x86 Machine with dGPU
• DeepStream Version : deepstream-7.0
• TensorRT Version: 8.6.1.
• NVIDIA GPU Driver Version (valid for GPU only) : Driver Version: 535.86.10 CUDA Version: 12.2
• Issue Type: questions
Using newstreammux=yes
Hello everyone,
I’m currently working on a video analytics system using DeepStreamSDK 7.0 with Python 3.10 and Gst-python. In my setup, I’m integrating NVIDIA Triton Inference Server (optional) for inference, with frame reading handled via a Python backend.
I’ve encountered an issue where video artifacts appear only when processing RTSP streams using nvurisrcbin. Interestingly, this problem does not occur when using MP4 files as input. Furthermore, when I switch from nvurisrcbin to uridecodebin on the same RTSP channel, the artifacts disappear.
Here are the sample artifacts, the middle one is mp4.
Has anyone faced a similar issue? I’m wondering if there’s a configuration or pipeline element I’m missing that could resolve this.
Here’s a snippet of my code for reference:
#!/usr/bin/env python3
# SPDX-FileCopyrightText: Copyright (c) 2019-2023 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: Apache-2.0
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
import sys
sys.path.append('../')
from pathlib import Path
import gi
import configparser
import argparse
gi.require_version('Gst', '1.0')
from gi.repository import GLib, Gst
from ctypes import *
import time
import sys
import math
import platform
from common.is_aarch_64 import is_aarch64
from common.FPS import PERF_DATA
from ssd_parser import nvds_infer_parse_custom_tf_ssd, DetectionParam, NmsParam, BoxSizeParam
import os
import pyds
import pickle
import socket
from queue import Queue
import threading
import numpy as np
import logging
import traceback
import json
logging.basicConfig(
filename='app.log', # Specify the file name
filemode='a', # Append mode
format='%(asctime)s - %(name)s - %(levelname)s - %(message)s', # Log format
level=logging.INFO # Set the logging level
# Get a logger instance
FILE_LOGGER = logging.getLogger('FILE_LOGGER')
no_display = False
silent = False
file_loop = False
perf_data = None
MAX_DISPLAY_LEN=64
PGIE_CLASS_ID_VEHICLE = 0
PGIE_CLASS_ID_BICYCLE = 1
PGIE_CLASS_ID_PERSON = 2
PGIE_CLASS_ID_ROADSIGN = 3
MUXER_OUTPUT_WIDTH=1920
MUXER_OUTPUT_HEIGHT=1080
MUXER_BATCH_TIMEOUT_USEC = 33000
TILED_OUTPUT_WIDTH=1280
TILED_OUTPUT_HEIGHT=720
GST_CAPS_FEATURES_NVMM="memory:NVMM"
OSD_PROCESS_MODE= 0
OSD_DISPLAY_TEXT= 1
pgie_classes_str= ["Vehicle", "TwoWheeler", "Person","RoadSign"]
MAX_DISPLAY_LEN = 64
MUXER_OUTPUT_WIDTH = 1920
MUXER_OUTPUT_HEIGHT = 1080
MUXER_BATCH_TIMEOUT_USEC = 4000000
TILED_OUTPUT_WIDTH = 1280
TILED_OUTPUT_HEIGHT = 720
GST_CAPS_FEATURES_NVMM = "memory:NVMM"
OSD_PROCESS_MODE = 0
OSD_DISPLAY_TEXT = 0
pgie_classes_str = ["Vehicle", "TwoWheeler", "Person", "RoadSign"]
CLASS_NB = 91
ACCURACY_ALL_CLASS = 0.5
UNTRACKED_OBJECT_ID = 0xffffffffffffffff
IMAGE_HEIGHT = 1080
IMAGE_WIDTH = 1920
MIN_BOX_WIDTH = 32
MIN_BOX_HEIGHT = 32
TOP_K = 20
IOU_THRESHOLD = 0.3
OUTPUT_VIDEO_NAME = "./out.mp4"
MAX_NUM_SOURCES = 3
class TCPConnectionThread(threading.Thread):
def __init__(self, host, port):
super().__init__()
self.host = host
self.port = port
self.queue = Queue(maxsize=100)
self.stop_event = threading.Event()
self.sock = None
def connect(self):
while not self.stop_event.is_set():
try:
self.sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
self.sock.connect((self.host, self.port))
return True
except Exception as e:
print("From DS-7 pipeline- Error connecting:", e)
time.sleep(1) # Retry after 1 second
return False
