• Hardware Platform (Jetson / GPU) :Jetson nano 4gb
• DeepStream Version:5.1
• JetPack Version (valid for Jetson only):4.5.1
• TensorRT Version :7.1
• NVIDIA GPU Driver Version (valid for GPU only) :10.2
• Issue Type( questions, new requirements, bugs) :bugs
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing):yes
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description):deepstream RTSP_IN_RTSP_OUT
At Server/Producer Side:
I have merged the nvanalytics and Tracker with RTSPinRTSPout pipeline. And writing the stream on port 5400 using udp sink and then hosting it on rtsp server at port 8554 : rtsp://localhost:8554/ds-test
At Client/Consumer Side:
Fetched the video from rtsp://localhost:8554/ds-test and saved to local disk using gstreamer pipeline.
Problems I am facing:
- Few Video file (.mp4) got saved with size of bytes. (Out of 90 videos 30 videos in bytes(size) are not playable)
- We are not getting constant video duration (ranging from 2 sec to 13 sec)
Please see below the code for reference:
Server/Producer:
Standard GStreamer initialization
GObject.threads_init()
Gst.init(None)
# Create gstreamer elements */
# Create Pipeline element that will form a connection of other elements
print("Creating Pipeline \n ")
pipeline = Gst.Pipeline()
is_live = False
if not pipeline:
sys.stderr.write(" Unable to create Pipeline \n")
print("Creating streamux \n ")
# Create nvstreammux instance to form batches from one or more sources.
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
if not streammux:
sys.stderr.write(" Unable to create NvStreamMux \n")
pipeline.add(streammux)
for i in range(number_sources):
print("Creating source_bin ", i, " \n ")
uri_name = args[i]
if uri_name.find("rtsp://") == 0:
is_live = True
source_bin = create_source_bin(i, uri_name)
if not source_bin:
sys.stderr.write("Unable to create source bin \n")
pipeline.add(source_bin)
padname = "sink_%u" % i
sinkpad = streammux.get_request_pad(padname)
if not sinkpad:
sys.stderr.write("Unable to create sink pad bin \n")
srcpad = source_bin.get_static_pad("src")
if not srcpad:
sys.stderr.write("Unable to create src pad bin \n")
srcpad.link(sinkpad)
# queue1=Gst.ElementFactory.make("queue","queue1")
# queue2=Gst.ElementFactory.make("queue","queue2")
# queue3=Gst.ElementFactory.make("queue","queue3")
# queue4=Gst.ElementFactory.make("queue","queue4")
# queue5=Gst.ElementFactory.make("queue","queue5")
# queue6=Gst.ElementFactory.make("queue","queue6")
# queue7=Gst.ElementFactory.make("queue","queue7")
# pipeline.add(queue1)
# pipeline.add(queue2)
# pipeline.add(queue3)
# pipeline.add(queue4)
# pipeline.add(queue5)
# pipeline.add(queue6)
# pipeline.add(queue7)
print("Creating Pgie \n ")
if gie=="nvinfer":
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
else:
pgie = Gst.ElementFactory.make("nvinferserver", "primary-inference")
if not pgie:
sys.stderr.write(" Unable to create pgie \n")
print("Creating nvtracker \n ")
tracker = Gst.ElementFactory.make("nvtracker", "tracker")
if not tracker:
sys.stderr.write(" Unable to create tracker \n")
print("Creating nvdsanalytics \n ")
nvanalytics = Gst.ElementFactory.make("nvdsanalytics", "analytics")
if not nvanalytics:
sys.stderr.write(" Unable to create nvanalytics \n")
nvanalytics.set_property("config-file", 'config_ATMS.txt')
print("Creating tiler \n ")
tiler = Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
if not tiler:
sys.stderr.write(" Unable to create tiler \n")
print("Creating nvvidconv \n ")
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
if not nvvidconv:
sys.stderr.write(" Unable to create nvvidconv \n")
print("Creating nvosd \n ")
