We are integrating Primary Detector with Secondary Tracker as Classifier with Tracking ID’s on Deepstream with multiple URL’s, which is working out good.
But we are integrating Kafka with it which is getting stuck at 4th Frame as shown below:
Creating LL OSD context new
Frame Number = 0 Number of objects = 1 Vehicle Count = 1 Person Count = 0
Frame Number = 1 Number of objects = 1 Vehicle Count = 1 Person Count = 0
Frame Number = 2 Number of objects = 1 Vehicle Count = 1 Person Count = 0
Frame Number = 3 Number of objects = 1 Vehicle Count = 1 Person Count = 0
Frame Number = 4 Number of objects = 1 Vehicle Count = 1 Person Count = 0
[u]
Please find the below code:[/u]
* Copyright (c) 2018-2019, NVIDIA CORPORATION. All rights reserved.
* Permission is hereby granted, free of charge, to any person obtaining a
* copy of this software and associated documentation files (the "Software"),
* to deal in the Software without restriction, including without limitation
* the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
#include <gst/gst.h>
#include <glib.h>
#include <stdio.h>
#include <math.h>
#include <string.h>
#include <sys/time.h>
#include "gstnvdsmeta.h"
#ifndef PLATFORM_TEGRA
#include "gst-nvmessage.h"
#endif
#include "nvdsmeta_schema.h"
#define PGIE_CONFIG_FILE "dstest3_pgie_config.txt"
#define SGIE1_CONFIG_FILE "dstest2_sgie1_config.txt"
#define SGIE2_CONFIG_FILE "dstest2_sgie2_config.txt"
#define SGIE3_CONFIG_FILE "dstest2_sgie3_config.txt"
#define MAX_DISPLAY_LEN 64
#define MAX_TIME_STAMP_LEN 32
#define TRACKER_CONFIG_FILE "dstest2_tracker_config.txt"
#define MAX_TRACKING_ID_LEN 16
#define MSCONV_CONFIG_FILE "dstest4_msgconv_config.txt"
#define PGIE_CLASS_ID_VEHICLE 0
#define PGIE_CLASS_ID_PERSON 2
/* The muxer output resolution must be set if the input streams will be of
* different resolution. The muxer will scale all the input frames to this
* resolution. */
#define MUXER_OUTPUT_WIDTH 1920
#define MUXER_OUTPUT_HEIGHT 1080
/* Muxer batch formation timeout, for e.g. 40 millisec. Should ideally be set
* based on the fastest source's framerate. */
#define MUXER_BATCH_TIMEOUT_USEC 4000000
static gchar *cfg_file = NULL;
static gchar *input_file = NULL;
static gchar *topic = NULL;
static gchar *conn_str = "ec2-54-242-227-29.compute-1.amazonaws.com;9092;test";
static gchar *proto_lib = "/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_kafka_proto.so";
static gint schema_type = 0;
static gboolean display_off = FALSE;
#define TILED_OUTPUT_WIDTH 1920
#define TILED_OUTPUT_HEIGHT 1080
/* NVIDIA Decoder source pad memory feature. This feature signifies that source
* pads having this capability will push GstBuffers containing cuda buffers. */
#define GST_CAPS_FEATURES_NVMM "memory:NVMM"
gint frame_number = 0;
/* These are the strings of the labels for the respective models */
gchar sgie1_classes_str[12][32] = { "black", "blue", "brown", "gold", "green",
"grey", "maroon", "orange", "red", "silver", "white", "yellow"
gchar sgie2_classes_str[20][32] =
{ "Acura", "Audi", "BMW", "Chevrolet", "Chrysler",
"Dodge", "Ford", "GMC", "Honda", "Hyundai", "Infiniti", "Jeep", "Kia",
"Lexus", "Mazda", "Mercedes", "Nissan",
"Subaru", "Toyota", "Volkswagen"
gchar sgie3_classes_str[6][32] = { "coupe", "largevehicle", "sedan", "suv",
