Jetson Xavier NX
• DeepStream Version
6.1
5.0.2
In order to send count data to Azure, I am trying to integrate deepstream-test4 and deepstream-nvdsanalytics with python binding.
Could you tell me how to include the count data in user_meta into the message?
Thank you for your support in advance.
Here is my code
#!/usr/bin/env python3
# SPDX-FileCopyrightText: Copyright (c) 2020-2021 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: Apache-2.0
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
import sys
sys.path.append('../')
import gi
import configparser
gi.require_version('Gst', '1.0')
from gi.repository import GLib, Gst
from ctypes import *
import time
import sys
import math
import platform
from optparse import OptionParser
from common.is_aarch_64 import is_aarch64
from common.bus_call import bus_call
from common.utils import long_to_uint64
from common.FPS import PERF_DATA
import pyds
perf_data = None
MAX_DISPLAY_LEN = 64
MAX_TIME_STAMP_LEN = 32
PGIE_CLASS_ID_VEHICLE = 0
PGIE_CLASS_ID_BICYCLE = 1
PGIE_CLASS_ID_PERSON = 2
PGIE_CLASS_ID_ROADSIGN = 3
MUXER_OUTPUT_WIDTH = 1920
MUXER_OUTPUT_HEIGHT = 1080
MUXER_BATCH_TIMEOUT_USEC = 4000000
TILED_OUTPUT_WIDTH = 1280
TILED_OUTPUT_HEIGHT = 720
GST_CAPS_FEATURES_NVMM = "memory:NVMM"
OSD_PROCESS_MODE= 0
OSD_DISPLAY_TEXT= 1
pgie_classes_str= ["Vehicle", "TwoWheeler", "Person","RoadSign"]
input_file = None
schema_type = 0
proto_lib = None
conn_str = "localhost;2181;testTopic"
cfg_file = "cfg_azure.txt"
topic = None
no_display = False
PGIE_CONFIG_FILE = "dstest4_pgie_config.txt"
MSCONV_CONFIG_FILE = "dstest4_msgconv_config.txt"
# Callback function for deep-copying an NvDsEventMsgMeta struct
def meta_copy_func(data, user_data):
# Cast data to pyds.NvDsUserMeta
user_meta = pyds.NvDsUserMeta.cast(data)
src_meta_data = user_meta.user_meta_data
# Cast src_meta_data to pyds.NvDsEventMsgMeta
srcmeta = pyds.NvDsEventMsgMeta.cast(src_meta_data)
# Duplicate the memory contents of srcmeta to dstmeta
# First use pyds.get_ptr() to get the C address of srcmeta, then
# use pyds.memdup() to allocate dstmeta and copy srcmeta into it.
# pyds.memdup returns C address of the allocated duplicate.
dstmeta_ptr = pyds.memdup(pyds.get_ptr(srcmeta),
sys.getsizeof(pyds.NvDsEventMsgMeta))
# Cast the duplicated memory to pyds.NvDsEventMsgMeta
dstmeta = pyds.NvDsEventMsgMeta.cast(dstmeta_ptr)
# Duplicate contents of ts field. Note that reading srcmeat.ts
# returns its C address. This allows to memory operations to be
# performed on it.
dstmeta.ts = pyds.memdup(srcmeta.ts, MAX_TIME_STAMP_LEN + 1)
