#Pipeline Config
[source0]
enable=1
type=4
uri=rtsp://user:pass@192.168.204.195
select-rtp-protocol=4
num-sources=1
camera-id=0
gpu-id=0
cudadec-memtype=0
[source1]
enable=1
type=4
uri=rtsp://user:pass@192.168.204.196
num-sources=1
camera-id=1
gpu-id=0
cudadec-memtype=0
[source2]
enable=1
type=4
uri=rtsp://user:pass@192.168.204.197
num-sources=1
camera-id=2
gpu-id=0
cudadec-memtype=0
[source3]
enable=1
type=4
uri=rtsp://user:pass@192.168.204.198
num-sources=1
camera-id=3
gpu-id=0
cudadec-memtype=0
[source4]
enable=1
type=4
uri=rtsp://user:pass@192.168.205.195
num-sources=1
camera-id=4
gpu-id=0
cudadec-memtype=0
[source5]
enable=1
type=4
uri=rtsp://user:pass@192.168.194.23
num-sources=1
camera-id=5
gpu-id=0
cudadec-memtype=0
[source6]
enable=1
type=4
uri=rtsp://user:pass@192.168.194.5
num-sources=1
camera-id=6
gpu-id=0
cudadec-memtype=0
[source7]
enable=1
type=4
uri=rtsp://user:pass@192.168.194.6
num-sources=1
camera-id=7
gpu-id=0
cudadec-memtype=0
[source8]
enable=1
type=4
uri=rtsp://user:pass@192.168.194.7
num-sources=1
camera-id=8
gpu-id=0
cudadec-memtype=0
[source9]
enable=1
type=4
uri=rtsp://user:pass@192.168.194.8
num-sources=1
camera-id=9
gpu-id=0
cudadec-memtype=0
[source10]
enable=1
type=4
uri=rtsp://user:pass@192.168.194.10
num-sources=1
camera-id=10
gpu-id=0
cudadec-memtype=0
[source11]
enable=1
type=4
uri=rtsp://user:pass@192.168.194.11
num-sources=1
camera-id=11
gpu-id=0
cudadec-memtype=0
[source12]
enable=1
type=4
uri=rtsp://user:pass@192.168.194.12
num-sources=1
camera-id=12
gpu-id=0
cudadec-memtype=0
[source13]
enable=1
type=4
uri=rtsp://user:pass@192.168.194.13
num-sources=1
camera-id=13
gpu-id=0
cudadec-memtype=0
[source14]
enable=1
type=4
uri=rtsp://user:pass@192.168.194.14
num-sources=1
camera-id=14
gpu-id=0
cudadec-memtype=0
[source15]
enable=1
type=4
uri=rtsp://user:pass@192.168.206.196
num-sources=1
camera-id=15
gpu-id=0
cudadec-memtype=0
[source16]
enable=1
type=4
uri=rtsp://user:pass@192.168.206.205
num-sources=1
camera-id=16
gpu-id=0
cudadec-memtype=0
[source17]
enable=1
type=4
uri=rtsp://user:pass@192.168.206.197
num-sources=1
camera-id=17
gpu-id=0
cudadec-memtype=0
[source18]
enable=1
type=4
uri=rtsp://user:pass@192.168.206.198
num-sources=1
camera-id=18
gpu-id=0
cudadec-memtype=0
[source19]
enable=1
type=4
uri=rtsp://user:pass@192.168.206.199
num-sources=1
camera-id=19
gpu-id=0
cudadec-memtype=0
[source20]
enable=1
type=4
uri=rtsp://user:pass@192.168.206.200
num-sources=1
camera-id=20
gpu-id=0
cudadec-memtype=0
[source21]
enable=1
type=4
uri=rtsp://user:pass@192.168.206.201
num-sources=1
camera-id=21
gpu-id=0
cudadec-memtype=0
[source22]
enable=1
type=4
uri=rtsp://user:pass@192.168.206.202
num-sources=1
camera-id=22
gpu-id=0
cudadec-memtype=0
[source23]
enable=1
type=4
uri=rtsp://user:pass@192.168.206.203
num-sources=1
camera-id=23
gpu-id=0
cudadec-memtype=0
[source24]
enable=1
type=4
uri=rtsp://user:pass@192.168.206.204
num-sources=1
camera-id=24
gpu-id=0
cudadec-memtype=0
[source25]
enable=1
type=4
uri=rtsp://user:pass@192.168.201.3
num-sources=1
camera-id=25
gpu-id=0
cudadec-memtype=0
[source26]
enable=1
type=4
uri=rtsp://user:pass@192.168.201.4
num-sources=1
camera-id=26
gpu-id=0
cudadec-memtype=0
[source27]
enable=1
type=4
uri=rtsp://user:pass@192.168.204.3
num-sources=1
camera-id=27
gpu-id=0
cudadec-memtype=0
[source28]
enable=1
type=4
uri=rtsp://user:pass@192.168.204.4
num-sources=1
camera-id=28
gpu-id=0
cudadec-memtype=0
[source29]
enable=1
type=4
uri=rtsp://user:pass@192.168.208.67
num-sources=1
camera-id=29
gpu-id=0
cudadec-memtype=0
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=1
batch-size=30
batched-push-timeout=66666
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=0
[sink0]
enable=1
type=4
source-id=0
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8554
udp-port=5000
gpu-id=0
[sink1]
enable=1
type=4
source-id=1
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8555
udp-port=5001
gpu-id=0
[sink2]
enable=1
type=4
source-id=2
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8556