"truck", "van"
gchar pgie_classes_str[4][32] ={ "Vehicle", "TwoWheeler", "Person", "RoadSign" };
/* gie_unique_id is one of the properties in the above dstest2_sgiex_config.txt
* files. These should be unique and known when we want to parse the Metadata
* respective to the sgie labels. Ideally these should be read from the config
* files but for brevity we ensure they are same. */
guint sgie1_unique_id = 2;
guint sgie2_unique_id = 3;
guint sgie3_unique_id = 4;
#define FPS_PRINT_INTERVAL 300
//static struct timeval start_time = { };
//static guint probe_counter = 0;
static void generate_ts_rfc3339 (char *buf, int buf_size)
time_t tloc;
struct tm tm_log;
struct timespec ts;
char strmsec[6]; //.nnnZ\0
clock_gettime(CLOCK_REALTIME, &ts);
memcpy(&tloc, (void *)(&ts.tv_sec), sizeof(time_t));
gmtime_r(&tloc, &tm_log);
strftime(buf, buf_size,"%Y-%m-%dT%H:%M:%S", &tm_log);
int ms = ts.tv_nsec/1000000;
g_snprintf(strmsec, sizeof(strmsec),".%.3dZ", ms);
strncat(buf, strmsec, buf_size);
static gpointer meta_copy_func (gpointer data, gpointer user_data)
NvDsUserMeta *user_meta = (NvDsUserMeta *) data;
NvDsEventMsgMeta *srcMeta = (NvDsEventMsgMeta *) user_meta->user_meta_data;
NvDsEventMsgMeta *dstMeta = NULL;
dstMeta = g_memdup (srcMeta, sizeof(NvDsEventMsgMeta));
if (srcMeta->ts)
dstMeta->ts = g_strdup (srcMeta->ts);
if (srcMeta->sensorStr)
dstMeta->sensorStr = g_strdup (srcMeta->sensorStr);
if (srcMeta->objSignature.size > 0) {
dstMeta->objSignature.signature = g_memdup (srcMeta->objSignature.signature,
srcMeta->objSignature.size);
dstMeta->objSignature.size = srcMeta->objSignature.size;
if (srcMeta->extMsgSize > 0) {
if (srcMeta->objType == NVDS_OBJECT_TYPE_VEHICLE) {
NvDsVehicleObject *srcObj = (NvDsVehicleObject *) srcMeta->extMsg;
NvDsVehicleObject *obj = (NvDsVehicleObject *) g_malloc0 (sizeof (NvDsVehicleObject));
if (srcObj->type)
obj->type = g_strdup (srcObj->type);
if (srcObj->make)
obj->make = g_strdup (srcObj->make);
if (srcObj->model)
obj->model = g_strdup (srcObj->model);
if (srcObj->color)
obj->color = g_strdup (srcObj->color);
if (srcObj->license)
obj->license = g_strdup (srcObj->license);
if (srcObj->region)
obj->region = g_strdup (srcObj->region);
dstMeta->extMsg = obj;
dstMeta->extMsgSize = sizeof (NvDsVehicleObject);
} else if (srcMeta->objType == NVDS_OBJECT_TYPE_PERSON) {
NvDsPersonObject *srcObj = (NvDsPersonObject *) srcMeta->extMsg;
NvDsPersonObject *obj = (NvDsPersonObject *) g_malloc0 (sizeof (NvDsPersonObject));
obj->age = srcObj->age;
if (srcObj->gender)
obj->gender = g_strdup (srcObj->gender);
if (srcObj->cap)
obj->cap = g_strdup (srcObj->cap);
if (srcObj->hair)
obj->hair = g_strdup (srcObj->hair);
if (srcObj->apparel)
obj->apparel = g_strdup (srcObj->apparel);
return dstMeta;
static void meta_free_func (gpointer data, gpointer user_data)
g_free (srcMeta->ts);
g_free (srcMeta->sensorStr);
g_free (srcMeta->objSignature.signature);
srcMeta->objSignature.size = 0;
NvDsVehicleObject *obj = (NvDsVehicleObject *) srcMeta->extMsg;
if (obj->type)
g_free (obj->type);
if (obj->color)
g_free (obj->color);
if (obj->make)
g_free (obj->make);
if (obj->model)
g_free (obj->model);
if (obj->license)
g_free (obj->license);
if (obj->region)
g_free (obj->region);
