Fail to get frame in Tensor Metadata
My target is to get the boxes of a person and the whole frame back in a video.I have already found relative parameters of boxes in obj_meta.I noticed I may could the output frame in NvDsInferTensorMeta and then I tried to get it in bachmeta-framemeta-usermeta->(?). But I got None. I printed user_mate and the content of it.It shows <pyds.NvDsUserMeta object at 0x7fb5645fb8> <capsule object NULL at 0x7fb5b9a990>.Here is my code adjusting from deepstream_test_3.py:
# Copyright (c) 2019, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
import sys
sys.path.append('../')
import gi
import configparser
gi.require_version('Gst', '1.0')
from gi.repository import GObject, Gst
from gi.repository import GLib
from ctypes import *
import time
import sys
import math
import platform
from common.is_aarch_64 import is_aarch64
from common.bus_call import bus_call
from common.FPS import GETFPS
import pyds
fps_streams={}
MAX_DISPLAY_LEN=64
PGIE_CLASS_ID_VEHICLE = 0
PGIE_CLASS_ID_BICYCLE = 1
PGIE_CLASS_ID_PERSON = 2
PGIE_CLASS_ID_ROADSIGN = 3
MUXER_OUTPUT_WIDTH=1920
MUXER_OUTPUT_HEIGHT=80
MUXER_BATCH_TIMEOUT_USEC=4000000
TILED_OUTPUT_WIDTH=1920
TILED_OUTPUT_HEIGHT=1080
GST_CAPS_FEATURES_NVMM="memory:NVMM"
pgie_classes_str= ["Vehicle", "TwoWheeler", "Person","RoadSign"]
# tiler_sink_pad_buffer_probe  will extract metadata received on OSD sink pad
# and update params for drawing rectangle, object information etc.
def tiler_src_pad_buffer_probe(pad,info,u_data):
    frame_number=0
    num_rects=0
    gst_buffer = info.get_buffer()
    # print('dir',dir(info))
    # print('dir_buffer',dir(gst_buffer))
    # print('hash(gst_buffer)',dir(hash(gst_buffer)),'********',hash(gst_buffer))
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return
    # Retrieve batch metadata from the gst_buffer
    # Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
    # C address of gst_buffer as input, which is obtained with hash(gst_buffer)
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
            # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
            # The casting is done by pyds.glist_get_nvds_frame_meta()
            # The casting also keeps ownership of the underlying memory
            # in the C code, so the Python garbage collector will leave
            # it alone.
            frame_meta = pyds.glist_get_nvds_frame_meta(l_frame.data)
        except StopIteration:
            break
        print("Frame Number is ", frame_meta.frame_num)
        print("Source id is ", frame_meta.source_id)
        print("Batch id is ", frame_meta.batch_id)
        print("Source Frame Width ", frame_meta.source_frame_width)
        print("Source Frame Height ", frame_meta.source_frame_height)
        print("Num object meta ", frame_meta.num_obj_meta)
        frame_number=frame_meta.frame_num
        l_obj=frame_meta.obj_meta_list
        l_usr=frame_meta.frame_user_meta_list
        print('l_usr',l_usr)
        num_rects = frame_meta.num_obj_meta
        obj_counter = {
        PGIE_CLASS_ID_VEHICLE:0,
        PGIE_CLASS_ID_PERSON:0,
        PGIE_CLASS_ID_BICYCLE:0,
        PGIE_CLASS_ID_ROADSIGN:0
        # srcmeta=pyds.glist_get_nvds_event_msg_meta()
        print('frame_meta.source_id',frame_meta.source_id,frame_meta.source_frame_height,frame_meta.source_frame_width,
        frame_meta.batch_id,frame_meta.base_meta
        user_event_meta = pyds.nvds_acquire_user_meta_from_pool(batch_meta)
        user_event_meta.base_meta.meta_type = pyds.NvDsMetaType.NVDS_EVENT_MSG_META
[b]        while l_usr is not None:
            try:
                # Casting l_obj.data to pyds.NvDsObjectMeta
                usr_meta=pyds.glist_get_nvds_user_meta(l_usr.data)
                break
            # user_event_meta = pyds.nvds_acquire_user_meta_from_pool(batch_meta)
            # fr=pyds.glist_get_nvds_frame_meta(l_fr.data)
            print("usr_meta",usr_meta,usr_meta.user_meta_data)
            print("usr_meta",usr_meta.)
            try:
                l_usr=l_usr.next
                break[/b]
        while l_obj is not None:
            try:
                obj_meta=pyds.glist_get_nvds_object_meta(l_obj.data)
                break
            print("obj_meta.class_id",obj_meta.class_id,"obj_meta.rect_params",obj_meta.rect_params.left,obj_meta.rect_params.top,obj_meta.rect_params.width,obj_meta.rect_params.height)
            # print(fr)
            obj_counter[obj_meta.class_id] += 1
            try:
                l_obj=l_obj.next
                break
        """display_meta=pyds.nvds_acquire_display_meta_from_pool(batch_meta)
        display_meta.num_labels = 1
        py_nvosd_text_params = display_meta.text_params[0]
        py_nvosd_text_params.display_text = "Frame Number={} Number of Objects={} Vehicle_count={} Person_count={}".format(frame_number, num_rects, vehicle_count, person)
        py_nvosd_text_params.x_offset = 10;
        py_nvosd_text_params.y_offset = 12;
        py_nvosd_text_params.font_params.font_name = "Serif"
        py_nvosd_text_params.font_params.font_size = 10
        py_nvosd_text_params.font_params.font_color.red = 1.0
        py_nvosd_text_params.font_params.font_color.green = 1.0
        py_nvosd_text_params.font_params.font_color.blue = 1.0
        py_nvosd_text_params.font_params.font_color.alpha = 1.0
        py_nvosd_text_params.set_bg_clr = 1
        py_nvosd_text_params.text_bg_clr.red = 0.0
        py_nvosd_text_params.text_bg_clr.green = 0.0
        py_nvosd_text_params.text_bg_clr.blue = 0.0
        py_nvosd_text_params.text_bg_clr.alpha = 1.0
        #print("Frame Number=", frame_number, "Number of Objects=",num_rects,"Vehicle_count=",vehicle_count,"Person_count=",person)
        pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)"""
        print("Frame Number=", frame_number, "Number of Objects=",num_rects,"Vehicle_count=",obj_counter[PGIE_CLASS_ID_VEHICLE],"Person_count=",obj_counter[PGIE_CLASS_ID_PERSON],"frame_meta.num_obj_meta",frame_meta.num_obj_meta
#         print('***************',object_meta.confidence,object_meta.rect_params,object_meta.text_params,object_meta.classifier_meta_list
#         print('***************',object_meta.obj_meta_list
        # Get frame rate through this probe
        fps_streams["stream{0}".format(frame_meta.pad_index)].get_fps()
        try:
            l_frame=l_frame.next
            break
    return Gst.PadProbeReturn.OK
def cb_newpad(decodebin, decoder_src_pad,data):
    print("In cb_newpad\n")
    caps=decoder_src_pad.get_current_caps()
    gststruct=caps.get_structure(0)
    gstname=gststruct.get_name()
    source_bin=data
    features=caps.get_features(0)
