Disconnected RTSP streams reduce the frame rate of other streams
2070 Super
• DeepStream Version
6.1
N/A
• TensorRT Version
8.2.5.1
515.48.07
Bug
Stream from multiple RTSP cameras and disconnect one or more cameras.
When streaming from RTSP cameras and one (or more) cameras disconnect all the other streams are capped at 4.79 FPS. Packets are still coming in at normal frame rate, but nvstreammux appear to only push out frames at a very limited rate.
Here’s sample output from deepstream-app when power cycling one camera 1:
**PERF:  FPS 0 (Avg)	FPS 1 (Avg)	FPS 2 (Avg)
**PERF:  26.32 (26.26)	29.68 (29.59)	26.32 (26.26)
**PERF:  29.40 (27.92)	29.40 (29.48)	29.40 (27.92)
**PERF:  13.07 (22.76)	29.98 (22.38)	13.07 (22.76)
**PERF:  4.79 (18.14)	0.00 (16.44)	4.79 (18.14)
** WARN: <watch_source_status:739>: No data from source 1 since last 10 sec. Trying reconnection
** INFO: <reset_source_pipeline:1572>: Resetting source 1
**PERF:  4.79 (15.41)	0.00 (12.99)	4.79 (15.41)
**PERF:  4.79 (13.61)	0.00 (10.74)	4.79 (13.61)
**PERF:  4.79 (12.33)	0.00 (9.16)	4.79 (12.33)
** ERROR: <cb_newpad3:500>: Failed to link depay loader to rtsp src
** INFO: <bus_callback:180>: Pipeline running
**PERF:  16.75 (12.90)	2.54 (9.83)	16.75 (12.90)
**PERF:  30.00 (14.82)	30.00 (12.13)	30.00 (14.82)
**PERF:  29.80 (16.32)	29.80 (13.92)	29.80 (16.32)
**PERF:  29.60 (17.55)	29.60 (15.39)	29.60 (17.55)
Here camera 0 and 2 (same RTSP camera but two different streams) are disconnected and then reconnected:
**PERF:  20.72 (20.60)	29.23 (28.95)	20.72 (20.60)
**PERF:  29.20 (25.16)	29.20 (29.11)	29.20 (25.16)
**PERF:  29.60 (26.70)	29.60 (29.30)	29.60 (26.70)
**PERF:  29.59 (27.45)	29.59 (29.38)	29.59 (27.45)
**PERF:  17.55 (22.19)	6.13 (24.27)	26.28 (22.15)
** WARN: <watch_source_status:739>: No data from source 0 since last 10 sec. Trying reconnection
** INFO: <reset_source_pipeline:1572>: Resetting source 0
**PERF:  0.00 (18.42)	4.79 (20.78)	0.00 (18.39)
** WARN: <watch_source_status:739>: No data from source 2 since last 13 sec. Trying reconnection
** INFO: <reset_source_pipeline:1572>: Resetting source 2
**PERF:  0.00 (15.75)	4.79 (18.35)	0.00 (15.72)
**PERF:  0.00 (13.75)	4.79 (16.56)	0.00 (13.72)
**PERF:  0.00 (12.20)	4.79 (15.19)	0.00 (12.18)
ERROR from src_elem0: Could not open resource for reading and writing.
Debug info: gstrtspsrc.c(7871): gst_rtspsrc_retrieve_sdp (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstRTSPSrc:src_elem0:
Failed to connect. (Generic error)
**PERF:  0.00 (10.97)	4.79 (14.10)	0.00 (10.95)
ERROR from src_elem2: Could not open resource for reading and writing.
Debug info: gstrtspsrc.c(7871): gst_rtspsrc_retrieve_sdp (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin2/GstRTSPSrc:src_elem2:
**PERF:  0.00 (9.96)	4.79 (13.22)	0.00 (9.94)
**PERF:  0.00 (9.12)	4.79 (12.49)	0.00 (9.10)
**PERF:  0.00 (8.41)	4.79 (11.88)	0.00 (8.40)
**PERF:  0.00 (7.81)	4.79 (11.36)	0.00 (7.79)
**PERF:  0.00 (7.28)	4.79 (10.91)	0.00 (7.27)
**PERF:  0.00 (6.82)	4.79 (10.52)	0.00 (6.81)
**PERF:  0.00 (6.42)	4.79 (10.17)	0.00 (6.41)
**PERF:  0.00 (6.06)	4.79 (9.87)	0.00 (6.05)
Warning: Color primaries 5 not present and will be treated BT.601
**PERF:  0.00 (5.74)	4.79 (9.59)	0.05 (5.77)
**PERF:  0.00 (5.45)	4.79 (9.35)	4.79 (5.72)
**PERF:  0.00 (5.19)	4.79 (9.13)	4.79 (5.68)
**PERF:  0.00 (4.95)	4.79 (8.93)	4.79 (5.64)
**PERF:  0.00 (4.74)	4.79 (8.74)	4.79 (5.60)
**PERF:  0.00 (4.54)	4.79 (8.58)	4.79 (5.57)
**PERF:  0.00 (4.36)	4.79 (8.42)	4.79 (5.54)
**PERF:  0.00 (4.19)	4.79 (8.28)	4.79 (5.51)
**PERF:  0.00 (4.03)	4.79 (8.15)	4.79 (5.48)
**PERF:  0.00 (3.89)	4.79 (8.02)	4.79 (5.45)
**PERF:  0.00 (3.75)	4.79 (7.91)	4.79 (5.43)
**PERF:  0.18 (3.78)	8.52 (7.94)	8.52 (5.54)
**PERF:  30.02 (4.64)	30.02 (8.67)	30.02 (6.34)
**PERF:  29.93 (5.43)	29.93 (9.34)	29.93 (7.07)
**PERF:  30.07 (6.18)	30.07 (9.98)	30.07 (7.78)
**PERF:  29.67 (6.87)	29.67 (10.56)	29.67 (8.42)
As you can see in the above output, as soon as a camera is disconnected it takes down the rest of the system to 4.79 FPS. Configuration:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
[tiled-display]
enable=1
rows=2
columns=2
width=1920
height=1080
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=4
uri=rtsp://192.168.4.11:8554/fhd
rtsp-reconnect-attempts=1000
rtsp-reconnect-interval-sec=10
num-sources=1
gpu-id=0
cudadec-memtype=0
[source1]
enable=1
type=4
uri=rtsp://192.168.4.10:554/s0
num-sources=1
gpu-id=0
cudadec-memtype=0
[source2]
enable=1
type=4
num-sources=1
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
type=2
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
[osd]
enable=0
[streammux]
gpu-id=0
live-source=1
batch-size=30
batched-push-timeout=40000
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=0
[tests]
file-loop=0
deepstream-app works with batched data, when there is one stream late, nvstreammux need to wait for a timeout period, the frame rate of each stream is impacted by the latency of the whole batch.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_plugin_gst-nvstreammux.html#gst-nvstreammux
Hi Fiona, how do I fix it? Changing batched-push-timeout doesn’t seem to have any impact.
You don’t need to fix it. The frame rate is just for a period. When the steams become stable, the frame rate will increase.
That doesn’t make sense. A stream can be offline for an indefinite amount of time. deepstream-app seems to have the same issue if the stream is offline when you start the application.
The log in this topic just show low fps during the rtsp connection period. In this period, there is no stable stream data received, so the fps is correct.
Can you set “batch-size=3” in [streammux] group in the configuration file.