NvDsPersonObject *obj = (NvDsPersonObject *) srcMeta->extMsg;
if (obj->gender)
g_free (obj->gender);
if (obj->cap)
g_free (obj->cap);
if (obj->hair)
g_free (obj->hair);
if (obj->apparel)
g_free (obj->apparel);
g_free (srcMeta->extMsg);
srcMeta->extMsgSize = 0;
g_free (user_meta->user_meta_data);
user_meta->user_meta_data = NULL;
static void
generate_vehicle_meta (gpointer data)
NvDsVehicleObject *obj = (NvDsVehicleObject *) data;
obj->type = g_strdup ("sedan");
obj->color = g_strdup ("blue");
obj->make = g_strdup ("Bugatti");
obj->model = g_strdup ("M");
obj->license = g_strdup ("XX1234");
obj->region = g_strdup ("CA");
static void
generate_person_meta (gpointer data)
NvDsPersonObject *obj = (NvDsPersonObject *) data;
obj->age = 45;
obj->cap = g_strdup ("none");
obj->hair = g_strdup ("black");
obj->gender = g_strdup ("male");
obj->apparel= g_strdup ("formal");
static void
generate_event_msg_meta (gpointer data, gint class_id)
NvDsEventMsgMeta *meta = (NvDsEventMsgMeta *) data;
meta->sensorId = 0;
meta->placeId = 0;
meta->moduleId = 0;
meta->sensorStr = g_strdup ("sensor-0");
meta->ts = (gchar *) g_malloc0 (MAX_TIME_STAMP_LEN + 1);
generate_ts_rfc3339(meta->ts, MAX_TIME_STAMP_LEN);
* This demonstrates how to attach custom objects.
* Any custom object as per requirement can be generated and attached
* like NvDsVehicleObject / NvDsPersonObject. Then that object should
* be handled in payload generator library (nvmsgconv.cpp) accordingly.
if (class_id == PGIE_CLASS_ID_VEHICLE) {
meta->type = NVDS_EVENT_MOVING;
meta->objType = NVDS_OBJECT_TYPE_VEHICLE;
meta->objClassId = PGIE_CLASS_ID_VEHICLE;
generate_vehicle_meta (obj);
meta->extMsg = obj;
meta->extMsgSize = sizeof (NvDsVehicleObject);
} else if (class_id == PGIE_CLASS_ID_PERSON) {
meta->type = NVDS_EVENT_ENTRY;
meta->objType = NVDS_OBJECT_TYPE_PERSON;
meta->objClassId = PGIE_CLASS_ID_PERSON;
generate_person_meta (obj);
meta->extMsg = obj;
meta->extMsgSize = sizeof (NvDsPersonObject);
/* tiler_sink_pad_buffer_probe will extract metadata received on OSD sink pad
* and update params for drawing rectangle, object information etc. */
static GstPadProbeReturn
tiler_src_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
gpointer u_data)
GstBuffer *buf = (GstBuffer *) info->data;
guint num_rects = 0;
NvDsObjectMeta *obj_meta = NULL;
guint vehicle_count = 0;
guint person_count = 0;
NvDsMetaList * l_frame = NULL;
NvDsMetaList * l_obj = NULL;
NvDsDisplayMeta *display_meta = NULL;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
gboolean is_first_object = TRUE;
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
int offset = 0;
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
l_obj = l_obj->next) {
obj_meta = (NvDsObjectMeta *) (l_obj->data);
if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
vehicle_count++;
num_rects++;
if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) {
person_count++;
num_rects++;
* Ideally NVDS_EVENT_MSG_META should be attached to buffer by the
* component implementing detection / recognition logic.
* Here it demonstrates how to use / attach that meta data.
if (is_first_object && !(frame_number % 30)) {
/* Frequency of messages to be send will be based on use case.
* Here message is being sent for first object every 30 frames.
