GPU
• DeepStream Version
DeepStream 6.2
• TensorRT Version
525
Bug
I have DeepStream reading some RTSP streams and for example when I try reading one frame from some RTSP stream by running this command - ffmpeg -y -i rtsp://admin:@192.168.0.101:554:network-caching=1000 -vframes 1 test.jpg DeepStream crashes and doesn’t reconnect to the stream, even though I these settings for each source group:
select-rtp-protocol=4
rtsp-reconnect-interval-sec=60
rtsp-reconnect-attempts=-1
Here are the logs for when it crashes:
**PERF: 20.00 (20.00) 20.02 (20.00) 20.00 (20.00) 20.03 (20.00) 20.02 (20.00) 20.00 (20.00) 20.02 (20.00) 20.03 (19.99) 20.00 (20.00) 20.02 (20.00)
** ERROR: <cb_newpad3:517>: Failed to link depay loader to rtsp src
ERROR from src_elem7: Internal data stream error.
Debug info: gstrtspsrc.c(6057): gst_rtspsrc_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin7/GstRTSPSrc:src_elem7:
streaming stopped, reason not-linked (-1)
** INFO: <reset_source_pipeline:1774>: Resetting source 7
(deepstream-app:1): GStreamer-CRITICAL **: 09:50:21.454: Padname recv_rtp_src_1_2_8 is not unique in element src_elem7, not adding
(deepstream-app:1): GStreamer-CRITICAL **: 09:50:21.607: Padname recv_rtp_src_0_2_98 is not unique in element src_elem7, not adding
(deepstream-app:1): GStreamer-CRITICAL **: 09:50:31.055: gst_pad_set_active: assertion 'GST_IS_PAD (pad)' failed
(deepstream-app:1): GStreamer-CRITICAL **: 09:50:31.055: gst_element_remove_pad: assertion 'GST_IS_PAD (pad)' failed
ERROR from src_elem7: Could not read from resource.
Debug info: gstrtspsrc.c(6421): gst_rtspsrc_try_send (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin7/GstRTSPSrc:src_elem7:
Could not receive message. (Received end-of-file)
ERROR from src_elem7: Could not write to resource.
Debug info: gstrtspsrc.c(8096): gst_rtspsrc_close (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin7/GstRTSPSrc:src_elem7:
Could not send message. (Received end-of-file)
(deepstream-app:1): GStreamer-CRITICAL **: 09:50:31.156: Padname recv_rtp_src_1_2_8 is not unique in element src_elem7, not adding
(deepstream-app:1): GStreamer-CRITICAL **: 09:50:31.296: Padname recv_rtp_src_0_2_98 is not unique in element src_elem7, not adding
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg) FPS 4 (Avg) FPS 5 (Avg) FPS 6 (Avg) FPS 7 (Avg) FPS 8 (Avg) FPS 9 (Avg)
**PERF: 20.00 (20.00) 19.98 (20.00) 20.00 (20.00) 20.00 (20.00) 20.00 (20.00) 20.00 (20.00) 19.98 (20.00) 19.89 (19.64) 20.00 (20.00) 20.00 (20.00)
**PERF: 20.00 (20.00) 20.00 (20.00) 20.00 (20.00) 20.00 (20.00) 19.98 (20.00) 20.00 (20.00) 20.00 (20.00) 0.00 (19.17) 19.97 (20.00) 19.98 (20.00)
(deepstream-app:1): GStreamer-CRITICAL **: 09:51:31.305: gst_pad_set_active: assertion 'GST_IS_PAD (pad)' failed
(deepstream-app:1): GStreamer-CRITICAL **: 09:51:31.305: gst_element_remove_pad: assertion 'GST_IS_PAD (pad)' failed
Debug info: gstrtspsrc.c(6323): gst_rtsp_src_receive_response (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin7/GstRTSPSrc:src_elem7:
Could not receive message. (System error)
Could not send message. (System error)
(deepstream-app:1): GStreamer-CRITICAL **: 09:51:31.401: Padname recv_rtp_src_1_2_8 is not unique in element src_elem7, not adding
(deepstream-app:1): GStreamer-CRITICAL **: 09:51:31.518: Padname recv_rtp_src_0_2_98 is not unique in element src_elem7, not adding
**PERF: 19.99 (20.00) 20.03 (20.00) 20.02 (20.00) 19.99 (20.00) 20.03 (20.00) 19.99 (20.00) 20.03 (20.00) 0.00 (18.72) 20.02 (20.00) 20.02 (20.00)
**PERF: 20.01 (20.00) 19.98 (20.00) 19.99 (20.00) 20.01 (20.00) 19.98 (20.00) 20.01 (20.00) 19.98 (20.00) 0.00 (18.29) 19.99 (20.00) 19.99 (20.00)
(deepstream-app:1): GStreamer-CRITICAL **: 09:52:31.344: gst_pad_set_active: assertion 'GST_IS_PAD (pad)' failed
(deepstream-app:1): GStreamer-CRITICAL **: 09:52:31.344: gst_element_remove_pad: assertion 'GST_IS_PAD (pad)' failed
(deepstream-app:1): GStreamer-CRITICAL **: 09:52:31.450: Padname recv_rtp_src_1_2_8 is not unique in element src_elem7, not adding
(deepstream-app:1): GStreamer-CRITICAL **: 09:52:31.567: Padname recv_rtp_src_0_2_98 is not unique in element src_elem7, not adding
**PERF: 19.99 (20.00) 20.02 (20.00) 19.99 (20.00) 19.99 (20.00) 20.02 (20.00) 19.99 (20.00) 20.02 (20.00) 0.00 (17.89) 19.99 (20.00) 20.02 (20.00)
**PERF: 20.01 (20.00) 19.98 (20.00) 20.01 (20.00) 20.01 (20.00) 20.00 (20.00) 20.01 (20.00) 19.98 (20.00) 0.00 (17.50) 20.01 (20.00) 19.98 (20.00)
I can then read this stream and record it using for example this command - ffmpeg -i rtsp://admin:@192.168.0.101:554:network-caching=1000 -t 60 1.mp4
However if I restart DeepStream it starts working again.
