Segmentation fault(core dumped) Deepstream
Below answers are from jtop:
Jetson AGX Orin
• DeepStream Version
Latest from sdk manager 7
Latest from SDK manager 6.0
• TensorRT Version
8.6.2.3
Comes with SDK manager for JP 6
My python script running deepstream inference dies all of a sudden and produces
Segmentation fault(core dumped).
Time seems to be different (dont really know how long, we talk about hours). I do not get any more error message than this.
Start a deepstream with three 1MP camera gray and run yolov8 inference for several hours. Always crash with segmentation error.
I can provide the code for reference on request.
Can the failure be reproduced with DeepStream sample code? How to reproduce?
I have not tried the sample code because it will not pick up my camera without modification. It is based on the deepstream-test3.py.
This is a difficult problem because I don’t know how to replicate it in a simulated environment. Perhaps I can show you the code and you see if my pipline for the deepstream is correct. I don’t know which part of the program that sends the message but I suspect its deepstream.
Could it be the pgie_src_pad_buffer_probe that saves my inference result (image and metadata as xml) would case it to crash? I would suspect it would give more insight if it would crash in python? So the problem would be in the inference?
There is no useful clue in your description. If you suspect anything, you can try any method to debug that part.
How can I debug the deepstream pipeline?
For DeepStream log, you can enable GStreamer log with “export GST_DEBUG=3”. Basic tutorial 11: Debugging tools (gstreamer.freedesktop.org)
Testing on another device trying to replicate the problem with info mode on:
I interpret this as frame-drops. Can it have anything to do with it?
I will let the system run for several hours to see if I can replicate it.
0:01:38.035070293  9022 0xffff4d341180 WARN                 v4l2src gstv4l2src.c:1123:gst_v4l2src_create:<usb-cam-source-0> lost frames detected: count = 1 - ts: 0:01:30.184302391
0:01:38.040568532  9022 0xffff4d3411e0 WARN                 v4l2src gstv4l2src.c:1123:gst_v4l2src_create:<usb-cam-source-2> lost frames detected: count = 6 - ts: 0:01:30.276062351
0:01:38.066184188  9022 0xffff4d341180 WARN                 v4l2src gstv4l2src.c:1123:gst_v4l2src_create:<usb-cam-source-0> lost frames detected: count = 5 - ts: 0:01:30.284297647
0:01:38.092041022  9022 0xffff4d341240 WARN                 v4l2src gstv4l2src.c:1123:gst_v4l2src_create:<usb-cam-source-4> lost frames detected: count = 5 - ts: 0:01:30.287846359
0:01:38.118001247  9022 0xffff4d3411e0 WARN                 v4l2src gstv4l2src.c:1123:gst_v4l2src_create:<usb-cam-source-2> lost frames detected: count = 1 - ts: 0:01:30.326058295
0:01:38.160249441  9022 0xffff4d341180 WARN                 v4l2src gstv4l2src.c:1123:gst_v4l2src_create:<usb-cam-source-0> lost frames detected: count = 1 - ts: 0:01:30.350960327
0:01:38.164897908  9022 0xffff4d3411e0 WARN                 v4l2src gstv4l2src.c:1123:gst_v4l2src_create:<usb-cam-source-2> lost frames detected: count = 3 - ts: 0:01:30.409376287
0:01:38.164915252  9022 0xffff4d341240 WARN                 v4l2src gstv4l2src.c:1123:gst_v4l2src_create:<usb-cam-source-4> lost frames detected: count = 4 - ts: 0:01:30.404504063
0:01:38.196275957  9022 0xffff4d341180 WARN                 v4l2src gstv4l2src.c:1123:gst_v4l2src_create:<usb-cam-source-0> lost frames detected: count = 3 - ts: 0:01:30.417623423
0:01:38.266526888  9022 0xffff4d3411e0 WARN                 v4l2src gstv4l2src.c:1123:gst_v4l2src_create:<usb-cam-source-2> lost frames detected: count = 1 - ts: 0:01:30.459375415
0:01:38.300683176  9022 0xffff4d341240 WARN                 v4l2src gstv4l2src.c:1123:gst_v4l2src_create:<usb-cam-source-4> lost frames detected: count = 5 - ts: 0:01:30.554500551
0:01:38.300683112  9022 0xffff4d341180 WARN                 v4l2src gstv4l2src.c:1123:gst_v4l2src_create:<usb-cam-source-0> lost frames detected: count = 1 - ts: 0:01:30.484282743
0:01:38.304039738  9022 0xffff4d3411e0 WARN                 v4l2src gstv4l2src.c:1123:gst_v4l2src_create:<usb-cam-source-2> lost frames detected: count = 4 - ts: 0:01:30.559377191
0:01:38.351780732  9022 0xffff4d341240 WARN                 v4l2src gstv4l2src.c:1123:gst_v4l2src_create:<usb-cam-source-4> lost frames detected: count = 1 - ts: 0:01:30.587830487
0:01:38.357877261  9022 0xffff4d341180 WARN                 v4l2src gstv4l2src.c:1123:gst_v4l2src_create:<usb-cam-source-0> lost frames detected: count = 4 - ts: 0:01:30.567614583
That means there is something abnormal with the camera. gst-plugins-good/sys/v4l2/gstv4l2src.c at master · GStreamer/gst-plugins-good · GitHub
If the 3 cameras send data at 60fps each, total 180fps. My real framerate, after inference and saving the output as image and xml via pgie_src_pad_buffer_probe, is about 28fps per camera. Would this mean that deepstream has framedrops due to the pgie pad buffer?
