nvidia@nvidia-desktop:~$ gst-launch-1.0 -v rtspsrc location=rtsp://admin:password@192.168.1.101:554 ! application/x-rtp, media=video, encoding-name=H264 ! rtph264depay ! video/x-h264, clock-rate=90000 ! h264parse ! video/x-h264, width=3840, height=2160, framerate=30/1 ! omxh264dec ! ‘video/x-raw(memory:NVMM), width=3840, height=2160, framerate=30/1’ ! nvoverlaysink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://admin:password@192.168.1.101:554
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: latency = 2000
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: ntp-sync = false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: rfc7273-sync = false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: ntp-time-source = NTP time based on realtime clock
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: drop-on-latency = false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: max-rtcp-rtp-time-diff = 1000
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: max-ts-offset-adjustment = 0
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: buffer-mode = Slave receiver to sender clock
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0: timeout = 5000000000
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AM42NQB4AIf/gLcBAQFAAAD6AAAnEDoYA9MAAA5OHC7y40MAemAAAcnDhd5cK,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“3840,2160”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)705696609
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1: caps = application/x-rtcp
Progress: (open) Opened Stream
Setting pipeline to PLAYING …
New clock: GstSystemClock
Progress: (request) Sending PLAY request
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AM42NQB4AIf/gLcBAQFAAAD6AAAnEDoYA9MAAA5OHC7y40MAemAAAcnDhd5cK,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“3840,2160”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)705696609, clock-base=(uint)148305420, seqnum-base=(uint)13953, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
Progress: (request) Sent PLAY request
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AM42NQB4AIf/gLcBAQFAAAD6AAAnEDoYA9MAAA5OHC7y40MAemAAAcnDhd5cK,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“3840,2160”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)705696609, clock-base=(uint)148305420, seqnum-base=(uint)13953, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtp_sink_0.GstProxyPad:proxypad0: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AM42NQB4AIf/gLcBAQFAAAD6AAAnEDoYA9MAAA5OHC7y40MAemAAAcnDhd5cK,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“3840,2160”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)705696609, clock-base=(uint)148305420, seqnum-base=(uint)13953, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstFunnel:funnel0.GstFunnelPad:funnelpad0: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AM42NQB4AIf/gLcBAQFAAAD6AAAnEDoYA9MAAA5OHC7y40MAemAAAcnDhd5cK,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“3840,2160”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)705696609, clock-base=(uint)148305420, seqnum-base=(uint)13953, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtp_sink_0: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AM42NQB4AIf/gLcBAQFAAAD6AAAnEDoYA9MAAA5OHC7y40MAemAAAcnDhd5cK,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“3840,2160”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)705696609, clock-base=(uint)148305420, seqnum-base=(uint)13953, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1.GstPad:src: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtcp_sink_0.GstProxyPad:proxypad1: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstFunnel:funnel1.GstFunnelPad:funnelpad1: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtcp_sink_0: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0: timeout = 0