NvDsEventMsgMeta *msg_meta = (NvDsEventMsgMeta *) g_malloc0 (sizeof (NvDsEventMsgMeta));
msg_meta->bbox.top = obj_meta->rect_params.top;
msg_meta->bbox.left = obj_meta->rect_params.left;
msg_meta->bbox.width = obj_meta->rect_params.width;
msg_meta->bbox.height = obj_meta->rect_params.height;
msg_meta->frameId = frame_number;
msg_meta->trackingId = obj_meta->object_id;
msg_meta->confidence = obj_meta->confidence;
generate_event_msg_meta (msg_meta, obj_meta->class_id);
g_print ("CLASS ID = %d ",
NvDsUserMeta *user_event_meta = nvds_acquire_user_meta_from_pool (batch_meta);
if (user_event_meta) {
user_event_meta->user_meta_data = (void *) msg_meta;
user_event_meta->base_meta.meta_type = NVDS_EVENT_MSG_META;
user_event_meta->base_meta.copy_func = (NvDsMetaCopyFunc) meta_copy_func;
user_event_meta->base_meta.release_func = (NvDsMetaReleaseFunc) meta_free_func;
nvds_add_user_meta_to_frame(frame_meta, user_event_meta);
} else {
g_print ("Error in attaching event meta to buffer\n");
is_first_object = FALSE;
display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
NvOSD_TextParams *txt_params = &display_meta->text_params[0];
display_meta->num_labels = 1;
txt_params->display_text = g_malloc0 (MAX_DISPLAY_LEN);
offset = snprintf(txt_params->display_text, MAX_DISPLAY_LEN, "Person = %d ", person_count);
offset = snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN, "Vehicle = %d ", vehicle_count);
/* Now set the offsets where the string should appear */
txt_params->x_offset = 10;
txt_params->y_offset = 12;
/* Font , font-color and font-size */
txt_params->font_params.font_name = "Serif";
txt_params->font_params.font_size = 10;
txt_params->font_params.font_color.red = 1.0;
txt_params->font_params.font_color.green = 1.0;
txt_params->font_params.font_color.blue = 1.0;
txt_params->font_params.font_color.alpha = 1.0;
/* Text background color */
txt_params->set_bg_clr = 1;
txt_params->text_bg_clr.red = 0.0;
txt_params->text_bg_clr.green = 0.0;
txt_params->text_bg_clr.blue = 0.0;
txt_params->text_bg_clr.alpha = 1.0;
nvds_add_display_meta_to_frame(frame_meta, display_meta);
g_print ("Frame Number = %d Number of objects = %d "
"Vehicle Count = %d Person Count = %d\n",
frame_number, num_rects, vehicle_count, person_count);
frame_number++;
return GST_PAD_PROBE_OK;
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
GMainLoop *loop = (GMainLoop *) data;
switch (GST_MESSAGE_TYPE (msg)) {
case GST_MESSAGE_EOS:
g_print ("End of stream\n");
g_main_loop_quit (loop);
break;
case GST_MESSAGE_WARNING:
gchar *debug;
GError *error;
gst_message_parse_warning (msg, &error, &debug);
g_printerr ("WARNING from element %s: %s\n",
GST_OBJECT_NAME (msg->src), error->message);
g_free (debug);
g_printerr ("Warning: %s\n", error->message);
g_error_free (error);
break;
case GST_MESSAGE_ERROR:
gchar *debug;
GError *error;
gst_message_parse_error (msg, &error, &debug);
g_printerr ("ERROR from element %s: %s\n",
if (debug)
g_printerr ("Error details: %s\n", debug);
g_free (debug);
break;
case GST_MESSAGE_ELEMENT:
if (gst_nvmessage_is_stream_eos (msg)) {
guint stream_id;
if (gst_nvmessage_parse_stream_eos (msg, &stream_id)) {
g_print ("Got EOS from stream %d\n", stream_id);
break;
#endif
default:
break;
return TRUE;
/* Tracker config parsing */
#define CHECK_ERROR(error) \
if (error) { \
g_printerr ("Error while parsing config file: %s\n", error->message); \
goto done; \
#define CONFIG_GROUP_TRACKER "tracker"
#define CONFIG_GROUP_TRACKER_WIDTH "tracker-width"
#define CONFIG_GROUP_TRACKER_HEIGHT "tracker-height"
#define CONFIG_GROUP_TRACKER_LL_CONFIG_FILE "ll-config-file"
#define CONFIG_GROUP_TRACKER_LL_LIB_FILE "ll-lib-file"
#define CONFIG_GROUP_TRACKER_ENABLE_BATCH_PROCESS "enable-batch-process"
#define CONFIG_GPU_ID "gpu-id"
static gchar *
get_absolute_file_path (gchar *cfg_file_path, gchar *file_path)
gchar abs_cfg_path[PATH_MAX + 1];
gchar *abs_file_path;
gchar *delim;
if (file_path && file_path[0] == '/') {
return file_path;
if (!realpath (cfg_file_path, abs_cfg_path)) {
g_free (file_path);
return NULL;
// Return absolute path of config file if file_path is NULL.