I try to understand if my buffer probe is causing a problem when saving so fast from the cameras onto my nfs file-share.
I have not turned on the debug on my running production system because it will affect FPS. Also it will overflood the screen with information. I will see if I can get something out of it.
Yes.
The probe function is the “blocking” callback, you need to guarantee the processing inside it spends less than 1/60 second if your streams are 60fps.
ahhh. I thought they were running in parallell so that deepstream continuous in the background.
Good to know.
Would this also be the problem when the pgie buffer writes the meta data to disk via fileshare could cause the deepstream to fail and result in Segmentation fault and dies?
DeepStream SDK does not do this. It depends on your own implementation.
I understand, But I implement a file save in the pgie buffer probe.
I would like to know if that would trigger the segmentation issue in the deepstream pipline. So if I crash (for some reason) in the buffer probe method, it would in turn trigger the deepstream sdk to get segmentation error. I could throw a try/catch block in the buffer probe and see if that message comes from my custom implementation of the save function. if not it must be something else…
As mentioned before, it depends on how you implement in the probe function.
I implemented the probe as your example: deepstream-test3.py
With modification to get the box location and write to XML.
I see that I read my property file every time I probe. That is wrong of course.
import os
import gi
import sys
import cv2
import math
import time
import pyds
import hashlib
import logging
import configparser
import numpy as np
import xml.etree.cElementTree as ET
from threading import Thread
from common.FPS import PERF_DATA
gi.require_version('Gst', '1.0')
from gi.repository import GLib, Gst
from datetime import datetime as dt
from common.bus_call import bus_call
current_time = dt.now().strftime("%m:%d:%Y_%H:%M:%S").encode('utf-8')
UNIQUE_IDENTIFIER = hashlib.md5(current_time).hexdigest()
pgie_classes_str = []
frame_number = 0
perf_data = None
LOT_ID = "NoLotID"
# Generate XML file and save image upon detection
def createXML(img_object, frame_copy, line, output_folder, _lot_id):
    fileString = img_object["filename"]
    root = ET.Element("annotation")
    ET.SubElement(root, "machine").text = line
    ET.SubElement(root, "timestamp").text = img_object["timestamp"]
    ET.SubElement(root, "lotid").text = _lot_id
    ET.SubElement(root, "folder").text = "Live"
    ET.SubElement(root, "filename").text = fileString
    ET.SubElement(root, "path").text = output_folder
    source = ET.SubElement(root, "source")
    ET.SubElement(source, "database").text = str(img_object["database"])
    size = ET.SubElement(root, "size")
    ET.SubElement(size, "width").text = str(img_object["width"])
    ET.SubElement(size, "height").text = str(img_object["height"])
    ET.SubElement(size, "depth").text = "1"
    ET.SubElement(root, "segmented").text = "0"
    dIndex = 0
    nrBoxes = 0
    for box in img_object['annotations']:
        if (box["conf"] >= 0.0):
            objelement = ET.SubElement(root, "object")
            ET.SubElement(objelement, "name").text = box["class"]
            ET.SubElement(objelement, "pose").text = "Unspecified"
            ET.SubElement(objelement, "truncated").text = "0"
            ET.SubElement(objelement, "difficult").text = "0"
            ET.SubElement(objelement, "conf").text = str(box["conf"])
            bndBox = ET.SubElement(objelement, "bndbox")
            ET.SubElement(bndBox, "xmin").text = str(box["box_coordinates"]["Xmin"])
            ET.SubElement(bndBox, "ymin").text = str(box["box_coordinates"]["Ymin"])
            ET.SubElement(bndBox, "xmax").text = str(box["box_coordinates"]["Xmax"])
            ET.SubElement(bndBox, "ymax").text = str(box["box_coordinates"]["Ymax"])
            nrBoxes+=1
        dIndex+=1
    if(nrBoxes > 0):
        tree = ET.ElementTree(root)
        full_filename = output_folder +"/" + fileString + ".xml"
        tree.write(full_filename)
