• Hardware Platform (Jetson / GPU) - GPU - 1050ti
• DeepStream Version 5.1
• TensorRT Version 7.1.2
• NVIDIA GPU Driver Version (valid for GPU only) 465
• Issue Type( questions, new requirements, bugs) Bugs
I have 3 RTSP streams and I want to stream out 3 input streams. Based on the NVIDIA specifications, I am using GTX 1050ti which supports 3 stream encoders.
Here is my configure file.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
[tiled-display]
enable=0
rows=1
columns=3
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=4
uri=rtsp://192.168.1.16/sub-stream
drop-frame-interval=0
num-sources=1
gpu-id=0
cudadec-memtype=0
nvbuf-memory-type=3
crop-left=0
crop-top=0
crop-right=1280
crop-bottom=720
[source1]
enable=1
type=4
uri=rtsp://admin:3@192.168.1.11/channel1-encoder1
num-sources=1
gpu-id=0
cudadec-memtype=0
nvbuf-memory-type=3
crop-left=0
crop-top=0
crop-right=1280
crop-bottom=720
[source2]
enable=1
type=4
uri=rtsp://admin:3@192.168.1.11/channel1-encoder2
num-sources=1
gpu-id=0
cudadec-memtype=0
nvbuf-memory-type=3
crop-left=0
crop-top=0
crop-right=1280
crop-bottom=720
[source3]
enable=0
type=4
uri=rtsp://1.1.1.1/init
num-sources=1
gpu-id=0
cudadec-memtype=0
nvbuf-memory-type=3
crop-left=0
crop-top=0
crop-right=1280
crop-bottom=720
[source4]
enable=0
type=4
num-sources=1
gpu-id=0
cudadec-memtype=0
nvbuf-memory-type=3
crop-left=0
crop-top=0
crop-right=1280
crop-bottom=720
[source5]
enable=0
type=4
num-sources=1
gpu-id=0
cudadec-memtype=0
nvbuf-memory-type=3
crop-left=0
crop-top=0
crop-right=1280
crop-bottom=720
[source6]
enable=0
type=4
num-sources=1
gpu-id=0
cudadec-memtype=0
nvbuf-memory-type=3
crop-left=0
crop-top=0
crop-right=1280
crop-bottom=720
[source7]
enable=0
type=4
num-sources=1
gpu-id=0
cudadec-memtype=0
nvbuf-memory-type=3
crop-left=0
crop-top=0
crop-right=1280
crop-bottom=720
[source8]
enable=0
type=4
num-sources=1
gpu-id=0
cudadec-memtype=0
nvbuf-memory-type=3
crop-left=0
crop-top=0
crop-right=1280
crop-bottom=720
[source9]
enable=0
type=4
num-sources=1
gpu-id=0
cudadec-memtype=0
nvbuf-memory-type=3
crop-left=0
crop-top=0
crop-right=1280
crop-bottom=720
[source10]
enable=0
type=4
num-sources=1
gpu-id=0
cudadec-memtype=0
nvbuf-memory-type=3
crop-left=0
crop-top=0
crop-right=1280
crop-bottom=720
[source11]
enable=0
type=4
num-sources=1
gpu-id=0
cudadec-memtype=0
nvbuf-memory-type=3
crop-left=0
crop-top=0
crop-right=1280
crop-bottom=720
[source12]
enable=0
type=4
num-sources=1
gpu-id=0
cudadec-memtype=0
nvbuf-memory-type=3
crop-left=0
crop-top=0
crop-right=1280
crop-bottom=720
[source13]
enable=0
type=4
num-sources=1
gpu-id=0
cudadec-memtype=0
nvbuf-memory-type=3
crop-left=0
crop-top=0
crop-right=1280
crop-bottom=720
[source14]
enable=0
type=4
num-sources=1
gpu-id=0
cudadec-memtype=0
nvbuf-memory-type=3
crop-left=0
crop-top=0
crop-right=1280
crop-bottom=720
[source15]
enable=0
type=4
num-sources=1
gpu-id=0
cudadec-memtype=0
nvbuf-memory-type=3
crop-left=0
crop-top=0
crop-right=1280
crop-bottom=720
# rstp out
[sink0]
enable=1
type=4
source-id=0
codec=1
enc-type=0
sync=1
bitrate=4000000
profile=0
rtsp-port=8550
udp-port=5400
output-file=ANPR-streaming
iframeinterval=5
gpu-id=0
qos=0
[sink1]
enable=1
type=4
source-id=1
codec=1
enc-type=0
sync=1
bitrate=4000000
profile=0
rtsp-port=8551
udp-port=5410
iframeinterval=5
gpu-id=0
qos=0
[sink2]
enable=1
type=4
source-id=2
codec=1
enc-type=0
sync=1
bitrate=4000000
profile=0
rtsp-port=8552
udp-port=5420
iframeinterval=5
gpu-id=0
qos=0
[sink3]
enable=0
# type2 = window
type=2
sync=0 # faster > reduce 1 second
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink16]
enable=1
type=6
msg-conv-config=ANPR_msgconv_config.txt
msg-conv-payload-type=257
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_kafka_proto.so
msg-broker-conn-str=localhost;9092
topic=anpr
msg-broker-config=ANPR_cfg_kafka.txt
msg-conv-msg2p-lib=../message_broker_custom/libnvds_msgconv.so
[message-consumer0]
enable=1
config-file=ANPR_cfg_kafka.txt
subscribe-topic-list=deepStreamConfig;deepStreamHeartbeat
[streammux]
gpu-id=0
live-source=1
batch-size=4
batched-push-timeout=40000
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=3
[primary-gie]
enable=1
gpu-id=0
batch-size=4
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=ANPR_YOLOV4Model_Config_30June.txt
[secondary-gie0]
enable=1
gpu-id=0
gie-unique-id=2
operate-on-gie-id=1
operate-on-class-ids=0;1
batch-size=4
config-file=ANPR_LPRModel_Config_8July.txt
nvbuf-memory-type=0
[osd]
enable=1
gpu-id=0
border-width=1
text-size=13
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=1
clock-x-offset=1000
clock-y-offset=10
clock-text-size=20
clock-color=1;0;0;0
nvbuf-memory-type=0
[tracker]
enable=1
tracker-width=640
tracker-height=480
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_mot_klt.so
gpu-id=0
enable-batch-process=0
display-tracking-id=0
[nvds-analytics]
enable=1
config-file=ANPR_config_nvdsanalytics.txt
[tests]
file-loop=0
The error will be
I set up 3 input streams as source 0, 1,2 and 3 RTSP output streams as sink 0,1,2.