    # Need to check if the pad created by the decodebin is for video and not
    # audio.
    print("gstname=",gstname)
    if(gstname.find("video")!=-1):
        # Link the decodebin pad only if decodebin has picked nvidia
        # decoder plugin nvdec_*. We do this by checking if the pad caps contain
        # NVMM memory features.
        print("features=",features)
        if features.contains("memory:NVMM"):
            # Get the source bin ghost pad
            bin_ghost_pad=source_bin.get_static_pad("src")
            if not bin_ghost_pad.set_target(decoder_src_pad):
                sys.stderr.write("Failed to link decoder src pad to source bin ghost pad\n")
        else:
            sys.stderr.write(" Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy,Object,name,user_data):
    print("Decodebin child added:", name, "\n")
    if(name.find("decodebin") != -1):
        Object.connect("child-added",decodebin_child_added,user_data)
    if(is_aarch64() and name.find("nvv4l2decoder") != -1):
        print("Seting bufapi_version\n")
        Object.set_property("bufapi-version",True)
def create_source_bin(index,uri):
    print("Creating source bin")
    # Create a source GstBin to abstract this bin's content from the rest of the
    # pipeline
    bin_name="source-bin-%02d" %index
    print(bin_name)
    nbin=Gst.Bin.new(bin_name)
    if not nbin:
        sys.stderr.write(" Unable to create source bin \n")
    # Source element for reading from the uri.
    # We will use decodebin and let it figure out the container format of the
    # stream and the codec and plug the appropriate demux and decode plugins.
    uri_decode_bin=Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
    if not uri_decode_bin:
        sys.stderr.write(" Unable to create uri decode bin \n")
    # We set the input uri to the source element
    uri_decode_bin.set_property("uri",uri)
    # Connect to the "pad-added" signal of the decodebin which generates a
    # callback once a new pad for raw data has beed created by the decodebin
    uri_decode_bin.connect("pad-added",cb_newpad,nbin)
    uri_decode_bin.connect("child-added",decodebin_child_added,nbin)
    # We need to create a ghost pad for the source bin which will act as a proxy
    # for the video decoder src pad. The ghost pad will not have a target right
    # now. Once the decode bin creates the video decoder and generates the
    # cb_newpad callback, we will set the ghost pad target to the video decoder
    # src pad.
    Gst.Bin.add(nbin,uri_decode_bin)
    bin_pad=nbin.add_pad(Gst.GhostPad.new_no_target("src",Gst.PadDirection.SRC))
    if not bin_pad:
        sys.stderr.write(" Failed to add ghost pad in source bin \n")
        return None
    return nbin
def main(args):
    # Check input arguments
    if len(args) < 2:
        sys.stderr.write("usage: %s <uri1> [uri2] ... [uriN]\n" % args[0])
        sys.exit(1)
    for i in range(0,len(args)-1):
        fps_streams["stream{0}".format(i)]=GETFPS(i)
    number_sources=len(args)-1
    # Standard GStreamer initialization
    GObject.threads_init()
    Gst.init(None)
    # Create gstreamer elements */
    # Create Pipeline element that will form a connection of other elements
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    if not pipeline:
        sys.stderr.write(" Unable to create Pipeline \n")
    print("Creating streamux \n ")
