• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 7.0.0
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 535.171.04
• Issue Type( questions, new requirements, bugs) questions
I am currently running a custom model using Python code with DeepStream.
In DeepStream, I am taking 4 RTSP streams as input and outputting them as RTSP streams. The problem is that the RTSP streams being output are unstable. When I use ffmpeg to convert the RTSP streams to MPEG-DASH for live streaming on the web, the segmentation creation in ffmpeg terminates due to EOF.
When I use JSMPeg or another RTSP stream player for web streaming, the video frequently buffers or freezes.
I would like to know how to stabilize the output RTSP streams in DeepStream and what options to change to prevent these issues.
Below is the current Python code.
def decodebin_child_added(child_proxy, Object, name, user_data):
if name.find('decodebin') != -1:
Object.connect('child-added', decodebin_child_added, user_data)
if name.find('nvv4l2decoder') != -1:
Object.set_property('drop-frame-interval', 0)
Object.set_property('num-extra-surfaces', 1)
Object.set_property('cudadec-memtype', 0)
Object.set_property('gpu-id', GPU_ID)
def cb_newpad(decodebin, pad, user_data):
streammux_sink_pad = user_data
caps = pad.get_current_caps()
if not caps:
caps = pad.query_caps()
structure = caps.get_structure(0)
name = structure.get_name()
features = caps.get_features(0)
if name.find('video') != -1:
if features.contains('memory:NVMM'):
if pad.link(streammux_sink_pad) != Gst.PadLinkReturn.OK:
sys.stderr.write('ERROR: Failed to link source to streammux sink pad\n')
else:
sys.stderr.write('ERROR: decodebin did not pick NVIDIA decoder plugin')
def create_uridecode_bin(stream_id, uri, streammux):
bin_name = 'source-bin-%04d' % stream_id
bin = Gst.ElementFactory.make('uridecodebin', bin_name)
bin.set_property('uri', uri)
bin.set_property('expose-all-streams', False)
if 'rtsp://' in uri:
rtspsrc = bin.get_by_name("source")
if rtspsrc:
rtspsrc.set_property('short-header', True)
rtspsrc.set_property('ntp-sync', True)
rtspsrc.set_property('latency', 200)
rtspsrc.set_property('ntp-time-source', 3) # 3 usually stands for "automatic"
pad_name = 'sink_%u' % stream_id
streammux_sink_pad = streammux.get_request_pad(pad_name)
bin.connect('pad-added', cb_newpad, streammux_sink_pad)
bin.connect('child-added', decodebin_child_added, 0)
fps_streams['stream{0}'.format(stream_id)] = GETFPS(stream_id)
return bin
def bus_call(bus, message, user_data):
loop = user_data
t = message.type
if os.path.exists('quit.txt'):
os.remove('quit.txt')
with open('flow_quit.txt', 'w') as f:
f.write('')
loop.quit()
if t == Gst.MessageType.EOS:
sys.stdout.write('DEBUG: EOS\n')
loop.quit()
elif t == Gst.MessageType.WARNING:
err, debug = message.parse_warning()
sys.stderr.write('WARNING: %s: %s\n' % (err, debug))
elif t == Gst.MessageType.ERROR:
err, debug = message.parse_error()
sys.stderr.write('ERROR: %s: %s\n' % (err, debug))
loop.quit()
return True
def run_script_in_conda_env(conda_env_name, script_path):
# Find the path to the conda executable
conda_executable = "/home/ubuntu/anaconda3/bin/activate" # Update this to the actual path of your conda executable
# Construct the command to activate the environment and run the script
command = f'python3 {script_path}'
# Execute the command
result = subprocess.run(command, shell=True, capture_output=True, text=True, executable='/bin/bash')
# Print the output and error if any
print(result.stdout)
if result.stderr:
print(result.stderr)
def main():
global ip, port, cctv_id, cctv_pw
flow_thread = Thread(target=run_script_in_conda_env, args=("count", "detect_and_track_sub.py"))
flow_thread.daemon = True
flow_thread.start()
Gst.init(None)
loop = GLib.MainLoop()
pipeline = Gst.Pipeline()
if not pipeline:
sys.stderr.write('ERROR: Failed to create pipeline\n')
sys.exit(1)
streammux = Gst.ElementFactory.make('nvstreammux', 'nvstreammux')
if not streammux:
sys.stderr.write('ERROR: Failed to create nvstreammux\n')
sys.exit(1)
pipeline.add(streammux)
tiler = Gst.ElementFactory.make('nvmultistreamtiler', 'nvtiler')