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstFunnel:funnel0.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AM42NQB4AIf/gLcBAQFAAAD6AAAnEDoYA9MAAA5OHC7y40MAemAAAcnDhd5cK,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“3840,2160”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)705696609, clock-base=(uint)148305420, seqnum-base=(uint)13953, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:recv_rtp_src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AM42NQB4AIf/gLcBAQFAAAD6AAAnEDoYA9MAAA5OHC7y40MAemAAAcnDhd5cK,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“3840,2160”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)705696609, clock-base=(uint)148305420, seqnum-base=(uint)13953, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpStorage:rtpstorage0.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AM42NQB4AIf/gLcBAQFAAAD6AAAnEDoYA9MAAA5OHC7y40MAemAAAcnDhd5cK,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“3840,2160”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)705696609, clock-base=(uint)148305420, seqnum-base=(uint)13953, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSsrcDemux:rtpssrcdemux0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AM42NQB4AIf/gLcBAQFAAAD6AAAnEDoYA9MAAA5OHC7y40MAemAAAcnDhd5cK,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“3840,2160”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)705696609, clock-base=(uint)148305420, seqnum-base=(uint)13953, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpStorage:rtpstorage0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AM42NQB4AIf/gLcBAQFAAAD6AAAnEDoYA9MAAA5OHC7y40MAemAAAcnDhd5cK,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“3840,2160”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)705696609, clock-base=(uint)148305420, seqnum-base=(uint)13953, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:recv_rtp_sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AM42NQB4AIf/gLcBAQFAAAD6AAAnEDoYA9MAAA5OHC7y40MAemAAAcnDhd5cK,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“3840,2160”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)705696609, clock-base=(uint)148305420, seqnum-base=(uint)13953, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AM42NQB4AIf/gLcBAQFAAAD6AAAnEDoYA9MAAA5OHC7y40MAemAAAcnDhd5cK,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“3840,2160”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)705696609, clock-base=(uint)148305420, seqnum-base=(uint)13953, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpPtDemux:rtpptdemux0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AM42NQB4AIf/gLcBAQFAAAD6AAAnEDoYA9MAAA5OHC7y40MAemAAAcnDhd5cK,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“3840,2160”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)705696609, clock-base=(uint)148305420, seqnum-base=(uint)13953, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter4: caps = application/x-rtp, media=(string)video, encoding-name=(string)H264
