there any update on this issue ?
Regards
Sorry for keeping you waiting.
We just got the response from internal team this morning.
You can fix this issue with the following workaround:
diff --git a/deepstream_test2_app.cpp b/deepstream_test2_app.cpp
index 50db65c..e6c2000 100644
--- a/deepstream_test2_app.cpp
+++ b/deepstream_test2_app.cpp
@@ -132,6 +132,10 @@
+       nvds_acquire_meta_lock (batch_meta);
+        frame_meta->bInferDone = TRUE;
+        nvds_release_meta_lock (batch_meta);
The root cause of this issue is that gstnvinfer won’t parse bbox when the network-type=100.
It’s user’s responsibility to attach bbox into NvDsFrameMeta for the generic model type.
Without the attachment, NvDCF believe that the inference is not done for all the input frames.
This won’t happen to KLT tracker just because it doesn’t check this field yet.
We are discussing to implement some simple APIs in gst-utils to improve the attach_metadata_xxx.
Currently, please use the above workaround to avoid this issue.
Thanks for the great support on this issue. I verified it in my code and its working.
We will be looking forward to new API attach_metadata_xxx in future upgrades!!
Regards
Pallab Sarkar