    # Create nvstreammux instance to form batches from one or more sources.
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    pipeline.add(streammux)
    for i in range(number_sources):
        print("Creating source_bin ",i," \n ")
        uri_name=args[i+1]
        source_bin=create_source_bin(i, uri_name)
        if not source_bin:
            sys.stderr.write("Unable to create source bin \n")
        pipeline.add(source_bin)
        padname="sink_%u" %i
        sinkpad= streammux.get_request_pad(padname)
        if not sinkpad:
            sys.stderr.write("Unable to create sink pad bin \n")
        srcpad=source_bin.get_static_pad("src")
        if not srcpad:
            sys.stderr.write("Unable to create src pad bin \n")
        srcpad.link(sinkpad)
    print("Creating Pgie \n ")
    pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    if not pgie:
        sys.stderr.write(" Unable to create pgie \n")
    print("Creating tiler \n ")
    tiler=Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
    if not tiler:
        sys.stderr.write(" Unable to create tiler \n")
    print("Creating nvvidconv \n ")
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
    if not nvvidconv:
        sys.stderr.write(" Unable to create nvvidconv \n")
    print("Creating nvosd \n ")
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    if not nvosd:
        sys.stderr.write(" Unable to create nvosd \n")
    if(is_aarch64()):
        print("Creating transform \n ")
        transform=Gst.ElementFactory.make("nvegltransform", "nvegl-transform")
        if not transform:
            sys.stderr.write(" Unable to create transform \n")
    print("Creating EGLSink \n")
    sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
    if not sink:
        sys.stderr.write(" Unable to create egl sink \n")
    streammux.set_property('width', 1080)
    streammux.set_property('height', 720)
    streammux.set_property('batch-size', number_sources)
    streammux.set_property('batched-push-timeout', 4000000)
    streammux.set_property('live-source',1)
    pgie.set_property('config-file-path', "dstest3_pgie_config.txt")
    pgie.set_property('output-tensor-meta', 1)   #(long)
    pgie_batch_size=pgie.get_property("batch-size")
    if(pgie_batch_size != number_sources):
        print("WARNING: Overriding infer-config batch-size",pgie_batch_size," with number of sources ", number_sources," \n")
        pgie.set_property("batch-size",number_sources)
    tiler_rows=int(math.sqrt(number_sources))
    tiler_columns=int(math.ceil((1.0*number_sources)/tiler_rows))
    tiler.set_property("rows",tiler_rows)
    tiler.set_property("columns",tiler_columns)
    tiler.set_property("width", TILED_OUTPUT_WIDTH)
    tiler.set_property("height", TILED_OUTPUT_HEIGHT)
    print("Adding elements to Pipeline \n")
    pipeline.add(pgie)
    pipeline.add(tiler)
    pipeline.add(nvvidconv)
    pipeline.add(nvosd)
    if is_aarch64():
        pipeline.add(transform)
    pipeline.add(sink)
    print("Linking elements in the Pipeline \n")
    streammux.link(pgie)
    pgie.link(tiler)
    tiler.link(nvvidconv)
    nvvidconv.link(nvosd)
    if is_aarch64():
        nvosd.link(transform)
        transform.link(sink)
    else:
        nvosd.link(sink)
    # create an event loop and feed gstreamer bus mesages to it
    loop = GObject.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect ("message", bus_call, loop)
    tiler_src_pad=pgie.get_static_pad("src")
    if not tiler_src_pad:
        sys.stderr.write(" Unable to get src pad \n")
    else:
        tiler_src_pad.add_probe(Gst.PadProbeType.BUFFER, tiler_src_pad_buffer_probe, 0)
    # List the sources
    print("Now playing...")
    for i, source in enumerate(args):
        if (i != 0):
            print(i, ": ", source)
    print("Starting pipeline \n")
    # start play back and listed to events
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
    except:
        pass
    # cleanup
    print("Exiting app\n")
    pipeline.set_state(Gst.State.NULL)
if __name__ == '__main__':
    sys.exit(main(sys.argv))
I would appreciate if you can help me to find the Tensor Metadata or suggest other ways to get the output frame.
I may find a way in C, but are there any accesses in python?
https://devtalk.nvidia.com/default/topic/1060956/deepstream-sdk/access-frame-pointer-in-deepstream-app/1
To get frame image data, you need to access NvBufSurface like in the C sample linked in your post above. NvDsInferTensorMeta contains raw tensors from inferencing which can be parsed and post-processed into boxes. It does not contain image data.
The alpha release of our python bindings does not include NvBufSurface or NvDsInferTensorMeta (which is why you get None). NvBufSurface support will be available in the next release.
Thank you for your replay.I tried the method above but I got all black pictures.And the value of pixel printed out is neither 0 or big.I also have questions about the lenth of buffer_size and est_size.The est_size is the same as picture size 1920*1080 and the buffer_size is bigger than the ext_size about 3.5 billion(tested by the video in deepstream 4.0.1). But why we copy memory in size of buffer_size from GPU to CPU rather tahn est_size.
Here is my code:
 * Copyright (c) 2018-2019, NVIDIA CORPORATION. All rights reserved.
 * Permission is hereby granted, free of charge, to any person obtaining a
 * copy of this software and associated documentation files (the "Software"),
 * to deal in the Software without restriction, including without limitation
 * the rights to use, copy, modify, merge, publish, distribute, sublicense,
 * and/or sell copies of the Software, and to permit persons to whom the
 * Software is furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
 * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
 * DEALINGS IN THE SOFTWARE.
#include <gst/gst.h>
#include <glib.h>
#include <stdio.h>
#include <math.h>
#include <string.h>
#include <sys/time.h>
#include <jpeglib.h>
#include "nvbufsurface.h"
#include "cuda_runtime.h"
#include "device_launch_parameters.h"
#include "gstnvdsmeta.h"
//#include "gstnvstreammeta.h"
#ifndef PLATFORM_TEGRA
#include "gst-nvmessage.h"
