Preprocessing of frames - gst-dsexample
• Hardware Platform (Jetson / GPU) Jetson Nano
• DeepStream Version 5.0
• JetPack Version (valid for Jetson only) 4.4-b144
• TensorRT Version 7.1.3
• Issue Type( questions, new requirements, bugs) question
Dear all,
I am trying to apply a pre-processing to frames before they reach the PGIE.
I am able to place a dsexample instance after the PGIE, filter the frames with the opencv sepia filtering and save the image on the disk:
  // Use openCV to remove padding and convert RGBA to BGR. Can be skipped if
  // algorithm can handle padded RGBA data.
  in_mat =
      cv::Mat (dest_height, dest_width,
      CV_8UC4, nvbuf->surfaceList[0].mappedAddr.addr[0],
      nvbuf->surfaceList[0].pitch);
  out_mat =
      cv::Mat (cv::Size(dest_width, dest_height), CV_8UC3);
  saved_mat =
  cv::cvtColor (in_mat, out_mat, cv::COLOR_RGBA2BGR);
  cv::transform(out_mat, saved_mat, kernel);
  time( &rawtime );
  info = localtime( &rawtime );
  static gint dump = 0;
  char filename[64];
  snprintf(filename, 64, "/home/jnano/jnanoImages/%04d_%02d_%02d_%02d_%02d_%02d.jpg", info->tm_year+1900, info->tm_mon+1, info->tm_mday+1, info->tm_hour, info->tm_min, info->tm_sec);
  cv::imwrite(filename, saved_mat);
However, I am not able to execute such filtering before the PGIE on all the frames.
I have tried a number of different approaches.
I have tried to modify the gst-dsexample and follow the same approach that it is used for blurring object, but I obtain a segmentation fault:
/* Cache the mapped data for CPU access */
    NvBufSurfaceSyncForCpu (surface, frame_meta->batch_id, 0);
    in_mat =
                cv::Mat (surface->surfaceList[frame_meta->batch_id].planeParams.height[0],
                surface->surfaceList[frame_meta->batch_id].planeParams.width[0], CV_8UC4,
                surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0],
                surface->surfaceList[frame_meta->batch_id].planeParams.pitch[0]);
    cv::transform(in_mat, in_mat, kernel);
    in_mat.convertTo(in_mat,CV_8UC4);
    /* Cache the mapped data for device access */
    NvBufSurfaceSyncForDevice (surface, frame_meta->batch_id, 0);
However, in the execution of cv::transform(in_mat, in_mat, kernel); I get a segmentation fault :(
Moreover, I I get
5168 Segmentation fault (core dumped)
Even if I try to copy the buffer instead of doing a transform:
cv::Mat image_copy = in_mat.clone();
However, no segmentation fault at all if I use another opencv function such as:
cv::filter2D(in_mat, in_mat,-1, kernel);
The problem is that of course the function is not doing what I need to do…
But the PGIE is correctly receiving the filtered images (you see below that the filter2D creates a white image because of the convolution):
This is the result of the filter2D that of course is doing a convolution of the pixels and not what I need that is a meshing of the different channels.
I think that this give an interesting information. The problem might come from the specific operation that the opencv function cv::transform is doing on the deepstream buffer.