        img_path = output_folder +"/" + fileString + ".jpg"
        cv2.imwrite(img_path, frame_copy)
# Probe the pipline and get image and inference information
def pgie_src_pad_buffer_probe(pad,info,u_data):
    global frame_number, perf_data, LOT_ID
    aiProperties = configparser.ConfigParser()
    aiProperties.read('default.properties')
    OUTPUT_FOLDER = aiProperties.get('AI','output_folder')
    LINE = aiProperties.get('MQTT','machineID')
    num_rects=0
    got_fps = False
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        logging.debug("Unable to get GstBuffer ")
        return
    # Retrieve batch metadata from the gst_buffer
    # Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
    # C address of gst_buffer as input, which is obtained with hash(gst_buffer)
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
            # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
            # The casting is done by pyds.NvDsFrameMeta.cast()
            # The casting also keeps ownership of the underlying memory
            # in the C code, so the Python garbage collector will leave
            # it alone.
        except StopIteration:
            break
        frame_number=frame_meta.frame_num
        l_obj=frame_meta.obj_meta_list
        num_rects = frame_meta.num_obj_meta
        filename="ID"+str(frame_meta.source_id) + "_" + str(UNIQUE_IDENTIFIER) + "_" + str(1000000000+frame_number)
        timestamp = dt.now().strftime("%Y-%m-%d %H:%M:%S")
        new_item ={
            "filename":filename,
            "timestamp":timestamp,
            "width":frame_meta.source_frame_width,
            "height":frame_meta.source_frame_height,
            "database" : frame_meta.source_id,
            "annotations":[]
        while l_obj is not None:
            try:
                # Casting l_obj.data to pyds.NvDsObjectMeta
                obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
                break
#            obj_counter[obj_meta.class_id] += 1
            new_annotation={
                        "class":pgie_classes_str[obj_meta.class_id],
                        "conf":obj_meta.confidence,
                        "box_coordinates":{
                            "Xmin":int(obj_meta.rect_params.left),
                            "Ymin":int(obj_meta.rect_params.top),
                            "Xmax":int(obj_meta.rect_params.left+obj_meta.rect_params.width),
                            "Ymax":int(obj_meta.rect_params.top+obj_meta.rect_params.height),
            new_item["annotations"].append(new_annotation)
            try:
                l_obj=l_obj.next
                break
        n_frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
        frame_copy = np.array(n_frame, copy=True, order='C')
        frame_copy = cv2.cvtColor(frame_copy, cv2.COLOR_BGR2RGB)
        pyds.unmap_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
        if new_item["annotations"]:
            # print(frame_meta.source_id) #Add this to the XLXML for camera information
            createXML(new_item, frame_copy,LINE, OUTPUT_FOLDER,LOT_ID)
            #logging.debug("Frame Number=", frame_number, "Number of Objects=",num_rects)
        # Update frame rate through this probe
        stream_index = "stream{0}".format(frame_meta.pad_index)
        perf_data.update_fps(stream_index)
        try:
            l_frame=l_frame.next
            logging.debug("Error in l_frame")
            break
    return Gst.PadProbeReturn.OK
#Read the object classes from file
def readClassesFile(filename):
    file_path = filename
    labels = []
    with open(file_path, 'r') as file:
        labels = file.readlines()
    # Optionally, you can strip newline characters from the end of each line
    labels = [label.strip() for label in labels]
    return labels
class AIDetectionManager:
    def __init__(self):
        logging.getLogger(__name__)
        logging.debug("AI Detection Manager initiated")
        self.aiProperties = configparser.ConfigParser()
        self.aiProperties.read('default.properties')
        self.number_sources = int(self.aiProperties.get('AI','number_sources'))
        self.runAIDM = None