#endif
#define MAX_DISPLAY_LEN 64
#define PGIE_CLASS_ID_VEHICLE 0
#define PGIE_CLASS_ID_PERSON 2
/* The muxer output resolution must be set if the input streams will be of
 * different resolution. The muxer will scale all the input frames to this
 * resolution. */
#define MUXER_OUTPUT_WIDTH 1920
#define MUXER_OUTPUT_HEIGHT 1080
/* Muxer batch formation timeout, for e.g. 40 millisec. Should ideally be set
 * based on the fastest source's framerate. */
#define MUXER_BATCH_TIMEOUT_USEC 4000000
#define TILED_OUTPUT_WIDTH 1920
#define TILED_OUTPUT_HEIGHT 1080
/* NVIDIA Decoder source pad memory feature. This feature signifies that source
 * pads having this capability will push GstBuffers containing cuda buffers. */
#define GST_CAPS_FEATURES_NVMM "memory:NVMM"
int txtnumb=0;
gchar pgie_classes_str[4][32] = { "Vehicle", "TwoWheeler", "Person",
  "RoadSign"
#define FPS_PRINT_INTERVAL 300
//static struct timeval start_time = { };
//static guint probe_counter = 0;
/* tiler_sink_pad_buffer_probe  will extract metadata received on OSD sink pad
 * and update params for drawing rectangle, object information etc. */
int outnumber=0;
int write_jpeg_file( char *filename, unsigned char* rgb_image , int width, int height, int bytes_per_pixel, J_COLOR_SPACE color_space )
  // char filenametxt[200];
  // int txtstep;
  // FILE *fp1;
  // sprintf(filenametxt,"file_y_%dx%d_%d.txt",1920,1080,outnumber);
  // fp1=fopen(filenametxt,"w");
  // for (txtstep=0;txtstep<2073600;txtstep++)
  //   fprintf(fp1,"%hhn\n",rgb_image);
  // fclose(fp1);
  // printf("rgb_image:%ld",sizeof(rgb_image));
	struct jpeg_compress_struct cinfo;
	struct jpeg_error_mgr jerr;
	JSAMPROW row_pointer[1];
	FILE *outfile = fopen( filename, "wb" );
	if ( !outfile )
		printf("Error opening output jpeg file %s\n!", filename );
		return -1;
	cinfo.err = jpeg_std_error( &jerr );
	jpeg_create_compress(&cinfo);
	jpeg_stdio_dest(&cinfo, outfile);
	cinfo.image_width = width;
	cinfo.image_height = height;
	cinfo.input_components = bytes_per_pixel;
	cinfo.in_color_space = color_space; //JCS_RGB
	jpeg_set_defaults( &cinfo );
	jpeg_start_compress( &cinfo, TRUE );
	while( cinfo.next_scanline < cinfo.image_height )
		row_pointer[0] = &rgb_image[ cinfo.next_scanline * cinfo.image_width *  cinfo.input_components];
		jpeg_write_scanlines( &cinfo, row_pointer, 1 );
	jpeg_finish_compress( &cinfo );
	jpeg_destroy_compress( &cinfo );
	fclose( outfile );
	return 1;
static GstPadProbeReturn
tiler_src_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
    gpointer u_data)
    GstBuffer *buf = (GstBuffer *) info->data;
    guint num_rects = 0;
    NvDsObjectMeta *obj_meta = NULL;
    guint vehicle_count = 0;
    guint person_count = 0;
    NvDsMetaList * l_frame = NULL;
    NvDsMetaList * l_obj = NULL;
  	NvDsUserMeta *user_meta = NULL;
    FILE *fp1;
    //NvDsDisplayMeta *display_meta = NULL;
    char *txtfilename=NULL;
    NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
	  GstMapInfo in_map_info;
	  NvBufSurface *surface = NULL;
    int imgpix=0;
    int txtstep;
    unsigned char totalpix=0;
	  memset (&in_map_info, 0, sizeof (in_map_info));
	  if (!gst_buffer_map (buf, &in_map_info, GST_MAP_READ)) {
	    g_print ("Error: Failed to map gst buffer\n");
	  surface = (NvBufSurface *) in_map_info.data;
      for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
        l_frame = l_frame->next) {
        NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
        uint32_t frame_width  =  surface->surfaceList[frame_meta->batch_id].width;
        uint32_t frame_height =  surface->surfaceList[frame_meta->batch_id].height;
        uint32_t Y_stride     =  surface->surfaceList[frame_meta->batch_id].pitch;
        uint32_t buffer_size = surface->surfaceList[frame_meta->batch_id].dataSize;
        uint32_t est_size = frame_width*frame_height;
        void *src_data = (char*) malloc(surface->surfaceList[frame_meta->batch_id].dataSize);
        if(src_data == NULL) {
            g_print("Error: failed to malloc src_data \n");
            continue;
        printf("src_size:%ld\n",sizeof(src_data));
        printf("Buffer size : %i64u,%d\n", buffer_size,Y_stride);
        printf("Estimated size : %d\n", est_size);
        printf("frame_width : %d\n", frame_width);
        printf("frame_height : %d\n", frame_height);
        cudaMemcpy((void*)src_data,
                   (void*)surface->surfaceList[frame_meta->batch_id].dataPtr,
                   surface->surfaceList[frame_meta->batch_id].dataSize,
                   cudaMemcpyDeviceToHost);
        // printf("\nError returned by cudamemcpy : %d\n", err);
        // char filename[200];
        // sprintf(filename,"file_y_%dx%d.jpg",frame_width,frame_height);
        char filename[200];
        sprintf(filename,"file_y_%dx%d_%d.jpg",frame_width,frame_height,outnumber);
        outnumber=outnumber+1;
        printf("filename:%s\n",filename);
        write_jpeg_file( filename, src_data , frame_width, frame_height, 1, JCS_GRAYSCALE );
        // sprintf(txtfilename,"www%d.txt",txtnumb);
        // FILE *txtoutput=NULL;
        // txtoutput=fopen(txtfilename,"ab");
        // scanf("%s",rgb_img);
        // fwrite(rgb_img,sizeof(char),2073600,txtoutput);
        // fclose(txtoutput);
        // txtnumb=txtnumb+1;
        printf("!%ln!",(long unsigned int*) src_data);
        // printf("!%d!",(long unsigned int*) src_data[1]);
        // printf("!%d!",(long unsigned int*) src_data[2]);
        if(src_data != NULL) {
            free(src_data);
            src_data = NULL;
        //int offset = 0;
        for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
                l_obj = l_obj->next) {
            obj_meta = (NvDsObjectMeta *) (l_obj->data);
            if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
                vehicle_count++;
                num_rects++;
            if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) {
                person_count++;
                num_rects++;
          g_print ("Frame Number = %d Number of objects = %d "
            "Vehicle Count = %d Person Count = %d\n",
            frame_meta->frame_num, num_rects, vehicle_count, person_count);
