How to run multi input, multi rtsp output
Hello
I want multiple sources and RTSP sink
however the rtsp output works fine up to 3 inputs, but an error occurs after 4
ERROR from sink_sub_bin_encoder1: Device ‘/dev/nvhost-msenc’ failed during initialization
Debug info: gstv4l2object.c(4074): gst_v4l2_object_set_format_full (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstBin:sink_sub_bin1/nvv4l2h264enc:sink_sub_bin_encoder1:
Call to S_FMT failed for YM12 @ 1920x1080: Unknown error -1
here is my config file
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=3
uri=file://…/…/…/…/…/samples/streams/sample_1080p_h264.mp4
num-sources=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
[source1]
enable=1
type=3
uri=file://…/…/…/…/…/samples/streams/sample_qHD.mp4
num-sources=1
gpu-id=0
source-id=1
nvbuf-memory-type=0
[source2]
enable=1
type=3
uri=file://…/…/…/…/…/samples/streams/sample_720p.h264
num-sources=1
source-id=2
gpu-id=0
nvbuf-memory-type=0
[source3]
enable=1
type=3
uri=file://…/…/…/…/…/samples/streams/sample_cam5.mp4
num-sources=1
gpu-id=0
source-id=3
nvbuf-memory-type=0
[source4]
enable=1
type=3
uri=file://…/…/…/…/…/samples/streams/sample_cam6.mp4
num-sources=1
source-id=4
gpu-id=0
nvbuf-memory-type=0
[source5]
enable=1
type=3
num-sources=1
gpu-id=0
source-id=5
nvbuf-memory-type=0
[source6]
enable=1
type=3
num-sources=1
source-id=6
gpu-id=0
nvbuf-memory-type=0
[source7]
enable=1
type=3
num-sources=1
gpu-id=0
source-id=7
nvbuf-memory-type=0
[source8]
enable=1
type=3
num-sources=1
gpu-id=0
source-id=8
nvbuf-memory-type=0
[sink11]
enable=1
type=4
source-id=1
codec=1
#enc-type=0
sync=0
bitrate=4000000
#profile=0
rtsp-port=8555
udp-port=5001
gpu-id=0
nvbuf-memory-type=0
[sink12]
enable=1
type=4
source-id=2
codec=1
#enc-type=0
sync=0
bitrate=4000000
#profile=0
rtsp-port=8556
udp-port=5002
gpu-id=0
nvbuf-memory-type=0
[sink13]
enable=1
type=4
source-id=3
codec=1
#enc-type=0
sync=0
bitrate=4000000
#profile=0
rtsp-port=8557
udp-port=5003
gpu-id=0
nvbuf-memory-type=0
[sink14]
enable=1
type=4
source-id=4
codec=1
#enc-type=0
sync=0
bitrate=4000000
#profile=0
rtsp-port=8558
udp-port=5004
gpu-id=0
nvbuf-memory-type=0
[sink15]
enable=1
type=4
source-id=5
codec=1
#enc-type=0
sync=0
bitrate=4000000
#profile=0
rtsp-port=8559
udp-port=5005
gpu-id=0
nvbuf-memory-type=0
[sink16]
enable=1
type=4
source-id=6
codec=1
#enc-type=0
sync=0
bitrate=4000000
#profile=0
rtsp-port=8560
udp-port=5006
gpu-id=0
nvbuf-memory-type=0
[sink17]
enable=1
type=4
source-id=7
codec=1
#enc-type=0
sync=0
bitrate=4000000
#profile=0
rtsp-port=8561
udp-port=5007
gpu-id=0
nvbuf-memory-type=0
[sink18]
enable=1
type=4
source-id=8
codec=1
#enc-type=0
sync=0
bitrate=4000000
#profile=0
rtsp-port=8562
udp-port=5008
gpu-id=0
nvbuf-memory-type=0
• DeepStream Version
• TensorRT Version
GPU : nvidia titanX
DeepStream Version : nvcr.io/nvidia/deepstream:5.1-21.02-triton
NVIDIA GPU Driver Version : 465.27
I configured via docker container
and I have successfully tested 9 internal display outputs (type=2) with 9 inputs
Please refer to Video Encode and Decode GPU Support Matrix [NEW] | NVIDIA Developer
Titan X HW codec only supports 3 encoding sessions. Your RTSP settings enable more than 3 HW encoding sessions( by default, “enc-type=0”(DeepStream Reference Application - deepstream-app — DeepStream 6.3 Release documentation)). So it failed. Please just enable 3 HW encoders(“enc-type=0”) and the others use SW encoders(“enc-type=1”).
