**• GPU **
Tesla P4
• DeepStream Version
V5.0 (Obtained as in image: 5.0-20.07-devel)
• TensorRT Version
**• NVIDIA GPU Driver Version (valid for GPU only) **
440.33.01
questions/bugs
Used deepstream-app to run a config which had more than 6 sources and sinks. Once all the sinks are up, one can connect the output RTSP port to several VLC instances and observe that the frames from cameras are being randomly shown on other output displays.
It appears as if frames from all cameras are being displayed on every output RTSP feed.
Attaching the config below:
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=4
uri=rtsp://support:%24Upp0r%2B543@10.125.204.195
select-rtp-protocol=4
num-sources=1
camera-id=0
#drop-frame-interval=2
gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
[source1]
enable=1
type=4
uri=rtsp://support:%24Upp0r%2B543@10.125.204.196
num-sources=1
camera-id=0
gpu-id=0
cudadec-memtype=0
[source2]
enable=1
type=4
uri=rtsp://support:%24Upp0r%2B543@10.125.204.197
num-sources=1
camera-id=2
gpu-id=0
cudadec-memtype=0
[source3]
enable=1
type=4
uri=rtsp://support:%24Upp0r%2B543@10.125.206.196
num-sources=1
camera-id=3
gpu-id=0
cudadec-memtype=0
[source4]
enable=1
type=4
uri=rtsp://support:%24Upp0r%2B543@10.125.206.198
num-sources=1
camera-id=4
gpu-id=0
cudadec-memtype=0
[source5]
enable=1
type=4
uri=rtsp://support:%24Upp0r%2B543@10.125.206.199
num-sources=1
camera-id=5
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
source-id=0
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=5000
udp-port=10000
gpu-id=0
[sink1]
enable=1
type=4
source-id=1
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=5001
udp-port=10001
gpu-id=0
[sink2]
enable=1
type=4
source-id=2
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=5002
udp-port=10002
gpu-id=0
[sink3]
enable=1
type=4
source-id=3
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=5003
udp-port=10003
gpu-id=0
[sink4]
enable=1
type=4
source-id=4
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=5004
udp-port=10004
gpu-id=0
[sink5]
enable=1
type=4
source-id=5
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=5005
udp-port=10005
gpu-id=0
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=1
batch-size=6
batched-push-timeout=40000
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
config-file=/opt/nvidia/deepstream/deepstream-5.0/js-asset/build/sample/model/pgie.txt
batch-size=6
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
[tests]
file-loop=0
[nvds-analytics]
enable=0
config-file=roi.txt
[ds-example]
enable=0
processing-width=1280
processing-height=720
full-frame=1
unique-id=15
gpu-id=0