#if 0
        display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
        NvOSD_TextParams *txt_params  = &display_meta->text_params;
        txt_params->display_text = g_malloc0 (MAX_DISPLAY_LEN);
        offset = snprintf(txt_params->display_text, MAX_DISPLAY_LEN, "Person = %d ", person_count);
        offset = snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN, "Vehicle = %d ", vehicle_count);
        /* Now set the offsets where the string should appear */
        txt_params->x_offset = 10;
        txt_params->y_offset = 12;
        /* Font , font-color and font-size */
        txt_params->font_params.font_name = "Serif";
        txt_params->font_params.font_size = 10;
        txt_params->font_params.font_color.red = 1.0;
        txt_params->font_params.font_color.green = 1.0;
        txt_params->font_params.font_color.blue = 1.0;
        txt_params->font_params.font_color.alpha = 1.0;
        /* Text background color */
        txt_params->set_bg_clr = 1;
        txt_params->text_bg_clr.red = 0.0;
        txt_params->text_bg_clr.green = 0.0;
        txt_params->text_bg_clr.blue = 0.0;
        txt_params->text_bg_clr.alpha = 1.0;
        nvds_add_display_meta_to_frame(frame_meta, display_meta);
#endif
    gst_buffer_unmap (buf, &in_map_info);
    return GST_PAD_PROBE_OK;
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
  GMainLoop *loop = (GMainLoop *) data;
  switch (GST_MESSAGE_TYPE (msg)) {
    case GST_MESSAGE_EOS:
      g_print ("End of stream\n");
      g_main_loop_quit (loop);
      break;
    case GST_MESSAGE_WARNING:
      gchar *debug;
      GError *error;
      gst_message_parse_warning (msg, &error, &debug);
      g_printerr ("WARNING from element %s: %s\n",
          GST_OBJECT_NAME (msg->src), error->message);
      g_free (debug);
      g_printerr ("Warning: %s\n", error->message);
      g_error_free (error);
      break;
    case GST_MESSAGE_ERROR:
      gchar *debug;
      GError *error;
      gst_message_parse_error (msg, &error, &debug);
      g_printerr ("ERROR from element %s: %s\n",
      if (debug)
        g_printerr ("Error details: %s\n", debug);
      g_free (debug);
      break;
    case GST_MESSAGE_ELEMENT:
      if (gst_nvmessage_is_stream_eos (msg)) {
        guint stream_id;
        if (gst_nvmessage_parse_stream_eos (msg, &stream_id)) {
          g_print ("Got EOS from stream %d\n", stream_id);
      break;
#endif
    default:
      break;
  return TRUE;
static void
cb_newpad (GstElement * decodebin, GstPad * decoder_src_pad, gpointer data)
  g_print ("In cb_newpad\n");
  GstCaps *caps = gst_pad_get_current_caps (decoder_src_pad);
  const GstStructure *str = gst_caps_get_structure (caps, 0);
  const gchar *name = gst_structure_get_name (str);
  GstElement *source_bin = (GstElement *) data;
  GstCapsFeatures *features = gst_caps_get_features (caps, 0);
  /* Need to check if the pad created by the decodebin is for video and not
   * audio. */
  if (!strncmp (name, "video", 5)) {
    /* Link the decodebin pad only if decodebin has picked nvidia
     * decoder plugin nvdec_*. We do this by checking if the pad caps contain
     * NVMM memory features. */
    if (gst_caps_features_contains (features, GST_CAPS_FEATURES_NVMM)) {
      /* Get the source bin ghost pad */
      GstPad *bin_ghost_pad = gst_element_get_static_pad (source_bin, "src");
      if (!gst_ghost_pad_set_target (GST_GHOST_PAD (bin_ghost_pad),
              decoder_src_pad)) {
        g_printerr ("Failed to link decoder src pad to source bin ghost pad\n");
      gst_object_unref (bin_ghost_pad);
    } else {
      g_printerr ("Error: Decodebin did not pick nvidia decoder plugin.\n");
static void
decodebin_child_added (GstChildProxy * child_proxy, GObject * object,
    gchar * name, gpointer user_data)
  g_print ("Decodebin child added: %s\n", name);
  if (g_strrstr (name, "decodebin") == name) {
    g_signal_connect (G_OBJECT (object), "child-added",
        G_CALLBACK (decodebin_child_added), user_data);
  if (g_strstr_len (name, -1, "nvv4l2decoder") == name) {
    g_print ("Seting bufapi_version\n");
    g_object_set (object, "bufapi-version", TRUE, NULL);
static GstElement *
create_source_bin (guint index, gchar * uri)
  GstElement *bin = NULL, *uri_decode_bin = NULL;
  gchar bin_name[16] = { };
  g_snprintf (bin_name, 15, "source-bin-%02d", index);
  /* Create a source GstBin to abstract this bin's content from the rest of the
   * pipeline */
  bin = gst_bin_new (bin_name);
  /* Source element for reading from the uri.
   * We will use decodebin and let it figure out the container format of the
   * stream and the codec and plug the appropriate demux and decode plugins. */
  uri_decode_bin = gst_element_factory_make ("uridecodebin", "uri-decode-bin");
  if (!bin || !uri_decode_bin) {
    g_printerr ("One element in source bin could not be created.\n");
    return NULL;
  /* We set the input uri to the source element */
  g_object_set (G_OBJECT (uri_decode_bin), "uri", uri, NULL);
  /* Connect to the "pad-added" signal of the decodebin which generates a
   * callback once a new pad for raw data has beed created by the decodebin */
  g_signal_connect (G_OBJECT (uri_decode_bin), "pad-added",
      G_CALLBACK (cb_newpad), bin);
  g_signal_connect (G_OBJECT (uri_decode_bin), "child-added",
      G_CALLBACK (decodebin_child_added), bin);
  gst_bin_add (GST_BIN (bin), uri_decode_bin);
  /* We need to create a ghost pad for the source bin which will act as a proxy
   * for the video decoder src pad. The ghost pad will not have a target right
   * now. Once the decode bin creates the video decoder and generates the
   * cb_newpad callback, we will set the ghost pad target to the video decoder
   * src pad. */
  if (!gst_element_add_pad (bin, gst_ghost_pad_new_no_target ("src",
              GST_PAD_SRC))) {
    g_printerr ("Failed to add ghost pad in source bin\n");
    return NULL;
  return bin;
int
main (int argc, char *argv[])
  GMainLoop *loop = NULL;
  GstElement *pipeline = NULL, *streammux = NULL, *sink = NULL, *pgie = NULL,
      *nvvidconv = NULL, *nvosd = NULL, *tiler = NULL;
#ifdef PLATFORM_TEGRA
  GstElement *transform = NULL;
#endif
  GstBus *bus = NULL;