if (!file_path) {
abs_file_path = g_strdup (abs_cfg_path);
return abs_file_path;
delim = g_strrstr (abs_cfg_path, "/");
*(delim + 1) = '\0';
abs_file_path = g_strconcat (abs_cfg_path, file_path, NULL);
g_free (file_path);
static gboolean
set_tracker_properties (GstElement *nvtracker)
gboolean ret = FALSE;
GError *error = NULL;
gchar **keys = NULL;
gchar **key = NULL;
GKeyFile *key_file = g_key_file_new ();
if (!g_key_file_load_from_file (key_file, TRACKER_CONFIG_FILE, G_KEY_FILE_NONE,
&error)) {
g_printerr ("Failed to load config file: %s\n", error->message);
return FALSE;
keys = g_key_file_get_keys (key_file, CONFIG_GROUP_TRACKER, NULL, &error);
CHECK_ERROR (error);
for (key = keys; *key; key++) {
if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_WIDTH)) {
gint width =
g_key_file_get_integer (key_file, CONFIG_GROUP_TRACKER,
CONFIG_GROUP_TRACKER_WIDTH, &error);
g_object_set (G_OBJECT (nvtracker), "tracker-width", width, NULL);
} else if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_HEIGHT)) {
gint height =
CONFIG_GROUP_TRACKER_HEIGHT, &error);
g_object_set (G_OBJECT (nvtracker), "tracker-height", height, NULL);
} else if (!g_strcmp0 (*key, CONFIG_GPU_ID)) {
guint gpu_id =
CONFIG_GPU_ID, &error);
g_object_set (G_OBJECT (nvtracker), "gpu_id", gpu_id, NULL);
} else if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_LL_CONFIG_FILE)) {
char* ll_config_file = get_absolute_file_path (TRACKER_CONFIG_FILE,
g_key_file_get_string (key_file,
CONFIG_GROUP_TRACKER_LL_CONFIG_FILE, &error));
g_object_set (G_OBJECT (nvtracker), "ll-config-file", ll_config_file, NULL);
} else if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_LL_LIB_FILE)) {
char* ll_lib_file = get_absolute_file_path (TRACKER_CONFIG_FILE,
CONFIG_GROUP_TRACKER_LL_LIB_FILE, &error));
g_object_set (G_OBJECT (nvtracker), "ll-lib-file", ll_lib_file, NULL);
} else if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_ENABLE_BATCH_PROCESS)) {
gboolean enable_batch_process =
CONFIG_GROUP_TRACKER_ENABLE_BATCH_PROCESS, &error);
g_object_set (G_OBJECT (nvtracker), "enable_batch_process",
enable_batch_process, NULL);
} else {
g_printerr ("Unknown key '%s' for group [%s]", *key,
CONFIG_GROUP_TRACKER);
ret = TRUE;
done:
if (error) {
if (keys) {
g_strfreev (keys);
if (!ret) {
g_printerr ("%s failed", __func__);
return ret;
static void
cb_newpad (GstElement * decodebin, GstPad * decoder_src_pad, gpointer data)
g_print ("In cb_newpad\n");
GstCaps *caps = gst_pad_get_current_caps (decoder_src_pad);
const GstStructure *str = gst_caps_get_structure (caps, 0);
const gchar *name = gst_structure_get_name (str);
GstElement *source_bin = (GstElement *) data;
GstCapsFeatures *features = gst_caps_get_features (caps, 0);
/* Need to check if the pad created by the decodebin is for video and not
* audio. */
if (!strncmp (name, "video", 5)) {
/* Link the decodebin pad only if decodebin has picked nvidia
* decoder plugin nvdec_*. We do this by checking if the pad caps contain
* NVMM memory features. */
if (gst_caps_features_contains (features, GST_CAPS_FEATURES_NVMM)) {
/* Get the source bin ghost pad */
GstPad *bin_ghost_pad = gst_element_get_static_pad (source_bin, "src");
if (!gst_ghost_pad_set_target (GST_GHOST_PAD (bin_ghost_pad),
decoder_src_pad)) {
g_printerr ("Failed to link decoder src pad to source bin ghost pad\n");
gst_object_unref (bin_ghost_pad);
} else {
g_printerr ("Error: Decodebin did not pick nvidia decoder plugin.\n");
static void
decodebin_child_added (GstChildProxy * child_proxy, GObject * object,
gchar * name, gpointer user_data)
g_print ("Decodebin child added: %s\n", name);
if (g_strrstr (name, "decodebin") == name) {
g_signal_connect (G_OBJECT (object), "child-added",
G_CALLBACK (decodebin_child_added), user_data);
if (g_strstr_len (name, -1, "nvv4l2decoder") == name) {
g_print ("Seting bufapi_version\n");
g_object_set (object, "bufapi-version", TRUE, NULL);
static GstElement *
create_source_bin (guint index, gchar * uri)
GstElement *bin = NULL, *uri_decode_bin = NULL;
gchar bin_name[16] = { };
g_snprintf (bin_name, 15, "source-bin-%02d", index);
/* Create a source GstBin to abstract this bin's content from the rest of the
* pipeline */
bin = gst_bin_new (bin_name);
/* Source element for reading from the uri.
