How to analyze video by source UDP?
In example deepstream-test1, I try to use a UDP source replacing the local file <sample.h264>. I modify the code in deepstream-test1_app.c. The program does not report an error but there is no video output。
Server:
gst­-launch­-1.0 v4l2src device=/dev/video1 ! video/x­-h264, width=1920,
height=1080, framerate=30/1 ! udpsink host=172.19.65.69 port=5000
For the client, i just modify the code in the main function :
deepstream-test1_app.c:
int main (int argc, char *argv[])
  GMainLoop *loop = NULL;
  GstElement *pipeline = NULL, *source = NULL, *h264parser = NULL,
      *decoder = NULL, *streammux = NULL, *sink = NULL, *pgie = NULL, *nvvidconv = NULL,
      *nvosd = NULL;
#ifdef PLATFORM_TEGRA
  GstElement *transform = NULL;
#endif
  GstBus *bus = NULL;
  guint bus_watch_id;
  GstPad *osd_sink_pad = NULL;
  /* Check input arguments */
  /*if (argc != 2) {
    g_printerr ("Usage: %s <H264 filename>\n", argv[0]);
    return -1;
  /* Standard GStreamer initialization */
  gst_init (&argc, &argv);
  loop = g_main_loop_new (NULL, FALSE);
  /* Create gstreamer elements */
  /* Create Pipeline element that will form a connection of other elements */
  pipeline = gst_pipeline_new ("dstest1-pipeline");
  /* Source element for reading from the file */
  source = gst_element_factory_make ("udpsrc", "UDP-source");
  /* Since the data format in the input file is elementary h264 stream,
   * we need a h264parser */
  h264parser = gst_element_factory_make ("h264parse", "h264-parser");
  /* Use nvdec_h264 for hardware accelerated decode on GPU */
  decoder = gst_element_factory_make ("omxh264dec", "nvv4l2-decoder");          //nvv4l2decoder
  /* Create nvstreammux instance to form batches from one or more sources. */
  streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
  if (!pipeline || !streammux) {
    g_printerr ("One element could not be created. Exiting.\n");
    return -1;
  /* Use nvinfer to run inferencing on decoder's output,
   * behaviour of inferencing is set through config file */
  pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
  /* Use convertor to convert from NV12 to RGBA as required by nvosd */
  nvvidconv = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter");
  /* Create OSD to draw on the converted RGBA buffer */
  nvosd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
  /* Finally render the osd output */
  transform = gst_element_factory_make ("nvegltransform", "nvegl-transform");
#endif
  sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
  if (!source || !h264parser || !decoder || !pgie
      || !nvvidconv || !nvosd || !sink) {
    return -1;
  if(!transform) {
    g_printerr ("One tegra element could not be created. Exiting.\n");
    return -1;
#endif
  /* we set the input filename to the source element */
  g_object_set (G_OBJECT (source), "port", 5000, NULL);
  g_object_set (G_OBJECT (streammux),"width", MUXER_OUTPUT_WIDTH, "height",
      MUXER_OUTPUT_HEIGHT,"batch-size", 1,
      "batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
  /* Set all the necessary properties of the nvinfer element,
   * the necessary ones are : */
  g_object_set (G_OBJECT (pgie),
      "config-file-path", "dstest1_pgie_config.txt", NULL);
  /* we add a message handler */
  bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
  bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
  gst_object_unref (bus);
  /* Set up the pipeline */
  /* we add all elements into the pipeline */
  gst_bin_add_many (GST_BIN (pipeline),
      source, h264parser, decoder, streammux, pgie,
      nvvidconv, nvosd, transform, sink, NULL);
#else
      nvvidconv, nvosd, sink, NULL);
#endif
  GstPad *sinkpad, *srcpad;
  gchar pad_name_sink[16] = "sink_0";
  gchar pad_name_src[16] = "src";
  sinkpad = gst_element_get_request_pad (streammux, pad_name_sink);
  if (!sinkpad) {
    g_printerr ("Streammux request sink pad failed. Exiting.\n");
    return -1;
  srcpad = gst_element_get_static_pad (decoder, pad_name_src);
  if (!srcpad) {
    g_printerr ("Decoder request src pad failed. Exiting.\n");
    return -1;
  if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
      g_printerr ("Failed to link decoder to stream muxer. Exiting.\n");
      return -1;
