• Hardware Platform (Jetson / GPU) Quadro RTX 6000
• DeepStream Version Deepstream 5.1
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) Cuda 11.7
• Issue Type( questions, new requirements, bugs) Question
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) I’m using single-RTSP stream as an input
I’m getting a following log when I run a deepstream-app, after that, it is not getting either terminated or killed, it is just stuck at that point. This happens, whenever reset_source_pipeline is getting called. I’ve provided 2 different logs which I got from running the app.
Log1:
[2023-12-07T19:38:18.512604Z] pid=2236 tid=2236 component=deepstream-app deepstream_source_bin.cpp:1189:reset_source_pipeline Resetting source 0
[2023-12-07T19:38:18.604992Z] pid=2236 tid=2236 component=deepstream-app deepstream_app_main.cpp:656:perf_cb **PERF: 1.070000 (29.049999
[2023-12-07T19:38:18.605465Z] pid=2236 tid=2236 component=deepstream-app deepstream_app.cpp:101:bus_callback WARNING from src_bin_muxer: Either host or Source 0 seems to be out of NTP sync SYS TIME = 2023-12-07T19:38:18.351Z CALCULATED NTP TIME = 2023-12-07T19:37:59.057Z
[2023-12-07T19:38:18.605486Z] pid=2236 tid=2236 component=deepstream-app deepstream_app.cpp:106:bus_callback Debug info: gstnvstreammux_ntp.cpp(97): check_if_sys_rtcp_time_is_ntp_sync (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstNvStreamMux:src_bin_muxer
[2023-12-07T19:38:23.817787Z] pid=2236 tid=2236 component=deepstream-app deepstream_app_main.cpp:656:perf_cb **PERF: 0.000000 (29.040001
Log2:
[2023-12-16T21:42:33.723367Z] pid=389 tid=389 component=deepstream_app deepstream_source_bin.cpp:1189:reset_source_pipeline Resetting source 0
[2023-12-16T21:42:33.748290Z] pid=389 tid=389 component=deepstream_app deepstream_source_bin.cpp:1189:reset_source_pipeline Resetting source 0
[2023-12-16T21:42:33.879280Z] pid=389 tid=389 component=deepstream_app deepstream_app_main.cpp:656:perf_cb **PERF: 0.240000 (29.719999
[2023-12-16T21:42:33.879624Z] pid=389 tid=389 component=deepstream_app deepstream_app.cpp:101:bus_callback WARNING from src_bin_muxer: Either host or Source 0 seems to be out of NTP sync SYS TIME = 2023-12-16T21:42:30.749Z CALCULATED NTP TIME = 2023-12-16T21:40:12.519Z
[2023-12-16T21:42:33.879659Z] pid=389 tid=389 component=deepstream_app deepstream_app.cpp:106:bus_callback Debug info: gstnvstreammux_ntp.cpp(97): check_if_sys_rtcp_time_is_ntp_sync (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstNvStreamMux:src_bin_muxer
[2023-12-16T21:42:33.879716Z] pid=389 tid=389 component=deepstream_app deepstream_app.cpp:101:bus_callback WARNING from src_elem0: Could not write to resource.
[2023-12-16T21:42:33.879739Z] pid=389 tid=389 component=deepstream_app deepstream_app.cpp:106:bus_callback Debug info: gstrtspsrc.c(4884): gst_rtspsrc_send_keep_alive (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstRTSPSrc:src_elem0:
Could not send keep-alive. (Operation interrupted)
[2023-12-16T21:42:33.904650Z] pid=389 tid=389 component=deepstream_app deepstream_app.cpp:118:bus_callback ERROR from src_elem0: Could not read from resource.
[2023-12-16T21:42:33.904699Z] pid=389 tid=389 component=deepstream_app deepstream_app.cpp:118:bus_callback ERROR from src_elem0: Could not write to resource.
[2023-12-16T21:42:33.904722Z] pid=389 tid=389 component=deepstream_app deepstream_app.cpp:101:bus_callback WARNING from src_elem0: Could not read from resource.
[2023-12-16T21:42:33.904734Z] pid=389 tid=389 component=deepstream_app deepstream_app.cpp:106:bus_callback Debug info: gstrtspsrc.c(5200): gst_rtspsrc_loop_interleaved (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstRTSPSrc:src_elem0:
The server closed the connection.
[2023-12-16T21:42:33.907139Z] pid=389 tid=389 component=deepstream_app deepstream_app.cpp:118:bus_callback ERROR from src_elem0: Could not open resource for reading and writing.
Warning: Color primaries 5 not present and will be treated BT.601
[2023-12-16T21:42:48.949205Z] pid=389 tid=389 component=deepstream_app deepstream_app_main.cpp:656:perf_cb **PERF: 0.000000 (29.700001
[2023-12-16T21:42:51.825665Z] pid=389 tid=389 component=deepstream_app deepstream_app_main.cpp:656:perf_cb **PERF: 0.000000 (29.690001
I just want to know 2 things,
- Why reset_source_pipeline is getting called in the first place?
- And why after the call, the app got stuck? Any solution, to fix this problem. Other than porting to higher version.