def run(self):
if not self.sock:
if not self.connect():
# If unable to connect, wait before retrying
time.sleep(1)
continue
try:
if not self.queue.empty():
data = self.queue.get()
# Pickle the data
serialized_data = pickle.dumps(data)
# Calculate the length of the data
data_length = len(serialized_data)
# Convert data length to bytes (4 bytes for an integer)
length_bytes = data_length.to_bytes(4, byteorder='big')
# Send the length of the data
self.sock.sendall(length_bytes)
# Send the data
self.sock.sendall(serialized_data)
else:
time.sleep(0.1) # Sleep briefly to avoid busy waiting
print("Error sending data:", e)
self.sock.close()
self.sock = None
def stop(self):
self.stop_event.set()
if self.sock:
self.sock.close()
def send_message(self, obj):
try:
self.queue.put(obj,block=False)
pass
def get_label_names_from_file(filepath):
""" Read a label file and convert it to string list """
labels = "connected components"
return labels
def osd_sink_pad_buffer_probe(pad, info, u_data):
frame_number = 0
# Intiallizing object counter with 0.
obj_counter = dict(enumerate([0] * CLASS_NB))
num_rects = 0
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
# Retrieve batch metadata from the gst_buffer
# Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
# C address of gst_buffer as input, which is obtained with hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
except StopIteration:
break
frame_number = frame_meta.frame_num
num_rects = frame_meta.num_obj_meta
l_obj = frame_meta.obj_meta_list
while l_obj is not None:
try:
# Casting l_obj.data to pyds.NvDsObjectMeta
obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
break
obj_counter[obj_meta.class_id] += 1
try:
l_obj = l_obj.next
break
# Acquiring a display meta object. The memory ownership remains in
# the C code so downstream plugins can still access it. Otherwise
# the garbage collector will claim it when this probe function exits.
display_meta = pyds.nvds_acquire_display_meta_from_pool(batch_meta)
display_meta.num_labels = 1
py_nvosd_text_params = display_meta.text_params[0]
# Setting display text to be shown on screen
# Note that the pyds module allocates a buffer for the string, and the
# memory will not be claimed by the garbage collector.
# Reading the display_text field here will return the C address of the
# allocated string. Use pyds.get_string() to get the string content.
id_dict = {
val: index
for index, val in enumerate(get_label_names_from_file("labels.txt"))
disp_string = "Frame Number={} Number of Objects={} Vehicle_count={} Person_count={}"
py_nvosd_text_params.display_text = disp_string.format(
frame_number,
num_rects,
obj_counter[id_dict["car"]],
obj_counter[id_dict["person"]],
# Now set the offsets where the string should appear
py_nvosd_text_params.x_offset = 10
py_nvosd_text_params.y_offset = 12
# Font , font-color and font-size
py_nvosd_text_params.font_params.font_name = "Serif"
py_nvosd_text_params.font_params.font_size = 10
# set(red, green, blue, alpha); set to White
py_nvosd_text_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
# Text background color
py_nvosd_text_params.set_bg_clr = 1
# set(red, green, blue, alpha); set to Black
py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
# Using pyds.get_string() to get display_text as string
print(pyds.get_string(py_nvosd_text_params.display_text))
pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
try:
l_frame = l_frame.next
break
return Gst.PadProbeReturn.OK
def add_obj_meta_to_frame(frame_object, batch_meta, frame_meta, label_names):
""" Inserts an object into the metadata """