        self.CLASS_LABEL_FILE = self.aiProperties.get('AI','class_label_file')
        self.INPUT_FPS = int(self.aiProperties.get('AI','input_fps'))
        self.STREAMMUX_WIDTH = int(self.aiProperties.get('AI','streammux_width'))
        self.STREAMMUX_HEIGHT = int(self.aiProperties.get('AI','streammux_height'))
        self.CONFIG_FILE_PATH = self.aiProperties.get('AI','config_file_path')
        self.OSD_PROCESS_MODE = int(self.aiProperties.get('AI','osd_process_mode'))
        self.OSD_DISPLAY_TEXT = int(self.aiProperties.get('AI','osd_display_text'))
        self.TILED_OUTPUT_WIDTH = int(self.aiProperties.get('AI','tiled_output_width'))
        self.TILED_OUTPUT_HEIGHT = int(self.aiProperties.get('AI','tiled_output_height'))
        self.NO_DISPLAY = eval(self.aiProperties.get('AI','no_display'))
        self.loop = None
        self.pipeline = None
# export GST_DEBUG=4, 0
    def run(self):
        global perf_data, pgie_classes_str, LOT_ID
        number_sources=self.number_sources
        pgie_classes_str = readClassesFile(self.CLASS_LABEL_FILE)
        perf_data = PERF_DATA(number_sources)
        logging.debug("Starting deepstream")
        # Standard GStreamer initialization
        Gst.init(None)
        logging.debug("Creating Pipeline \n ")
        pipeline = Gst.Pipeline()
        logging.debug("Creating sources pipeline")
        sources=[]
        caps_v4l2srcs=[]
        vidconvsrcs=[]
        nvvidconvsrcs=[]
        caps_vidconvsrcs=[]
        for s in range(number_sources):
            source = Gst.ElementFactory.make("v4l2src", f"usb-cam-source-"+str(s*2))
            source.set_property('device', '/dev/video'+str(s*2))
            caps_v4l2src = Gst.ElementFactory.make("capsfilter", "v4l2src_caps"+str(s*2))
            caps_v4l2src.set_property('caps', Gst.Caps.from_string(f"video/x-raw, framerate={self.INPUT_FPS}/1"))
            vidconvsrc = Gst.ElementFactory.make("videoconvert", "convertor_src1_"+str(s*2))
            nvvidconvsrc = Gst.ElementFactory.make("nvvideoconvert", "convertor_src2_"+str(s*2))
            caps_vidconvsrc = Gst.ElementFactory.make("capsfilter", "nvmm_caps"+str(s*2))
            caps_vidconvsrc.set_property('caps', Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA"))
            pipeline.add(source)
            pipeline.add(caps_v4l2src)
            pipeline.add(vidconvsrc)
            pipeline.add(nvvidconvsrc)
            pipeline.add(caps_vidconvsrc)
            sources.append(source)
            caps_v4l2srcs.append(caps_v4l2src)
            vidconvsrcs.append(vidconvsrc)
            nvvidconvsrcs.append(nvvidconvsrc)
            caps_vidconvsrcs.append(caps_vidconvsrc)
        streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
        queue1=Gst.ElementFactory.make("queue","queue1")
        queue2=Gst.ElementFactory.make("queue","queue2")
        queue3=Gst.ElementFactory.make("queue","queue3")
        queue4=Gst.ElementFactory.make("queue","queue4")
        queue5=Gst.ElementFactory.make("queue","queue5")
        pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
        tiler=Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
        nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
        nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
        transform = Gst.ElementFactory.make("nvegltransform", "nvegl-transform")
        sink = None
        if self.NO_DISPLAY:
            logging.debug("Creating Fakesink \n")
            sink = Gst.ElementFactory.make("fakesink", "nvvideo-renderer")
            sink.set_property('enable-last-sample', 0)
            sink.set_property('sync', 0)
        else:
            sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
            sink.set_property('sync', False)
        logging.debug("Setting common properties")
        streammux.set_property('width', self.STREAMMUX_WIDTH)
        streammux.set_property('height', self.STREAMMUX_HEIGHT)
        streammux.set_property('batch-size', number_sources)
        streammux.set_property('batched-push-timeout', 4000000)
        streammux.set_property('live-source',1)
