Nvmultistreamtiler error: [NvTiler::Composite] ERROR: 335; ScaleAndPlaceAllMeta failed (0x7f5b4c840970;0x7f5b4c47ad60)
**• NVIDIA GeForce RTX 3050
**• DeepStream 6.1.1
**• NVIDIA GPU Driver Version 525
I am trying to use deepstream to receive RTSP streams, perform inference and then broadcast the streams again via RTSP using the nvmultistreamtiler
I managed to get it working a while back but when I tried it again I am getting the following error log:
Error: gst-resource-error-quark: GstNvTiler: FATAL ERROR; NvTiler::Composite failed (1): gstnvtiler.cpp(665): gst_nvmultistreamtiler_transform (): /GstPipeline:pipeline0/GstNvMultiStreamTiler:nvtiler
[NvTiler::ScaleAndPlaceAllMeta] ERROR: 175; scaleX=0.000000 scaleY=0.000000 frameMeta=0x7f5b4ca34530
[NvTiler::Composite] ERROR: 335; ScaleAndPlaceAllMeta failed (0x7f5b4ca24e80;0x7f5b4c988b40)
The error is repeated again and again. Is it something to do with the alignment of the width and height of the streammuxer and the tiler ? My full source code below
def setup_and_run_pipeline(logger, streams, config):
	global g_streams
	global g_config
	global g_source_bins
	global pipeline
	global nvanalytics
	global streammux
	global g_logger
	global CONTAINER_ID
	g_streams = streams
	g_config = config
	g_logger = logger
	CONTAINER_ID = open('/root/containerid').read().strip()
	GObject.threads_init()
	Gst.init(None)
	pipeline = Gst.Pipeline()
	pipeline_elements = []
	if not pipeline:
		print("Error starting gstream pipeline")
		sys.exit(1)
	number_sources = len(streams.get_streams())
	# Force 1 if no online cams
	if number_sources <= 0:
		number_sources = 1
	# Set up streammux
	streammux = generate_element('nvstreammux', "Stream-muxer")
	streammux.set_property('width', PIPELINE_WIDTH)
	streammux.set_property('height', PIPELINE_HEIGHT)
	streammux.set_property('batched-push-timeout', 100000)
	pipeline_elements.append(streammux)
	# Set up PGIE
	pgie = generate_element("nvinfer", "primary-inference")
	#pgie.set_property('config-file-path', 'model/traffic_cam_infer.txt')
	pgie.set_property('config-file-path', 'model/pgie_yolov4_tiny_tao_config.txt')
	pipeline_elements.append(pgie)
	streammux.set_property('batch-size', number_sources)
	pgie.set_property('batch-size', 8)
	#pgie.set_property('model-engine-file', "model/resnet34_peoplenet_pruned.etlt_b1_gpu0_fp16.engine".format(1))
	#pgie.set_property('model-engine-file', "model/resnet18_trafficcamnet_pruned.etlt_b{}_gpu0_fp32.engine".format(number_sources))
	pgie.set_property("model-engine-file", "model_b{}_gpu0_fp32.engine".format(8))
	# Tracker
	tracker = generate_element('nvtracker', 'tracker')
	tracker.set_property('tracker-width', PIPELINE_WIDTH)
	tracker.set_property('tracker-height', PIPELINE_HEIGHT)
	tracker.set_property('gpu_id', 0)
	tracker.set_property('ll-lib-file', "/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so")
	#tracker.set_property('ll-config-file', "pipeline/config_tracker_IOU.yml")
	tracker.set_property('ll-config-file', 'pipeline/config_tracker_NvDCF_perf.yml')
	tracker.set_property('enable_batch_process', 1)
	tracker.set_property('compute-hw', 1)
	pipeline_elements.append(tracker)
	# Analytics
	nvanalytics = generate_element('nvdsanalytics', 'analytics')
	nvanalytics.set_property('config-file', 'pipeline/config_analytics.txt')
	pipeline_elements.append(nvanalytics)
	nvvidconv1 = generate_element('nvvideoconvert', 'convertor1')
	pipeline_elements.append(nvvidconv1)
	if config['output_rtsp'] == "True":
		tiler = generate_element('nvmultistreamtiler', 'nvtiler')
		tiler_rows = int(math.sqrt(number_sources))
		tiler_columns = int(math.ceil((1.0 * number_sources) / tiler_rows))
		tiler.set_property('rows', tiler_rows)
		tiler.set_property('columns', tiler_columns)
		tiler.set_property('width', TILED_OUTPUT_WIDTH)
		tiler.set_property('height', TILED_OUTPUT_HEIGHT)
		tiler.set_property('qos', 0)
		pipeline_elements.append(tiler)
		mem_type = int(pyds.NVBUF_MEM_CUDA_UNIFIED)
		streammux.set_property("nvbuf-memory-type", mem_type)