udp-port=5002
gpu-id=0
[sink3]
enable=1
type=4
source-id=3
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8557
udp-port=5003
gpu-id=0
[sink4]
enable=1
type=4
source-id=4
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8558
udp-port=5004
gpu-id=0
[sink5]
enable=1
type=4
source-id=5
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8559
udp-port=5005
gpu-id=0
[sink6]
enable=1
type=4
source-id=6
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8560
udp-port=5006
gpu-id=0
[sink7]
enable=1
type=4
source-id=7
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8561
udp-port=5007
gpu-id=0
[sink8]
enable=1
type=4
source-id=8
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8562
udp-port=5008
gpu-id=0
[sink9]
enable=1
type=4
source-id=9
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8563
udp-port=5009
gpu-id=0
[sink10]
enable=1
type=4
source-id=10
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8564
udp-port=5010
gpu-id=0
[sink11]
enable=1
type=4
source-id=11
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8565
udp-port=5011
gpu-id=0
[sink12]
enable=1
type=4
source-id=12
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8566
udp-port=5012
gpu-id=0
[sink13]
enable=1
type=4
source-id=13
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8567
udp-port=5013
gpu-id=0
[sink14]
enable=1
type=4
source-id=14
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8568
udp-port=5014
gpu-id=0
[sink15]
enable=1
type=4
source-id=15
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8569
udp-port=5015
gpu-id=0
[sink16]
enable=1
type=4
source-id=16
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8570
udp-port=5016
gpu-id=0
[sink17]
enable=1
type=4
source-id=17
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8571
udp-port=5017
gpu-id=0
[sink18]
enable=1
type=4
source-id=18
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8572
udp-port=5018
gpu-id=0
[sink19]
enable=1
type=4
source-id=19
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8573
udp-port=5019
gpu-id=0
[sink20]
enable=1
type=4
source-id=20
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8574
udp-port=5020
gpu-id=0
[sink21]
enable=1
type=4
source-id=21
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8575
udp-port=5021
gpu-id=0
[sink22]
enable=1
type=4
source-id=22
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8576
udp-port=5022
gpu-id=0
[sink23]
enable=1
type=4
source-id=23
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8577
udp-port=5023
gpu-id=0
[sink24]
enable=1
type=4
source-id=24
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8578
udp-port=5024
gpu-id=0
[sink25]
enable=1
type=4
source-id=25
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8579
udp-port=5025
gpu-id=0
[sink26]
enable=1
type=4
source-id=26
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8580
udp-port=5026
gpu-id=0
[sink27]
enable=1
type=4
source-id=27
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8581
udp-port=5027
gpu-id=0
[sink28]
enable=1
type=4
source-id=28
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8582
udp-port=5028
gpu-id=0
[sink29]
enable=1
type=4
source-id=29
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8583
udp-port=5029
gpu-id=0
[primary-gie]
enable=1
gpu-id=0
config-file=/js/model/pgie.txt
batch-size=30
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=4
gie-unique-id=1
nvbuf-memory-type=0
[ds-example]
enable=0
processing-width=1280
processing-height=720
full-frame=1
unique-id=15
gpu-id=0
#/js/model/pgie.txt File
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
tlt-encoded-model=resnet10_detector.etlt
tlt-model-key=key
labelfile-path=labels.txt
int8-calib-file=calibration.bin
batch-size=30
force-implicit-batch-dim=1
process-mode=1
model-color-format=0
network-mode=1
num-detected-classes=3
interval=4
gie-unique-id=1
infer-dims=3;1080;1920
uff-input-blob-name=input_1
output-blob-names=output_cov/Sigmoid;output_bbox/BiasAdd
[class-attrs-all]
pre-cluster-threshold=0.2
eps=0.2
group-threshold=1