* We will use decodebin and let it figure out the container format of the
* stream and the codec and plug the appropriate demux and decode plugins. */
uri_decode_bin = gst_element_factory_make ("uridecodebin", "uri-decode-bin");
if (!bin || !uri_decode_bin) {
g_printerr ("One element in source bin could not be created.\n");
return NULL;
/* We set the input uri to the source element */
g_object_set (G_OBJECT (uri_decode_bin), "uri", uri, NULL);
/* Connect to the "pad-added" signal of the decodebin which generates a
* callback once a new pad for raw data has beed created by the decodebin */
g_signal_connect (G_OBJECT (uri_decode_bin), "pad-added",
G_CALLBACK (cb_newpad), bin);
g_signal_connect (G_OBJECT (uri_decode_bin), "child-added",
G_CALLBACK (decodebin_child_added), bin);
gst_bin_add (GST_BIN (bin), uri_decode_bin);
/* We need to create a ghost pad for the source bin which will act as a proxy
* for the video decoder src pad. The ghost pad will not have a target right
* now. Once the decode bin creates the video decoder and generates the
* cb_newpad callback, we will set the ghost pad target to the video decoder
* src pad. */
if (!gst_element_add_pad (bin, gst_ghost_pad_new_no_target ("src",
GST_PAD_SRC))) {
g_printerr ("Failed to add ghost pad in source bin\n");
return NULL;
return bin;
int
main (int argc, char *argv[])
GMainLoop *loop = NULL;
GstElement *pipeline = NULL, *streammux = NULL, *sink = NULL, *pgie = NULL,
*nvvidconv = NULL, *nvosd = NULL, *tiler = NULL, *sgie1 = NULL, *sgie2 = NULL, *sgie3 = NULL, *nvtracker = NULL;
GstElement *msgconv = NULL, *msgbroker = NULL, *tee = NULL;
GstElement *queue1 = NULL, *queue2 = NULL;
g_print ("With tracker\n");
#ifdef PLATFORM_TEGRA
GstElement *transform = NULL;
#endif
GstBus *bus = NULL;
guint bus_watch_id;
GstPad *tiler_src_pad = NULL;
guint i, num_sources;
guint tiler_rows, tiler_columns;
guint pgie_batch_size;
//GstPad *osd_sink_pad = NULL;
GstPad *tee_render_pad = NULL;
GstPad *tee_msg_pad = NULL;
GstPad *sink_pad = NULL;
GstPad *src_pad = NULL;
GOptionContext *ctx = NULL;
GOptionGroup *group = NULL;
ctx = g_option_context_new ("Nvidia DeepStream Test4");
group = g_option_group_new ("test4", NULL, NULL, NULL, NULL);
//g_option_group_add_entries (group, entries);
g_option_context_set_main_group (ctx, group);
g_option_context_add_group (ctx, gst_init_get_option_group ());
if (!g_option_context_parse (ctx, &argc, &argv, &error)) {
g_option_context_free (ctx);
g_printerr ("%s", error->message);
return -1;
loop = g_main_loop_new (NULL, FALSE);
/* Check input arguments */
if (argc < 2) {
g_printerr ("Usage: %s <uri1> [uri2] ... [uriN] \n", argv[0]);
return -1;
num_sources = argc - 1;
/* Standard GStreamer initialization */
gst_init (&argc, &argv);
/* Create gstreamer elements */
/* Create Pipeline element that will form a connection of other elements */
pipeline = gst_pipeline_new ("dstest3-pipeline");
/* Create nvstreammux instance to form batches from one or more sources. */
streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
if (!pipeline || !streammux) {
g_printerr ("One element could not be created. Exiting.\n");
return -1;
gst_bin_add (GST_BIN (pipeline), streammux);
for (i = 0; i < num_sources; i++) {
GstPad *sinkpad, *srcpad;
gchar pad_name[16] = { };
GstElement *source_bin = create_source_bin (i, argv[i + 1]);
if (!source_bin) {
g_printerr ("Failed to create source bin. Exiting.\n");