Finally, I have also tried to edit the function get_converted_mat as follows:
static GstFlowReturn
filter_frame (GstDsExample * dsexample, NvBufSurface *input_buf, gint idx,
    NvOSD_RectParams * crop_rect_params, gdouble & ratio, gint input_width,
    gint input_height)
  NvBufSurfTransform_Error err;
  NvBufSurfTransformConfigParams transform_config_params;
  NvBufSurfTransformParams transform_params;
  NvBufSurfTransformRect src_rect;
  NvBufSurfTransformRect dst_rect;
  NvBufSurface ip_surf;
  cv::Mat in_mat, out_mat, filtered_mat;
  ip_surf = *input_buf;
  time_t rawtime;
  struct tm *info;
  ip_surf.numFilled = ip_surf.batchSize = 1;
  ip_surf.surfaceList = &(input_buf->surfaceList[idx]);
  gint src_left = GST_ROUND_UP_2(crop_rect_params->left);
  gint src_top = GST_ROUND_UP_2(crop_rect_params->top);
  gint src_width = GST_ROUND_DOWN_2(crop_rect_params->width);
  gint src_height = GST_ROUND_DOWN_2(crop_rect_params->height);
  gint src_left = crop_rect_params->left;
  gint src_top = crop_rect_params->top;
  gint src_width = crop_rect_params->width;
  gint src_height = crop_rect_params->height;
  //g_print("ltwh = %d %d %d %d \n", src_left, src_top, src_width, src_height);
  guint dest_width, dest_height;
  dest_width = src_width;
  dest_height = src_height;
  NvBufSurface *nvbuf;
  NvBufSurfaceCreateParams create_params;
  create_params.gpuId  = dsexample->gpu_id;
  create_params.width  = dest_width;
  create_params.height = dest_height;
  create_params.size = 0;
  create_params.colorFormat = NVBUF_COLOR_FORMAT_RGBA;
  create_params.layout = NVBUF_LAYOUT_PITCH;
#ifdef __aarch64__
  create_params.memType = NVBUF_MEM_DEFAULT;
#else
  create_params.memType = NVBUF_MEM_CUDA_UNIFIED;
#endif
  NvBufSurfaceCreate (&nvbuf, 1, &create_params);
  // Configure transform session parameters for the transformation
  transform_config_params.compute_mode = NvBufSurfTransformCompute_Default;
  transform_config_params.gpu_id = dsexample->gpu_id;
  transform_config_params.cuda_stream = dsexample->cuda_stream;
  // Set the transform session parameters for the conversions executed in this
  // thread.
  err = NvBufSurfTransformSetSessionParams (&transform_config_params);
  if (err != NvBufSurfTransformError_Success) {
    GST_ELEMENT_ERROR (dsexample, STREAM, FAILED,
        ("NvBufSurfTransformSetSessionParams failed with error %d", err), (NULL));
    goto error;
  // Calculate scaling ratio while maintaining aspect ratio
  ratio = MIN (1.0 * dest_width/ src_width, 1.0 * dest_height / src_height);
  if ((crop_rect_params->width == 0) || (crop_rect_params->height == 0)) {
        ("%s:crop_rect_params dimensions are zero",__func__), (NULL));
    goto error;
#ifdef __aarch64__
  if (ratio <= 1.0 / 16 || ratio >= 16.0) {
    // Currently cannot scale by ratio > 16 or < 1/16 for Jetson
    goto error;
#endif
  // Set the transform ROIs for source and destination
  src_rect = {(guint)src_top, (guint)src_left, (guint)src_width, (guint)src_height};
  dst_rect = {0, 0, (guint)dest_width, (guint)dest_height};
  // Set the transform parameters
  transform_params.src_rect = &src_rect;
  transform_params.dst_rect = &dst_rect;
  transform_params.transform_flag =
    NVBUFSURF_TRANSFORM_FILTER | NVBUFSURF_TRANSFORM_CROP_SRC |
      NVBUFSURF_TRANSFORM_CROP_DST;
  transform_params.transform_filter = NvBufSurfTransformInter_Default;
  //Memset the memory
  NvBufSurfaceMemSet (nvbuf, 0, 0, 0);
  GST_DEBUG_OBJECT (dsexample, "Scaling and converting input buffer\n");
  // Transformation scaling+format conversion if any.