if not tiler:
sys.stderr.write('ERROR: Failed to create nvmultistreamtiler\n')
sys.exit(1)
tiler.set_property('rows', ROWS)
tiler.set_property('columns', COLUMNS)
tiler.set_property('width', STREAMMUX_WIDTH / ROWS)
tiler.set_property('height', STREAMMUX_HEIGHT / COLUMNS)
pipeline.add(tiler)
pgie = Gst.ElementFactory.make('nvinfer', 'pgie')
if not pgie:
sys.stderr.write('ERROR: Failed to create nvinfer\n')
sys.exit(1)
converter = Gst.ElementFactory.make('nvvideoconvert', 'nvvideoconvert')
if not converter:
sys.stderr.write('ERROR: Failed to create nvvideoconvert\n')
sys.exit(1)
osd = Gst.ElementFactory.make('nvdsosd', 'nvdsosd')
if not osd:
sys.stderr.write('ERROR: Failed to create nvdsosd\n')
sys.exit(1)
nvvidconv_postosd = Gst.ElementFactory.make("nvvideoconvert", "convertor_postosd")
caps = Gst.ElementFactory.make("capsfilter", "filter")
caps.set_property(
"caps", Gst.Caps.from_string(f"video/x-raw(memory:NVMM), format=I420, width=(int)1920, height=(int)1080")
# Make the encoder
encoder = Gst.ElementFactory.make("nvv4l2h264enc", "encoder")
if not encoder:
sys.stderr.write(" Unable to create encoder")
encoder.set_property("bitrate", bitrate)
# encoder.set_property("bitrate", 8000000)
encoder.set_property("iframeinterval", 60)
encoder.set_property("profile", 2)
# Make the payload-encode video into RTP packets
rtppay = Gst.ElementFactory.make("rtph264pay", "rtppay")
# rtppay.set_property("mtu", 1400)
print("Creating H264 rtppay")
# Make the UDP sink
udpsink_port_num = 25400
sink = Gst.ElementFactory.make("udpsink", "udpsink")
if not sink:
sys.stderr.write(" Unable to create udpsink")
sink.set_property("host", "127.0.0.1")
sink.set_property("port", udpsink_port_num)
sink.set_property("async", False)
sink.set_property("sync", True)
sink.set_property("buffer-size", buf_size)
streammux.set_property('batch-size', STREAMMUX_BATCH_SIZE)
streammux.set_property('batched-push-timeout', 25000)
streammux.set_property('width', STREAMMUX_WIDTH)
streammux.set_property('height', STREAMMUX_HEIGHT)
streammux.set_property('enable-padding', 0)
streammux.set_property('live-source', True)
streammux.set_property('attach-sys-ts', True)
pgie.set_property('config-file-path', CONFIG_INFER)
osd.set_property('process-mode', int(pyds.MODE_GPU))
osd.set_property('display-bbox', 1)
osd.set_property('display-text', 0)
pipeline.add(pgie)
pipeline.add(converter)
pipeline.add(osd)
pipeline.add(nvvidconv_postosd)
pipeline.add(caps)
pipeline.add(encoder)
pipeline.add(rtppay)
pipeline.add(sink)
streammux.link(tiler)
tiler.link(pgie)
pgie.link(converter)
converter.link(osd)
osd.link(nvvidconv_postosd)
nvvidconv_postosd.link(caps)
caps.link(encoder)
encoder.link(rtppay)
rtppay.link(sink)
sources = [None, None, None, None]
for idx in range(4):
sources[idx] = 'rtsp://' + str(cctv_id[idx]) + ':' + str(cctv_pw[idx]) + '@' + \
str(ip[idx]) + ':' + str(port[idx]) + '/profile2/media.smp'
for idx, source in enumerate(sources):
source_bin = create_uridecode_bin(idx, source, streammux)
pipeline.add(source_bin)
source_bin.sync_state_with_parent()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect('message', bus_call, loop)
# Connect custom probe function to pgie src pad
pgie_src_pad = pgie.get_static_pad('src')
if not pgie_src_pad:
sys.stderr.write('ERROR: Failed to get pgie src pad\n')
sys.exit(1)
else:
pgie_src_pad.add_probe(Gst.PadProbeType.BUFFER, tracker_src_pad_buffer_probe, 0)
rtsp_port_num = 18555
server = GstRtspServer.RTSPServer.new()
server.props.service = "%d" % rtsp_port_num
server.attach(None)
factory = GstRtspServer.RTSPMediaFactory.new()
factory.set_launch(
'( udpsrc name=pay0 port=%d buffer-size=%d caps="application/x-rtp, media=video, clock-rate=90000, '
'encoding-name=(string)%s, payload=96 " )'
% (udpsink_port_num, buf_size, 'H264')
factory.set_shared(True)
server.get_mount_points().add_factory("/ds-test", factory)
print(
"\n *** DeepStream: Launched RTSP Streaming at rtsp://localhost:%d/ds-test ***\n\n"
% rtsp_port_num
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except Exception as e:
print(e)
pass
pipeline.set_state(Gst.State.NULL)