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
if not nvosd:
sys.stderr.write(" Unable to create nvosd \n")
nvvidconv_postosd = Gst.ElementFactory.make(
"nvvideoconvert", "convertor_postosd")
if not nvvidconv_postosd:
sys.stderr.write(" Unable to create nvvidconv_postosd \n")
# Create a caps filter
caps = Gst.ElementFactory.make("capsfilter", "filter")
caps.set_property(
"caps", Gst.Caps.from_string("video/x-raw(memory:NVMM), format=I420")
# Make the encoder
if codec == "H264":
encoder = Gst.ElementFactory.make("nvv4l2h264enc", "encoder")
print("Creating H264 Encoder")
elif codec == "H265":
encoder = Gst.ElementFactory.make("nvv4l2h265enc", "encoder")
print("Creating H265 Encoder")
if not encoder:
sys.stderr.write(" Unable to create encoder")
encoder.set_property("bitrate", bitrate)
if is_aarch64():
encoder.set_property("preset-level", 1)
encoder.set_property("insert-sps-pps", 1)
encoder.set_property("bufapi-version", 1)
# Make the payload-encode video into RTP packets
if codec == "H264":
rtppay = Gst.ElementFactory.make("rtph264pay", "rtppay")
print("Creating H264 rtppay")
rtppay = Gst.ElementFactory.make("rtph265pay", "rtppay")
print("Creating H265 rtppay")
if not rtppay:
sys.stderr.write(" Unable to create rtppay")
# Make the UDP sink
updsink_port_num = 5400
sink = Gst.ElementFactory.make("udpsink", "udpsink")
if not sink:
sys.stderr.write(" Unable to create udpsink")
sink.set_property("host", "224.224.255.255")
sink.set_property("port", updsink_port_num)
sink.set_property("async", False)
sink.set_property("sync", 1)
if is_live:
print("Atleast one of the sources is live")
streammux.set_property('live-source', 1)
streammux.set_property("width", 1280)
streammux.set_property("height", 960)
streammux.set_property("batch-size", 1)
streammux.set_property("batched-push-timeout", 4000000)
if gie=="nvinfer":
pgie.set_property("config-file-path", "ATMS_pgie_config.txt")
else:
pgie.set_property("config-file-path", "dstest1_pgie_inferserver_config.txt")
pgie_batch_size = pgie.get_property("batch-size")
if pgie_batch_size != number_sources:
print(
"WARNING: Overriding infer-config batch-size",
pgie_batch_size,
" with number of sources ",
number_sources,
" \n",
pgie.set_property("batch-size", number_sources)
print("Adding elements to Pipeline \n")
tiler_rows = int(math.sqrt(number_sources))
tiler_columns = int(math.ceil((1.0 * number_sources) / tiler_rows))
tiler.set_property("rows", tiler_rows)
tiler.set_property("columns", tiler_columns)
tiler.set_property("width", TILED_OUTPUT_WIDTH)
tiler.set_property("height", TILED_OUTPUT_HEIGHT)
sink.set_property("qos", 0)
#Set properties of tracker
config = configparser.ConfigParser()
config.read('ATMS_tracker_config.txt')
config.sections()
for key in config['tracker']:
if key == 'tracker-width' :
tracker_width = config.getint('tracker', key)
tracker.set_property('tracker-width', tracker_width)
if key == 'tracker-height' :
tracker_height = config.getint('tracker', key)
tracker.set_property('tracker-height', tracker_height)
if key == 'gpu-id' :
tracker_gpu_id = config.getint('tracker', key)
tracker.set_property('gpu_id', tracker_gpu_id)
if key == 'll-lib-file' :
tracker_ll_lib_file = config.get('tracker', key)
tracker.set_property('ll-lib-file', tracker_ll_lib_file)
if key == 'll-config-file' :
tracker_ll_config_file = config.get('tracker', key)
tracker.set_property('ll-config-file', tracker_ll_config_file)
if key == 'enable-batch-process' :
tracker_enable_batch_process = config.getint('tracker', key)
tracker.set_property('enable_batch_process', tracker_enable_batch_process)
if key == 'enable-past-frame' :