  guint bus_watch_id;
  GstPad *tiler_src_pad = NULL;
  guint i, num_sources;
  guint tiler_rows, tiler_columns;
  guint pgie_batch_size;
  /* Check input arguments */
  if (argc < 2) {
    g_printerr ("Usage: %s <uri1> [uri2] ... [uriN] \n", argv[0]);
    return -1;
  num_sources = argc - 1;
  /* Standard GStreamer initialization */
  gst_init (&argc, &argv);
  loop = g_main_loop_new (NULL, FALSE);
  /* Create gstreamer elements */
  /* Create Pipeline element that will form a connection of other elements */
  pipeline = gst_pipeline_new ("dstest3-pipeline");
  /* Create nvstreammux instance to form batches from one or more sources. */
  streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
  if (!pipeline || !streammux) {
    g_printerr ("One element could not be created. Exiting.\n");
    return -1;
  gst_bin_add (GST_BIN (pipeline), streammux);
  for (i = 0; i < num_sources; i++) {
    GstPad *sinkpad, *srcpad;
    gchar pad_name[16] = { };
    GstElement *source_bin = create_source_bin (i, argv[i + 1]);
    if (!source_bin) {
      g_printerr ("Failed to create source bin. Exiting.\n");
      return -1;
    gst_bin_add (GST_BIN (pipeline), source_bin);
    g_snprintf (pad_name, 15, "sink_%u", i);
    sinkpad = gst_element_get_request_pad (streammux, pad_name);
    if (!sinkpad) {
      g_printerr ("Streammux request sink pad failed. Exiting.\n");
      return -1;
    srcpad = gst_element_get_static_pad (source_bin, "src");
    if (!srcpad) {
      g_printerr ("Failed to get src pad of source bin. Exiting.\n");
      return -1;
    if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
      g_printerr ("Failed to link source bin to stream muxer. Exiting.\n");
      return -1;
    gst_object_unref (srcpad);
    gst_object_unref (sinkpad);
  /* Use nvinfer to infer on batched frame. */
  pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
  /* Use nvtiler to composite the batched frames into a 2D tiled array based
   * on the source of the frames. */
  tiler = gst_element_factory_make ("nvmultistreamtiler", "nvtiler");
  /* Use convertor to convert from NV12 to RGBA as required by nvosd */
  nvvidconv = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter");
  /* Create OSD to draw on the converted RGBA buffer */
  nvosd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
  /* Finally render the osd output */
  transform = gst_element_factory_make ("nvegltransform", "nvegl-transform");
#endif
  sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
  if (!pgie || !tiler || !nvvidconv || !nvosd || !sink) {
    return -1;
  if(!transform) {
    g_printerr ("One tegra element could not be created. Exiting.\n");
    return -1;
#endif
  g_object_set (G_OBJECT (streammux), "width", MUXER_OUTPUT_WIDTH, "height",
      MUXER_OUTPUT_HEIGHT, "batch-size", num_sources,
      "batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
  /* Configure the nvinfer element using the nvinfer config file. */
  g_object_set (G_OBJECT (pgie),
      "config-file-path", "dstest3_pgie_config.txt", NULL);
  /* Override the batch-size set in the config file with the number of sources. */
  g_object_get (G_OBJECT (pgie), "batch-size", &pgie_batch_size, NULL);
  if (pgie_batch_size != num_sources) {
    g_printerr
        ("WARNING: Overriding infer-config batch-size (%d) with number of sources (%d)\n",
        pgie_batch_size, num_sources);
    g_object_set (G_OBJECT (pgie), "batch-size", num_sources, NULL);
  tiler_rows = (guint) sqrt (num_sources);
  tiler_columns = (guint) ceil (1.0 * num_sources / tiler_rows);
  /* we set the tiler properties here */
  g_object_set (G_OBJECT (tiler), "rows", tiler_rows, "columns", tiler_columns,
      "width", TILED_OUTPUT_WIDTH, "height", TILED_OUTPUT_HEIGHT, NULL);
  /* we add a message handler */
  bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
  bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
  gst_object_unref (bus);
  /* Set up the pipeline */
  /* we add all elements into the pipeline */
  gst_bin_add_many (GST_BIN (pipeline), pgie, tiler, nvvidconv, nvosd, transform, sink,
      NULL);
  /* we link the elements together
   * nvstreammux -> nvinfer -> nvtiler -> nvvidconv -> nvosd -> video-renderer */
  if (!gst_element_link_many (streammux, pgie, tiler, nvvidconv, nvosd, transform, sink,
          NULL)) {
    g_printerr ("Elements could not be linked. Exiting.\n");
    return -1;
#else
gst_bin_add_many (GST_BIN (pipeline), pgie, tiler, nvvidconv, nvosd, sink,
      NULL);
  if (!gst_element_link_many (streammux, pgie, tiler, nvvidconv, nvosd, sink,
          NULL)) {
    return -1;
#endif
  /* Lets add probe to get informed of the meta data generated, we add probe to
   * the sink pad of the osd element, since by that time, the buffer would have
   * had got all the metadata. */
  tiler_src_pad = gst_element_get_static_pad (pgie, "src");
  if (!tiler_src_pad)
    g_print ("Unable to get src pad\n");
  else
    gst_pad_add_probe (tiler_src_pad, GST_PAD_PROBE_TYPE_BUFFER,
        tiler_src_pad_buffer_probe, NULL, NULL);
  /* Set the pipeline to "playing" state */
  g_print ("Now playing:");
    g_print (" %s,", argv[i + 1]);
  g_print ("\n");
  gst_element_set_state (pipeline, GST_STATE_PLAYING);
  /* Wait till pipeline encounters an error or EOS */
  g_print ("Running...\n");
  g_main_loop_run (loop);
  /* Out of the main loop, clean up nicely */
  g_print ("Returned, stopping playback\n");
  gst_element_set_state (pipeline, GST_STATE_NULL);
  g_print ("Deleting pipeline\n");
  gst_object_unref (GST_OBJECT (pipeline));
  g_source_remove (bus_watch_id);
  g_main_loop_unref (loop);
  return 0;
The alpha release of our python bindings does not include NvBufSurface or NvDsInferTensorMeta (which is why you get None). >NvBufSurface support will be available in the next release.
I have the same question.
When will the ā€œnext releaseā€ you say be released?
Please tell me if there is no problem.
the next release is under testing, will release it this week or next week.
Correct this comment, the next release DS4.0.2 will not include python bindings, we will add the feature in later release.
Thank you very much bcao for your quick advice!
