deepstream redaction app not running with RTSP
I am running redaction app with rtsp url but getting error like:
ERROR from element udpsrc3: Internal data stream error.
I am running app like : ./deepstream-redaction-app -c ./configs/pgie_config_fd_lpd.txt -i “rtsp://192.168.1.201:554/user=admin&password=&channel=1&stream=0.sdp?real_stram”
My deepstream_redaction_app.c file is:
 * Copyright (c) 2018, NVIDIA CORPORATION. All rights reserved.
 * Permission is hereby granted, free of charge, to any person obtaining a
 * copy of this software and associated documentation files (the "Software"),
 * to deal in the Software without restriction, including without limitation
 * the rights to use, copy, modify, merge, publish, distribute, sublicense,
 * and/or sell copies of the Software, and to permit persons to whom the
 * Software is furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
 * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
 * DEALINGS IN THE SOFTWARE.
#include <gst/gst.h>
#include <glib.h>
#include <stdio.h>
#include <time.h>
#include "gstnvdsmeta.h"
/* Define global variables:
 * `frame_number` & `pgie_classes_str` are used for writing meta to kitti;
 * `pgie_config`,`input_mp4`,`output_mp4`,`output_kitti` are configurable file paths parsed through command line. */
clock_t t_start;
clock_t t_end;
GstElement *pipeline, *video_full_processing_bin;
gint frame_number = 0;
gchar pgie_classes_str[4][32] = { "face", "license_plate", "make", "model" };
gchar *pgie_config = NULL;
gchar *input_mp4 = NULL;
gchar *output_mp4 = NULL;
gchar *output_kitti = NULL;
/* initialize our gstreamer components for the app */
GMainLoop *loop = NULL;
GstElement *source = NULL, *decoder = NULL, *streammux = NULL,
    *queue_pgie = NULL, *pgie = NULL, *nvvidconv_osd =
    NULL, *osd = NULL, *queue_sink = NULL, *nvvidconv_sink =
    NULL, *filter_sink = NULL, *videoconvert = NULL, *encoder = NULL, *muxer =
    NULL, *sink = NULL, *nvvidconv_src = NULL, *vidconv_src=NULL, *filter_src=NULL;
#ifdef PLATFORM_TEGRA
  GstElement *transform = NULL;
#endif
GstBus *bus = NULL;
guint bus_watch_id;
GstCaps *caps_filter_osd = NULL, *caps_filter_sink = NULL, *caps_filter_src = NULL;
gulong osd_probe_id = 0;
GstPad *osd_sink_pad = NULL, *videopad = NULL;
/* osd_sink_pad_buffer_probe function will extract metadata received on OSD sink pad
 * and then update params for drawing rectangle and write bbox to kitti file. */
static GstPadProbeReturn
osd_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
    gpointer u_data)
  GstBuffer *buf = (GstBuffer *) info->data;
  NvDsObjectMeta *obj_meta = NULL;
  NvDsMetaList * l_frame = NULL;
  NvDsMetaList * l_obj = NULL;
  NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
  FILE *bbox_params_dump_file = NULL;
  gchar bbox_file[1024] = { 0 };
  for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
      l_frame = l_frame->next) {
    NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
    if (frame_meta == NULL) {
      g_print ("NvDS Meta contained NULL meta \n");
      frame_number++;
      return GST_PAD_PROBE_OK;
    if (output_kitti) {
      g_snprintf (bbox_file, sizeof (bbox_file) - 1, "%s/%06d.txt",
          output_kitti, frame_number);
        bbox_params_dump_file = fopen (bbox_file, "w");
    for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
        l_obj = l_obj->next) {
      obj_meta = (NvDsObjectMeta *) (l_obj->data);
      NvOSD_RectParams * rect_params = &(obj_meta->rect_params);
      NvOSD_TextParams * text_params = &(obj_meta->text_params);
      if (text_params->display_text) {
        text_params->set_bg_clr = 0;
        text_params->font_params.font_size = 0;
      /* Draw black patch to cover license plates (class_id = 1) */
      if (obj_meta->class_id == 1) {
        rect_params->border_width = 1;
        rect_params->has_bg_color = 0;
        rect_params->bg_color.red = 0.0;
        rect_params->bg_color.green = 0.0;
        rect_params->bg_color.blue = 0.0;