# this is a good place to insert objects into the metadata.
# Here's an example of inserting a single object.
obj_meta = pyds.nvds_acquire_obj_meta_from_pool(batch_meta)
# Set bbox properties. These are in input resolution.
rect_params = obj_meta.rect_params
rect_params.left = int(frame_object.left)
rect_params.top = int(frame_object.top)
rect_params.width = int(frame_object.width)
rect_params.height = int(frame_object.height)
# print(rect_params.height)
# Semi-transparent yellow backgroud
rect_params.has_bg_color = 0
rect_params.bg_color.set(1, 1, 0, 0.4)
# Red border of width 3
rect_params.border_width = 3
rect_params.border_color.set(1, 0, 0, 1)
# Set object info including class, detection confidence, etc.
obj_meta.confidence = frame_object.detectionConfidence
obj_meta.class_id = frame_object.classId
# There is no tracking ID upon detection. The tracker will
# assign an ID.
obj_meta.object_id = UNTRACKED_OBJECT_ID
lbl_id = frame_object.classId
if lbl_id >= len(label_names):
lbl_id = 0
# Set the object classification label.
obj_meta.obj_label = label_names[lbl_id]
# Set display text for the object.
txt_params = obj_meta.text_params
if txt_params.display_text:
pyds.free_buffer(txt_params.display_text)
txt_params.x_offset = int(rect_params.left)
txt_params.y_offset = max(0, int(rect_params.top) - 10)
txt_params.display_text = (
label_names[lbl_id] + " " + "{:04.3f}".format(frame_object.detectionConfidence)
txt_params.font_params.font_name = "Serif"
txt_params.font_params.font_size = 10
txt_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
txt_params.set_bg_clr = 1
txt_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
# Inser the object into current frame meta
# This object has no parent
pyds.nvds_add_obj_meta_to_frame(frame_meta, obj_meta, None)
def pgie_sink_pad_buffer_probe(pad, info, u_data,q,c,t0):
#print(['Data_Probed',time.ctime()]) # c+=1
# print(['from sink probes ',c,(time.time()-t0)//c])
ordered_dict = OrderedDict()
# print("\n\n")
if not gst_buffer:
return
try:
# it alone.
source_id = frame_meta.source_id
# print(f"frame number sending from sink pad={frame_number}")
if source_id not in ordered_dict:
ordered_dict[source_id]=[time.time(),frame_number]
break
#print(ordered_dict)
# Define the host and port of the server
host = 'localhost'
port = 12345
# q.put(ordered_dict, host, port)
def pgie_src_pad_buffer_probe(pad, info, u_data,connection_thread):
if not gst_buffer:
return
detection_params = DetectionParam(CLASS_NB, ACCURACY_ALL_CLASS)
box_size_param = BoxSizeParam(IMAGE_HEIGHT, IMAGE_WIDTH,
MIN_BOX_WIDTH, MIN_BOX_HEIGHT)
nms_param = NmsParam(TOP_K, IOU_THRESHOLD)
label_names = get_label_names_from_file("labels.txt")
source_id_list=[]
try:
# it alone.
source_id_list.append(source_id)
# print(f"source is is {source_id}")
break
l_user = frame_meta.frame_user_meta_list
while l_user is not None:
try:
# Note that l_user.data needs a cast to pyds.NvDsUserMeta
# it alone.
user_meta = pyds.NvDsUserMeta.cast(l_user.data)
break
if (
user_meta.base_meta.meta_type
!= pyds.NvDsMetaType.NVDSINFER_TENSOR_OUTPUT_META
continue
tensor_meta = pyds.NvDsInferTensorMeta.cast(user_meta.user_meta_data)
# Boxes in the tensor meta should be in network resolution which is
# found in tensor_meta.network_info. Use this info to scale boxes to
# the input frame resolution.
layers_info = []
for i in range(tensor_meta.num_output_layers):
layer = pyds.get_nvds_LayerInfo(tensor_meta, i)
layers_info.append(layer)
frame_object_list = nvds_infer_parse_custom_tf_ssd(
layers_info, detection_params, box_size_param, nms_param
try:
l_user = l_user.next
break
for frame_object in frame_object_list:
try:
# indicate inference is performed on the frame
frame_meta.bInferDone = True
break
connection_thread.send_message(np.array(source_id_list))
def cb_newpad(decodebin, decoder_src_pad,data):
print("In cb_newpad\n")
caps=decoder_src_pad.get_current_caps()
if not caps:
caps = decoder_src_pad.query_caps()
gststruct=caps.get_structure(0)
gstname=gststruct.get_name()
source_bin=data
features=caps.get_features(0)
