How to run H265 RTSP IP camera in deepstream_app
Greetings,
Below i have mentioned details of camera that I am using,
  • HikVision Camera
  • H.265+ encodings
  • model: DS-2CD202WF-I
When I play the url in VSPlayer I am able to view the stream.
If I run this command
gst-launch-1.0 uridecodebin rtsp://<admin>:<password>@192.168.0.175:554/Stream/Channels/101 ! nvoverlaysink
I get
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://<admin>:<password>@192.168.0.175:554/Stream/Channels/101
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
ERROR: from element /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source: Unauthorized
Additional debug info:
gstrtspsrc.c(6116): gst_rtspsrc_send (): /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source:
Unauthorized (401)
ERROR: pipeline doesn't want to preroll.
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
I tried https://devtalk.nvidia.com/default/topic/1058086/deepstream-sdk/how-to-run-rtp-camera-in-deepstream-on-nano/post/5369243/#5369243 as suggested by DaneLLL but I get a blank screen.
I have also tried https://devtalk.nvidia.com/default/topic/1058086/deepstream-sdk/how-to-run-rtp-camera-in-deepstream-on-nano/post/5367474/#5367474
and I get the blankscreen again
deepstream-app -c /home/botjet/PD_Wrk/deepstream_sdk_v4.0.1_jetson/samples/configs/deepstream-app/source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx1.txt
Creating LL OSD context new
cb_sourcesetup set 100 latency
Runtime commands:
	h: Print this help
	q: Quit
	p: Pause
	r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
      To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:189>: Pipeline ready
** INFO: <bus_callback:175>: Pipeline running
**PERF: FPS 0 (Avg)	FPS 1 (Avg)
**PERF: 0.00 (0.00)	0.00 (0.00)
ERROR from source: Could not read from resource.
Debug info: gstrtspsrc.c(5917): gst_rtsp_src_receive_response (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstRTSPSrc:source:
Could not receive message. (Timeout while waiting for server response)
Quitting
Debug info: gstrtspsrc.c(5917): gst_rtsp_src_receive_response (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin1/GstURIDecodeBin:src_elem/GstRTSPSrc:source:
App run failed
Thank you.
Please check if you can run
$ export RTSP_PATH=rtsp://admin:int123$%^@192.168.0.175:554/Stream/Channels/101
$ gst-launch-1.0 rtspsrc location="$RTSP_PATH" ! rtph265depay ! h265parse ! omxh265dec ! nvoverlaysink
$ gst-launch-1.0 rtspsrc location="$RTSP_PATH" ! rtph265depay ! h265parse ! nvv4l2decoder ! nvoverlaysink
Let’s firstly confirm the URI is valid.
Hello @DaneLLL,
Thank you for your quick reply.
I applied your method in my Jetson nano and the stream is unavailable. So this means my uri is wrong?
Opening in BLOCKING MODE
Progress: (connect) Connecting to rtsp://<admin>:<password>@192.168.0.175:554/live2.sdp
ERROR: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0: Unauthorized
gstrtspsrc.c(6116): gst_rtspsrc_send (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0:
Unauthorized (401)
I checked these uri in VLC and I get good results,
  • rtsp://:@192.168.0.175:554/Stream/Channels/101
  • rtsp://:@192.168.0.175:554/live2.sdp
I also tried
<ol>
<li>./test-mp4 /home/botjet/PD_Wrk/deepstream_sdk_v4.0.1_jetson/samples/streams/sample_1080p_h265.mp4
stream ready at rtsp://127.0.0.1:8554/test</li>
<li>export RTSP_PATH=rtsp://127.0.0.1:8554/test</li>
<li>gst-launch-1.0 rtspsrc location="$RTSP_PATH" ! rtph265depay ! h265parse ! nvv4l2decoder ! nvoverlaysink</li>
</ol>
and this too gave error
Progress: (connect) Connecting to rtsp://127.0.0.1:8554/test
ERROR: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0: Could not read from resource.
gstrtspsrc.c(5917): gst_rtsp_src_receive_response (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0:
I will look into my uri and then get back
Thank you.
