Deepstream python multi source input, multi sink output giving errors
• Hardware Platform : GPU
• DeepStream Version : 6.1.1
• TensorRT Version : 8.4.1.5
• NVIDIA GPU Driver Version (valid for GPU only) : 525.60.13
I have the following pipeline which works well when I give it one stream as input but results in error when I give it more than 1.
def cb_newpad(decodebin, decoder_src_pad,data):
    print("In cb_newpad\n")
    caps=decoder_src_pad.get_current_caps()
    if not caps:
        caps = decoder_src_pad.query_caps()
    gststruct=caps.get_structure(0)
    gstname=gststruct.get_name()
    source_bin=data
    features=caps.get_features(0)
    # Need to check if the pad created by the decodebin is for video and not
    # audio.
    print("gstname=",gstname)
    if(gstname.find("video")!=-1):
        # Link the decodebin pad only if decodebin has picked nvidia
        # decoder plugin nvdec_*. We do this by checking if the pad caps contain
        # NVMM memory features.
        print("features=",features)
        if features.contains("memory:NVMM"):
            # Get the source bin ghost pad
            bin_ghost_pad=source_bin.get_static_pad("src")
            if not bin_ghost_pad.set_target(decoder_src_pad):
                sys.stderr.write("Failed to link decoder src pad to source bin ghost pad\n")
        else:
            sys.stderr.write(" Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy,Object,name,user_data):
    print("Decodebin child added:", name, "\n")
    if(name.find("decodebin") != -1):
        Object.connect("child-added",decodebin_child_added,user_data)
    if "source" in name:
        source_element = child_proxy.get_by_name("source")
        if source_element.find_property('drop-on-latency') != None:
            Object.set_property("drop-on-latency", True)
def create_source_bin(index,uri):
    print("Creating source bin")
    # Create a source GstBin to abstract this bin's content from the rest of the
    # pipeline
    bin_name="source-bin-%02d" %index
    print(bin_name)
    nbin=Gst.Bin.new(bin_name)
    if not nbin:
        sys.stderr.write(" Unable to create source bin \n")
    # Source element for reading from the uri.
    # We will use decodebin and let it figure out the container format of the
    # stream and the codec and plug the appropriate demux and decode plugins.
    if file_loop:
        # use nvurisrcbin to enable file-loop
        uri_decode_bin=Gst.ElementFactory.make("nvurisrcbin", "uri-decode-bin")
        uri_decode_bin.set_property("file-loop", 1)
    else:
        uri_decode_bin=Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
    if not uri_decode_bin:
        sys.stderr.write(" Unable to create uri decode bin \n")
    # We set the input uri to the source element
    uri_decode_bin.set_property("uri",uri)
    # Connect to the "pad-added" signal of the decodebin which generates a
    # callback once a new pad for raw data has beed created by the decodebin
    uri_decode_bin.connect("pad-added",cb_newpad,nbin)
    uri_decode_bin.connect("child-added",decodebin_child_added,nbin)
    # We need to create a ghost pad for the source bin which will act as a proxy
    # for the video decoder src pad. The ghost pad will not have a target right
    # now. Once the decode bin creates the video decoder and generates the
    # cb_newpad callback, we will set the ghost pad target to the video decoder
    # src pad.
    Gst.Bin.add(nbin,uri_decode_bin)
    bin_pad=nbin.add_pad(Gst.GhostPad.new_no_target("src",Gst.PadDirection.SRC))
    if not bin_pad:
        sys.stderr.write(" Failed to add ghost pad in source bin \n")
        return None
    return nbin
TILED_OUTPUT_WIDTH=1280
TILED_OUTPUT_HEIGHT=720
RTSPOUTPUTPORTNUM="1000"
def main(args, requested_pgie=None, config=None):
    number_sources=len(args)
    # Standard GStreamer initialization
    Gst.init(None)
    # Create gstreamer elements */
    # Create Pipeline element that will form a connection of other elements
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    is_live = False
    if not pipeline:
        sys.stderr.write(" Unable to create Pipeline \n")
    print("Creating streamux \n ")