I rebuild code in c in #4,but nothing is in memory ā€œsrc_dataā€.I find buffer size is bigger than widthheight… I think the picture data may be in the middle of the 3.5 billion data.(buffsize is 3.5billion picture is 19201080)I printed 3.5 billion pointers in buffer one by one. They are all 0.Here is my new code.
#include <glib.h>
#include <stdio.h>
#include <math.h>
#include <string.h>
#include "/usr/local/cuda-10.0/targets/aarch64-linux/include/cuda_runtime.h"
#include "/usr/local/cuda-10.0/targets/aarch64-linux/include/device_launch_parameters.h"
#endif
 * resolution. */
int txtnumb=0;
  "RoadSign"
int outnumber=0;
  // int txtstep;
  // FILE *fp1;
  // for (txtstep=0;txtstep<100;txtstep++)
  //   printf("%d\n",rgb_image[txtstep]);
  // fclose(fp1);
	if ( !outfile )
		return -1;
	fclose( outfile );
	return 1;
    gpointer u_data)
    FILE *fp1;
    int imgpix=0;
    int txtstep;
    unsigned char *totalpix;
    char *totalpix1;
    unsigned int *totalpix2;
    long unsigned int *totalpix3;
        void *src_data = (void*) malloc(surface->surfaceList[frame_meta->batch_id].dataSize);
            continue;
        printf("src_size:%ld\n",sizeof(char));
        printf("totalpix1:%ld\n",sizeof(unsigned char));
        printf("totalpix2:%ld\n",sizeof(unsigned int));
        printf("totalpix3:%ld\n",sizeof(long unsigned int));
        printf("Buffer size : %d,%d\n", buffer_size,Y_stride);
        printf("dataPtr : %p\n", surface->surfaceList[frame_meta->batch_id].dataPtr);
// #ifdef PLATFORM_TEGRA
//         NvBufSurfaceMap (surface, -1, -1, NVBUF_MAP_READ);
//         NvBufSurfacePlaneParams *pParams = &surface->surfaceList[frame_meta->batch_id].planeParams;
//         unsigned int offset = 0;
//         for(unsigned int num_planes=0; num_planes < pParams->num_planes; num_planes++){
//             if(num_planes>0)
//                 offset += pParams->height[num_planes-1]*(pParams->bytesPerPix[num_planes-1]*pParams->width[num_planes-1]);
//             for (unsigned int h = 0; h < pParams->height[num_planes]; h++) {
//              memcpy((void *)(src_data+offset+h*pParams->bytesPerPix[num_planes]*pParams->width[num_planes]),
//                     (void *)((char *)surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[num_planes]+h*pParams->pitch[num_planes]),
//                     pParams->bytesPerPix[num_planes]*pParams->width[num_planes]
//         NvBufSurfaceSyncForDevice (surface, -1, -1);
//         NvBufSurfaceUnMap (surface, -1, -1);
// #else
//         cudaMemcpy((void*)src_data,
//                    (void*)surface->surfaceList[frame_meta->batch_id].dataPtr,
//                    surface->surfaceList[frame_meta->batch_id].dataSize,
//                    cudaMemcpyDeviceToHost);
// #endif
        // int pixsum=0;
        // int pixsumint=0;
        totalpix=src_data;
        FILE *fp1;
        for (txtstep=0;txtstep<buffer_size;txtstep++)
          printf("Address:%p-%x!!",totalpix,*totalpix);
          // pixsumint=(int) totalpix[txtstep];
          // if (pixsumint>0)
          //   fprintf(fp1,"!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!\n");
          // else
          //   fprintf(fp1,"\n");
          // pixsum=pixsum+pixsumint;
          totalpix=totalpix+1;
        fclose(fp1);
        // printf("pixsum:%d\n",pixsum);
        printf("-%ln-",(long unsigned int*) src_data);
        printf("=%s=",(char*) src_data);
        char filename[200];
            free(src_data);
            src_data = NULL;
        //int offset = 0;
                vehicle_count++;
                num_rects++;
                person_count++;
                num_rects++;
#if 0
#endif
static gboolean
      break;
      gchar *debug;
      GError *error;
      g_free (debug);
      break;
      gchar *debug;
      GError *error;
      if (debug)
      g_free (debug);
      break;
        guint stream_id;
      break;
#endif
    default:
      break;
  return TRUE;
static void
   * audio. */
              decoder_src_pad)) {
    } else {
static void
static GstElement *
   * pipeline */
    return NULL;
   * src pad. */
              GST_PAD_SRC))) {
    return NULL;
  return bin;
int
#endif
  GstBus *bus = NULL;
  guint bus_watch_id;
  if (argc < 2) {
    return -1;
    return -1;
    if (!source_bin) {
      return -1;
    if (!sinkpad) {
      return -1;
    if (!srcpad) {
      return -1;
      return -1;
#endif
    return -1;
  if(!transform) {
    return -1;
#endif
    g_printerr
      NULL);
          NULL)) {
    return -1;
#else
      NULL);
          NULL)) {
    return -1;
#endif
  if (!tiler_src_pad)
  else
  g_print ("\n");
  return 0;
And here is the result:
I didn’t see the image you shared, also would you mind to share your log print.
