Deepstream-5.1 RTSP out streams interfacing with each other
• Hardware Platform (Jetson / GPU) - GPU
• DeepStream Version - 5.1
• TensorRT Version - 7.2.2
• NVIDIA GPU Driver Version (valid for GPU only)- 470
Hi
I am running deepstream-test1-rtsp-out sample test app on different pc which has similar setup as mentioned above. We have different rtsp out link(like rtsp://localhost:8554/ds-test and rtsp://localhost:8555/ds-test1),different rtsp port numbers, different input media files, different ip configuration only similar thing is we are on same network but problem is wherever we are running same code and use VLC player to display output stream then that time our output streams frames are interfacing with each other.
I would really appreciate your help.
Please update to the latest DeepStream 6.0.1
I can not reproduce your problem with our deepstream-app sample app