    # Create nvstreammux instance to form batches from one or more sources.
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    pipeline.add(streammux)
    for i in range(number_sources):
        print("Creating source_bin ",i," \n ")
        uri_name=args[i]
        if uri_name.find("rtsp://") == 0 :
            is_live = True
        source_bin=create_source_bin(i, uri_name)
        if not source_bin:
            sys.stderr.write("Unable to create source bin \n")
        pipeline.add(source_bin)
        padname="sink_%u" %i
        sinkpad= streammux.get_request_pad(padname)
        if not sinkpad:
            sys.stderr.write("Unable to create sink pad bin \n")
        srcpad=source_bin.get_static_pad("src")
        if not srcpad:
            sys.stderr.write("Unable to create src pad bin \n")
        srcpad.link(sinkpad)
    queue1=Gst.ElementFactory.make("queue","queue1")
    queue2=Gst.ElementFactory.make("queue","queue2")
    queue3=Gst.ElementFactory.make("queue","queue3")
    queue4=Gst.ElementFactory.make("queue","queue4")
    pipeline.add(queue1)
    pipeline.add(queue2)
    pipeline.add(queue3)
    pipeline.add(queue4)
    print("Creating Pgie \n ")
    pgie = Gst.ElementFactory.make("nvinferserver", "primary-inference")
    if not pgie:
        sys.stderr.write(" Unable to create pgie :  %s\n" % requested_pgie)
    if is_live:
        print("At least one of the sources is live")
        streammux.set_property('live-source', 1)
    streammux.set_property('width', 1920)
    streammux.set_property('height', 1080)
    streammux.set_property('batch-size', number_sources)
    streammux.set_property('batched-push-timeout', 4000000)
    pgie.set_property('config-file-path', config)
    pgie.set_property("batch-size",number_sources)
    print("Creating nvvidconv1 \n ")
    nvvidconv1 = Gst.ElementFactory.make("nvvideoconvert", "convertor1")
    if not nvvidconv1:
        sys.stderr.write(" Unable to create nvvidconv1 \n")
    print("Creating filter1 \n ")
    caps1 = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
    filter1 = Gst.ElementFactory.make("capsfilter", "filter1")
    if not filter1:
        sys.stderr.write(" Unable to get the caps filter1 \n")
    filter1.set_property("caps", caps1)
    if not is_aarch64():
        # Use CUDA unified memory in the pipeline so frames
        # can be easily accessed on CPU in Python.
        mem_type = int(pyds.NVBUF_MEM_CUDA_UNIFIED)
        streammux.set_property("nvbuf-memory-type", mem_type)
        nvvidconv1.set_property("nvbuf-memory-type", mem_type)
    print("Creating nvstreamdemux \n ")
    nvstreamdemux = Gst.ElementFactory.make("nvstreamdemux", "nvstreamdemux")
    if not nvstreamdemux:
        sys.stderr.write(" Unable to create nvstreamdemux \n")
    print("Adding elements to Pipeline \n")
    pipeline.add(pgie)
    pipeline.add(nvvidconv1)
    pipeline.add(filter1)
    pipeline.add(nvstreamdemux)
    print("Linking elements in the Pipeline \n")
    streammux.link(queue1)
    queue1.link(pgie)
    pgie.link(queue2)
    queue2.link(nvvidconv1)
    nvvidconv1.link(queue3)
    queue3.link(filter1)
    filter1.link(queue4)
    queue4.link(nvstreamdemux)
        padname = "src_%u" % i
        demuxsrcpad = nvstreamdemux.get_request_pad(padname)
        if not demuxsrcpad:
            sys.stderr.write("Unable to create demux src pad \n")
        queue=Gst.ElementFactory.make("queue",f"nvvidconv1_queue_{i}")
        if not queue:
            sys.stderr.write(" Unable to create queue element \n")
        pipeline.add(queue)
        queuesinkpad = queue.get_static_pad("sink")
        if not queuesinkpad:
            sys.stderr.write("Unable to create queue sink pad \n")
        demuxsrcpad.link(queuesinkpad)
        tiler=Gst.ElementFactory.make("nvmultistreamtiler", f"nvtiler_{i}")
        if not tiler:
            sys.stderr.write(" Unable to create tiler \n")
        tiler.set_property("rows",1)
