Hardware Platform GPU
Deepstream 5.1
TensorRt 7.2.1
NVIDIA GPU Driver Version 455.23.05
Issue Type Questions
when deepstream-app rtsp sink is used for 8 streams with tiled-display disabled. if any of the stream is opened through rtsp link it stuck after 10 to 20 seconds and even if i use only one stream and one rtsp sink it still has the
same problem. if i enable tiled-display it will work fine without any issue.
• How to reproduce the issue ?
deepstream-app -c config.txt
Config.txt content:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=1
[tiled-display]
enable=0
rows=1
columns=2
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=3
uri=file:///opt/nvidia/deepstream/deepstream-5.1/samples/streams/sample_720p.h264
num-sources=1
gpu-id=0
cudadec-memtype=0
[source1]
enable=1
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
[source2]
enable=1
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
[source3]
enable=1
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
[source4]
enable=1
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
[source5]
enable=1
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
[source6]
enable=1
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
[source7]
enable=1
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
type=4
codec=1
sync=0
source-id=0
gpu-id=0
bitrate=4000000
nvbuf-memory-type=0
udp-port=5400
rtsp-port=8554
[sink1]
enable=1
type=4
codec=1
sync=0
source-id=1
gpu-id=0
bitrate=4000000
nvbuf-memory-type=0
udp-port=5401
rtsp-port=8555
[sink2]
enable=1
type=4
codec=1
sync=0
source-id=2
gpu-id=0
bitrate=4000000
nvbuf-memory-type=0
udp-port=5402
rtsp-port=8556
[sink3]
enable=1
type=4
codec=1
sync=0
source-id=3
gpu-id=0
bitrate=4000000
nvbuf-memory-type=0
udp-port=5403
rtsp-port=8557
[sink4]
enable=1
type=4
codec=1
sync=0
source-id=4
gpu-id=0
bitrate=4000000
nvbuf-memory-type=0
udp-port=5404
rtsp-port=8558
[sink5]
enable=1
type=4
codec=1
sync=0
source-id=5
gpu-id=0
bitrate=4000000
nvbuf-memory-type=0
udp-port=5405
rtsp-port=8559
[sink6][application]
[tiled-display]
enable=0
rows=1
columns=2
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
[source1]
enable=1
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
[source2]
enable=1
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
[source3]
enable=1
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
[source4]
enable=1
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
[source5]
enable=1
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
[source6]
enable=1
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
[source7]
enable=1
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
type=4
codec=1
sync=0
source-id=0
gpu-id=0
bitrate=4000000
nvbuf-memory-type=0
udp-port=5400
rtsp-port=8554
[sink1]
enable=1
type=4
codec=1
sync=0
source-id=1
gpu-id=0
bitrate=4000000
nvbuf-memory-type=0
udp-port=5401
rtsp-port=8555
[sink2]
enable=1
type=4
codec=1
sync=0
source-id=2
gpu-id=0
bitrate=4000000
nvbuf-memory-type=0
udp-port=5402
rtsp-port=8556
[sink3]
enable=1
type=4
codec=1
sync=0
source-id=3
gpu-id=0
bitrate=4000000
nvbuf-memory-type=0
udp-port=5403
rtsp-port=8557
[sink4]
enable=1
type=4
codec=1
sync=0
source-id=4
gpu-id=0
bitrate=4000000
nvbuf-memory-type=0
udp-port=5404
rtsp-port=8558
[sink5]
enable=1
type=4
codec=1
sync=0
source-id=5
gpu-id=0
enable=1
type=4
codec=1
sync=0
source-id=6
gpu-id=0
bitrate=4000000
nvbuf-memory-type=0
udp-port=5406
rtsp-port=8560
[sink7]
enable=1
type=4
codec=1
sync=0
source-id=7
gpu-id=0
bitrate=4000000
nvbuf-memory-type=0
udp-port=5407
rtsp-port=8561
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=1
batch-size=8
batched-push-timeout=40000
width=1280
height=720
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=dstest3_pgie_config.txt
[tests]
file-loop=1
I also tested this on jetson nano it also has the similar issue on it too.