# Need to check if the pad created by the decodebin is for video and not
# audio.
print("gstname=",gstname)
if(gstname.find("video")!=-1):
# Link the decodebin pad only if decodebin has picked nvidia
# decoder plugin nvdec_*. We do this by checking if the pad caps contain
# NVMM memory features.
print("features=",features)
if features.contains("memory:NVMM"):
# Get the source bin ghost pad
bin_ghost_pad=source_bin.get_static_pad("src")
if not bin_ghost_pad.set_target(decoder_src_pad):
sys.stderr.write("Failed to link decoder src pad to source bin ghost pad\n")
else:
sys.stderr.write(" Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy,Object,name,user_data):
print("Decodebin child added:", name, "\n")
if(name.find("decodebin") != -1):
Object.connect("child-added",decodebin_child_added,user_data)
if "source" in name:
source_element = child_proxy.get_by_name("source")
if source_element.find_property('drop-on-latency') != None:
Object.set_property("drop-on-latency", True)
def create_source_bin(index,uri):
print("Creating source bin")
# Create a source GstBin to abstract this bin's content from the rest of the
# pipeline
bin_name="source-bin-%02d" %index
print(bin_name)
nbin=Gst.Bin.new(bin_name)
if not nbin:
sys.stderr.write(" Unable to create source bin \n")
# Source element for reading from the uri.
# We will use decodebin and let it figure out the container format of the
# stream and the codec and plug the appropriate demux and decode plugins.
if file_loop:
# use nvurisrcbin to enable file-loop
uri_decode_bin=Gst.ElementFactory.make("nvurisrcbin", "uri-decode-bin")
uri_decode_bin.set_property("file-loop", 1)
uri_decode_bin.set_property("rtsp-reconnect-interval", 10)
uri_decode_bin.set_property("rtsp-reconnect-attempts", 2160)
# uri_decode_bin.set_property("cudadec-memtype", 2)
else:
uri_decode_bin=Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
if not uri_decode_bin:
sys.stderr.write(" Unable to create uri decode bin \n")
# We set the input uri to the source element
uri_decode_bin.set_property("uri",uri)
# Connect to the "pad-added" signal of the decodebin which generates a
# callback once a new pad for raw data has beed created by the decodebin
uri_decode_bin.connect("pad-added",cb_newpad,nbin)
uri_decode_bin.connect("child-added",decodebin_child_added,nbin)
# We need to create a ghost pad for the source bin which will act as a proxy
# for the video decoder src pad. The ghost pad will not have a target right
# now. Once the decode bin creates the video decoder and generates the
# cb_newpad callback, we will set the ghost pad target to the video decoder
# src pad.
Gst.Bin.add(nbin,uri_decode_bin)
bin_pad=nbin.add_pad(Gst.GhostPad.new_no_target("src",Gst.PadDirection.SRC))
if not bin_pad:
sys.stderr.write(" Failed to add ghost pad in source bin \n")
return None
return nbin
def kill_the_pipeline(loop,pipeline,connection_thread):
pipeline.set_state(Gst.State.NULL)
connection_thread.stop()
loop.quit()
sys.exit(1)
def bus_call(bus, message, loop,pipeline,connection_thread):
This is call back from gstreamer
This method takes 1 parameter and access the messages that is posted on pipeline's bus.