		nvvidconv1.set_property("nvbuf-memory-type", mem_type)
		tiler.set_property("nvbuf-memory-type", mem_type)
		nvosd = generate_element('nvdsosd', 'onscreendisplay')
		pipeline_elements.append(nvosd)
		nvvidconv_postosd = generate_element('nvvideoconvert', 'convertor_postosd')
		pipeline_elements.append(nvvidconv_postosd)
		caps = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=I420")
		filter1 = generate_element("capsfilter", "filter1")
		filter1.set_property('caps', caps)
		pipeline_elements.append(filter1)
		encoder = generate_element('nvv4l2h264enc', 'encoder')
		encoder.set_property('bitrate', 4000000)
		pipeline_elements.append(encoder)
		rtppay = generate_element('rtph264pay', 'rtppay')
		pipeline_elements.append(rtppay)
		udpsink_port_num = 5400
		sink = generate_element('udpsink', 'udpsink')
		sink.set_property('host', '224.224.255.255')
		sink.set_property('port', udpsink_port_num)
		sink.set_property('async', False)
		sink.set_property('sync', 1)
		pipeline_elements.append(sink)
	else:
		caps = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
		sink = generate_element('fakesink', 'fakesink')
		sink.set_property('sync', 0)
		sink.set_property('qos', 0)
	for elem in pipeline_elements:
		pipeline.add(elem)
	if config['stream_video_file'] == "False":
		print("Streaming live")
		for stream in streams.get_streams():
			print("Creating source_bin{} for stream {}".format(stream.camera_id, stream.rtsp_url))
			uri_name = streams.get_uri(stream)
			source_bin = create_source_bin(g_logger, stream.camera_id, uri_name)
			if not source_bin:
				print("Error creating source bin")
				sys.exit(1)
			g_source_bins[stream.camera_id] = source_bin
			pipeline.add(source_bin)
			padname = "sink_%u" % stream.camera_id
			sinkpad = streammux.get_request_pad(padname)
			if not sinkpad:
				print("unable to get sink pad bin")
				sys.exit(1)
			srcpad = source_bin.get_static_pad("src")
			if not srcpad:
				print("Unable to get source pad")
				sys.exit(1)
			srcpad.link(sinkpad)
		streammux.set_property('live-source', 1)
	else:
		print("Adding file source to pipeline")
		stream_id = "0"
		srcbin = generate_element("filesrc", "file-source")
		srcbin.set_property('location', 'testvid5.264')
		pipeline.add(srcbin)
		h264parse = generate_element('h264parse', 'h264-parser')
		pipeline.add(h264parse)
		decoder = generate_element('nvv4l2decoder', 'nvv4l2-decoder')
		pipeline.add(decoder)
		redis_conn.set("stream{}-crossings".format(stream_id), cPickle.dumps([]))
		srcbin.link(h264parse)
		h264parse.link(decoder)
		sinkpad = streammux.get_request_pad('sink_0')
		if not sinkpad:
			print("Error getting sink pad for video")
			sys.exit(1)
		srcpad = decoder.get_static_pad('src')
		if not srcpad:
			print("Error getting source pad for video")
			sys.exit(1)
		print("Done with file source")
	for i in range(1, len(pipeline_elements)):
		pipeline_elements[i - 1].link(pipeline_elements[i])
	loop = GObject.MainLoop()
	bus = pipeline.get_bus()
	bus.add_signal_watch()
	bus.connect("message", bus_call, loop)
		rtsp_port_num = 8554
		generate_rtsp_server(rtsp_port_num, udpsink_port_num)
		sink_pad = tiler.get_static_pad('sink')
	else:
		sink_pad = sink.get_static_pad('sink')
	if not sink_pad:
		print("Unable to get sink pad")
		sys.exit(1)
	else:
		sink_pad.add_probe(Gst.PadProbeType.BUFFER, sink_pad_buffer_probe, 0)
	pipeline.set_state(Gst.State.PLAYING)
	# TODO Check sources
	GObject.timeout_add_seconds(10, add_delete_streams)
	print(streams.get_streams())
		print(stream.camera_id, "(", stream.name, "): ", streams.get_uri(stream))
	try:
		loop.run()
	except:
		print("LOOP EXCEPTION")
		pass
	print("Exiting App\n")
	pipeline.set_state(Gst.State.NULL)
def generate_element(key, name):
	elem = Gst.ElementFactory.make(key, name)
	if not elem:
		print("Error creating", key)
		sys.exit(1)
	return elem
def cb_newpad(decodebin, decoder_src_pad,data):
	caps=decoder_src_pad.get_current_caps()
	gststruct=caps.get_structure(0)
	gstname=gststruct.get_name()
	source_bin=data
	features=caps.get_features(0)