tracker_enable_past_frame = config.getint('tracker', key)
tracker.set_property('enable_past_frame', tracker_enable_past_frame)
pipeline.add(pgie)
pipeline.add(tracker)
pipeline.add(nvanalytics)
pipeline.add(tiler)
pipeline.add(nvvidconv)
pipeline.add(nvosd)
pipeline.add(nvvidconv_postosd)
pipeline.add(caps)
pipeline.add(encoder)
pipeline.add(rtppay)
pipeline.add(sink)
streammux.link(pgie)
pgie.link(tracker)
tracker.link(nvanalytics)
nvanalytics.link(nvvidconv)
nvvidconv.link(tiler)
tiler.link(nvosd)
nvosd.link(nvvidconv_postosd)
nvvidconv_postosd.link(caps)
caps.link(encoder)
encoder.link(rtppay)
rtppay.link(sink)
# create an event loop and feed gstreamer bus mesages to it
loop = GObject.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect("message", bus_call, loop)
# nvanalytics_src_pad=nvanalytics.get_static_pad("src")
# if not nvanalytics_src_pad:
# sys.stderr.write(" Unable to get src pad \n")
# else:
# nvanalytics_src_pad.add_probe(Gst.PadProbeType.BUFFER, nvanalytics_src_pad_buffer_probe, 0)
tiler_sink_pad = tiler.get_static_pad("sink")
if not tiler_sink_pad:
sys.stderr.write(" Unable to get sink pad \n")
else:
tiler_sink_pad.add_probe(Gst.PadProbeType.BUFFER, tiler_sink_pad_buffer_probe, 0)
# Start streaming
rtsp_port_num = 8554
server = GstRtspServer.RTSPServer.new()
server.props.service = "%d" % rtsp_port_num
server.attach(None)
factory = GstRtspServer.RTSPMediaFactory.new()
factory.set_launch(
'( udpsrc name=pay0 port=%d buffer-size=524288 caps="application/x-rtp, media=video, clock-rate=90000, encoding-name=(string)%s, payload=96 " )'
% (updsink_port_num, codec)
factory.set_shared(True)
server.get_mount_points().add_factory("/ds-test", factory)
print(
"\n *** DeepStream: Launched RTSP Streaming at rtsp://localhost:%d/ds-test ***\n\n"
% rtsp_port_num
for i, source in enumerate(args):
if (i != 0):
print(i, ": ", source)
# start play back and listen to events
print("Starting pipeline \n")
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except BaseException:
pass
# cleanup
pipeline.set_state(Gst.State.NULL)
def parse_args():
parser = argparse.ArgumentParser(description='RTSP Output Sample Application Help ')
parser.add_argument("-i", “–input”,
help=“Path to input H264 elementry stream”, nargs="+", default=[“a”], required=True)
parser.add_argument("-g", “–gie”, default=“nvinfer”,
help=“choose GPU inference engine type nvinfer or nvinferserver , default=nvinfer”, choices=[‘nvinfer’,‘nvinferserver’])
parser.add_argument("-c", “–codec”, default=“H264”,
help=“RTSP Streaming Codec H264/H265 , default=H264”, choices=[‘H264’,‘H265’])
parser.add_argument("-b", “–bitrate”, default=4000000,
help="Set the encoding bitrate ", type=int)
# Check input arguments
if len(sys.argv)==1:
parser.print_help(sys.stderr)
sys.exit(1)
args = parser.parse_args()
global codec
global bitrate
global stream_path
global gie
gie = args.gie
codec = args.codec
bitrate = args.bitrate
stream_path = args.input
return stream_path
if name == ‘main’:
stream_path = parse_args()
sys.exit(main(stream_path))
Client/Listener:
# Initializes Gstreamer, it’s variables, paths
Gst.init(sys.argv)
command="rtspsrc location=rtsp://localhost:8554/ds-test latency=0 ! rtph264depay ! h264parse ! mp4mux ! filesink location="+tempFileName
pipeline = Gst.parse_launch(command)
# allow bus to emit messages to main thread
# Init GObject loop to handle Gstreamer Bus Events
# Add handler to specific signal
bus.connect("message", on_message, loop)
# Start pipeline
time.sleep(15)
pipeline.send_event(Gst.Event.new_eos())
try:
loop.run()
except Exception:
#traceback.print_exc()
loop.quit()
# Stop Pipeline
