Tiler not showing all the streams in deepstream-app
**• Hardware Platform (Jetson / GPU)**Jetson Nano
• DeepStream Version 6.0
• JetPack Version (valid for Jetson only) 4.6
• TensorRT Version
I am running source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt and the output should be 8 streams tiled together but I get just 1. I tried changing 8 streams to 4 in config files, but I am still getting 1.
I think something is wrong with tiler.
Here is my config file:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=2
columns=2
width=1920
height=1080
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=4
uri=rtsp://admin:L23465FD@192.168.10.58:554/cam/realmonitor?channel=1&subtype=0
#uri=file:/home/ahmad096/Desktop/pyPro/Nvidia/media/vid.mp4
#uri=file://…/…/streams/sample_1080p_h264.mp4
num-sources=4
#drop-frame-interval=2
gpu-id=0
#(0): memtype_device - Memory type Device
#(1): memtype_pinned - Memory type Host Pinned
#(2): memtype_unified - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=5
sync=1
source-id=0
gpu-id=0
qos=0
nvbuf-memory-type=0
overlay-id=1
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
encoder type 0=Hardware 1=Software
enc-type=0
sync=0
#iframeinterval=10
bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
output-file=out.mp4
source-id=0
[sink2]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=1
batch-size=4
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
#set muxer output width and height
width=1920
height=1080
#enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
##If set to TRUE, system timestamp will be attached as ntp timestamp
##If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
#attach-sys-ts-as-ntp=1
#config-file property is mandatory for any gie section.
Omniverse Other properties are optional and if set will override the properties set in
#the infer config file.
[primary-gie]
enable=1
gpu-id=0
model-engine-file=…/…/models/Primary_Detector_Nano/resnet10.caffemodel_b4_gpu0_fp16.engine
batch-size=4
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=5
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_nano.txt
[tracker]
enable=0
#For NvDCF and DeepSORT tracker, tracker-width and tracker-height must be a multiple of 32, respectively
tracker-width=640
tracker-height=384
ll-lib-file=/opt/nvidia/deepstream/deepstream-6.0/lib/libnvds_nvmultiobjecttracker.so
#ll-config-file required to set different tracker types
#ll-config-file=config_tracker_IOU.yml
ll-config-file=config_tracker_NvDCF_perf.yml
#ll-config-file=config_tracker_NvDCF_accuracy.yml
#ll-config-file=config_tracker_DeepSORT.yml
gpu-id=0
enable-batch-process=1
enable-past-frame=1
display-tracking-id=1
[tests]
file-loop=0
And by running this, I am getting output like this:
I have also tried changing uri type but nothing to gain.
Terminal output:
Can you use multi source group in the config file and try again?
I already did, same results.
It works on my side, please share your complete config file.