        tiler.set_property("columns",1)
        tiler.set_property("width", TILED_OUTPUT_WIDTH)
        tiler.set_property("height", TILED_OUTPUT_HEIGHT)
            tiler.set_property("nvbuf-memory-type", mem_type)
        pipeline.add(tiler)
        queue.link(tiler)
        queue=Gst.ElementFactory.make("queue",f"tiler_queue_{i}")
        if not queue:
        pipeline.add(queue)
        tiler.link(queue)
        # Create OSD to draw on the converted RGBA buffer
        nvosd = Gst.ElementFactory.make("nvdsosd", f"onscreendisplay_{i}")
        if not nvosd:
            sys.stderr.write("ERROR: Unable to create nvosd\n")
            sys.exit(1)
        pipeline.add(nvosd)
        queue.link(nvosd)
        queue=Gst.ElementFactory.make("queue",f"nvidconv_queue_{i}")
        if not queue:
        pipeline.add(queue)
        nvosd.link(queue)
        nvvidconv_postosd = Gst.ElementFactory.make("nvvideoconvert", f"convertor_postosd_{i}")
        if not nvvidconv_postosd:
            sys.stderr.write("ERROR: Unable to create nvvidconv_postosd\n")
            sys.exit(1)
            nvvidconv_postosd.set_property("nvbuf-memory-type", mem_type)
        pipeline.add(nvvidconv_postosd)
        queue.link(nvvidconv_postosd)
        queue=Gst.ElementFactory.make("queue",f"caps_queue_{i}")
        if not queue:
        pipeline.add(queue)
        nvvidconv_postosd.link(queue)
        # Create a caps filter
        caps = Gst.ElementFactory.make("capsfilter", f"filter_{i}")
        caps.set_property("caps", Gst.Caps.from_string("video/x-raw(memory:NVMM), format=I420, width=1200, height=600"))
        pipeline.add(caps)
        queue.link(caps)
        if display == "fakesink":
            queue=Gst.ElementFactory.make("queue",f"sink_queue_{i}")
            if not queue:
            pipeline.add(queue)
            caps.link(queue)
            print("Creating Fakesink ", i,"\n")
            sink = Gst.ElementFactory.make("fakesink", f"fakesink_{i}")
            if not sink:
                sys.stderr.write(" Unable to create sink element \n")
            sink.set_property('enable-last-sample', 0)
            sink.set_property('sync', 0)
            sink.set_property("qos",0)
            pipeline.add(sink)
            queue.link(sink)
        else:
            queue=Gst.ElementFactory.make("queue",f"encoder_queue_{i}")
            if not queue:
            pipeline.add(queue)
            caps.link(queue)
            # Make the encoder
            if CODEC == "H264":
                encoder = Gst.ElementFactory.make("nvv4l2h264enc", f"encoder_{i}")
            elif CODEC == "H265":
                encoder = Gst.ElementFactory.make("nvv4l2h265enc", f"encoder_{i}")
            if not encoder:
                sys.stderr.write("ERROR: Unable to create encoder")
                sys.exit(1)
            encoder.set_property('bitrate', int(BITRATE))
            if is_aarch64():
                encoder.set_property('preset-level', 1)
                encoder.set_property('insert-sps-pps', 1)
                encoder.set_property('bufapi-version', 1)
            # Add the V$L2/H264 encoder element to the pipeline, then link the caps filter to it
            pipeline.add(encoder)
            queue.link(encoder)
            queue=Gst.ElementFactory.make("queue",f"rtp_queue_{i}")
            if not queue:
            pipeline.add(queue)
            encoder.link(queue)
            # Make the payload-encode video into RTP packets
            if CODEC == "H264":
                rtppay = Gst.ElementFactory.make("rtph264pay", f"rtppay_{i}")
                rtppay = Gst.ElementFactory.make("rtph265pay", f"rtppay_{i}")
            if not rtppay:
                sys.stderr.write("ERROR: Unable to create rtppay")
                sys.exit(1)
            # Add the RTP packet encoder element to the pipeline, then link the H264 encoder onto it
            pipeline.add(rtppay)
            queue.link(rtppay)