  err = NvBufSurfTransform (&ip_surf, nvbuf, &transform_params);
        ("NvBufSurfTransform failed with error %d while converting buffer", err),
        (NULL));
    goto error;
  // Map the buffer so that it can be accessed by CPU
  //if (NvBufSurfaceMap (nvbuf, 0, 0, NVBUF_MAP_READ) != 0){
  if (NvBufSurfaceMap (nvbuf, 0, 0, NVBUF_MAP_READ_WRITE) != 0){
    goto error;
  // Cache the mapped data for CPU access
  NvBufSurfaceSyncForCpu (nvbuf, 0, 0);
  in_mat =
  out_mat =
  filtered_mat =
  //cv::cvtColor (in_mat, out_mat, cv::COLOR_RGBA2BGR);
  //cv::transform(out_mat, filtered_mat, kernel);
  //cv::cvtColor (in_mat, in_mat, cv::COLOR_RGBA2BGR);
  //cv::cvtColor (in_mat, in_mat, cv::COLOR_BGR2RGBA);
  NvBufSurfaceSyncForDevice (nvbuf, 0, 0);
  time( &rawtime );
  char filename[64];
  if (NvBufSurfaceUnMap (nvbuf, 0, 0)){
    goto error;
  NvBufSurfaceDestroy(nvbuf);
#ifdef __aarch64__
  // To use the converted buffer in CUDA, create an EGLImage and then use
  // CUDA-EGL interop APIs
  if (USE_EGLIMAGE) {
    if (NvBufSurfaceMapEglImage (dsexample->inter_buf, 0) !=0 ) {
      goto error;
    // dsexample->inter_buf->surfaceList[0].mappedAddr.eglImage
    // Use interop APIs cuGraphicsEGLRegisterImage and
    // cuGraphicsResourceGetMappedEglFrame to access the buffer in CUDA
    // Destroy the EGLImage
    NvBufSurfaceUnMapEglImage (dsexample->inter_buf, 0);
#endif
  /* We will first convert only the Region of Interest (the entire frame or the
   * object bounding box) to RGB and then scale the converted RGB frame to
   * processing resolution. */
  return GST_FLOW_OK;
error:
  return GST_FLOW_ERROR;
With this approach I do not get any segmentation fault, but the PGIE is NOT receiving the filtered image. Instead what the PGIE receive is the original frames. It seems that I am not writing in the buffer as it was happening in the previous example.
I hope that you could give me some suggestion.
Thank you very much!!
What is your pipeline? Can you send the code for us to reproduce the problem?
Ciao Fiona,
of course I can.
First of all, please find attached to the message the source code for gstdsexample.cpp.
You will see in the code that I have used the input parameter “process-full-frame” as a trigger to make this custom plugin applicable both for saving the frames if something is detected by PGIE and for pre-processing all the frames to be the input og PGIE. This second functionality is what I cannot make it work.
Relevant code will be from line 1136 to 1240.
When it comes to the pipeline, I have edited the example of deepstream_test3_app.