# Copy the sensorStr. This field is a string property. The getter (read)
# returns its C address. The setter (write) takes string as input,
# allocates a string buffer and copies the input string into it.
# pyds.get_string() takes C address of a string and returns the reference
# to a string object and the assignment inside the binder copies content.
dstmeta.sensorStr = pyds.get_string(srcmeta.sensorStr)
if srcmeta.objSignature.size > 0:
dstmeta.objSignature.signature = pyds.memdup(
srcmeta.objSignature.signature, srcmeta.objSignature.size)
dstmeta.objSignature.size = srcmeta.objSignature.size
if srcmeta.extMsgSize > 0:
if srcmeta.objType == pyds.NvDsObjectType.NVDS_OBJECT_TYPE_VEHICLE:
srcobj = pyds.NvDsVehicleObject.cast(srcmeta.extMsg)
obj = pyds.alloc_nvds_vehicle_object()
obj.type = pyds.get_string(srcobj.type)
obj.make = pyds.get_string(srcobj.make)
obj.model = pyds.get_string(srcobj.model)
obj.color = pyds.get_string(srcobj.color)
obj.license = pyds.get_string(srcobj.license)
obj.region = pyds.get_string(srcobj.region)
dstmeta.extMsg = obj
dstmeta.extMsgSize = sys.getsizeof(pyds.NvDsVehicleObject)
if srcmeta.objType == pyds.NvDsObjectType.NVDS_OBJECT_TYPE_PERSON:
srcobj = pyds.NvDsPersonObject.cast(srcmeta.extMsg)
obj = pyds.alloc_nvds_person_object()
obj.age = srcobj.age
obj.gender = pyds.get_string(srcobj.gender)
obj.cap = pyds.get_string(srcobj.cap)
obj.hair = pyds.get_string(srcobj.hair)
obj.apparel = pyds.get_string(srcobj.apparel)
return dstmeta
# Callback function for freeing an NvDsEventMsgMeta instance
def meta_free_func(data, user_data):
srcmeta = pyds.NvDsEventMsgMeta.cast(user_meta.user_meta_data)
# pyds.free_buffer takes C address of a buffer and frees the memory
# It's a NOP if the address is NULL
pyds.free_buffer(srcmeta.ts)
pyds.free_buffer(srcmeta.sensorStr)
pyds.free_buffer(srcmeta.objSignature.signature)
srcmeta.objSignature.size = 0
pyds.free_buffer(obj.type)
pyds.free_buffer(obj.color)
pyds.free_buffer(obj.make)
pyds.free_buffer(obj.model)
pyds.free_buffer(obj.license)
pyds.free_buffer(obj.region)
pyds.free_buffer(obj.gender)
pyds.free_buffer(obj.cap)
pyds.free_buffer(obj.hair)
pyds.free_buffer(obj.apparel)
pyds.free_gbuffer(srcmeta.extMsg)
srcmeta.extMsgSize = 0
def generate_vehicle_meta(data):
obj = pyds.NvDsVehicleObject.cast(data)
obj.type = "sedan"
obj.color = "blue"
obj.make = "Bugatti"
obj.model = "M"
obj.license = "XX1234"
obj.region = "CA"
return obj
def generate_person_meta(data):
obj = pyds.NvDsPersonObject.cast(data)
obj.age = 45
obj.cap = "none"
obj.hair = "black"
obj.gender = "male"
obj.apparel = "formal"
return obj
def generate_event_msg_meta(data, class_id):
meta = pyds.NvDsEventMsgMeta.cast(data)
meta.sensorId = 0
meta.placeId = 0
meta.moduleId = 0
meta.sensorStr = "sensor-0"
meta.ts = pyds.alloc_buffer(MAX_TIME_STAMP_LEN + 1)
pyds.generate_ts_rfc3339(meta.ts, MAX_TIME_STAMP_LEN)
# This demonstrates how to attach custom objects.
# Any custom object as per requirement can be generated and attached
# like NvDsVehicleObject / NvDsPersonObject. Then that object should
# be handled in payload generator library (nvmsgconv.cpp) accordingly.
if class_id == PGIE_CLASS_ID_VEHICLE:
meta.type = pyds.NvDsEventType.NVDS_EVENT_MOVING
meta.objType = pyds.NvDsObjectType.NVDS_OBJECT_TYPE_VEHICLE
meta.objClassId = PGIE_CLASS_ID_VEHICLE
obj = generate_vehicle_meta(obj)
meta.extMsg = obj
if class_id == PGIE_CLASS_ID_PERSON:
meta.type = pyds.NvDsEventType.NVDS_EVENT_ENTRY
meta.objType = pyds.NvDsObjectType.NVDS_OBJECT_TYPE_PERSON
meta.objClassId = PGIE_CLASS_ID_PERSON
obj = generate_person_meta(obj)
meta.extMsg = obj
meta.extMsgSize = sys.getsizeof(pyds.NvDsPersonObject)