            # The RTSP stream output sink sends to this local multicast UDP port
            # This is received by the GstRtspStreamer instance created below once
            # the pipeline is started. See "GstRtspStreamer" below for details.
            UDP_MULTICAST_ADDRESS = '224.224.255.255'
            UDP_MULTICAST_PORT = (int(RTSPOUTPUTPORTNUM) + i) * 2
            if not queue:
            pipeline.add(queue)
            rtppay.link(queue)
            sink = Gst.ElementFactory.make("udpsink", f"udpsink_{i}")
            if not sink:
                sys.stderr.write("ERROR: Unable to create udpsink")
                sys.exit(1)
            sink.set_property('host', UDP_MULTICAST_ADDRESS)
            sink.set_property('port', UDP_MULTICAST_PORT)
            sink.set_property('async', False)
            # The command below tells it to sync to a clock (1) or don't sync (0).
            # I find that using 1 slows things down, but it seems much more regular.
            # When I use 0 it is much faster but it freezes intermittently.
            sink.set_property("sync", 0)
            # Add the RTSP output stream sink element to the pipeline, then link the RTP paket encoder onto it
            pipeline.add(sink)
            queue.link(sink)
            server = GstRtspServer.RTSPServer.new()
            server.props.service = str(int(RTSPOUTPUTPORTNUM) + i)
            server.attach(None)
            factory = GstRtspServer.RTSPMediaFactory.new()
            factory.set_shared(True)
            factory.set_launch( "( udpsrc name=pay0 port=%d buffer-size=524288 caps=\"application/x-rtp, media=video, clock-rate=90000, encoding-name=(string)%s, payload=96 \" )" % (UDP_MULTICAST_PORT, CODEC))
            server.get_mount_points().add_factory(RTSPOUTPUTPATH, factory)
    # create an event loop and feed gstreamer bus mesages to it
    loop = GLib.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect ("message", bus_call, loop)
    # List the sources
    print("Now playing...")
    for i, source in enumerate(args):
        print(i, ": ", source)
    print("Starting pipeline \n")
    # start play back and listed to events
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
    except:
        pass
    # cleanup
    print("Exiting app\n")
    pipeline.set_state(Gst.State.NULL)
Error on giving more than one stream as input
[NvTiler::ScaleAndPlaceAllMeta] ERROR: 175; scaleX=0.110937 scaleY=0.000000 frameMeta=0x7ff4ac019580
[NvTiler::Composite] ERROR: 335; ScaleAndPlaceAllMeta failed (0x7ff4b402fca0;0x7ff4b402fcc0)
Error: gst-resource-error-quark: GstNvTiler: FATAL ERROR; NvTiler::Composite failed (1): gstnvtiler.cpp(665): gst_nvmultistreamtiler_transform (): /GstPipeline:pipeline0/GstNvMultiStreamTiler:nvtiler_1
Exiting app
Can someone please help me figure out what mistake am I making here?
If I just remove tiler (and it makes sense to do so) then I get
ERROR: infer_utils.cpp:113 Unknown data-type:-1509970992
ERROR: ./infer_utils.h:389 Failed to get element size on Unknown datatype:-1
ERROR: infer_utils.cpp:285 Unsupported data-type:kNone to capi
ERROR: infer_preprocess.cpp:391 Failed to convert input-format to network format
ERROR: infer_preprocess.cpp:280 Failed to preprocess buffer during cudaTransform.
You have already used the nvstreamdemux plugin, there’s no need to use the nvmultistreamtiler plugin anymore.
