• Hardware Platform (Jetson / GPU) NVIDIA A2 • DeepStream Version 6.3 • TensorRT Version 8.4.0 • NVIDIA GPU Driver Version (valid for GPU only) 535.129.03
I am using a deepstream pipeline in Python and inferring it with nvinfersever and have an issue that I tried to reproduce on deepstream_test3.
My pipeline serves 20+ RTSP streams, but I find that some streams stop suddenly. The sad part is that it doesn’t reconnect again. However, it works fine when I do the same thing with fewer cameras!
I’ll attach the code, screenshots, the commands I used to build RTSP server, and maybe the configs on PeopleNet I use.
please refer to this topic. you can modify batched-push-timeout to improve.
please refer to this FAQ for how to set parameters reasonably to improve the efficiency of nvstreammux in live mode.
I encountered a similar RTSP stream re-connection issue when using nvurisrcbin with deepstream python test3.
Despite setting the suggested parameters, when processing multiple RTSP streams, one of the streams disconnects randomly and never reconnects forcing you to restart the whole pipeline and disturb the processing of the other streams.
Due to this reconnection unreliability with nvurisrcbin, I’m currently trying a different implementation using uridecodebin with deepstream_rt_src_add_del to reconnect a disrupted stream.
I’m still in the process of implementing and testing it with deepstream_test3.py. So that’s why at this moment in time, I can’t say with 100% certainty if this solution is better.
However, what I can say based on my testing/observations is that currently I can’t rely on using nvurisrcbin stream reconnection feature when processing many RTSP streams.
in this topic , I tested two RTSP sources. the reconnecting functionality worked fine. please refer to the log. @JoeShz to narrow down this issue, could you use the following method to get some logs?
You can see in the same topic that the reconnecting functionality failed for 6 public RTSP streams (each of 15 framerate) and also for 2 local RTSP streams (of 20 and 25 framerate). I have shared the logs.
Have you tried testing with more than 2 RTSP streams? And with streams having different framerate? And also left the streams processing in the pipeline for at least 24 hours?
thanks for the sharing! let’s focus this “also for 2 local RTSP streams (of 20 and 25 framerate)” issue first.
I tested two RTSP sources. one is 15fps, the other is 30fps. the reconnection functionality worked well, please refer to log 30fps-15fps.txt (120.2 KB).
from your log two-local-rtsp-streams-reconnect.txt, the fps still is 0 after Resetting source. we can’t rule out the network issue because there is no related logs. to narrow down this issue, could you provide more logs by setting env variable. export GST_DEBUG=3,rtpjitterbuffer:6 first?
are these sources physical camera or virtual rtsp server? how did you imitate disconnecting source? turn off camera? unplug the network cable?
in the log 1.txt, the max fps is 3.8, is it the actual fps?
in the log 1.txt, there is no rtpjitterbuffer logs, which represents receiving status. please redirect the log by " command-line >1.log 2>1.log". for example,
0:00:07.608818879 e[332m 3301e[00m 0x7fd7080038c0 e[37mDEBUG e[00m e[00m rtpjitterbuffer gstrtpjitterbuffer.c:2983:gst_rtp_jitter_buffer_chain:<rtpjitterbuffer0>e[00m Received packet #31258 at time 0:00:03.482960395, discont 0, rtx 0
noticing the two RTSP sources also has reconnection issue in your test. to smiplify the issue, could you test with only two sources? Thanks!
Sure let me do that and share logs with you. Thank you for your response.
During the pipeline’s reconnection attempts, I checked the streams in vlc media player and they were playing properly at that time. Which would not have been possible if a network issue was present.
It seems like @user87838 is right. Whenever I use rtsp-reconnect-interval with nvurisrcbin, some steams suddenly disconnect. Seems like it isn’t functional.
And of course, when I disable this property, and I disconnect some sources, the whole pipeline hangs and this is expected.
So, we need a workaround without using nvurisrcbin or is it fixed in DS 6.4 or something?
