• Hardware Platform (Jetson / GPU) 3090
• DeepStream Version 5.1docker
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) NVIDIA-SMI 470.57.02 Driver Version: 470.57.02 CUDA Version: 11.4
• Issue Type( questions, new requirements, bugs) rtsp Unauthorized (401)
In DeepStream docker, I can get image by opencv with the rtsp soures, but I get the issues following by run command “deepstream-app -c deepstream_app_config.txt”
root@b651cada942b:/opt/nvidia/deepstream/deepstream-5.1/sources/yolo# deepstream-app -c deepstream_app_config.txt
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
0:00:03.305325363 3374 0x55745ddd9550 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1702> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.1/sources/yolo/yolov5s.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT data 3x640x640
1 OUTPUT kFLOAT prob 6001x1x1
0:00:03.305425708 3374 0x55745ddd9550 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1806> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.1/sources/yolo/yolov5s.engine
0:00:03.306828319 3374 0x55745ddd9550 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.1/sources/yolo/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** INFO: <bus_callback:181>: Pipeline ready
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
WARNING from src_elem0: Could not read from resource.
Debug info: gstrtspsrc.c(5427): gst_rtspsrc_reconnect (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstRTSPSrc:src_elem0:
Could not receive any UDP packets for 5.0000 seconds, maybe your firewall is blocking it. Retrying using a tcp connection.
ERROR from src_elem0: Could not open resource for reading.
Debug info: gstrtspsrc.c(5829): gst_rtspsrc_setup_auth (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstRTSPSrc:src_elem0:
No supported authentication protocol was found
ERROR from src_elem0: Unauthorized
Debug info: gstrtspsrc.c(6116): gst_rtspsrc_send (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstRTSPSrc:src_elem0:
Unauthorized (401)
** INFO: <reset_source_pipeline:1433>: Resetting source 0
Unauthorized (401)
**PERF: 0.00 (0.00)
^C** ERROR: <_intr_handler:140>: User Interrupted..
Quitting
App run successful
added my configure file:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=1
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=4
#uri=rtsp://120.237.216.198:9090/dss/monitor/param?cameraid=1000001%2432&substream=1
uri=rtsp://120.237.216.198:9090/dss/monitor/param?cameraid=1000001%2436&substream=1
#rtsp-reconnect-interval-sec=60
num-sources=1
gpu-id=0
cudadec-memtype=0
[sink0]
enable=0
type=2
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=4
rtsp-port=8554
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
#sync=1
#source-id=0
#gpu-id=0
#nvbuf-memory-type=2
[sink2]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=UDPSink 5=nvoverlaysink 6=MsgConvBroker
type=6
msg-conv-config=dstest5_msgconv_sample_config.txt
#(0): PAYLOAD_DEEPSTREAM - Deepstream schema payload
#(1): PAYLOAD_DEEPSTREAM_MINIMAL - Deepstream schema payload minimal
#(256): PAYLOAD_RESERVED - Reserved type
#(257): PAYLOAD_CUSTOM - Custom schema payload
msg-conv-payload-type=0
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_kafka_proto.so
#Provide your msg-broker-conn-str here
msg-broker-conn-str=127.0.0.1;9092;test
topic=test
#Optional:
#msg-broker-config=../../deepstream-test4/cfg_kafka.txt
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
display-text=1
display-bbox=1
[streammux]
gpu-id=0
live-source=1
batch-size=1
batched-push-timeout=40000
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
batch-size=1
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary.txt
[tests]
file-loop=0