Please find here below the main function:
int
main (int argc, char *argv[])
  GMainLoop *loop = NULL;
  GstElement *pipeline = NULL, *streammux = NULL, *sink = NULL, *pgie = NULL,
      *nvvidconv = NULL, *nvosd = NULL, *tiler = NULL;
  GstElement *msgconv = NULL, *msgbroker = NULL, *tee = NULL;
  GstElement *queue1 = NULL, *queue2 = NULL;
  GstElement *videobalance1 = NULL;
  GstElement *saveframe = NULL;
  GstElement *filterframe = NULL;
#ifdef PLATFORM_TEGRA
  GstElement *transform = NULL;
#endif
  GstBus *bus = NULL;
  guint bus_watch_id;
  GstPad *tee_render_pad = NULL;
  GstPad *tee_msg_pad = NULL;
  GstPad *tiler_src_pad = NULL;
  guint i, num_sources;
  guint tiler_rows, tiler_columns;
  guint pgie_batch_size;
  GstPad *sink_pad = NULL;
  GstPad *src_pad = NULL;
  /* Check input arguments */
  if (argc < 2) {
    g_printerr ("Usage: %s <uri1> [uri2] ... [uriN] \n", argv[0]);
    return -1;
  num_sources = argc - 1;
  /* Standard GStreamer initialization */
  gst_init (&argc, &argv);
  loop = g_main_loop_new (NULL, FALSE);
  /* Create gstreamer elements */
  /* Create Pipeline element that will form a connection of other elements */
  pipeline = gst_pipeline_new ("dstest3-pipeline");
  /* Create nvstreammux instance to form batches from one or more sources. */
  streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
  //videobalance1 = gst_element_factory_make ("videobalance", "videobalance1-pre");
  if (!pipeline || !streammux) {
    g_printerr ("One element could not be created. Exiting.\n");
    return -1;
  gst_bin_add (GST_BIN (pipeline), streammux);
  for (i = 0; i < num_sources; i++) {
    GstPad *sinkpad, *srcpad;
    gchar pad_name[16] = { };
    GstElement *source_bin = create_source_bin (i, argv[i + 1]);
    if (!source_bin) {
      g_printerr ("Failed to create source bin. Exiting.\n");
      return -1;
    gst_bin_add (GST_BIN (pipeline), source_bin);
    g_snprintf (pad_name, 15, "sink_%u", i);
    sinkpad = gst_element_get_request_pad (streammux, pad_name);
    if (!sinkpad) {
      g_printerr ("Streammux request sink pad failed. Exiting.\n");
      return -1;
    srcpad = gst_element_get_static_pad (source_bin, "src");
    if (!srcpad) {
      g_printerr ("Failed to get src pad of source bin. Exiting.\n");
      return -1;
    if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
      g_printerr ("Failed to link source bin to stream muxer. Exiting.\n");
      return -1;
    gst_object_unref (srcpad);
    gst_object_unref (sinkpad);
  /* Use nvinfer to infer on batched frame. */
  pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
  /* Use nvtiler to composite the batched frames into a 2D tiled array based
   * on the source of the frames. */
  tiler = gst_element_factory_make ("nvmultistreamtiler", "nvtiler");
  /* Use convertor to convert from NV12 to RGBA as required by nvosd */
  nvvidconv = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter");
  /* Create OSD to draw on the converted RGBA buffer */
  nvosd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
  /* Create msg converter to generate payload from buffer metadata */
  msgconv = gst_element_factory_make ("nvmsgconv", "nvmsg-converter");
  /* Create msg broker to send payload to server */
  msgbroker = gst_element_factory_make ("nvmsgbroker", "nvmsg-broker");
  /* Create tee to render buffer and send message simultaneously*/
  tee = gst_element_factory_make ("tee", "nvsink-tee");
  /* Create queues */
  queue1 = gst_element_factory_make ("queue", "nvtee-que1");
  queue2 = gst_element_factory_make ("queue", "nvtee-que2");
  // ############# MODIFICA
  /* Finally render the osd output */
  //transform = gst_element_factory_make ("nvegltransform", "nvegl-transform");
  transform = gst_element_factory_make ("queue", "queue");