Also you can refer https://docs.nvidia.com/metropolis/deepstream/dev-guide/DeepStream_Development_Guide/baggage/structNvBufSurface.html
My output is like this:
waveshare@waveshare-desktop:~/Downloads/deepstream_sdk_v4.0.1_jetson/sources/apps/sample_apps/deepstream-test3$ ./deepstream-test3-app file:///home/waveshare/Downloads/deepstream_sdk_v4.0.1_jetson/samples/streams/sample_720p.mp4
Now playing: file:///home/waveshare/Downloads/deepstream_sdk_v4.0.1_jetson/samples/streams/sample_720p.mp4,
Using winsys: x11
Creating LL OSD context new
Decodebin child added: source
Decodebin child added: decodebin0
Running…
Decodebin child added: qtdemux0
Decodebin child added: multiqueue0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: aacparse0
Decodebin child added: avdec_aac0
Decodebin child added: nvv4l2decoder0
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
In cb_newpad
In cb_newpad
src_size:1
totalpix1:1
totalpix2:4
totalpix3:8
Buffer size : 3407872,2048
Estimated size : 2073600
frame_width : 1920
frame_height : 1080
dataPtr : 0x7f4c0b1a20
0x7f20390c37-0!!Address:0x7f20390c38-0!!Address:0x7f20390c39-0!!Address:0x7f20390c3a-0!!Address:0x7f20390c3b-0!!Address:0x7f20390c3c-0!!Address:0x7f20390c3d-0!!Address:0x7f20390c3e-0!!Address:0x7f20390c3f-0!!Address:0x7f20390c40-0!!Address:0x7f20390c41-0!!Address:0x7f20390c42-0!!Address:0x7f20390c43-0!!Address:0x7f20390c44-0!!Address:0x7f20390c45-0!!Address:0x7f20390c46-0!!Address:0x7f20390c47-0!!Address:0x7f20390c48-0!!Address:0x7f20390c49-0!!Address:0x7f20390c4a-0!!Address:0x7f20390c4b-0!!Address:0x7f20390c4c-0!!Address:0x7f20390c4d-0!!Address:0x7f20390c4e-0!!Address:0x7f20390c4f-0!!Address:0x7f20390c50-0!!Address:0x7f20390c51-0!!Address:0x7f20390c52-0!!Address:0x7f20390c53-0!!Address:0x7f20390c54-0!!Address:0x7f20390c55-0!!Address:0x7f20390c56-0!!Address:0x7f20390c57-0!!Address:0x7f2039
dataSize will be more than the pixel data size because for our platforms pitch > width, it’s expected, just like your log print, it should work ideally but it will copy the extra bytes from the pitch. I think you cannot check all the pixel value only by eye.
BTW, I noticed you are using Tegra platform, you should use these code:
            if(num_planes>0)
Although I include nvbufsurface.h, program still can not find NvBufSurfaceMap.
cc -c -o deepstream_test3_app.o -DPLATFORM_TEGRA -I../../../includes `pkg-config --cflags gstreamer-1.0` deepstream_test3_app.c
cc -o deepstream-test3-app deepstream_test3_app.o `pkg-config --libs gstreamer-1.0` -L/opt/nvidia/deepstream/deepstream-4.0/lib/ -lnvdsgst_meta -lnvds_meta -lnvdsgst_helper -lm -Wl,-rpath,/opt/nvidia/deepstream/deepstream-4.0/lib/,-lcudart,-ljpeg
deepstream_test3_app.o: In function `tiler_src_pad_buffer_probe':
deepstream_test3_app.c:(.text+0x418): undefined reference to `NvBufSurfaceMap'
deepstream_test3_app.c:(.text+0x62c): undefined reference to `NvBufSurfaceSyncForDevice'
deepstream_test3_app.c:(.text+0x63c): undefined reference to `NvBufSurfaceUnMap'
collect2: error: ld returned 1 exit status
Makefile:58: recipe for target 'deepstream-test3-app' failed
make: *** [deepstream-test3-app] Error 1
My make file is:
APP:= deepstream-test3-app
TARGET_DEVICE = $(shell gcc -dumpmachine | cut -f1 -d -)
NVDS_VERSION:=4.0
LIB_INSTALL_DIR?=/opt/nvidia/deepstream/deepstream-$(NVDS_VERSION)/lib/
ifeq ($(TARGET_DEVICE),aarch64)
  CFLAGS:= -DPLATFORM_TEGRA
endif
SRCS:= $(wildcard *.c)
INCS:= $(wildcard *.h)
PKGS:= gstreamer-1.0
OBJS:= $(SRCS:.c=.o)
CFLAGS+= -I../../../includes
CFLAGS+= `pkg-config --cflags $(PKGS)`
LIBS:= `pkg-config --libs $(PKGS)`
LIBS+= -L$(LIB_INSTALL_DIR) -lnvdsgst_meta -lnvds_meta -lnvdsgst_helper -lm \
       -Wl,-rpath,$(LIB_INSTALL_DIR),-lcudart,-ljpeg
all: $(APP)
%.o: %.c $(INCS) Makefile
	$(CC) -c -o $@ $(CFLAGS) $<
$(APP): $(OBJS) Makefile
	$(CC) -o $(APP) $(OBJS) $(LIBS)
Could you help me out ?
It’s basic compile problem, you need to find the corresponding header files and specify it in your makefile, you can google for more details.
When will ā€œthe feature in later releaseā€ you say be released?
The date is still not sure.
OHHHH! I finally got it! Thank you very much!
In summary, the platform is quite important in getting a frame in video in deepstream(4.0.1). First you need to find if your platform is Tegra.
For noob like me my new makefile is:
# Copyright (c) 2018-2019, NVIDIA CORPORATION. All rights reserved.
NVDS_VERSION:=4.0
endif
       -Wl,-rpath,$(LIB_INSTALL_DIR),-lcudart,-ljpeg,-lnvbufsurface
all: $(APP)
clean:
	rm -rf $(OBJS) $(APP)
Now I’m forward to RGB picture.
when i use this make file i receive this error :
cc -o deepstream-test3-app deepstream_test3_app.o pkg-config --libs gstreamer-1.0 -L/opt/nvidia/deepstream/deepstream-4.0/lib/ -lnvdsgst_meta -lnvds_meta -lnvdsgst_helper -lm -Wl,-rpath,/opt/nvidia/deepstream/deepstream-4.0/lib/,-lcudart,-ljpeg,-lnvbufsurface
/usr/bin/ld: cannot find -lcudart
Makefile:59: recipe for target ā€˜deepstream-test3-app’ failed
can anyone help me.
You might not install cuda or cudnn. You can try to search libcudart.so in your computer and add its path in
As to how to add ,I don’t know.Have a try!
yes ,i solve it by using this:
ld -lcuda -L/usr/local/cuda/lib64
export LDFLAGS=-L/usr/local/cuda/lib64
make
thank you for reply.
Sorry, but how did you solve this issue?
although I include nvbufsurface.h, the program still can not find NvBufSurfaceMap.
