How to remove camera distortion with camera instead of video
We currently do not have this camera. Cause it’s open source, could you help to debug it first?
1.You can add some log on the: sources\gst-plugins\gst-nvdewarper path to check if the function call process is normal.
2.Could you attach the pipeline to us by referring the link: https://forums.developer.nvidia.com/t/deepstream-sdk-faq/80236/10
3.You also can use the gst-lunch-1.0 to run the pipeline to check if it works well:
gst-launch-1.0 v4l2src device=/dev/video0 ! nvvideoconvert ! nvdewarper config-file=config_dewarper.txt source-id=6 ! m.sink_0 nvstreammux name=m width=960 height=752 batch-size=4 num-surfaces-per-frame=4 ! nvmultistreamtiler ! nv3dsink