#endif
  //sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
//  sink = gst_element_factory_make ("nvoverlaysink", "nvvideo-renderer");
  sink = gst_element_factory_make ("fakesink", "nvvideo-renderer");
  saveframe = gst_element_factory_make ("dsexample", "save-frame");
  filterframe = gst_element_factory_make ("dsexample", "filter-frame");
  if (!pgie || !tiler || !nvvidconv || !nvosd || !msgconv || !msgbroker || !tee
      || !queue1 || !queue2 || !sink || !saveframe || !filterframe) {
    return -1;
  if(!transform) {
    g_printerr ("One tegra element could not be created. Exiting.\n");
    return -1;
#endif
  //g_object_set (G_OBJECT(videobalance1), "saturation", 0.0, NULL);
  g_object_set (G_OBJECT(sink), "sync", FALSE, NULL);
  g_object_set (G_OBJECT (streammux), "width", MUXER_OUTPUT_WIDTH, "height",
      MUXER_OUTPUT_HEIGHT, "batch-size", num_sources,
      "batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
  /* Configure the nvinfer element using the nvinfer config file. */
  g_object_set (G_OBJECT (pgie),
      "config-file-path", PGIE_CONFIG_FILE, NULL);
  /* Override the batch-size set in the config file with the number of sources. */
  g_object_get (G_OBJECT (pgie), "batch-size", &pgie_batch_size, NULL);
  if (pgie_batch_size != num_sources) {
    g_printerr
        ("WARNING: Overriding infer-config batch-size (%d) with number of sources (%d)\n",
        pgie_batch_size, num_sources);
    g_object_set (G_OBJECT (pgie), "batch-size", num_sources, NULL);
  tiler_rows = (guint) sqrt (num_sources);
  tiler_columns = (guint) ceil (1.0 * num_sources / tiler_rows);
  /* we set the tiler properties here */
  g_object_set (G_OBJECT (tiler), "rows", tiler_rows, "columns", tiler_columns,
      "width", TILED_OUTPUT_WIDTH, "height", TILED_OUTPUT_HEIGHT, NULL);
  g_object_set (G_OBJECT(msgconv), "config", MSCONV_CONFIG_FILE, NULL);
  g_object_set (G_OBJECT(msgconv), "payload-type", schema_type, NULL);
  g_object_set (G_OBJECT(msgbroker), "proto-lib", proto_lib,
                "conn-str", conn_str, "config", cfg_file, "topic", topic, "sync", FALSE, NULL);
  g_object_set (G_OBJECT (saveframe), "full-frame", TRUE, NULL);
  g_object_set (G_OBJECT (filterframe), "full-frame", FALSE, NULL);
  /* we add a message handler */
  bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
  bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
  gst_object_unref (bus);
  /* Set up the pipeline */
  /* we add all elements into the pipeline */
  gst_bin_add_many (GST_BIN (pipeline),filterframe, pgie, tiler, nvvidconv, nvosd, tee, queue1, queue2, msgconv,
      msgbroker, transform, saveframe, sink, NULL);
  /* we link the elements together
   * nvstreammux -> nvinfer -> nvtiler -> nvvidconv -> nvosd -> video-renderer */
  if (!gst_element_link_many (streammux, pgie, tiler, nvvidconv, nvosd, transform, sink,
          NULL)) {
    g_printerr ("Elements could not be linked. Exiting.\n");
    return -1;
  if (!gst_element_link_many (streammux, filterframe, pgie, tiler, nvvidconv, nvosd, tee, NULL)) {
    return -1;
  if (!gst_element_link_many (queue1, saveframe, msgconv, msgbroker, NULL)) {
    return -1;
  if (!gst_element_link_many (queue2, transform, sink, NULL)) {
      return -1;
#else
gst_bin_add_many (GST_BIN (pipeline), pgie, tiler, nvvidconv, nvosd, tee, queue1, queue2, msgconv,
      msgbroker, sink,
      NULL);
   * nvstreammux -> nvinfer -> nvtiler -> nvvidconv -> nvosd -> tee -> video-renderer
   *        |-> msgconv -> msgbroker  */
  /* we link the elements together */
  /* file-source -> h264-parser -> nvh264-decoder -> nvstreammux ->
   * nvinfer -> nvvidconv -> nvosd -> tee -> video-renderer
  if (!gst_element_link_many (streammux, pgie, tiler, nvvidconv, nvosd, sink,