        rect_params->bg_color.alpha = 1.0;
      /* Draw skin-color patch to cover faces (class_id = 0) */
      if (obj_meta->class_id == 0) {
        rect_params->bg_color.red = 0.92;
        rect_params->bg_color.green = 0.75;
        rect_params->bg_color.blue = 0.56;
      if (bbox_params_dump_file) {
        int left = (int) (rect_params->left);
        int top = (int) (rect_params->top);
        int right = left + (int) (rect_params->width);
        int bottom = top + (int) (rect_params->height);
        int class_index = obj_meta->class_id;
        char *text = pgie_classes_str[obj_meta->class_id];
        fprintf (bbox_params_dump_file,
            "%s 0.0 0 0.0 %d.00 %d.00 %d.00 %d.00 0.0 0.0 0.0 0.0 0.0 0.0 0.0\n",
            text, left, top, right, bottom);
      fclose (bbox_params_dump_file);
  frame_number++;
/* This bus callback function detects the error and state change in the main pipe
 * and then export messages, export pipeline images or terminate the pipeline accordingly. */
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
  GMainLoop *loop = (GMainLoop *) data;
  switch (GST_MESSAGE_TYPE (msg)) {
    case GST_MESSAGE_EOS:
      g_print ("End of stream\n");
      t_end = clock();
      clock_t t = t_end - t_start;
      double time_taken = ((double)t)/CLOCKS_PER_SEC; // in seconds
      double fps = frame_number/time_taken;
      g_print("\nThe program took %.2f seconds to redact %d frames, pref = %.2f fps \n\n", time_taken,frame_number,fps);
      g_main_loop_quit (loop);
      break;
    case GST_MESSAGE_ERROR:{
      gchar *debug;
      GError *error;
      gst_message_parse_error (msg, &error, &debug);
      g_printerr ("ERROR from element %s: %s\n",
          GST_OBJECT_NAME (msg->src), error->message);
      g_free (debug);
      g_printerr ("Error: %s\n", error->message);
      g_error_free (error);
      break;
    case GST_MESSAGE_STATE_CHANGED:{
      GstState oldstate, newstate;
      gst_message_parse_state_changed (msg, &oldstate, &newstate, NULL);
      if (GST_ELEMENT (GST_MESSAGE_SRC (msg)) == pipeline) {
        switch (newstate) {
          case GST_STATE_PLAYING:
            g_print ("Pipeline running\n");
            GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS (GST_BIN (pipeline),
                GST_DEBUG_GRAPH_SHOW_ALL, "ds-app-playing");
            t_start = clock();
            break;
          case GST_STATE_PAUSED:
            if (oldstate == GST_STATE_PLAYING) {
              g_print ("Pipeline paused\n");
            break;
          case GST_STATE_READY:
            // GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS (GST_BIN (pipeline), GST_DEBUG_GRAPH_SHOW_ALL,"ds-app-ready");
            if (oldstate == GST_STATE_NULL) {
              g_print ("Pipeline ready\n");
            } else {
              g_print ("Pipeline stopped\n");
            break;
          default:
            break;
      break;
    default:
      break;
  return TRUE;
/* The callback function is called when the decoder_bin establishes video source from the input mp4 file,
 * then connects the src pad to the following video_full_processing_bin.
 * The connection is dynamic. */
static void
cb_newpad (GstElement * decodebin, GstPad * pad, gpointer data)
  GstCaps *caps;
  GstStructure *str;
  GstPad *videopad;
  /*only link once */
  videopad = gst_element_get_static_pad (video_full_processing_bin, "sink");
  if (GST_PAD_IS_LINKED (videopad)) {
    g_object_unref (videopad);
    return;
  /* check media type */
  caps = gst_pad_query_caps (pad, NULL);
  str = gst_caps_get_structure (caps, 0);
  if (!g_strrstr (gst_structure_get_name (str), "video")) {
    gst_caps_unref (caps);
    gst_object_unref (videopad);
    return;
  /* link’n’play */
  gst_pad_link (pad, videopad);
/* In the main function, we create elements, configure the elements, assemble to elements to pipe and run the pipe */
int
main (int argc, char *argv[])
  /* initialize the app using GOption */