return -1;
gst_bin_add (GST_BIN (pipeline), source_bin);
g_snprintf (pad_name, 15, "sink_%u", i);
sinkpad = gst_element_get_request_pad (streammux, pad_name);
if (!sinkpad) {
g_printerr ("Streammux request sink pad failed. Exiting.\n");
return -1;
srcpad = gst_element_get_static_pad (source_bin, "src");
if (!srcpad) {
g_printerr ("Failed to get src pad of source bin. Exiting.\n");
return -1;
if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
g_printerr ("Failed to link source bin to stream muxer. Exiting.\n");
return -1;
gst_object_unref (srcpad);
gst_object_unref (sinkpad);
/* Use nvinfer to infer on batched frame. */
pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
/* We need to have a tracker to track the identified objects */
nvtracker = gst_element_factory_make ("nvtracker", "tracker");
/* We need three secondary gies so lets create 3 more instances of
nvinfer */
sgie1 = gst_element_factory_make ("nvinfer", "secondary1-nvinference-engine");
sgie2 = gst_element_factory_make ("nvinfer", "secondary2-nvinference-engine");
sgie3 = gst_element_factory_make ("nvinfer", "secondary3-nvinference-engine");
/* Use nvtiler to composite the batched frames into a 2D tiled array based
* on the source of the frames. */
tiler = gst_element_factory_make ("nvmultistreamtiler", "nvtiler");
/* Use convertor to convert from NV12 to RGBA as required by nvosd */
nvvidconv = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter");
/* Create OSD to draw on the converted RGBA buffer */
nvosd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
// KAFKA ATTACH
/* Create msg converter to generate payload from buffer metadata */
msgconv = gst_element_factory_make ("nvmsgconv", "nvmsg-converter");
/* Create msg broker to send payload to server */
msgbroker = gst_element_factory_make ("nvmsgbroker", "nvmsg-broker");
/* Create tee to render buffer and send message simultaneously*/
tee = gst_element_factory_make ("tee", "nvsink-tee");
/* Create queues */
queue1 = gst_element_factory_make ("queue", "nvtee-que1");
queue2 = gst_element_factory_make ("queue", "nvtee-que2");
/* Finally render the osd output */
transform = gst_element_factory_make ("nvegltransform", "nvegl-transform");
#endif
sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
/* if (display_off) {
sink = gst_element_factory_make ("fakesink", "nvvideo-renderer");
} else {
if (!transform) {
g_printerr ("nvegltransform element could not be created. Exiting.\n");
return -1;
#endif
#endif
if (!pgie || !tiler || !nvvidconv || !nvosd || !sink || !sgie1 || !sgie2 || !sgie3 ||
!nvtracker || !msgconv || !msgbroker || !tee
|| !queue1 || !queue2 ) {
return -1;
if(!transform) {
g_printerr ("One tegra element could not be created. Exiting.\n");
return -1;
#endif
//g_object_set (G_OBJECT (source), "location", input_file, NULL);
g_object_set (G_OBJECT (streammux), "width", MUXER_OUTPUT_WIDTH, "height",
MUXER_OUTPUT_HEIGHT, "batch-size", num_sources,
"batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
/* Configure the nvinfer element using the nvinfer config file. */
g_object_set (G_OBJECT (pgie),
"config-file-path", "dstest3_pgie_config.txt", NULL);
g_object_set (G_OBJECT (sgie1), "config-file-path", SGIE1_CONFIG_FILE, NULL);
g_object_set (G_OBJECT (sgie2), "config-file-path", SGIE2_CONFIG_FILE, NULL);
g_object_set (G_OBJECT (sgie3), "config-file-path", SGIE3_CONFIG_FILE, NULL);