:param loop: this is added from mainloop so that u can kill the loop to kill entire pipeline from messges
:return: None
t = message.type
if t == Gst.MessageType.EOS:
sys.stdout.write("End-of-stream\n")
FILE_LOGGER.info("I am here at the EOS part")
FILE_LOGGER.error(f"The EOS recieved from the triton Pipeline, Exiting the application")
elif t==Gst.MessageType.WARNING:
err, debug = message.parse_warning()
FILE_LOGGER.warning(f"Warning: {err}: {debug}")
elif t == Gst.MessageType.ERROR:
err, debug = message.parse_error()
FILE_LOGGER.error(f"Error: {err}: {debug}")
print(f"Error: {err}: {debug}")
src_element = message.src
parent_obj = src_element.get_parent()
if parent_obj:
try:
parent_obj_name = parent_obj.name
FILE_LOGGER.info(f"parent object name is {parent_obj_name}")
print(f"parent object name is {parent_obj.name}")
# kill_the_pipeline(loop,pipeline,connection_thread)
FILE_LOGGER.info(traceback.print_exc())
print("Error! exiting the app ")
FILE_LOGGER.error("Error! exiting the app ",exc_info=True)
elif t == Gst.MessageType.ELEMENT:
struct = message.get_structure()
#Check for stream-eos message
if struct is not None and struct.has_name("stream-eos"):
parsed, stream_id = struct.get_uint("stream-id")
if parsed:
#Set eos status of stream to True, to be deleted in delete-sources
print("Got EOS from stream %d" % stream_id)
FILE_LOGGER.info("Got EOS from stream %d" % stream_id)
# Uncomment the below code if you need to restart the entire system
return True
def main(args, requested_pgie=None, config=None, disable_probe=False):
host = '127.0.0.1'
port = 54321
connection_thread = TCPConnectionThread(host, port)
connection_thread.start()
#connection_thread.send_message(stats)
global perf_data
perf_data = PERF_DATA(len(args))
number_sources=len(args)
# Standard GStreamer initialization
Gst.init(None)
# Create gstreamer elements */
# Create Pipeline element that will form a connection of other elements
print("Creating Pipeline \n ")
pipeline = Gst.Pipeline()
is_live = False
if not pipeline:
sys.stderr.write(" Unable to create Pipeline \n")
print("Creating streamux \n ")
# Create nvstreammux instance to form batches from one or more sources.
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
if not streammux:
sys.stderr.write(" Unable to create NvStreamMux \n")
pipeline.add(streammux)
for i in range(number_sources):
print("Creating source_bin ",i," \n ")
uri_name=args[i]
if uri_name.find("rtsp://") == 0 :
is_live = True
source_bin=create_source_bin(i, uri_name)
if not source_bin:
sys.stderr.write("Unable to create source bin \n")
pipeline.add(source_bin)
padname="sink_%u" %i
sinkpad= streammux.get_request_pad(padname)
if not sinkpad:
sys.stderr.write("Unable to create sink pad bin \n")
srcpad=source_bin.get_static_pad("src")
if not srcpad:
sys.stderr.write("Unable to create src pad bin \n")
srcpad.link(sinkpad)
queue1=Gst.ElementFactory.make("queue","queue1")
queue2=Gst.ElementFactory.make("queue","queue2")
queue3=Gst.ElementFactory.make("queue","queue3")
queue4=Gst.ElementFactory.make("queue","queue4")
queue5=Gst.ElementFactory.make("queue","queue5")
pipeline.add(queue1)
pipeline.add(queue2)
pipeline.add(queue3)
pipeline.add(queue4)
pipeline.add(queue5)
nvdslogger = None
print("Creating Pgie \n ")
if True :
pgie = Gst.ElementFactory.make("nvinferserver", "primary-inference")
# elif requested_pgie != None and requested_pgie == 'nvinfer':
# pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
# else:
if not pgie:
sys.stderr.write(" Unable to create pgie : %s\n" % requested_pgie)
if disable_probe:
# Use nvdslogger for perf measurement instead of probe function
print ("Creating nvdslogger \n")
nvdslogger = Gst.ElementFactory.make("nvdslogger", "nvdslogger")
print("Creating tiler \n ")
tiler=Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
if not tiler:
sys.stderr.write(" Unable to create tiler \n")
print("Creating nvvidconv \n ")
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
if not nvvidconv:
sys.stderr.write(" Unable to create nvvidconv \n")
print("Creating nvosd \n ")
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