  gst_object_unref (sinkpad);
  gst_object_unref (srcpad);
  /* we link the elements together */
  /* file-source -> h264-parser -> nvh264-decoder ->
   * nvinfer -> nvvidconv -> nvosd -> video-renderer */
  if (!gst_element_link_many (source, h264parser, decoder, NULL)) {
    g_printerr ("Elements could not be linked: 1. Exiting.\n");
    return -1;
  if (!gst_element_link_many (streammux, pgie,
      nvvidconv, nvosd, transform, sink, NULL)) {
    g_printerr ("Elements could not be linked: 2. Exiting.\n");
    return -1;
#else
      nvvidconv, nvosd, sink, NULL)) {
    return -1;
#endif
  /* Lets add probe to get informed of the meta data generated, we add probe to
   * the sink pad of the osd element, since by that time, the buffer would have
   * had got all the metadata. */
  osd_sink_pad = gst_element_get_static_pad (nvosd, "sink");
  if (!osd_sink_pad)
    g_print ("Unable to get sink pad\n");
  else
    gst_pad_add_probe (osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
        osd_sink_pad_buffer_probe, NULL, NULL);
  /* Set the pipeline to "playing" state */
  g_print ("Now playing: %s\n", argv[1]);
  gst_element_set_state (pipeline, GST_STATE_PLAYING);
  /* Wait till pipeline encounters an error or EOS */
  g_print ("Running...\n");
  g_main_loop_run (loop);
  /* Out of the main loop, clean up nicely */
  g_print ("Returned, stopping playback\n");
  gst_element_set_state (pipeline, GST_STATE_NULL);
  g_print ("Deleting pipeline\n");
  gst_object_unref (GST_OBJECT (pipeline));
  g_source_remove (bus_watch_id);
  g_main_loop_unref (loop);
  return 0;
Did I missed something?
How do you check and get “there is no video output” ?
Do you want to forward camera input to udp stream?
Below are the GStreamre commands to setup udp sender and receriver with camera input, both commands run on Jetson-Xavier/Jetpack4.3 (other Jetson platform and Jetpack release should work as well).
From below commands, you could find what you are missing in your setup.
Sender:
$ gst-launch-1.0 v4l2src device=/dev/video0 ! videoconvert ! “video/x-raw,format=I420,width=640,height=480,framerate=(fraction)30/1” ! queue2 ! nvvideoconvert ! ‘video/x-raw(memory:NVMM), width=(int)1280, height=(int)480, format=(string)I420’ ! nvv4l2h264enc ! “video/x-h264, stream-format=(string)byte-stream” ! h264parse ! rtph264pay mtu=1400 ! udpsink host=127.0.0.1 port=5000 sync=false async=false
Receiver:
$ gst-launch-1.0 udpsrc port=5000 ! application/x-rtp,encoding-name=H264,payload=96 ! rtph264depay ! h264parse ! queue ! omxh264dec ! nvoverlaysink
sync=false async=false -e
Hello, sorry for replying late, I try to write the code Gstream Receiver you given to me in example deepstream-test1.
It runs with an error: “Elements could not be linked: 1. Exiting”
Could you help me find where is the problem?
int
      *nvosd = NULL, *depay=NULL, *queue=NULL;
  GstCaps *caps1=NULL;
#endif
  GstBus *bus = NULL;
  guint bus_watch_id;
  /*if (argc != 2) {
    return -1;
  source = gst_element_factory_make ("udpsrc", "file-source");
  //filter1 = gst_element_factory_make ("capsfilter", "filter1");
  depay = gst_element_factory_make ("rtph264depay", "rtph264depay");
  queue = gst_element_factory_make ("queue", "queue");
  decoder = gst_element_factory_make ("omxh264dec", "nvv4l2-decoder");          //omxh264dec
    return -1;
#endif
      || !nvvidconv || !nvosd || !sink|| !depay || !queue ) {
    return -1;
  if(!transform) {
    return -1;
#endif
  caps1 = gst_caps_from_string ("application/x-rtp,encoding-name=H264,payload=96");
  g_object_set (G_OBJECT (source), "caps", caps1, NULL);
  gst_caps_unref (caps1);
      source, depay, h264parser, queue, decoder, streammux, pgie,
#else
#endif
  if (!sinkpad) {
    return -1;
  if (!srcpad) {
    return -1;
      return -1;
    return -1;
    return -1;
#else
    return -1;
#endif
  if (!osd_sink_pad)
  else
  return 0;
Hi
Sorry for late reply!
The error comes from below code.
g_printerr (“Elements could not be linked: 1. Exiting.\n”);
return -1;
According to above code, you connect source (udpsrc port=5000 ! application/x-rtp,encoding-name=H264,payload=96) to h264parser, but in my Receiver GStreamer command line, the source is connecting to rtph264depay.
Could you double check your code?