	# Need to check if the pad created by the decodebin is for video and not
	# audio.
	if(gstname.find("video")!=-1):
		# Link the decodebin pad only if decodebin has picked nvidia
		# decoder plugin nvdec_*. We do this by checking if the pad caps contain
		# NVMM memory features.
		if features.contains("memory:NVMM"):
			# Get the source bin ghost pad
			bin_ghost_pad=source_bin.get_static_pad("src")
			if not bin_ghost_pad.set_target(decoder_src_pad):
				sys.exit("Failed to link decoder src pad to source bin ghost pad")
		else:
			sys.exit("Error: Decodebin did not pick nvidia decoder plugin")
def decodebin_child_added(child_proxy,Object,name,user_data):
	global g_streams
	source_bin_name = user_data.get_property('name')
	camera_id = int(source_bin_name.partition("source-bin-")[2])
	if(name.find("source") != -1):
		Object.set_property("latency", g_streams.get_rtsp_latency(camera_id))
		Object.set_property("retry",65535)
		#Object.set_property("tcp-timeout",100000000)
		#Object.set_property("timeout",100000000)
		Object.set_property("drop-on-latency",True)
		Object.set_property("do-retransmission", eval(g_config["do-retransmission"]))
		print("Camera id {} rtsp latency: {}".format(camera_id, Object.get_property("latency")))
	if "nvv4l2decoder" in name:
		#Object.set_property("drop-frame-interval", g_streams.get_decoder_drop_frame_interval(camera_id))
		Object.set_property("num-extra-surfaces", g_streams.get_decoder_num_extra_surfaces(camera_id))
		print("Camera id {} decode drop-frame-interval: {}".format(camera_id, Object.get_property("drop-frame-interval")))
		print("Camera id {} decoder num-extra-surfaces: {}".format(camera_id, Object.get_property("num-extra-surfaces")))
	if(name.find("decodebin") != -1):
		Object.connect("child-added",decodebin_child_added,user_data)
def generate_rtsp_server(rtsp_port_num, udpsink_port_num):
	server = GstRtspServer.RTSPServer.new()
	server.props.service = "%d" % rtsp_port_num
	server.attach(None)
	factory = GstRtspServer.RTSPMediaFactory.new()
	factory.set_launch( "( udpsrc name=pay0 port=%d buffer-size=524288 caps=\"application/x-rtp, media=video, clock-rate=90000, encoding-name=(string)%s, payload=96 \" )" % (udpsink_port_num, 'H264'))
	factory.set_shared(True)
	server.get_mount_points().add_factory('/ds-test', factory)
	print("\n *** DeepStream: Launched RTSP Streaming at rtsp://localhost:%d/ds-test ***\n\n" % rtsp_port_num)
def create_source_bin(logger, index, uri):
	# Create a source GstBin to abstract this bin's content from the rest of the
	# pipeline
	bin_name="source-bin-%02d" %index
	nbin=Gst.Bin.new(bin_name)
	if not nbin:
		logger.error("Unable to create source bin")
		sys.exit("Unable to create source bin")
	# Source element for reading from the uri.
	# We will use decodebin and let it figure out the container format of the
	# stream and the codec and plug the appropriate demux and decode plugins.
	uri_decode_bin=Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
	if not uri_decode_bin:
		logger.error("Unable to create uri decode bin")
		sys.exit("Unable to create uri decode bin")
	# We set the input uri to the source element
	uri_decode_bin.set_property("uri",uri)
	uri_decode_bin.set_property("buffer-duration",1000)
	# Connect to the "pad-added" signal of the decodebin which generates a
	# callback once a new pad for raw data has been created by the decodebin
	uri_decode_bin.connect("pad-added",cb_newpad,nbin)
	uri_decode_bin.connect("child-added",decodebin_child_added,nbin)
	# We need to create a ghost pad for the source bin which will act as a proxy
	# for the video decoder src pad. The ghost pad will not have a target right
	# now. Once the decode bin creates the video decoder and generates the
	# cb_newpad callback, we will set the ghost pad target to the video decoder
	# src pad.
	Gst.Bin.add(nbin,uri_decode_bin)
	bin_pad=nbin.add_pad(Gst.GhostPad.new_no_target("src",Gst.PadDirection.SRC))
	if not bin_pad:
		logger.error("Failed to add ghost pad in source bin")
		sys.exit("Failed to add ghost pad in source bin")
		return None
	# Reset crossing data for stream
	print("srckey", "stream{}".format(index))
	redis_conn.set("stream{}".format(index) + '-crossings', cPickle.dumps([]))
	return nbin
Any suggestions would be appreciated
how to run this code? can this issue be reproduced every time? there are many custom codes, can you simplify the code to reproduce the issue?
please refer to this sample, deepstream_python_apps/deepstream_test1_rtsp_in_rtsp_out.py at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub, it can accept rtsp source and output rtsp.
