I’m running deepstream -segmentation-test and i’m wondering if it is possible to get some information that is put on the screen?
For example:
I want to get the recognized classes from the frame.
I want to know the coordinates of the class’s pixels in the frame.
Is it possible to obtain this information by editing the deepstream-segmentation-test code?
my code deepstream_segmentation_test.c. I’m use the config file dstest_segmentation_config_semantic.txt
* Copyright (c) 2019, NVIDIA CORPORATION. All rights reserved.
* Permission is hereby granted, free of charge, to any person obtaining a
* copy of this software and associated documentation files (the "Software"),
* to deal in the Software without restriction, including without limitation
* the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
#include <gst/gst.h>
#include <glib.h>
#include <stdio.h>
#include <math.h>
#include <string.h>
#include <sys/time.h>
#include <unistd.h>
#include "gstnvdsinfer.h"
#include "gstnvdsmeta.h"
#include "nvbufsurface.h"
#ifndef PLATFORM_TEGRA
#include "gst-nvmessage.h"
#endif
#define getName(var) #var
#define MAX_DISPLAY_LEN 64
#define DUMP(varname) fprintf(stderr, "%s = %x", #varname, varname);
#define PGIE_CLASS_ID_VEHICLE 0
#define PGIE_CLASS_ID_PERSON 2
/* The muxer output resolution must be set if the input streams will be of
* different resolution. The muxer will scale all the input frames to this
* resolution. */
#define MUXER_OUTPUT_WIDTH 1280
#define MUXER_OUTPUT_HEIGHT 720
/* Muxer batch formation timeout, for e.g. 40 millisec. Should ideally be set
* based on the fastest source's framerate. */
#define MUXER_BATCH_TIMEOUT_USEC 4000000
#define TILED_OUTPUT_WIDTH 512
#define TILED_OUTPUT_HEIGHT 512
/* tiler_sink_pad_buffer_probe will extract metadata received on segmentation
* src pad */
static GstPadProbeReturn
tiler_src_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
gpointer u_data)
GstBuffer *buf = (GstBuffer *) info->data;
NvDsInferSegmentationMeta *obj_meta = NULL;
NvDsMetaList * l_frame = NULL;
NvDsMetaList * l_obj = NULL;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
FILE *bbox_params_dump_file = NULL;
//NvDsInferSegmentationMeta *user_meta;
gchar bbox_file[1024] = { 0 };
NvDsUserMeta *user_meta = NULL;
gchar *user_meta_data = NULL;
NvDsUserMeta *of_user_meta = NULL;
int classe = 1;
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
for (l_obj = frame_meta->frame_user_meta_list; l_obj != NULL;
l_obj = l_obj->next) {
of_user_meta = (NvDsUserMeta *)l_obj->data;
NvDsInferSegmentationMeta *segmeta = (NvDsInferSegmentationMeta *) (of_user_meta->user_meta_data);
//Faz o crop da imagem que é mostrada no plugin
//segmeta->width = 100;
//segmeta->height = 100;
for(int pix_id = 0; pix_id < segmeta->width * segmeta->height; pix_id++) {
// altera o background da imagem
//segmeta->class_map[pix_id] = 255;
for(int pix_id_x = 0; pix_id_x < segmeta->width ; pix_id_x++) {
for(int pix_id = 0; pix_id < segmeta->height ; pix_id++) {
printf("Novo class_map: %i \n ", segmeta->class_map[pix_id * segmeta->width + pix_id_x]);
segmeta->class_map[pix_id * segmeta->width + pix_id_x] = 25;
for(int pix_id_y = 0; pix_id_y < segmeta->height ; pix_id_y++) {
printf("noovoo: %f \n", segmeta->class_probabilities_map[classe * segmeta->width * segmeta->height + pix_id_y * segmeta->width + pix_id_x ]);
printf("noovoo classe 0: %f \n", segmeta->class_probabilities_map[classe * segmeta->width * segmeta->height + 0 * segmeta->width + 0 ]);
//classe = 1;
printf("noovoo classe 1: %f \n", segmeta->class_probabilities_map[classe * segmeta->width * segmeta->height + 0 * segmeta->width + 50 ]);
//classe = 2;
printf("noovoo classe 2: %f \n", segmeta->class_probabilities_map[classe * segmeta->width * segmeta->height + 0 * segmeta->width + 55 ]);
//classe = 3;
printf("noovoo classe 3: %f \n", segmeta->class_probabilities_map[classe * segmeta->width * segmeta->height + 0 * segmeta->width + 60 ]);
printf(" classes : %i \n", segmeta->classes);
printf(" class_map: %d \n", segmeta->class_map[1]);
if (frame_meta == NULL) {
g_print ("NvDS Meta contained NULL meta \n");
return GST_PAD_PROBE_OK;
//gst_buffer_unmap (buf, &in_map_info);
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
GMainLoop *loop = (GMainLoop *) data;
switch (GST_MESSAGE_TYPE (msg)) {