My mistake,
I have set the camera to H.264 hence it currently works with
gst-launch-1.0 rtspsrc location="$RTSP_PATH" ! rtph264depay ! h264parse ! omxh264dec ! nvoverlaysink
Thank you DaneLLL for setting me in the right path.
Progress: (request) SETUP stream 0
Progress: (open) Opened Stream
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Progress: (request) Sending PLAY request
Progress: (request) Sent PLAY request
(gst-launch-1.0:15161): GStreamer-CRITICAL **: 12:05:55.340: gst_caps_is_empty: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:15161): GStreamer-CRITICAL **: 12:05:55.340: gst_caps_truncate: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:15161): GStreamer-CRITICAL **: 12:05:55.340: gst_caps_fixate: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:15161): GStreamer-CRITICAL **: 12:05:55.341: gst_caps_get_structure: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:15161): GStreamer-CRITICAL **: 12:05:55.341: gst_structure_get_string: assertion 'structure != NULL' failed
(gst-launch-1.0:15161): GStreamer-CRITICAL **: 12:05:55.341: gst_mini_object_unref: assertion 'mini_object != NULL' failed
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Allocating new output: 1920x1088 (x 12), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3605: Send OMX_EventPortSettingsChanged: nFrameWidth = 1920, nFrameHeight = 1080
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:01:38.549964059
But I tried it in deepstream app and there is some problem while output since the video gives some pixel error in video (looks like the output from different bin is played together, since I saw same action performed by us repeats like 3 times when we move)
by error in video i meant: If I move my hand to one direction the output window shows I moved it three times in that directon with pixel errors. So is this usual case when you shift from web cam to rtsp or do we have solution?
Thank You
You may attach config file for reference. Would be great if you can also share brand and model ID of the IP camera.
@DaneLLL
I got the same result as @akshaypd156 when using the omxh264dec (which I presume is going to be depreciated). I tried the nvv4ldecoder and got the following error messages ( GStreamer- CRITICAL **: 12:06:27.523: gst_mini_object_unref: assertion ‘mini_object != NULL’ failed) :
$ gst-launch-1.0 rtspsrc location=“$RTSP_PATH” ! rtph264depay ! h264parse ! nvv4l2decoder ! nvoverlaysink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Progress: (connect) Connecting to rtsp://192.168.1.168:8554/0
Progress: (request) SETUP stream 1
Setting pipeline to PLAYING …
(gst-launch-1.0:12314): GStreamer- CRITICAL **: 12:06:27.523: gst_mini_object_unref: assertion ‘mini_object != NULL’ failed
Interrupt: Stopping pipeline …
Execution ended after 0:00:08.783611470
Setting pipeline to READY …
Hi james1122,
Please help to open a new topic for your issue. Thanks
In vlc, you can check the video at the following address.
rtsp://root:root@10.10.221.37:554/cam0_2
But when I run it with gst-launch, I can’t check the video.
Can you tell me what the problem is by looking at the following log?
nvidia@nvidia-desktop:/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app$ export RTSP_PATH=rtsp://root:root@10.10.221.37:554/cam0_2
nvidia@nvidia-desktop:/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app$ gst-launch-1.0 rtspsrc location=“$RTSP_PATH” ! rtph265depay ! h265parse ! omxh265dec ! nvoverlaysink
Progress: (connect) Connecting to rtsp://root:root@10.10.221.37:554/cam0_2
WARNING: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0: Delayed linking failed.
./grammar.y(510): gst_parse_no_more_pads (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0:
failed delayed linking some pad of GstRTSPSrc named rtspsrc0 to some pad of GstRtpH265Depay named rtph265depay0
Execution ended after 0:00:50.260977370
Setting pipeline to NULL …
Freeing pipeline …
nvidia@nvidia-desktop:/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app$ gst-launch-1.0 rtspsrc location=“$RTSP_PATH” ! rtph265depay ! h265parse ! nvv4l2decoder ! nvoverlaysink
Thank you.