if not nvosd:
sys.stderr.write(" Unable to create nvosd \n")
nvosd.set_property('process-mode',OSD_PROCESS_MODE)
nvosd.set_property('display-text',OSD_DISPLAY_TEXT)
if file_loop:
if is_aarch64():
# Set nvbuf-memory-type=4 for aarch64 for file-loop (nvurisrcbin case)
streammux.set_property('nvbuf-memory-type', 4)
else:
# Set nvbuf-memory-type=2 for x86 for file-loop (nvurisrcbin case)
streammux.set_property('nvbuf-memory-type', 1)
pass
if no_display:
print("Creating Fakesink \n")
sink = Gst.ElementFactory.make("fakesink", "fakesink")
sink.set_property('enable-last-sample', 0)
sink.set_property('sync', 0)
else:
if is_aarch64():
print("Creating nv3dsink \n")
sink = Gst.ElementFactory.make("nv3dsink", "nv3d-sink")
if not sink:
sys.stderr.write(" Unable to create nv3dsink \n")
else:
print("Creating EGLSink \n")
sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
if not sink:
sys.stderr.write(" Unable to create egl sink \n")
if not sink:
sys.stderr.write(" Unable to create sink element \n")
# if is_live:
# print("At least one of the sources is live")
# streammux.set_property('live-source', 1)
if os.environ["USE_NEW_NVSTREAMMUX"]=="yes":
streammux.set_property("config-file-path", "/opt/nvidia/deepstream/deepstream-7.0/sources/src/streammux.txt")
streammux.set_property("batch-size", 30)
print("###################Using the new SteramMUX########################\n\n\n\n")
else:
streammux.set_property("batched-push-timeout", 25000)
streammux.set_property("width", 640) #640 3840
streammux.set_property("height", 480) #480 2160
streammux.set_property('batched-push-timeout', MUXER_BATCH_TIMEOUT_USEC)
if requested_pgie == "nvinferserver" and config != None:
pgie.set_property('config-file-path', config)
elif requested_pgie == "nvinferserver-grpc" and config != None:
elif requested_pgie == "nvinfer" and config != None:
else:
#pgie.set_property('config-file-path', "/opt/nvidia/deepstream/deepstream-7.0/sources/src/dstest1_pgie_inferserver_config_fake_1080.txt") # dstest1_pgie_inferserver_config_torch_resnet50.txt
# pgie.set_property('config-file-path', "/opt/nvidia/deepstream/deepstream-7.0/sources/src/dstest1_pgie_inferserver_config_fake_640_10.txt") # dstest1_pgie_inferserver_config_torch_resnet50.txt
print('########################################OK')
# pgie.set_property('config-file-path', "/opt/nvidia/deepstream/deepstream-7.0/sources/src/dstest1_pgie_inferserver_config_torch_resnet50.txt")
pgie_batch_size=pgie.get_property("batch-size")
if(pgie_batch_size != number_sources):
print("WARNING: Overriding infer-config batch-size",pgie_batch_size," with number of sources ", number_sources," \n")
pgie.set_property("batch-size",number_sources)
tiler_rows=int(math.sqrt(number_sources))
tiler_columns=int(math.ceil((1.0*number_sources)/tiler_rows))
tiler.set_property("rows",tiler_rows)
tiler.set_property("columns",tiler_columns)
tiler.set_property("width", TILED_OUTPUT_WIDTH)
tiler.set_property("height", TILED_OUTPUT_HEIGHT)
sink.set_property("qos",0)
print("Adding elements to Pipeline \n")
# pipeline.add(pgie)
if nvdslogger:
pipeline.add(nvdslogger)
pipeline.add(tiler)
pipeline.add(nvvidconv)
pipeline.add(nvosd)
pipeline.add(sink)
print("Linking elements in the Pipeline \n")
streammux.link(queue1)
# queue1.link(pgie)
queue1.link(queue2)
if nvdslogger:
queue2.link(nvdslogger)
nvdslogger.link(tiler)
else:
queue2.link(tiler)
tiler.link(queue3)
queue3.link(nvvidconv)
nvvidconv.link(queue4)
queue4.link(nvosd)
nvosd.link(queue5)
queue5.link(sink)
# create an event loop and feed gstreamer bus mesages to it
loop = GLib.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect ("message", bus_call, loop,pipeline,connection_thread)
pgie_src_pad=pgie.get_static_pad("src")
if not pgie_src_pad:
sys.stderr.write(" Unable to get src pad \n")
else:
if not disable_probe:
pgie_src_pad.add_probe(Gst.PadProbeType.BUFFER, pgie_src_pad_buffer_probe, 0,connection_thread)
# perf callback function to print fps every 5 sec
# GLib.timeout_add(5000, perf_data.perf_print_callback)
# List the sources
print("Now playing...")
