Ok sure
0:00:00.114999852 e[336m14783e[00m 0x7f5403f6d0 e[32;01mFIXME e[00m e[00;04m default gstutils.c:3981:gst_pad_create_stream_id_internal:<fakesrc0:src>e[00m Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:00:02.532296991 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m v4l2 gstv4l2object.c:4430:gst_v4l2_object_probe_caps:<nvv4l2decoder0:src>e[00m Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:02.532397151 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7f240cd390e[00m Failed to determine interlace mode
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
0:00:02.637314717 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m v4l2 gstv4l2object.c:4430:gst_v4l2_object_probe_caps:<nvv4l2decoder0:src>e[00m Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:02.637539325 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7f240cd390e[00m Failed to determine interlace mode
0:00:02.640764918 e[336m14783e[00m 0x7f340044f0 e[32;01mFIXME e[00m e[00m basesink gstbasesink.c:3145:gst_base_sink_default_event:<appsink0>e[00m stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:02.641952851 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<videoconvert0>e[00m transform could not transform video/x-raw(memory:NVMM), format=(string)NV12, width=(int)928, height=(int)576, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)jpeg, colorimetry=(string)bt601, framerate=(fraction)0/1 in anything we support
0:00:02.642560882 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<videoconvert0>e[00m transform could not transform video/x-raw(memory:NVMM), format=(string)NV12, width=(int)928, height=(int)576, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)jpeg, colorimetry=(string)bt601, framerate=(fraction)0/1 in anything we support
0:00:02.642646546 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00;01;31;41m GST_PADS gstpad.c:4226:gst_pad_peer_query:<uridecodebin0:src_0>e[00m could not send sticky events
0:00:02.643311728 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m v4l2videodec gstv4l2videodec.c:1632:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder0>e[00m Duration invalid, not setting latency
0:00:02.645428652 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m v4l2bufferpool gstv4l2bufferpool.c:1057:gst_v4l2_buffer_pool_start:<nvv4l2decoder0:pool:src>e[00m Uncertain or not enough buffers, enabling copy threshold
0:00:02.649424547 e[336m14783e[00m 0x7f54008ca0 e[33;01mWARN e[00m e[00m v4l2bufferpool gstv4l2bufferpool.c:1503:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:src>e[00m Driver should never set v4l2_buffer.field to ANY
0:00:02.650021378 e[336m14783e[00m 0x7f54008ca0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<videoconvert0>e[00m transform could not transform video/x-raw(memory:NVMM), format=(string)NV12, width=(int)928, height=(int)576, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)jpeg, colorimetry=(string)bt601, framerate=(fraction)0/1 in anything we support
0:00:02.650449377 e[336m14783e[00m 0x7f54008ca0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<videoconvert0>e[00m transform could not transform video/x-raw(memory:NVMM), format=(string)NV12, width=(int)928, height=(int)576, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)jpeg, colorimetry=(string)bt601, framerate=(fraction)0/1 in anything we support
0:00:02.650821792 e[336m14783e[00m 0x7f54008ca0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<videoconvert0>e[00m transform could not transform video/x-raw(memory:NVMM), format=(string)NV12, width=(int)928, height=(int)576, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)jpeg, colorimetry=(string)bt601, framerate=(fraction)0/1 in anything we support
0:00:02.651961438 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.652076093 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.652130109 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.654376569 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.654430648 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.654463544 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.656302132 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.656348212 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.656381780 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.657868721 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.657906641 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.657927089 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.659101614 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.659133774 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.659176686 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.660366380 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.660396844 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.660418508 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.661536809 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.661566089 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.661582057 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.662453959 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.662475783 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.662491111 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.663394021 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.663416997 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.663433189 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.664333251 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.664372803 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.664390787 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.665322401 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.665348609 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.665364545 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.666306687 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.666331199 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.666347775 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.667262525 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.667284893 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.667300765 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.668202459 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.668225595 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.668254523 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.669192825 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.669220505 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.669236153 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.670198710 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.670221078 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.670236758 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.671153300 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.671175060 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.671190580 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.672090482 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.672112978 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.672128178 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.673052240 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.673090736 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.673108432 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.674017966 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.674040366 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.674055726 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.675014188 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.675041100 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.675056972 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.676000970 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.676023882 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.676039402 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.676976680 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.677015080 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.677031656 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.679762018 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.679805346 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.679821410 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.680821376 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.680848160 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.680864192 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.681869245 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.681896349 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.681912701 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.682864571 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.682888219 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.682904123 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.683835769 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.683875289 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.683891961 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.684825239 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter0>e[00m transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)928, height=(int)576, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:02.684847447 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
0:00:02.684862871 e[336m14783e[00m 0x7f340044f0 e[33;01mWARN e[00m e[00m basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter0>e[00m warning: not negotiated