  GOptionContext *ctx;
  GError *err = NULL;
  GOptionEntry entries[] = {
    {"pgie_config", 'c', 0, G_OPTION_ARG_STRING, &pgie_config,
          "(required) configuration file for the nvinfer detector (primary gie)",
        NULL},
    {"input_mp4", 'i', 0, G_OPTION_ARG_STRING, &input_mp4,
          "(optional) path to input mp4 file. If this is unset then usb webcam will be used as input", NULL},
    {"output_mp4", 'o', 0, G_OPTION_ARG_STRING, &output_mp4,
          "(optional) path to output mp4 file. If this is unset then on-screen display will be used",
        NULL},
    {"output_kitti", 'k', 0, G_OPTION_ARG_STRING, &output_kitti,
          "(optional) path to the folder for containing output kitti files. If this is unset or \
the path does not exist then app won't output kitti files",
        NULL},
    {NULL},
  ctx =
      g_option_context_new
      ("\n\n  'Fast Video Redaction App using NVIDIA Deepstream'\n  \
contact: Shuo Wang (shuow@nvidia.com)");
  g_option_context_add_main_entries (ctx, entries, NULL);
  g_option_context_add_group (ctx, gst_init_get_option_group ());
  if (!g_option_context_parse (ctx, &argc, &argv, &err)) {
    g_print ("Failed to initialize: %s\n", err->message);
    g_clear_error (&err);
    g_option_context_free (ctx);
    return 1;
  /* Check input arguments */
  if (!pgie_config) {
    g_printerr ("missing pgie configuration file\n");
    g_printerr ("run: %s --help for usage instruction\n", argv[0]);
    return -1;
  /* Create gstreamer loop */
  loop = g_main_loop_new (NULL, FALSE);
  /* Create gstreamer pipeline */
  pipeline = gst_pipeline_new ("ds-redaction-pipeline");
  /* Create components for the input source */
  [b]if (input_mp4) {
    source = gst_element_factory_make("rtspsrc", "source");
    g_object_set (G_OBJECT (source), "location", input_mp4, NULL);
    g_object_set(source, "latency", 0, NULL);
    decoder = gst_element_factory_make ("decodebin", "decoder");
    g_signal_connect (decoder, "pad-added", G_CALLBACK (cb_newpad), NULL);
    gst_bin_add_many (GST_BIN (pipeline), source, decoder, NULL);
    gst_element_link (source, decoder);
  }[/b] else {
    source = gst_element_factory_make ("v4l2src", "camera-source");
    g_object_set (G_OBJECT (source), "device", "/dev/video0", NULL);
    vidconv_src = gst_element_factory_make ("videoconvert", "vidconv_src");
    nvvidconv_src = gst_element_factory_make ("nvvideoconvert", "nvvidconv_src");
    filter_src = gst_element_factory_make ("capsfilter", "filter_src");
    g_object_set (G_OBJECT (nvvidconv_src), "nvbuf-memory-type", 0, NULL);
    caps_filter_src =
        gst_caps_from_string ("video/x-raw(memory:NVMM), format=NV12, width=1280, height=720, framerate=30/1");
    g_object_set (G_OBJECT (filter_src), "caps", caps_filter_src, NULL);
    gst_caps_unref (caps_filter_src);
       (GST_BIN (pipeline), source, vidconv_src, nvvidconv_src, filter_src, NULL);
    gst_element_link_many (source, vidconv_src, nvvidconv_src, filter_src, NULL);
  /* Create main processing bin */
  video_full_processing_bin = gst_bin_new ("video-process-bin");
  /* Create nvstreammux instance to form batches from one or more sources. */
  streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
  g_object_set (G_OBJECT (streammux), "width", 1280, "height",
      720, "batch-size", 1, "batched-push-timeout", 40000, NULL);
  g_object_set (G_OBJECT (streammux), "nvbuf-memory-type", 0, NULL);
  gchar pad_name_sink[16] = "sink_0";
  videopad = gst_element_get_request_pad (streammux, pad_name_sink);
  /* Use nvinfer to run inferencing on decoder's output,
   * behaviour of inferencing is set through config file.
   * Create components for the detection */
  queue_pgie = gst_element_factory_make ("queue", "queue_pgie");
  pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
  g_object_set (G_OBJECT (pgie), "config-file-path", pgie_config, NULL);
  /* Use nvosd to render bbox/text on top of the input video.