/GstPipeline:pipeline0/GstCapsFilter:capsfilter4.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AM42NQB4AIf/gLcBAQFAAAD6AAAnEDoYA9MAAA5OHC7y40MAemAAAcnDhd5cK,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“3840,2160”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)705696609, clock-base=(uint)148305420, seqnum-base=(uint)13953, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:src: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)014d4033ffe10030674d40338d8d401e0021ffe02dc040405000003e800009c40e8600f4c0000393870bbcb8d0c01e9800007270e177970a01000468ee3880, level=(string)5.1, profile=(string)main
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-h264, clock-rate=(int)90000, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)014d4033ffe10030674d40338d8d401e0021ffe02dc040405000003e800009c40e8600f4c0000393870bbcb8d0c01e9800007270e177970a01000468ee3880, level=(string)5.1, profile=(string)main
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:sink: caps = video/x-h264, clock-rate=(int)90000, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)014d4033ffe10030674d40338d8d401e0021ffe02dc040405000003e800009c40e8600f4c0000393870bbcb8d0c01e9800007270e177970a01000468ee3880, level=(string)5.1, profile=(string)main
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)014d4033ffe10030674d40338d8d401e0021ffe02dc040405000003e800009c40e8600f4c0000393870bbcb8d0c01e9800007270e177970a01000468ee3880, level=(string)5.1, profile=(string)main
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AM42NQB4AIf/gLcBAQFAAAD6AAAnEDoYA9MAAA5OHC7y40MAemAAAcnDhd5cK,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“3840,2160”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)705696609, clock-base=(uint)148305420, seqnum-base=(uint)13953, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter4.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AM42NQB4AIf/gLcBAQFAAAD6AAAnEDoYA9MAAA5OHC7y40MAemAAAcnDhd5cK,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“3840,2160”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)705696609, clock-base=(uint)148305420, seqnum-base=(uint)13953, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0.GstGhostPad:recv_rtp_src_0_705696609_96.GstProxyPad:proxypad4: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AM42NQB4AIf/gLcBAQFAAAD6AAAnEDoYA9MAAA5OHC7y40MAemAAAcnDhd5cK,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“3840,2160”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)705696609, clock-base=(uint)148305420, seqnum-base=(uint)13953, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtp_src_0_705696609_96.GstProxyPad:proxypad3: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AM42NQB4AIf/gLcBAQFAAAD6AAAnEDoYA9MAAA5OHC7y40MAemAAAcnDhd5cK,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“3840,2160”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)705696609, clock-base=(uint)148305420, seqnum-base=(uint)13953, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, clock-rate=(int)90000, stream-format=(string)byte-stream, alignment=(string)au, level=(string)5.1, profile=(string)high, pixel-aspect-ratio=(fraction)1/1, width=(int)3840, height=(int)2160, framerate=(fraction)20/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< “application/x-rtp-source-stats,\ ssrc=(uint)595304235,\ internal=(boolean)true,\ validated=(boolean)true,\ received-bye=(boolean)false,\ is-csrc=(boolean)false,\ is-sender=(boolean)false,\ seqnum-base=(int)-1,\ clock-rate=(int)-1,\ octets-sent=(guint64)0,\ packets-sent=(guint64)0,\ octets-received=(guint64)0,\ packets-received=(guint64)0,\ bitrate=(guint64)0,\ packets-lost=(int)0,\ jitter=(uint)0,\ sent-pli-count=(uint)0,\ recv-pli-count=(uint)0,\ sent-fir-count=(uint)0,\ recv-fir-count=(uint)0,\ sent-nack-count=(uint)0,\ recv-nack-count=(uint)0,\ have-sr=(boolean)false,\ sr-ntptime=(guint64)0,\ sr-rtptime=(uint)0,\ sr-octet-count=(uint)0,\ sr-packet-count=(uint)0;”, “application/x-rtp-source-stats,\ ssrc=(uint)705696609,\ internal=(boolean)false,\ validated=(boolean)true,\ received-bye=(boolean)false,\ is-csrc=(boolean)false,\ is-sender=(boolean)true,\ seqnum-base=(int)-1,\ clock-rate=(int)90000,\ rtp-from=(string)192.168.1.101:8216,\ octets-sent=(guint64)0,\ packets-sent=(guint64)0,\ octets-received=(guint64)262158,\ packets-received=(guint64)212,\ bitrate=(guint64)689409,\ packets-lost=(int)0,\ jitter=(uint)69,\ sent-pli-count=(uint)0,\ recv-pli-count=(uint)0,\ sent-fir-count=(uint)0,\ recv-fir-count=(uint)0,\ sent-nack-count=(uint)0,\ recv-nack-count=(uint)0,\ have-sr=(boolean)false,\ sr-ntptime=(guint64)0,\ sr-rtptime=(uint)0,\ sr-octet-count=(uint)0,\ sr-packet-count=(uint)0,\ sent-rb=(boolean)true,\ sent-rb-fractionlost=(uint)0,\ sent-rb-packetslost=(int)0,\ sent-rb-exthighestseq=(uint)14165,\ sent-rb-jitter=(uint)69,\ sent-rb-lsr=(uint)0,\ sent-rb-dlsr=(uint)0,\ have-rb=(boolean)false,\ rb-fractionlost=(uint)0,\ rb-packetslost=(int)0,\ rb-exthighestseq=(uint)0,\ rb-jitter=(uint)0,\ rb-lsr=(uint)0,\ rb-dlsr=(uint)0,\ rb-round-trip=(uint)0;” >, rtx-count=(uint)0;
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:send_rtcp_src: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:send_rtcp_src_0: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSink:udpsink1.GstPad:sink: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:send_rtcp_src_0.GstProxyPad:proxypad2: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< “application/x-rtp-source-stats,\ ssrc=(uint)595304235,\ internal=(boolean)true,\ validated=(boolean)true,\ received-bye=(boolean)false,\ is-csrc=(boolean)false,\ is-sender=(boolean)false,\ seqnum-base=(int)-1,\ clock-rate=(int)-1,\ octets-sent=(guint64)0,\ packets-sent=(guint64)0,\ octets-received=(guint64)0,\ packets-received=(guint64)0,\ bitrate=(guint64)0,\ packets-lost=(int)0,\ jitter=(uint)0,\ sent-pli-count=(uint)0,\ recv-pli-count=(uint)0,\ sent-fir-count=(uint)0,\ recv-fir-count=(uint)0,\ sent-nack-count=(uint)0,\ recv-nack-count=(uint)0,\ have-sr=(boolean)false,\ sr-ntptime=(guint64)0,\ sr-rtptime=(uint)0,\ sr-octet-count=(uint)0,\ sr-packet-count=(uint)0;”, “application/x-rtp-source-stats,\ ssrc=(uint)705696609,\ internal=(boolean)false,\ validated=(boolean)true,\ received-bye=(boolean)false,\ is-csrc=(boolean)false,\ is-sender=(boolean)true,\ seqnum-base=(int)-1,\ clock-rate=(int)90000,\ rtp-from=(string)192.168.1.101:8216,\ octets-sent=(guint64)0,\ packets-sent=(guint64)0,\ octets-received=(guint64)368730,\ packets-received=(guint64)305,\ bitrate=(guint64)677863,\ packets-lost=(int)0,\ jitter=(uint)29,\ sent-pli-count=(uint)0,\ recv-pli-count=(uint)0,\ sent-fir-count=(uint)0,\ recv-fir-count=(uint)0,\ sent-nack-count=(uint)0,\ recv-nack-count=(uint)0,\ have-sr=(boolean)false,\ sr-ntptime=(guint64)0,\ sr-rtptime=(uint)0,\ sr-octet-count=(uint)0,\ sr-packet-count=(uint)0,\ sent-rb=(boolean)true,\ sent-rb-fractionlost=(uint)0,\ sent-rb-packetslost=(int)0,\ sent-rb-exthighestseq=(uint)14165,\ sent-rb-jitter=(uint)69,\ sent-rb-lsr=(uint)0,\ sent-rb-dlsr=(uint)0,\ have-rb=(boolean)false,\ rb-fractionlost=(uint)0,\ rb-packetslost=(int)0,\ rb-exthighestseq=(uint)0,\ rb-jitter=(uint)0,\ rb-lsr=(uint)0,\ rb-dlsr=(uint)0,\ rb-round-trip=(uint)0;” >, rtx-count=(uint)0;
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< “application/x-rtp-source-stats,\ ssrc=(uint)595304235,\ internal=(boolean)true,\ validated=(boolean)true,\ received-bye=(boolean)false,\ is-csrc=(boolean)false,\ is-sender=(boolean)false,\ seqnum-base=(int)-1,\ clock-rate=(int)-1,\ octets-sent=(guint64)0,\ packets-sent=(guint64)0,\ octets-received=(guint64)0,\ packets-received=(guint64)0,\ bitrate=(guint64)0,\ packets-lost=(int)0,\ jitter=(uint)0,\ sent-pli-count=(uint)0,\ recv-pli-count=(uint)0,\ sent-fir-count=(uint)0,\ recv-fir-count=(uint)0,\ sent-nack-count=(uint)0,\ recv-nack-count=(uint)0,\ have-sr=(boolean)false,\ sr-ntptime=(guint64)0,\ sr-rtptime=(uint)0,\ sr-octet-count=(uint)0,\ sr-packet-count=(uint)0;”, “application/x-rtp-source-stats,\ ssrc=(uint)705696609,\ internal=(boolean)false,\ validated=(boolean)true,\ received-bye=(boolean)false,\ is-csrc=(boolean)false,\ is-sender=(boolean)true,\ seqnum-base=(int)-1,\ clock-rate=(int)90000,\ rtp-from=(string)192.168.1.101:8216,\ octets-sent=(guint64)0,\ packets-sent=(guint64)0,\ octets-received=(guint64)832387,\ packets-received=(guint64)676,\ bitrate=(guint64)805326,\ packets-lost=(int)0,\ jitter=(uint)39,\ sent-pli-count=(uint)0,\ recv-pli-count=(uint)0,\ sent-fir-count=(uint)0,\ recv-fir-count=(uint)0,\ sent-nack-count=(uint)0,\ recv-nack-count=(uint)0,\ have-sr=(boolean)false,\ sr-ntptime=(guint64)0,\ sr-rtptime=(uint)0,\ sr-octet-count=(uint)0,\ sr-packet-count=(uint)0,\ sent-rb=(boolean)true,\ sent-rb-fractionlost=(uint)0,\ sent-rb-packetslost=(int)0,\ sent-rb-exthighestseq=(uint)14629,\ sent-rb-jitter=(uint)39,\ sent-rb-lsr=(uint)0,\ sent-rb-dlsr=(uint)0,\ have-rb=(boolean)false,\ rb-fractionlost=(uint)0,\ rb-packetslost=(int)0,\ rb-exthighestseq=(uint)0,\ rb-jitter=(uint)0,\ rb-lsr=(uint)0,\ rb-dlsr=(uint)0,\ rb-round-trip=(uint)0;” >, rtx-count=(uint)0;
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< “application/x-rtp-source-stats,\ ssrc=(uint)595304235,\ internal=(boolean)true,\ validated=(boolean)true,\ received-bye=(boolean)false,\ is-csrc=(boolean)false,\ is-sender=(boolean)false,\ seqnum-base=(int)-1,\ clock-rate=(int)-1,\ octets-sent=(guint64)0,\ packets-sent=(guint64)0,\ octets-received=(guint64)0,\ packets-received=(guint64)0,\ bitrate=(guint64)0,\ packets-lost=(int)0,\ jitter=(uint)0,\ sent-pli-count=(uint)0,\ recv-pli-count=(uint)0,\ sent-fir-count=(uint)0,\ recv-fir-count=(uint)0,\ sent-nack-count=(uint)0,\ recv-nack-count=(uint)0,\ have-sr=(boolean)false,\ sr-ntptime=(guint64)0,\ sr-rtptime=(uint)0,\ sr-octet-count=(uint)0,\ sr-packet-count=(uint)0;”, “application/x-rtp-source-stats,\ ssrc=(uint)705696609,\ internal=(boolean)false,\ validated=(boolean)true,\ received-bye=(boolean)false,\ is-csrc=(boolean)false,\ is-sender=(boolean)true,\ seqnum-base=(int)-1,\ clock-rate=(int)90000,\ rtp-from=(string)192.168.1.101:8216,\ octets-sent=(guint64)0,\ packets-sent=(guint64)0,\ octets-received=(guint64)1222444,\ packets-received=(guint64)990,\ bitrate=(guint64)784685,\ packets-lost=(int)0,\ jitter=(uint)25,\ sent-pli-count=(uint)0,\ recv-pli-count=(uint)0,\ sent-fir-count=(uint)0,\ recv-fir-count=(uint)0,\ sent-nack-count=(uint)0,\ recv-nack-count=(uint)0,\ have-sr=(boolean)false,\ sr-ntptime=(guint64)0,\ sr-rtptime=(uint)0,\ sr-octet-count=(uint)0,\ sr-packet-count=(uint)0,\ sent-rb=(boolean)true,\ sent-rb-fractionlost=(uint)0,\ sent-rb-packetslost=(int)0,\ sent-rb-exthighestseq=(uint)14629,\ sent-rb-jitter=(uint)39,\ sent-rb-lsr=(uint)0,\ sent-rb-dlsr=(uint)0,\ have-rb=(boolean)false,\ rb-fractionlost=(uint)0,\ rb-packetslost=(int)0,\ rb-exthighestseq=(uint)0,\ rb-jitter=(uint)0,\ rb-lsr=(uint)0,\ rb-dlsr=(uint)0,\ rb-round-trip=(uint)0;” >, rtx-count=(uint)0;
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< “application/x-rtp-source-stats,\ ssrc=(uint)595304235,\ internal=(boolean)true,\ validated=(boolean)true,\ received-bye=(boolean)false,\ is-csrc=(boolean)false,\ is-sender=(boolean)false,\ seqnum-base=(int)-1,\ clock-rate=(int)-1,\ octets-sent=(guint64)0,\ packets-sent=(guint64)0,\ octets-received=(guint64)0,\ packets-received=(guint64)0,\ bitrate=(guint64)0,\ packets-lost=(int)0,\ jitter=(uint)0,\ sent-pli-count=(uint)0,\ recv-pli-count=(uint)0,\ sent-fir-count=(uint)0,\ recv-fir-count=(uint)0,\ sent-nack-count=(uint)0,\ recv-nack-count=(uint)0,\ have-sr=(boolean)false,\ sr-ntptime=(guint64)0,\ sr-rtptime=(uint)0,\ sr-octet-count=(uint)0,\ sr-packet-count=(uint)0;”, “application/x-rtp-source-stats,\ ssrc=(uint)705696609,\ internal=(boolean)false,\ validated=(boolean)true,\ received-bye=(boolean)false,\ is-csrc=(boolean)false,\ is-sender=(boolean)true,\ seqnum-base=(int)-1,\ clock-rate=(int)90000,\ rtp-from=(string)192.168.1.101:8216,\ octets-sent=(guint64)0,\ packets-sent=(guint64)0,\ octets-received=(guint64)1406746,\ packets-received=(guint64)1129,\ bitrate=(guint64)784685,\ packets-lost=(int)0,\ jitter=(uint)66,\ sent-pli-count=(uint)0,\ recv-pli-count=(uint)0,\ sent-fir-count=(uint)0,\ recv-fir-count=(uint)0,\ sent-nack-count=(uint)0,\ recv-nack-count=(uint)0,\ have-sr=(boolean)false,\ sr-ntptime=(guint64)0,\ sr-rtptime=(uint)0,\ sr-octet-count=(uint)0,\ sr-packet-count=(uint)0,\ sent-rb=(boolean)true,\ sent-rb-fractionlost=(uint)0,\ sent-rb-packetslost=(int)0,\ sent-rb-exthighestseq=(uint)14629,\ sent-rb-jitter=(uint)39,\ sent-rb-lsr=(uint)0,\ sent-rb-dlsr=(uint)0,\ have-rb=(boolean)false,\ rb-fractionlost=(uint)0,\ rb-packetslost=(int)0,\ rb-exthighestseq=(uint)0,\ rb-jitter=(uint)0,\ rb-lsr=(uint)0,\ rb-dlsr=(uint)0,\ rb-round-trip=(uint)0;” >, rtx-count=(uint)0;
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< “application/x-rtp-source-stats,\ ssrc=(uint)595304235,\ internal=(boolean)true,\ validated=(boolean)true,\ received-bye=(boolean)false,\ is-csrc=(boolean)false,\ is-sender=(boolean)false,\ seqnum-base=(int)-1,\ clock-rate=(int)-1,\ octets-sent=(guint64)0,\ packets-sent=(guint64)0,\ octets-received=(guint64)0,\ packets-received=(guint64)0,\ bitrate=(guint64)0,\ packets-lost=(int)0,\ jitter=(uint)0,\ sent-pli-count=(uint)0,\ recv-pli-count=(uint)0,\ sent-fir-count=(uint)0,\ recv-fir-count=(uint)0,\ sent-nack-count=(uint)0,\ recv-nack-count=(uint)0,\ have-sr=(boolean)false,\ sr-ntptime=(guint64)0,\ sr-rtptime=(uint)0,\ sr-octet-count=(uint)0,\ sr-packet-count=(uint)0;”, “application/x-rtp-source-stats,\ ssrc=(uint)705696609,\ internal=(boolean)false,\ validated=(boolean)true,\ received-bye=(boolean)false,\ is-csrc=(boolean)false,\ is-sender=(boolean)true,\ seqnum-base=(int)-1,\ clock-rate=(int)90000,\ rtp-from=(string)192.168.1.101:8216,\ octets-sent=(guint64)0,\ packets-sent=(guint64)0,\ octets-received=(guint64)1455726,\ packets-received=(guint64)1172,\ bitrate=(guint64)784685,\ packets-lost=(int)0,\ jitter=(uint)29,\ sent-pli-count=(uint)0,\ recv-pli-count=(uint)0,\ sent-fir-count=(uint)0,\ recv-fir-count=(uint)0,\ sent-nack-count=(uint)0,\ recv-nack-count=(uint)0,\ have-sr=(boolean)false,\ sr-ntptime=(guint64)0,\ sr-rtptime=(uint)0,\ sr-octet-count=(uint)0,\ sr-packet-count=(uint)0,\ sent-rb=(boolean)true,\ sent-rb-fractionlost=(uint)0,\ sent-rb-packetslost=(int)0,\ sent-rb-exthighestseq=(uint)15125,\ sent-rb-jitter=(uint)29,\ sent-rb-lsr=(uint)0,\ sent-rb-dlsr=(uint)0,\ have-rb=(boolean)false,\ rb-fractionlost=(uint)0,\ rb-packetslost=(int)0,\ rb-exthighestseq=(uint)0,\ rb-jitter=(uint)0,\ rb-lsr=(uint)0,\ rb-dlsr=(uint)0,\ rb-round-trip=(uint)0;” >, rtx-count=(uint)0;
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< “application/x-rtp-source-stats,\ ssrc=(uint)595304235,\ internal=(boolean)true,\ validated=(boolean)true,\ received-bye=(boolean)false,\ is-csrc=(boolean)false,\ is-sender=(boolean)false,\ seqnum-base=(int)-1,\ clock-rate=(int)-1,\ octets-sent=(guint64)0,\ packets-sent=(guint64)0,\ octets-received=(guint64)0,\ packets-received=(guint64)0,\ bitrate=(guint64)0,\ packets-lost=(int)0,\ jitter=(uint)0,\ sent-pli-count=(uint)0,\ recv-pli-count=(uint)0,\ sent-fir-count=(uint)0,\ recv-fir-count=(uint)0,\ sent-nack-count=(uint)0,\ recv-nack-count=(uint)0,\ have-sr=(boolean)false,\ sr-ntptime=(guint64)0,\ sr-rtptime=(uint)0,\ sr-octet-count=(uint)0,\ sr-packet-count=(uint)0;”, “application/x-rtp-source-stats,\ ssrc=(uint)705696609,\ internal=(boolean)false,\ validated=(boolean)true,\ received-bye=(boolean)false,\ is-csrc=(boolean)false,\ is-sender=(boolean)true,\ seqnum-base=(int)-1,\ clock-rate=(int)90000,\ rtp-from=(string)192.168.1.101:8216,\ octets-sent=(guint64)0,\ packets-sent=(guint64)0,\ octets-received=(guint64)1730671,\ packets-received=(guint64)1391,\ bitrate=(guint64)838231,\ packets-lost=(int)0,\ jitter=(uint)36,\ sent-pli-count=(uint)0,\ recv-pli-count=(uint)0,\ sent-fir-count=(uint)0,\ recv-fir-count=(uint)0,\ sent-nack-count=(uint)0,\ recv-nack-count=(uint)0,\ have-sr=(boolean)false,\ sr-ntptime=(guint64)0,\ sr-rtptime=(uint)0,\ sr-octet-count=(uint)0,\ sr-packet-count=(uint)0,\ sent-rb=(boolean)true,\ sent-rb-fractionlost=(uint)0,\ sent-rb-packetslost=(int)0,\ sent-rb-exthighestseq=(uint)15125,\ sent-rb-jitter=(uint)29,\ sent-rb-lsr=(uint)0,\ sent-rb-dlsr=(uint)0,\ have-rb=(boolean)false,\ rb-fractionlost=(uint)0,\ rb-packetslost=(int)0,\ rb-exthighestseq=(uint)0,\ rb-jitter=(uint)0,\ rb-lsr=(uint)0,\ rb-dlsr=(uint)0,\ rb-round-trip=(uint)0;” >, rtx-count=(uint)0;
^Chandling interrupt.
Interrupt: Stopping pipeline …
Execution ended after 0:00:16.029096058
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