//kafka CONFIG
g_object_set (G_OBJECT(msgconv), "config", MSCONV_CONFIG_FILE, NULL);
g_object_set (G_OBJECT(msgconv), "payload-type", schema_type, NULL);
g_object_set (G_OBJECT(msgbroker), "proto-lib", proto_lib,
"conn-str", conn_str, "sync", FALSE, NULL);
g_object_set (G_OBJECT (sink), "sync", TRUE, NULL);
/* we add a message handler */
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
gst_object_unref (bus);
/* Set necessary properties of the tracker element. */
if (!set_tracker_properties(nvtracker)) {
g_printerr ("Failed to set tracker properties. Exiting.\n");
return -1;
/* Override the batch-size set in the config file with the number of sources. */
g_object_get (G_OBJECT (pgie), "batch-size", &pgie_batch_size, NULL);
if (pgie_batch_size != num_sources) {
g_printerr
("WARNING: Overriding infer-config batch-size (%d) with number of sources (%d)\n",
pgie_batch_size, num_sources);
g_object_set (G_OBJECT (pgie), "batch-size", num_sources, NULL);
tiler_rows = (guint) sqrt (num_sources);
tiler_columns = (guint) ceil (1.0 * num_sources / tiler_rows);
/* we set the tiler properties here */
g_object_set (G_OBJECT (tiler), "rows", tiler_rows, "columns", tiler_columns,
"width", TILED_OUTPUT_WIDTH, "height", TILED_OUTPUT_HEIGHT, NULL);
/* Set up the pipeline */
/* we add all elements into the pipeline */
gst_bin_add_many (GST_BIN (pipeline), pgie, nvtracker , sgie1,
sgie2, sgie3, tiler, nvvidconv, nvosd, transform, tee, queue1, queue2, msgconv,
msgbroker, sink,
NULL);
/* we link the elements together
* nvstreammux -> nvinfer -> nvtiler -> nvvidconv -> nvosd -> video-renderer */
if (!gst_element_link_many (streammux, pgie , nvtracker, sgie1,
sgie2, sgie3, tiler, nvvidconv, nvosd, transform, sink,
NULL)) {
g_printerr ("Elements could not be linked. Exiting.\n");
return -1;
#else
gst_bin_add_many (GST_BIN (pipeline), pgie , nvtracker, sgie1,
sgie2, sgie3, tiler, nvvidconv, nvosd, tee, queue1, queue2, msgconv,
msgbroker, sink,
NULL);
sgie2, sgie3, tiler, nvvidconv, nvosd, sink,
NULL)) {
return -1;
#endif
/* Lets add probe to get informed of the meta data generated, we add probe to
* the sink pad of the osd element, since by that time, the buffer would have
* had got all the metadata. */
tiler_src_pad = gst_element_get_static_pad (pgie, "src");
//tiler_src_pad = gst_element_get_static_pad (nvosd, "sink");
if (!tiler_src_pad)
g_print ("Unable to get src pad\n");
else
gst_pad_add_probe (tiler_src_pad, GST_PAD_PROBE_TYPE_BUFFER,
tiler_src_pad_buffer_probe, NULL, NULL);
/* Set the pipeline to "playing" state */
g_print ("Now playing:");
g_print (" %s,", argv[i + 1]);
g_print ("\n");
gst_element_set_state (pipeline, GST_STATE_PLAYING);
/* Wait till pipeline encounters an error or EOS */
g_print ("Running...\n");
g_main_loop_run (loop);
/* Out of the main loop, clean up nicely */
g_print ("Returned, stopping playback\n");
g_free (cfg_file);
g_free (topic);
g_free (conn_str);
g_free (proto_lib);
/* Release the request pads from the tee, and unref them */
gst_element_release_request_pad (tee, tee_msg_pad);
gst_element_release_request_pad (tee, tee_render_pad);
gst_object_unref (tee_msg_pad);
gst_object_unref (tee_render_pad);
gst_element_set_state (pipeline, GST_STATE_NULL);
g_print ("Deleting pipeline\n");
gst_object_unref (GST_OBJECT (pipeline));
g_source_remove (bus_watch_id);
g_main_loop_unref (loop);
return 0;
Kindly do the needful ASAP. Thank You,