return meta
# osd_sink_pad_buffer_probe will extract metadata received on OSD sink pad
# and update params for drawing rectangle, object information etc.
# IMPORTANT NOTE:
# a) probe() callbacks are synchronous and thus holds the buffer
# (info.get_buffer()) from traversing the pipeline until user return.
# b) loops inside probe() callback could be costly in python.
# So users shall optimize according to their use-case.
def osd_sink_pad_buffer_probe(pad, info, u_data):
frame_number = 0
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
# Retrieve batch metadata from the gst_buffer
# Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
# C address of gst_buffer as input, which is obtained with hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
if not batch_meta:
return Gst.PadProbeReturn.OK
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.NvDsFrameMeta.cast()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
except StopIteration:
break
is_first_object = True
frame_number = frame_meta.frame_num
l_obj = frame_meta.obj_meta_list
num_rects = frame_meta.num_obj_meta
obj_counter = {
PGIE_CLASS_ID_VEHICLE:0,
PGIE_CLASS_ID_PERSON:0,
PGIE_CLASS_ID_BICYCLE:0,
PGIE_CLASS_ID_ROADSIGN:0
print("#"*50)
while l_obj:
try:
# Casting l_obj.data to pyds.NvDsObjectMeta
obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
break
# Update the object text display
txt_params = obj_meta.text_params
# Set display_text. Any existing display_text string will be
# freed by the bindings module.
txt_params.display_text = pgie_classes_str[obj_meta.class_id]
obj_counter[obj_meta.class_id] += 1
l_user_meta = obj_meta.obj_user_meta_list
# Extract object level meta data from NvDsAnalyticsObjInfo
while l_user_meta:
try:
user_meta = pyds.NvDsUserMeta.cast(l_user_meta.data)
if user_meta.base_meta.meta_type == pyds.nvds_get_user_meta_type("NVIDIA.DSANALYTICSOBJ.USER_META"):
user_meta_data = pyds.NvDsAnalyticsObjInfo.cast(user_meta.user_meta_data)
if user_meta_data.dirStatus: print("Object {0} moving in direction: {1}".format(obj_meta.object_id, user_meta_data.dirStatus))
if user_meta_data.lcStatus: print("Object {0} line crossing status: {1}".format(obj_meta.object_id, user_meta_data.lcStatus))
if user_meta_data.ocStatus: print("Object {0} overcrowding status: {1}".format(obj_meta.object_id, user_meta_data.ocStatus))
if user_meta_data.roiStatus: print("Object {0} roi status: {1}".format(obj_meta.object_id, user_meta_data.roiStatus))
break
try:
l_user_meta = l_user_meta.next
break
try:
l_obj=l_obj.next
break
# Font , font-color and font-size
txt_params.font_params.font_name = "Serif"
txt_params.font_params.font_size = 10
# set(red, green, blue, alpha); set to White
txt_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
# Text background color
txt_params.set_bg_clr = 1
# set(red, green, blue, alpha); set to Black
txt_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
# Ideally NVDS_EVENT_MSG_META should be attached to buffer by the
# component implementing detection / recognition logic.
# Here it demonstrates how to use / attach that meta data.
if is_first_object and (frame_number % 30) == 0:
# Frequency of messages to be send will be based on use case.
# Here message is being sent for first object every 30 frames.
# Allocating an NvDsEventMsgMeta instance and getting
# reference to it. The underlying memory is not manged by
# Python so that downstream plugins can access it. Otherwise
# the garbage collector will free it when this probe exits.
msg_meta = pyds.alloc_nvds_event_msg_meta()
msg_meta.bbox.top = obj_meta.rect_params.top
msg_meta.bbox.left = obj_meta.rect_params.left
msg_meta.bbox.width = obj_meta.rect_params.width
msg_meta.bbox.height = obj_meta.rect_params.height
msg_meta.frameId = frame_number
msg_meta.trackingId = long_to_uint64(obj_meta.object_id)
msg_meta.confidence = obj_meta.confidence
msg_meta = generate_event_msg_meta(msg_meta, obj_meta.class_id)
user_event_meta = pyds.nvds_acquire_user_meta_from_pool(
batch_meta)
if user_event_meta:
user_event_meta.user_meta_data = msg_meta
user_event_meta.base_meta.meta_type = pyds.NvDsMetaType.NVDS_EVENT_MSG_META
# Setting callbacks in the event msg meta. The bindings
# layer will wrap these callables in C functions.
# Currently only one set of callbacks is supported.
pyds.user_copyfunc(user_event_meta, meta_copy_func)
pyds.user_releasefunc(user_event_meta, meta_free_func)
pyds.nvds_add_user_meta_to_frame(frame_meta,
user_event_meta)
else:
print("Error in attaching event meta to buffer\n")
is_first_object = False
# try:
# l_obj = l_obj.next
# except StopIteration:
# break
# try:
# l_frame = l_frame.next
# break
# Get meta data from NvDsAnalyticsFrameMeta
l_user = frame_meta.frame_user_meta_list
while l_user:
try:
user_meta = pyds.NvDsUserMeta.cast(l_user.data)
if user_meta.base_meta.meta_type == pyds.nvds_get_user_meta_type("NVIDIA.DSANALYTICSFRAME.USER_META"):
user_meta_data = pyds.NvDsAnalyticsFrameMeta.cast(user_meta.user_meta_data)
if user_meta_data.objInROIcnt: print("Objs in ROI: {0}".format(user_meta_data.objInROIcnt))
if user_meta_data.objLCCumCnt: print("Linecrossing Cumulative: {0}".format(user_meta_data.objLCCumCnt))
if user_meta_data.objLCCurrCnt: print("Linecrossing Current Frame: {0}".format(user_meta_data.objLCCurrCnt))
if user_meta_data.ocStatus: print("Overcrowding status: {0}".format(user_meta_data.ocStatus))
break
try:
l_user = l_user.next
break
# print("Frame Number =", frame_number, "Vehicle Count =", obj_counter[PGIE_CLASS_ID_VEHICLE], "Person Count =",obj_counter[PGIE_CLASS_ID_PERSON])
print("Frame Number =", frame_number, "stream id=", frame_meta.pad_index, "Number of Objects=",num_rects,"Vehicle Count =", obj_counter[PGIE_CLASS_ID_VEHICLE], "Person Count =",obj_counter[PGIE_CLASS_ID_PERSON])
# Update frame rate through this probe
stream_index = "stream{0}".format(frame_meta.pad_index)
global perf_data
perf_data.update_fps(stream_index)
try:
l_frame=l_frame.next
break
print("#"*50 + '\n')
def cb_newpad(decodebin, decoder_src_pad,data):
print("In cb_newpad\n")
caps=decoder_src_pad.get_current_caps()
gststruct=caps.get_structure(0)
gstname=gststruct.get_name()
source_bin=data
features=caps.get_features(0)
# Need to check if the pad created by the decodebin is for video and not
# audio.
print("gstname=",gstname)
if(gstname.find("video")!=-1):
# Link the decodebin pad only if decodebin has picked nvidia
# decoder plugin nvdec_*. We do this by checking if the pad caps contain
# NVMM memory features.
print("features=",features)
if features.contains("memory:NVMM"):
# Get the source bin ghost pad
bin_ghost_pad=source_bin.get_static_pad("src")
if not bin_ghost_pad.set_target(decoder_src_pad):
sys.stderr.write("Failed to link decoder src pad to source bin ghost pad\n")
else:
sys.stderr.write(" Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy,Object,name,user_data):
print("Decodebin child added:", name, "\n")
if(name.find("decodebin") != -1):
Object.connect("child-added",decodebin_child_added,user_data)
def create_source_bin(index,uri):
print("Creating source bin")
# Create a source GstBin to abstract this bin's content from the rest of the
# pipeline
bin_name="source-bin-%02d" %index
print(bin_name)
nbin=Gst.Bin.new(bin_name)
if not nbin:
sys.stderr.write(" Unable to create source bin \n")
# Source element for reading from the uri.
# We will use decodebin and let it figure out the container format of the
# stream and the codec and plug the appropriate demux and decode plugins.
uri_decode_bin=Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
if not uri_decode_bin:
sys.stderr.write(" Unable to create uri decode bin \n")
# We set the input uri to the source element
uri_decode_bin.set_property("uri",uri)
# Connect to the "pad-added" signal of the decodebin which generates a
# callback once a new pad for raw data has beed created by the decodebin
uri_decode_bin.connect("pad-added",cb_newpad,nbin)
uri_decode_bin.connect("child-added",decodebin_child_added,nbin)