        pgie.set_property('config-file-path', "config_infer_primary_yoloV8.txt")
        pgie.set_property("batch-size",number_sources)
        nvosd.set_property('process-mode',self.OSD_PROCESS_MODE)
        nvosd.set_property('display-text',self.OSD_DISPLAY_TEXT)
        tiler_rows=int(math.sqrt(number_sources))
        tiler_columns=int(math.ceil((1.0*number_sources)/tiler_rows))
        tiler.set_property("rows",tiler_rows)
        tiler.set_property("columns",tiler_columns)
        tiler.set_property("width", self.TILED_OUTPUT_WIDTH)
        tiler.set_property("height", self.TILED_OUTPUT_HEIGHT)
        sink.set_property("qos",0)
        logging.debug(f"Playing {number_sources} cameras")
        pipeline.add(streammux)
        pipeline.add(queue1)
        pipeline.add(queue2)
        pipeline.add(queue3)
        pipeline.add(queue4)
        pipeline.add(queue5)
        pipeline.add(pgie)
        pipeline.add(tiler)
        pipeline.add(nvvidconv)
        pipeline.add(nvosd)
        pipeline.add(sink)
        if not self.NO_DISPLAY:
            pipeline.add(transform)
        srcpads = []
        sinkpads = []
            srcpad = caps_vidconvsrcs[s].get_static_pad("src")
            sinkpad = streammux.request_pad_simple("sink_"+str(s))
            logging.debug("sink_number:"+str(s))
            srcpads.append(srcpad)
            sinkpads.append(sinkpad)
        for i in range(number_sources):
            sources[i].link(caps_v4l2srcs[i])
            caps_v4l2srcs[i].link(vidconvsrcs[i])
            vidconvsrcs[i].link(nvvidconvsrcs[i])
            nvvidconvsrcs[i].link(caps_vidconvsrcs[i])
            srcpads[i].link(sinkpads[i])
        streammux.link(queue1)
        queue1.link(pgie)
        pgie.link(queue2) #pgie.link(tiler)
        queue2.link(tiler)
        tiler.link(queue3) #tiler.link(nvvidconv)
        queue3.link(nvvidconv)
        nvvidconv.link(queue4) #nvvidconv.link(nvosd)
        queue4.link(nvosd)
        nvosd.link(queue5) #nvosd.link(sink)
        if self.NO_DISPLAY:
            queue5.link(sink)
        else:
            queue5.link(transform)
            transform.link(sink)
        # create an event loop and feed gstreamer bus mesages to it
        self.loop = GLib.MainLoop()
        bus = pipeline.get_bus()
        bus.add_signal_watch()
        bus.connect ("message", bus_call, self.loop)
        # Lets add probe to get informed of the meta data generated, we add probe to
        # the sink pad of the osd element, since by that time, the buffer would have
        # had got all the metadata.
        pgie_src_pad = pgie.get_static_pad("src")
        if not pgie_src_pad:
            sys.stderr.write(" Unable to get sink pad of nvosd \n")
        pgie_src_pad.add_probe(Gst.PadProbeType.BUFFER, pgie_src_pad_buffer_probe, 0)
        GLib.timeout_add(5000, perf_data.perf_print_callback)
        # start play back and listen to events
        logging.debug("Starting pipeline \n")
        pipeline.set_state(Gst.State.PLAYING)
        try:
            self.loop.run()
        except:
            pass
        # cleanup
        pipeline.set_state(Gst.State.NULL)
    def start(self):
        logging.debug("AI Detection Manager started")
        Thread(target=self.run, args=(), name="AI Detection Manager").start()
        return self
    def stop(self):
        if self.loop is not None:
            self.loop.quit()
            logging.debug("AI Detection Manager stopping")
    def isRunning(self):
        if self.loop is not None:  # Check if self.loop is not None
            if self.loop.is_running():
                logging.debug("AI Detection is Running")
            return self.loop.is_running()
        else:
            logging.warning("AI detection manager is not initialized")
            return False
    def setLotID(self, lotID):
        global LOT_ID
        logging.debug("Settings lot ID")
        LOT_ID = lotID
What can we do for you? It is not reasonable for us to debug your code.
I understand. I will try to get you the debug error message. But I don’t understand where the segmentation fault comes from when all I see in the printout is:
user@AIDev:~$
I will keep you posted.