case GST_MESSAGE_EOS:
g_print ("End of stream\n");
// Add the delay to show the result
usleep(2000000);
g_main_loop_quit (loop);
break;
case GST_MESSAGE_WARNING:
gchar *debug;
GError *error;
gst_message_parse_warning (msg, &error, &debug);
g_printerr ("WARNING from element %s: %s\n",
GST_OBJECT_NAME (msg->src), error->message);
g_free (debug);
g_printerr ("Warning: %s\n", error->message);
g_error_free (error);
break;
case GST_MESSAGE_ERROR:
gchar *debug;
GError *error;
gst_message_parse_error (msg, &error, &debug);
g_printerr ("ERROR from element %s: %s\n",
if (debug)
g_printerr ("Error details: %s\n", debug);
g_free (debug);
break;
case GST_MESSAGE_ELEMENT:
if (gst_nvmessage_is_stream_eos (msg)) {
guint stream_id;
if (gst_nvmessage_parse_stream_eos (msg, &stream_id)) {
g_print ("Got EOS from stream %d\n", stream_id);
break;
#endif
default:
break;
return TRUE;
static GstElement *
create_source_bin (guint index, gchar * uri)
GstElement *bin = NULL;
gchar bin_name[16] = { };
g_snprintf (bin_name, 15, "source-bin-%02d", index);
/* Create a source GstBin to abstract this bin's content from the rest of the
* pipeline */
bin = gst_bin_new (bin_name);
GstElement *source, *jpegparser, *decoder;
source = gst_element_factory_make ("filesrc", "source");
jpegparser = gst_element_factory_make ("jpegparse", "jpeg-parser");
decoder = gst_element_factory_make ("nvv4l2decoder", "nvv4l2-decoder");
if (!source || !jpegparser || !decoder)
g_printerr ("One element could not be created. Exiting.\n");
return NULL;
g_object_set (G_OBJECT (source), "location", uri, NULL);
const char *dot = strrchr(uri, '.');
if ((!strcmp (dot+1, "mjpeg")) || (!strcmp (dot+1, "mjpg")))
#ifdef PLATFORM_TEGRA
g_object_set (G_OBJECT (decoder), "mjpeg", 1, NULL);
#endif
gst_bin_add_many (GST_BIN (bin), source, jpegparser, decoder, NULL);
gst_element_link_many (source, jpegparser, decoder, NULL);
/* We need to create a ghost pad for the source bin which will act as a proxy
* for the video decoder src pad. The ghost pad will not have a target right
* now. Once the decode bin creates the video decoder and generates the
* cb_newpad callback, we will set the ghost pad target to the video decoder
* src pad. */
if (!gst_element_add_pad (bin, gst_ghost_pad_new_no_target ("src",
GST_PAD_SRC))) {
g_printerr ("Failed to add ghost pad in source bin\n");
return NULL;
GstPad *srcpad = gst_element_get_static_pad (decoder, "src");
if (!srcpad) {
g_printerr ("Failed to get src pad of source bin. Exiting.\n");
return NULL;
GstPad *bin_ghost_pad = gst_element_get_static_pad (bin, "src");
if (!gst_ghost_pad_set_target (GST_GHOST_PAD (bin_ghost_pad),
srcpad)) {
g_printerr ("Failed to link decoder src pad to source bin ghost pad\n");
return bin;
int
main (int argc, char *argv[])
GMainLoop *loop = NULL;
GstElement *pipeline = NULL, *streammux = NULL, *sink = NULL, *seg = NULL,
*nvsegvisual = NULL, *tiler = NULL;
GstElement *transform = NULL;
#endif
GstBus *bus = NULL;
guint bus_watch_id;
GstPad *seg_src_pad = NULL;
GstPad *nvsegvisual_sink_pad = NULL;
guint i, num_sources;
guint tiler_rows, tiler_columns;
guint pgie_batch_size;
/* Check input arguments */
if (argc < 3) {
g_printerr ("Usage: %s config_file <file1> [file2] ... [fileN] \n", argv[0]);
return -1;
num_sources = argc - 2;
/* Standard GStreamer initialization */
gst_init (&argc, &argv);
loop = g_main_loop_new (NULL, FALSE);
/* Create gstreamer elements */
/* Create Pipeline element that will form a connection of other elements */
pipeline = gst_pipeline_new ("dstest-image-decode-pipeline");
/* Create nvstreammux instance to form batches from one or more sources. */
streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
if (!pipeline || !streammux) {
return -1;
gst_bin_add (GST_BIN (pipeline), streammux);
for (i = 0; i < num_sources; i++) {
GstPad *sinkpad, *srcpad;
gchar pad_name[16] = { };
GstElement *source_bin = create_source_bin (i, argv[i + 2]);
if (!source_bin) {
g_printerr ("Failed to create source bin. Exiting.\n");
return -1;
gst_bin_add (GST_BIN (pipeline), source_bin);
g_snprintf (pad_name, 15, "sink_%u", i);
sinkpad = gst_element_get_request_pad (streammux, pad_name);
if (!sinkpad) {
g_printerr ("Streammux request sink pad failed. Exiting.\n");
return -1;
srcpad = gst_element_get_static_pad (source_bin, "src");
if (!srcpad) {
