[application]
enable-perf-measurement=1
perf-measurement-interval-sec=10
[source0]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.125.93
select-rtp-protocol=4
num-sources=1
camera-id=0
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-duration=5
smart-rec-video-cache=20
smart-rec-start-time=2
smart-rec-default-duration=5
smart-rec-container=0
smart-rec-dir-path=/home/va/work/logs
smart-rec-file-prefix=camera100
[source1]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.125.94
num-sources=1
camera-id=1
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera101
[source2]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.125.95
num-sources=1
camera-id=2
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera102
[source3]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.125.96
num-sources=1
camera-id=3
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera103
[source4]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.125.97
num-sources=1
camera-id=4
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera104
[source5]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.117.108
num-sources=1
camera-id=5
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera105
[source6]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.117.109
num-sources=1
camera-id=6
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera106
[source7]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.117.110
num-sources=1
camera-id=7
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera107
[source8]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.117.111
num-sources=1
camera-id=8
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera108
[source9]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.117.112
num-sources=1
camera-id=9
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera109
[source10]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.112.214
num-sources=1
camera-id=10
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera110
[source11]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.112.215
num-sources=1
camera-id=11
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera111
[source12]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.112.216
num-sources=1
camera-id=12
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera112
[source13]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.112.217
num-sources=1
camera-id=13
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera113
[source14]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.176.93
num-sources=1
camera-id=14
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera114
[source15]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.176.94
num-sources=1
camera-id=15
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera115
[source16]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.113.25
num-sources=1
camera-id=16
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera116
[source17]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.113.26
num-sources=1
camera-id=17
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera117
[source18]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.116.111
num-sources=1
camera-id=18
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera118
[source19]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.116.112
num-sources=1
camera-id=19
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera119
[source20]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.116.113
num-sources=1
camera-id=20
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera120
[source21]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.116.114
num-sources=1
camera-id=21
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera121
[source22]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.116.115
num-sources=1
camera-id=22
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera122
[source23]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.116.116
num-sources=1
camera-id=23
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera123
[source24]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.116.117
num-sources=1
camera-id=24
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera124
[source25]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.116.118
num-sources=1
camera-id=25
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera125
[source26]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.114.40
num-sources=1
camera-id=26
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera126
[source27]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.114.41
num-sources=1
camera-id=27
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera127
[source28]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.114.42
num-sources=1
camera-id=28
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera128
[source29]
enable=1
type=4
uri=rtsp://admin:admin123@192.165.114.43
num-sources=1
camera-id=29
gpu-id=0
cudadec-memtype=0
smart-record=1
smart-rec-file-prefix=camera129
[sink0]
enable=1
type=4
source-id=0
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8554
udp-port=5000
gpu-id=0
[sink1]
enable=1
type=4
source-id=1
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8555
udp-port=5001
gpu-id=0
[sink2]
enable=1
type=4
source-id=2
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8556
udp-port=5002
gpu-id=0
[sink3]
enable=1
type=4
source-id=3
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8557
udp-port=5003
gpu-id=0
[sink4]
enable=1
type=4
source-id=4
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8558
udp-port=5004
gpu-id=0
[sink5]
enable=1
type=4
source-id=5
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8559
udp-port=5005
gpu-id=0
[sink6]
enable=1
type=4
source-id=6
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8560
udp-port=5006
gpu-id=0
[sink7]
enable=1
type=4
source-id=7
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8561
udp-port=5007
gpu-id=0
[sink8]
enable=1
type=4
source-id=8
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8562
udp-port=5008
gpu-id=0
[sink9]
enable=1
type=4
source-id=9
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8563
udp-port=5009
gpu-id=0
[sink10]
enable=1
type=4
source-id=10
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8564
udp-port=5010
gpu-id=0
[sink11]
enable=1
type=4
source-id=11
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8565
udp-port=5011
gpu-id=0
[sink12]
enable=1
type=4
source-id=12
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8566
udp-port=5012
gpu-id=0
[sink13]
enable=1
type=4
source-id=13
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8567
udp-port=5013
gpu-id=0
[sink14]
enable=1
type=4
source-id=14
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8568
udp-port=5014
gpu-id=0
[sink15]
enable=1
type=4
source-id=15
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8569
udp-port=5015
gpu-id=0
[sink16]
enable=1
type=4
source-id=16
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8570
udp-port=5016
gpu-id=0
[sink17]
enable=1
type=4
source-id=17
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8571
udp-port=5017
gpu-id=0
[sink18]
enable=1
type=4
source-id=18
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8572
udp-port=5018
gpu-id=0
[sink19]
enable=1
type=4
source-id=19
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8573
udp-port=5019
gpu-id=0
[sink20]
enable=1
type=4
source-id=20
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8574
udp-port=5020
gpu-id=0
[sink21]
enable=1
type=4
source-id=21
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8575
udp-port=5021
gpu-id=0
[sink22]
enable=1
type=4
source-id=22
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8576
udp-port=5022
gpu-id=0
[sink23]
enable=1
type=4
source-id=23
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8577
udp-port=5023
gpu-id=0
[sink24]
enable=1
type=4
source-id=24
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8578
udp-port=5024
gpu-id=0
[sink25]
enable=1
type=4
source-id=25
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8579
udp-port=5025
gpu-id=0
[sink26]
enable=1
type=4
source-id=26
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8580
udp-port=5026
gpu-id=0
[sink27]
enable=1
type=4
source-id=27
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8581
udp-port=5027
gpu-id=0
[sink28]
enable=1
type=4
source-id=28
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8582
udp-port=5028
gpu-id=0
[sink29]
enable=1
type=4
source-id=29
codec=1
enc-type=0
qos=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8583
udp-port=5029
gpu-id=0
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=1
batch-size=30
batched-push-timeout=60000
width=960
height=544
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
batch-size=2
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=pgie_config.txt
[nvds-analytics]
enable=1
config-file=roi_config.txt
[tracker]
enable=1
tracker-width=960
tracker-height=544
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_mot_iou.so
#ll-config-file=iou_config.txt
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_nvdcf.so
ll-config-file=tracker_config.yml
gpu-id=0
enable-batch-process=1
enable-past-frame=0
display-tracking-id=0
[img-save]
enable=1
second-to-skip-interval=30
min-box-width=40
min-box-height=40