Thanks for the response @yuweiw . I do understand that. Please look at my comment above. So lets say I remove tiler and my main looks like this
    Gst.init(None)
    is_live = False
    if not pipeline:
    if not streammux:
        uri_name=args[i]
            is_live = True
        if not source_bin:
        if not sinkpad:
        if not srcpad:
    if not pgie:
    if is_live:
    if not nvvidconv1:
    if not filter1:
    pipeline.add(pgie)
    queue1.link(pgie)
    pgie.link(queue2)
        if not demuxsrcpad:
        if not queue:
        pipeline.add(queue)
        if not nvosd:
            sys.exit(1)
        pipeline.add(nvosd)
        queue.link(nvosd)
        if not queue:
        pipeline.add(queue)
        nvosd.link(queue)
            sys.exit(1)
        if not queue:
        pipeline.add(queue)
        pipeline.add(caps)
        queue.link(caps)
            if not queue:
            pipeline.add(queue)
            caps.link(queue)
            if not sink:
            pipeline.add(sink)
            queue.link(sink)
        else:
            if not queue:
            pipeline.add(queue)
            caps.link(queue)
            # Make the encoder
            if CODEC == "H264":
            if not encoder:
                sys.exit(1)
            if is_aarch64():
            queue.link(encoder)
            if not queue:
            pipeline.add(queue)
            encoder.link(queue)
            if CODEC == "H264":
            if not rtppay:
                sys.exit(1)
            queue.link(rtppay)
            if not queue:
            pipeline.add(queue)
            rtppay.link(queue)
            if not sink:
                sys.exit(1)
            pipeline.add(sink)
            queue.link(sink)
            server.attach(None)
    # List the sources
    try:
        loop.run()
    except:
        pass
    # cleanup
then i get the following error with one input stream
ERROR: infer_grpc_client.cpp:292 Failed to synchronize cuda events on buffer, err :700, err_str:cudaErrorIllegalAddress
ERROR: infer_grpc_client.cpp:215 Failed to create IPC handle, err :700, err_str:cudaErrorIllegalAddress
ERROR: infer_grpc_client.cpp:311 Failed to set inference input: CUDA IPC handle error
ERROR: infer_grpc_backend.cpp:140 gRPC backend run failed to create request for model: fire-smoke-detection-triton
ERROR: infer_grpc_backend.cpp:195 TritonSimple failed to run inference on model fire-smoke-detection-triton, nvinfer error:NVDSINFER_TRITON_ERROR
0:00:01.358727740 25 0x7feb70001600 WARN nvinferserver gstnvinferserver.cpp:531:gst_nvinfer_server_push_buffer: error: inference failed with unique-id:1
and the following error with 2 inputs streams
Cuda failure: status=700 in cuResData at line 339
Im unable to find out how to debug this. can you share some inputs?
Could you refer to our demo code and run that first? This can ensure that there are no issues with your environment. Then you can refer to our demo code for customization.
https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/blob/master/apps/deepstream-demux-multi-in-multi-out/deepstream_demux_multi_in_multi_out.py
@yuweiw I already have a pipeline with different model running. The only difference is that in the other pipeline that I have running I also have tracker and sgie. So i am pretty sure theres nothing wrong with my environment
Additionally, I have used this https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/blob/master/apps/deepstream-demux-multi-in-multi-out/deepstream_demux_multi_in_multi_out.py itself and modified it according to my need.
@yuweiw
Adding nvosd.set_property(‘process-mode’,0) to code seems to fix it as per NVOSD BUG : Unable to copy between two host memories/Unable to allocate host memory - #5 by fanzh
        if not nvosd:
            sys.exit(1)
        nvosd.set_property('process-mode',0)
        pipeline.add(nvosd)
however this results in marked drop in fps as OSD works on CPU
It’s weird because the error from your log is a triton server error. In theory, it should have nothing to do with the osd plugin.
The osd can be worked on GPU if you set the process-mode=1.
@yuweiw
process-mode=1 is the default seeting i think.
so with nvosd.set_property(‘process-mode’,0) everything woks just fine but drop in FPS since its working on CPU
but with nvosd.set_property(‘process-mode’,1) i get the same error
ERROR: infer_utils.cpp:113 Unknown data-type:67103696
could this be a bug?
Yes. But you need to confirm the dependent version of your software first. You can refer to the link below:
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Quickstart.html#id6
If you use deepstream 6.1.1, you need to install R515.65.01. Or you can install deepstream 6.2.