return -1;
if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
g_printerr ("Failed to link source bin to stream muxer. Exiting.\n");
return -1;
gst_object_unref (srcpad);
gst_object_unref (sinkpad);
/* Use nvinfer to infer on batched frame. */
seg = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
nvsegvisual = gst_element_factory_make ("nvsegvisual", "nvsegvisual");
/* Use nvtiler to composite the batched frames into a 2D tiled array based
* on the source of the frames. */
tiler = gst_element_factory_make ("nvmultistreamtiler", "nvtiler");
transform = gst_element_factory_make ("nvegltransform", "transform");
#endif
sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
if (!seg || !nvsegvisual || !tiler || !sink) {
return -1;
if(!transform) {
g_printerr ("One tegra element could not be created. Exiting.\n");
return -1;
#endif
g_object_set (G_OBJECT (streammux), "width", MUXER_OUTPUT_WIDTH, "height",
MUXER_OUTPUT_HEIGHT, "batch-size", num_sources,
"batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
/* Configure the nvinfer element using the nvinfer config file. */
g_object_set (G_OBJECT (seg), "config-file-path", argv[1], NULL);
/* Override the batch-size set in the config file with the number of sources. */
g_object_get (G_OBJECT (seg), "batch-size", &pgie_batch_size, NULL);
if (pgie_batch_size != num_sources) {
g_printerr
("WARNING: Overriding infer-config batch-size (%d) with number of sources (%d)\n",
pgie_batch_size, num_sources);
g_object_set (G_OBJECT (seg), "batch-size", num_sources, NULL);
g_object_set (G_OBJECT (nvsegvisual), "batch-size", num_sources, NULL);
g_object_set (G_OBJECT (nvsegvisual), "width", 512, NULL);
g_object_set (G_OBJECT (nvsegvisual), "height", 512, NULL);
tiler_rows = (guint) sqrt (num_sources);
tiler_columns = (guint) ceil (1.0 * num_sources / tiler_rows);
/* we set the tiler properties here */
g_object_set (G_OBJECT (tiler), "rows", tiler_rows, "columns", tiler_columns,
"width", TILED_OUTPUT_WIDTH, "height", TILED_OUTPUT_HEIGHT, NULL);
g_object_set(G_OBJECT(sink), "async", FALSE, NULL);
/* we add a message handler */
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
gst_object_unref (bus);
/* Set up the pipeline */
/* Add all elements into the pipeline */
gst_bin_add_many (GST_BIN (pipeline), seg, nvsegvisual, tiler, transform, sink, NULL);
/* we link the elements together
* nvstreammux -> nvinfer -> nvsegvidsual -> nvtiler -> transform -> video-renderer */
if (!gst_element_link_many (streammux, seg, nvsegvisual, tiler, transform, sink, NULL))
g_printerr ("Elements could not be linked. Exiting.\n");
return -1;
#else
gst_bin_add_many (GST_BIN (pipeline), seg, nvsegvisual, tiler, sink, NULL);
/* Link the elements together
* nvstreammux -> nvinfer -> nvsegvisual -> nvtiler -> video-renderer */
if (!gst_element_link_many (streammux, seg, nvsegvisual, tiler, sink, NULL)) {
return -1;
#endif
/* Lets add probe to get informed of the meta data generated, we add probe to
* the src pad of the nvseg element, since by that time, the buffer would have
* had got all the segmentation metadata. */
seg_src_pad = gst_element_get_static_pad (seg, "src");
if (!seg_src_pad)
g_print ("Unable to get src pad\n");
else
gst_pad_add_probe (seg_src_pad, GST_PAD_PROBE_TYPE_BUFFER,
tiler_src_pad_buffer_probe, NULL, NULL);
nvsegvisual_sink_pad = gst_element_get_static_pad (nvsegvisual, "sink");
if (!nvsegvisual_sink_pad)
else
gst_pad_add_probe (nvsegvisual_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
nvsegvisual_sink_pad_buffer_probe, NULL, NULL);
/* Set the pipeline to "playing" state */
g_print ("Now playing:");
g_print (" %s,", argv[i + 2]);
g_print ("\n");
gst_element_set_state (pipeline, GST_STATE_PLAYING);
/* Wait till pipeline encounters an error or EOS */
g_print ("Running...\n");
g_main_loop_run (loop);
/* Out of the main loop, clean up nicely */
g_print ("Returned, stopping playback\n");
gst_element_set_state (pipeline, GST_STATE_NULL);
g_print ("Deleting pipeline\n");
gst_object_unref (GST_OBJECT (pipeline));
g_source_remove (bus_watch_id);
g_main_loop_unref (loop);
return 0;
deepstream-app --version-all
deepstream-app version 4.0.2
DeepStreamSDK 4.0.2
CUDA Driver Version: 10.0
CUDA Runtime Version: 10.0
TensorRT Version: 6.0
cuDNN Version: 7.6
libNVWarp360 Version: 2.0.0d5