   * Create components for the rendering */
  nvvidconv_osd = gst_element_factory_make ("nvvideoconvert", "nvvidconv_osd");
  osd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
  /* Create components for the output */
  if (output_mp4) {
    /* If output file is set, then create components for encoding and exporting to mp4 file */
    queue_sink = gst_element_factory_make ("queue", "queue_sink");
    nvvidconv_sink = gst_element_factory_make ("nvvideoconvert", "nvvidconv_sink");
    filter_sink = gst_element_factory_make ("capsfilter", "filter_sink");
    caps_filter_sink = gst_caps_from_string ("video/x-raw, format=I420");
    g_object_set (G_OBJECT (filter_sink), "caps", caps_filter_sink, NULL);
    gst_caps_unref (caps_filter_sink);
    videoconvert = gst_element_factory_make ("videoconvert", "videoconverter");
    encoder = gst_element_factory_make ("avenc_mpeg4", "mp4-encoder");
    g_object_set (G_OBJECT (encoder), "bitrate", 1000000, NULL);
    muxer = gst_element_factory_make ("qtmux", "muxer");
    sink = gst_element_factory_make ("filesink", "nvvideo-renderer");
    g_object_set (G_OBJECT (sink), "location", output_mp4, NULL);
  } else {
  	/* If output file is not set, use on-screen display as output */
    transform = gst_element_factory_make ("nvegltransform", "nvegl-transform");
    if(!transform) {
      g_printerr ("One tegra element could not be created. Exiting.\n");
      return -1;
    sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
    g_object_set (sink, "sync", FALSE, "max-lateness", -1,
      "async", FALSE, "qos", TRUE, NULL);
#else
    if (input_mp4) {
    	g_object_set (sink, "sync", TRUE, NULL);
#endif
  /* Check all components */
  if (!pipeline || !source || !video_full_processing_bin
      || !queue_pgie || !pgie || !nvvidconv_osd
      || !osd || !sink) {
    g_printerr ("One element could not be created. Exiting.\n");
    return -1;
  /* we add a message handler */
  bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
  bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
  gst_object_unref (bus);
  /* Set up the pipeline */
  gst_bin_add_many (GST_BIN (video_full_processing_bin), streammux,
      queue_pgie, pgie, nvvidconv_osd, osd, NULL);
  /* link the elements together */
  gst_element_link_many (streammux, queue_pgie, pgie, nvvidconv_osd, osd,
      NULL);
  gst_element_add_pad (video_full_processing_bin, gst_ghost_pad_new ("sink",
          videopad));
  gst_bin_add (GST_BIN (pipeline), video_full_processing_bin);
  /* link soure and video_full_processing_bin */
  if (!input_mp4){
    GstPad *sinkpad, *srcpad;
    sinkpad = gst_element_get_static_pad (video_full_processing_bin, "sink");
    if (!sinkpad) {
      g_printerr ("video_full_processing_bin request sink pad failed. Exiting.\n");
      return -1;
    srcpad = gst_element_get_static_pad (filter_src, "src");
    if (!srcpad) {
      g_printerr ("filter_src request src pad failed. Exiting.\n");
      return -1;
    if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
        g_printerr ("Failed to link pads. Exiting.\n");
        return -1;
    gst_object_unref (sinkpad);
    gst_object_unref (srcpad);
  if (output_mp4) {
        queue_sink, nvvidconv_sink, filter_sink, videoconvert, encoder, muxer,
        sink, NULL);
    gst_element_link_many (osd, queue_sink, nvvidconv_sink, filter_sink,
        videoconvert, encoder, muxer, sink, NULL);
  } else {
    gst_bin_add_many (GST_BIN (video_full_processing_bin), transform, sink, NULL);
    gst_element_link_many (osd, transform , sink, NULL);
#else
    gst_bin_add_many (GST_BIN (video_full_processing_bin), sink, NULL);
    gst_element_link (osd, sink);
#endif
  /* add probe to get informed of the meta data generated, we add probe to
   * the sink pad of the osd element, since by that time, the buffer would have
   * had got all the metadata. */
  osd_sink_pad = gst_element_get_static_pad (osd, "sink");
  if (!osd_sink_pad)
    g_print ("Unable to get sink pad\n");
  else
    osd_probe_id = gst_pad_add_probe (osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
        osd_sink_pad_buffer_probe, NULL, NULL);
  /* Set the pipeline to "playing" state */
  if (input_mp4) {
  	g_print ("Now playing: %s\n", input_mp4);
  } else {
  	g_print ("Now playing from webcam\n");
  gst_element_set_state (pipeline, GST_STATE_PLAYING);
  /* Wait till pipeline encounters an error or EOS */
  g_main_loop_run (loop);
  /* Out of the main loop, clean up nicely */
  g_print ("Returned, stopping playback\n");
  gst_element_set_state (pipeline, GST_STATE_NULL);
  g_print ("Deleting pipeline\n");
  gst_object_unref (GST_OBJECT (pipeline));
  g_source_remove (bus_watch_id);
  g_main_loop_unref (loop);
  return 0;
can anyone suggest where I am wrong please…
Thanks in advanced.
Do you use Jetson platforms or desktop GPU(x86 PC)?
hello,
I am using desktop GPU(NVIDIA GTX 2080TI)
and also jetson nano but on both i am getting similar issue.
Please help me out to resolve this.
On Jetson Nano, you can try
gst-launch-1.0 uri=rtsp://192.168.1.201:554/user=admin&password=&channel=1&stream=0.sdp?real_stram ! nvoverlaysink
If it is working, you can use uridecodebin in the code.
uridecodebing is used in deepstream-test3. You may refer to the code.
Thank you for your response,
I will try this solution also but I have resolved problem by using weights of redaction app in deep stream app. updated the source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt config file and run with deep stream app it is giving detection as well as tracking of faces on rtsp.