          NULL)) {
    return -1;
#endif
  sink_pad = gst_element_get_static_pad (queue1, "sink");
  tee_msg_pad = gst_element_get_request_pad (tee, "src_%u");
  tee_render_pad = gst_element_get_request_pad (tee, "src_%u");
  if (!tee_msg_pad || !tee_render_pad) {
    g_printerr ("Unable to get request pads\n");
    return -1;
  if (gst_pad_link (tee_msg_pad, sink_pad) != GST_PAD_LINK_OK) {
    g_printerr ("Unable to link tee and message converter\n");
    gst_object_unref (sink_pad);
    return -1;
  sink_pad = gst_element_get_static_pad (queue2, "sink");
  if (gst_pad_link (tee_render_pad, sink_pad) != GST_PAD_LINK_OK) {
    g_printerr ("Unable to link tee and render\n");
    return -1;
  /* Lets add probe to get informed of the meta data generated, we add probe to
   * the sink pad of the osd element, since by that time, the buffer would have
   * had got all the metadata. */
  tiler_src_pad = gst_element_get_static_pad (pgie, "src");
  if (!tiler_src_pad)
    g_print ("Unable to get src pad\n");
  else
    gst_pad_add_probe (tiler_src_pad, GST_PAD_PROBE_TYPE_BUFFER,
        tiler_src_pad_buffer_probe, NULL, NULL);
  /* Set the pipeline to "playing" state */
  g_print ("Now playing:");
    g_print (" %s,", argv[i + 1]);
  g_print ("\n");
  gst_element_set_state (pipeline, GST_STATE_PLAYING);
  /* Wait till pipeline encounters an error or EOS */
  g_print ("Running...\n");
  g_main_loop_run (loop);
  /* Out of the main loop, clean up nicely */
  g_print ("Returned, stopping playback\n");
  gst_element_set_state (pipeline, GST_STATE_NULL);
  g_print ("Deleting pipeline\n");
  gst_object_unref (GST_OBJECT (pipeline));
  g_source_remove (bus_watch_id);
  g_main_loop_unref (loop);
  return 0;
If you need further information, I am available.
Thank you very much in advance for your support.
gstdsexample.cpp (50.8 KB)
What is the result with the original test3 sample app?
Ciao Fiona,
Good morning :)
Please find here below the results of the tests:
  1. Original test3 app: it works perfectly
  2. Test3 app + gst-dsexample in the pipeline to save frames after PGIE: it works perfectly
  3. Test3 app + gst-dsexample in the pipeline to save frames after PGIE + pre-processing with gst-dsexample to all frames before PGIE (implementation as in lines 1170 - 1240 of gstdsexample.cpp - codes follow below) : segmentation fault
     } else if (0) {
       //if (1) {
         NvDsMetaList * l_obj = NULL;
         for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
           l_frame = l_frame->next)
           frame_meta = (NvDsFrameMeta *) (l_frame->data);
           cv::Mat in_mat, conv_mat;
           NvOSD_RectParams rect_params;
           /* Scale the entire frame to processing resolution */
           rect_params.left = 0;
           rect_params.top = 0;
           rect_params.width = dsexample->video_info.width;
           rect_params.height = dsexample->video_info.height;
           l_obj = frame_meta->obj_meta_list;
           if (1) {
             /* Map the buffer so that it can be accessed by CPU */
             if (surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0] == NULL){
               if (NvBufSurfaceMap (surface, frame_meta->batch_id, 0, NVBUF_MAP_READ_WRITE) != 0){
                     ("%s:buffer map to be accessed by CPU failed", __func__), (NULL));
             in_mat =
           //cv::filter2D(in_mat, in_mat,-1, kernel);
           //cv::Mat image_copy = in_mat.clone();
           //cv::cvtColor (image_copy, image_copy, cv::COLOR_RGBA2BGR);
           //g_print ("Transform start");
           //g_print ("Transform done");
           //in_mat.convertTo(in_mat,CV_8UC4);
           //g_print("\n inmat \n");
           //g_print(in_mat);