# We need to create a ghost pad for the source bin which will act as a proxy
# for the video decoder src pad. The ghost pad will not have a target right
# now. Once the decode bin creates the video decoder and generates the
# cb_newpad callback, we will set the ghost pad target to the video decoder
# src pad.
Gst.Bin.add(nbin,uri_decode_bin)
bin_pad=nbin.add_pad(Gst.GhostPad.new_no_target("src",Gst.PadDirection.SRC))
if not bin_pad:
sys.stderr.write(" Failed to add ghost pad in source bin \n")
return None
return nbin
def main(args):
global perf_data
perf_data = PERF_DATA(len(args) - 1)
number_sources=len(args)-1
# Standard GStreamer initialization
Gst.init(None)
# registering callbacks
pyds.register_user_copyfunc(meta_copy_func)
pyds.register_user_releasefunc(meta_free_func)
# Create gstreamer elements
# Create Pipeline element that will form a connection of other elements
print("Creating Pipeline \n ")
pipeline = Gst.Pipeline()
if not pipeline:
sys.stderr.write(" Unable to create Pipeline \n")
# Source element for reading from the file
print("Creating Source \n ")
source = Gst.ElementFactory.make("v4l2src", "usb-cam-source")
if not source:
sys.stderr.write(" Unable to create Source \n")
caps_v4l2src = Gst.ElementFactory.make("capsfilter", "v4l2src_caps")
if not caps_v4l2src:
sys.stderr.write(" Unable to create v4l2src capsfilter \n")
print("Creating Video Converter \n")
# Adding videoconvert -> nvvideoconvert as not all
# raw formats are supported by nvvideoconvert;
# Say YUYV is unsupported - which is the common
# raw format for many logi usb cams
# In case we have a camera with raw format supported in
# nvvideoconvert, GStreamer plugins' capability negotiation
# shall be intelligent enough to reduce compute by
# videoconvert doing passthrough (TODO we need to confirm this)
# videoconvert to make sure a superset of raw formats are supported
vidconvsrc = Gst.ElementFactory.make("videoconvert", "convertor_src1")
if not vidconvsrc:
sys.stderr.write(" Unable to create videoconvert \n")
# nvvideoconvert to convert incoming raw buffers to NVMM Mem (NvBufSurface API)
nvvidconvsrc = Gst.ElementFactory.make("nvvideoconvert", "convertor_src2")
if not nvvidconvsrc:
sys.stderr.write(" Unable to create Nvvideoconvert \n")
caps_vidconvsrc = Gst.ElementFactory.make("capsfilter", "nvmm_caps")
if not caps_vidconvsrc:
sys.stderr.write(" Unable to create capsfilter \n")
# Create nvstreammux instance to form batches from one or more sources.
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
if not streammux:
sys.stderr.write(" Unable to create NvStreamMux \n")
# Use nvinfer to run inferencing on camera's output,
# behaviour of inferencing is set through config file
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
if not pgie:
sys.stderr.write(" Unable to create pgie \n")
tracker = Gst.ElementFactory.make("nvtracker", "tracker")
if not tracker:
sys.stderr.write(" Unable to create tracker \n")
nvanalytics = Gst.ElementFactory.make("nvdsanalytics", "analytics")
if not nvanalytics:
sys.stderr.write(" Unable to create nvanalytics \n")
nvanalytics.set_property("config-file", "config_nvdsanalytics.txt")
tiler=Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
if not tiler:
sys.stderr.write(" Unable to create tiler \n")
# Use convertor to convert from NV12 to RGBA as required by nvosd
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
if not nvvidconv:
sys.stderr.write(" Unable to create nvvidconv \n")
# Create OSD to draw on the converted RGBA buffer
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
if not nvosd:
sys.stderr.write(" Unable to create nvosd \n")
nvosd.set_property('process-mode',OSD_PROCESS_MODE)
nvosd.set_property('display-text',OSD_DISPLAY_TEXT)
msgconv = Gst.ElementFactory.make("nvmsgconv", "nvmsg-converter")
if not msgconv:
sys.stderr.write(" Unable to create msgconv \n")
msgbroker = Gst.ElementFactory.make("nvmsgbroker", "nvmsg-broker")
if not msgbroker:
sys.stderr.write(" Unable to create msgbroker \n")
tee = Gst.ElementFactory.make("tee", "nvsink-tee")
if not tee:
sys.stderr.write(" Unable to create tee \n")
queue1 = Gst.ElementFactory.make("queue", "nvtee-que1")
if not queue1:
sys.stderr.write(" Unable to create queue1 \n")
queue2 = Gst.ElementFactory.make("queue", "nvtee-que2")
if not queue2:
sys.stderr.write(" Unable to create queue2 \n")
if no_display:
print("Creating FakeSink \n")
sink = Gst.ElementFactory.make("fakesink", "fakesink")
if not sink:
sys.stderr.write(" Unable to create fakesink \n")
else:
if is_aarch64():
transform = Gst.ElementFactory.make("nvegltransform", "nvegl-transform")
if not transform:
sys.stderr.write(" Unable to create transform \n")
print("Creating EGLSink \n")
sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
if not sink:
sys.stderr.write(" Unable to create egl sink \n")
print("Playing cam %s " %input_file)
caps_v4l2src.set_property('caps', Gst.Caps.from_string("video/x-raw, framerate=30/1"))
caps_vidconvsrc.set_property('caps', Gst.Caps.from_string("video/x-raw(memory:NVMM)"))
source.set_property('device', input_file)
streammux.set_property('width', 1920)
streammux.set_property('height', 1080)
streammux.set_property('batch-size', 1)
streammux.set_property('batched-push-timeout', 4000000)
pgie.set_property('config-file-path', PGIE_CONFIG_FILE)
msgconv.set_property('config', MSCONV_CONFIG_FILE)
msgconv.set_property('payload-type', schema_type)
msgbroker.set_property('proto-lib', proto_lib)
msgbroker.set_property('conn-str', conn_str)
if cfg_file is not None:
msgbroker.set_property('config', cfg_file)
if topic is not None:
msgbroker.set_property('topic', topic)
msgbroker.set_property('sync', False)
#Set properties of tracker
config = configparser.ConfigParser()
config.read('dsnvanalytics_tracker_config.txt')
config.sections()
for key in config['tracker']:
if key == 'tracker-width' :
tracker_width = config.getint('tracker', key)
tracker.set_property('tracker-width', tracker_width)
if key == 'tracker-height' :
tracker_height = config.getint('tracker', key)
tracker.set_property('tracker-height', tracker_height)
if key == 'gpu-id' :
tracker_gpu_id = config.getint('tracker', key)
tracker.set_property('gpu_id', tracker_gpu_id)
if key == 'll-lib-file' :
tracker_ll_lib_file = config.get('tracker', key)
tracker.set_property('ll-lib-file', tracker_ll_lib_file)
if key == 'll-config-file' :
tracker_ll_config_file = config.get('tracker', key)
tracker.set_property('ll-config-file', tracker_ll_config_file)
if key == 'enable-batch-process' :
tracker_enable_batch_process = config.getint('tracker', key)
tracker.set_property('enable_batch_process', tracker_enable_batch_process)
if key == 'enable-past-frame' :
tracker_enable_past_frame = config.getint('tracker', key)
tracker.set_property('enable_past_frame', tracker_enable_past_frame)
print("Adding elements to Pipeline \n")
pipeline.add(source)
pipeline.add(caps_v4l2src)
pipeline.add(vidconvsrc)
pipeline.add(nvvidconvsrc)
pipeline.add(caps_vidconvsrc)
pipeline.add(streammux)
pipeline.add(pgie)
pipeline.add(tracker)
pipeline.add(nvanalytics)
pipeline.add(tiler)
pipeline.add(nvvidconv)
pipeline.add(nvosd)
pipeline.add(tee)
pipeline.add(queue1)
pipeline.add(queue2)
pipeline.add(msgconv)
pipeline.add(msgbroker)
pipeline.add(sink)
if is_aarch64() and not no_display:
pipeline.add(transform)
# we link the elements together
# v4l2src -> nvvideoconvert -> mux ->
# nvinfer -> nvvideoconvert -> nvosd -> video-renderer
print("Linking elements in the Pipeline \n")
source.link(caps_v4l2src)
caps_v4l2src.link(vidconvsrc)
vidconvsrc.link(nvvidconvsrc)
nvvidconvsrc.link(caps_vidconvsrc)
sinkpad = streammux.get_request_pad("sink_0")
if not sinkpad:
sys.stderr.write(" Unable to get the sink pad of streammux \n")
srcpad = caps_vidconvsrc.get_static_pad("src")
if not srcpad:
sys.stderr.write(" Unable to get source pad of caps_vidconvsrc \n")
srcpad.link(sinkpad)
streammux.link(pgie)
pgie.link(tracker)
tracker.link(nvanalytics)
nvanalytics.link(tiler)
tiler.link(nvvidconv)
nvvidconv.link(nvosd)
nvosd.link(tee)
queue1.link(msgconv)
msgconv.link(msgbroker)
queue2.link(transform)
transform.link(sink)
else:
queue2.link(sink)
sink_pad = queue1.get_static_pad("sink")
tee_msg_pad = tee.get_request_pad('src_%u')
tee_render_pad = tee.get_request_pad("src_%u")
if not tee_msg_pad or not tee_render_pad:
sys.stderr.write("Unable to get request pads\n")
tee_msg_pad.link(sink_pad)
sink_pad = queue2.get_static_pad("sink")
tee_render_pad.link(sink_pad)
# create an event loop and feed gstreamer bus messages to it
loop = GLib.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect("message", bus_call, loop)
nvanalytics_src_pad=nvanalytics.get_static_pad("src")
if not nvanalytics_src_pad:
sys.stderr.write(" Unable to get src pad \n")
else:
nvanalytics_src_pad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
# perf callback function to print fps every 5 sec
GLib.timeout_add(5000, perf_data.perf_print_callback)
# Lets add probe to get informed of the meta data generated, we add probe to
# the sink pad of the osd element, since by that time, the buffer would have
# had got all the metadata.
osdsinkpad = nvosd.get_static_pad("sink")
if not osdsinkpad:
sys.stderr.write(" Unable to get sink pad of nvosd \n")
# osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
# start play back and listen to events
print("Starting pipeline \n")
# start play back and listed to events
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
# cleanup
pyds.unset_callback_funcs()
pipeline.set_state(Gst.State.NULL)
# Parse and validate input arguments
def parse_args():
parser = OptionParser()
parser.add_option("-c", "--cfg-file", dest="cfg_file",
help="Set the adaptor config file. Optional if "
"connection string has relevant details.",
metavar="FILE")
# parser.add_option("-i", "--input-file", dest="input_file",
# help="Set the input H264 file", metavar="FILE")
help="Set the input path ex)/dev/video0", metavar="PATH")
parser.add_option("-p", "--proto-lib", dest="proto_lib",
help="Absolute path of adaptor library", metavar="PATH")
parser.add_option("", "--conn-str", dest="conn_str",
help="Connection string of backend server. Optional if "
"it is part of config file.", metavar="STR")
parser.add_option("-s", "--schema-type", dest="schema_type", default="0",
help="Type of message schema (0=Full, 1=minimal), "
"default=0", metavar="<0|1>")
parser.add_option("-t", "--topic", dest="topic",
help="Name of message topic. Optional if it is part of "
"connection string or config file.", metavar="TOPIC")
parser.add_option("", "--no-display", action="store_true",
dest="no_display", default=False,
help="Disable display")
(options, args) = parser.parse_args()
global cfg_file
global input_file
global proto_lib
global conn_str
global topic
global schema_type
global no_display
cfg_file = options.cfg_file
input_file = options.input_file
proto_lib = options.proto_lib
conn_str = options.conn_str
topic = options.topic
no_display = options.no_display
if not (proto_lib and input_file):
# print("Usage: python3 deepstream_test_4.py -i <H264 filename> -p "
# "<Proto adaptor library> --conn-str=<Connection string>")
print("Usage: python3 deepstream_test_4.py -i <usbcam path> -p "
return 1
schema_type = 0 if options.schema_type == "0" else 1
if __name__ == '__main__':
ret = parse_args()
# If argument parsing fails, returns failure (non-zero)
if ret == 1:
sys.exit(1)
sys.exit(main(sys.argv))