for i, source in enumerate(args):
print(i, ": ", source)
print("Starting pipeline \n")
# start play back and listed to events
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
# cleanup
print("Exiting app\n")
def parse_args():
parser = argparse.ArgumentParser(prog="deepstream_test_3",
description="deepstream-test3 multi stream, multi model inference reference app")
# parser.add_argument(
# "-i",
# "--input",
# help="Path to input streams",
# nargs="+",
# metavar="URIs",
# default=["a"],
# required=True,
# "-c",
# "--configfile",
# metavar="config_location.txt",
# default=None,
# help="Choose the config-file to be used with specified pgie",
# "-g",
# "--pgie",
# default=None,
# help="Choose Primary GPU Inference Engine",
# choices=["nvinfer", "nvinferserver", "nvinferserver-grpc"],
# "--no-display",
# action="store_true",
# default=False,
# dest='no_display',
# help="Disable display of video output",
# "--file-loop",
# default=False,
# dest='file_loop',
# help="Loop the input file sources after EOS",
# "--disable-probe",
# default=False,
# dest='disable_probe',
# help="Disable the probe function and use nvdslogger for FPS",
# "-s",
# "--silent",
# default=False,
# dest='silent',
# help="Disable verbose output",
# # Check input arguments
# # if len(sys.argv) == 1:
# # parser.print_help(sys.stderr)
# # sys.exit(1)
# args = parser.parse_args()
# # stream_paths = args.input
# pgie = args.pgie
# config = args.configfile
# disable_probe = args.disable_probe
global no_display
global silent
global file_loop
pgie = None
config = None
disable_probe = False
# no_display = args.no_display
# silent = args.silent
# file_loop = args.file_loop
# if config and not pgie or pgie and not config:
# sys.stderr.write ("\nEither pgie or configfile is missing. Please specify both! Exiting...\n\n\n\n")
# parser.print_help()
# sys.exit(1)
# if config:
# config_path = Path(config)
# if not config_path.is_file():
# sys.stderr.write ("Specified config-file: %s doesn't exist. Exiting...\n\n" % config)
# sys.exit(1)
# print(vars(args))
return pgie, config, disable_probe
def write_json(D,filename):
with open(filename, 'w') as f:
json.dump(D, f, indent=4)
def read_json(filename):
with open(filename, 'r') as f:
D = json.load(f)
return D
def save_dict(di_, filename_):
with open(filename_, 'wb') as f:
pickle.dump(di_, f)
def load_dict(filename_):
with open(filename_, 'rb') as f:
ret_di = pickle.load(f)
return ret_di
def extract_addresses(cam_list):
addresses = []
if isinstance(cam_list[0], dict):
for key, cam in cam_list[0].items():
if isinstance(cam, dict) and 'Address' in cam:
addresses.append(cam['Address'])
return addresses
if __name__ == '__main__':
root_directory = '/opt/nvidia/deepstream/deepstream-7.0/sources/src/SP2023'
FILE_LOGGER.info("root dir is read as {}".format(root_directory))
Meta_File = os.path.join(root_directory, "Config/Meta.json")
Config_File = os.path.join(root_directory, "Config/Config.pkl")
meta_params = read_json(Meta_File)
Config=load_dict(Config_File)
list_of_cams = []
for key in Config:
if key != 'Set':
list_of_cams.append(Config[key])
stream_paths = extract_addresses(list_of_cams)
pgie, config, disable_probe = parse_args()
stream_paths = ['rtsp://localhost:554/video1',
'file:///opt/nvidia/deepstream/deepstream-7.0/sources/src/2.mp4',
'rtsp://192.168.1.6:8555/video1']
sys.exit(main(stream_paths, pgie, config, disable_probe))
streammux.txt
[property]
algorithm-type=2
batch-size=2
max-fps-control=1
overall-max-fps-n=20
overall-max-fps-d=1
overall-min-fps-n=20
overall-min-fps-d=1
max-same-source-frames=1
If anyone has insights or suggestions on what might be causing these artifacts and how to fix them, I would greatly appreciate your help!
Thank you in advance.