           //std::cout << "conv_mat = " << std::endl << " "  << image_copy << std::endl << std::endl;
           //int from_to[] = { 0,0, 1,1, 2,2, 3,3 };
           //cv::mixChannels( &in_mat, 1, &in_mat, 1, from_to, 4 );
           /* Process the object crop to obtain label */
           //output = DsExampleProcess (dsexample->dsexamplelib_ctx, dsexample->cvmat->data);
             /* Attach labels for the object */
            //attach_metadata_object (dsexample, obj_meta, output);
           //free (output);
           //cv::cvtColor (in_mat, in_mat, cv::COLOR_RGBA2BGRA);
           //g_print(std::to_string(frame_meta->batch_id));
           //std::cout << surface->surfaceList[frame_meta->batch_id].planeParams.pitch[0] << std::endl;
  4. Test3 app + gst-dsexample in the pipeline to save frames after PGIE + pre-processing with gst-dsexample to all frames before PGIE (implementation as in lines 1136- 1169 of gstdsexample.cpp - codes follow below): no segmentation fault, but the image that arrives to PGIE is NOT processed. It seems that I am not doing anything to the buffer
       } else if (!dsexample->process_full_frame) {
       //if (1) {
           if (frame_meta->obj_meta_list != NULL){
             if (filter_frame (dsexample, surface, i, &rect_params,
                   scale_ratio, dsexample->video_info.width,
                   dsexample->video_info.height) != GST_FLOW_OK) {
               goto error;
           /* Process to get the output */
           output =
           /* Attach the metadata for the full frame */
           //attach_metadata_full_frame (dsexample, frame_meta, scale_ratio, output, i);
           i++;
           free (output);
The function filter_frame is a modified version of get_converted_mat:
    gint input_height)
  time_t rawtime;
  struct tm *info;
#ifdef __aarch64__
#else
#endif
  // thread.
    goto error;
    goto error;
#ifdef __aarch64__
    goto error;
#endif
  //Memset the memory
        (NULL));
    goto error;
    goto error;
  in_mat =
  out_mat =
  filtered_mat =
  time( &rawtime );
  char filename[64];
    goto error;
#ifdef __aarch64__
  if (USE_EGLIMAGE) {
      goto error;
#endif
  return GST_FLOW_OK;
error:
I really hope that you can help me @Fiona.Chen .
Thank you very much in advance and have a nice day!
Dear @Fiona.Chen ,
Tentative number 3 that I have described in my previous message still gives me segmentation fault.
However, I was able to solve the problem by changing the way memory is mapped in tentative 4.
In the functiont "gst_dsexample_transform_ip " i changed from GST_MAP_READW to GST_MAP_READWRITE.
    if (!gst_buffer_map (inbuf, &in_map_info, GST_MAP_READWRITE)) {
      g_print ("Error: Failed to map gst buffer\n");
      goto error;
Then, instead of calling the get_converted_mat function. I call the following function:
    gint input_height)
  time_t rawtime;
  struct tm *info;
#ifdef __aarch64__
#else
#endif
  // thread.
    goto error;
    goto error;
#ifdef __aarch64__
    goto error;
#endif
  //Memset the memory
        (NULL));
    goto error;
  // OpenCV CUDA Test
  cv::cuda::GpuMat gpuMat;
  gpuMat = cv::cuda::GpuMat(dest_height,
                            dest_width,
                            CV_8UC4,
                            (void *) input_buf->surfaceList[index].dataPtr,
                            input_buf->surfaceList[index].pitch);
  const int aDstOrder[] = {2,0,1,3};
  cv::cuda::swapChannels(gpuMat, aDstOrder);
    goto error;
  in_mat =
  out_mat =
  filtered_mat =
  NvBufSurfaceMemSet (&ip_surf, 0, 0, 0);
  err = NvBufSurfTransform (nvbuf, &ip_surf, &transform_params);
        (NULL));
    goto error;
  time( &rawtime );
  char filename[64];
    goto error;
#ifdef __aarch64__
  if (USE_EGLIMAGE) {
      goto error;
#endif
  return GST_FLOW_OK;
error:
