Test2 facenet as secondary classifier
When running this test, it just halts after some frames. I don’t get the segmentation fault anymore.
Configuration file:
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
onnx-file=facenet.onnx
model-engine-file=facenet.onnx_b1_gpu0_fp16.engine
batch-size=1
force-implicit-batch-dim=1
input-object-min-width=10
input-object-min-height=10
gie-unique-id=2
network-mode=2
network-type=1
output-tensor-meta=1
classifier-async-mode=0
process-mode=2
operate-on-gie-id=1
operate-on-class-ids=0
Run Command:
GST_DEBUG=3 python3 deepstream_test_1.py …/…/…/streams/sample_720p.h264
Debug output, level4:
Debug level3 does not give any hints. the program just stops and does not respond to either closing the window of the video or ctrl+c in the terminal:
root@bounty-desktop:/opt/nvidia/deepstream/deepstream-5.1/samples/deepstream_python_apps/apps/deepstream-test1# GST_DEBUG=4 python3 deepstream_test_1.py ../../../streams/sample_720p.h264
0:00:00.000390226 114 0xe562b20 INFO GST_INIT gst.c:586:init_pre: Initializing GStreamer Core Library version 1.14.5
0:00:00.000588220 114 0xe562b20 INFO GST_INIT gst.c:587:init_pre: Using library installed in /usr/lib/aarch64-linux-gnu
0:00:00.000679168 114 0xe562b20 INFO GST_INIT gst.c:607:init_pre: Linux bounty-desktop 4.9.201-tegra #1 SMP PREEMPT Fri Feb 19 08:42:04 PST 2021 aarch64
0:00:00.001428323 114 0xe562b20 INFO GST_INIT gstmessage.c:127:_priv_gst_message_initialize: init messages
0:00:00.002346573 114 0xe562b20 INFO GST_INIT gstcontext.c:84:_priv_gst_context_initialize: init contexts
0:00:00.003206261 114 0xe562b20 INFO GST_PLUGIN_LOADING gstplugin.c:317:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.003624328 114 0xe562b20 INFO GST_PLUGIN_LOADING gstplugin.c:225:gst_plugin_register_static: registered static plugin “staticelements”
0:00:00.003689995 114 0xe562b20 INFO GST_PLUGIN_LOADING gstplugin.c:227:gst_plugin_register_static: added static plugin “staticelements”, result: 1
0:00:00.003769711 114 0xe562b20 INFO GST_REGISTRY gstregistry.c:1727:ensure_current_registry: reading registry cache: /root/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.088734674 114 0xe562b20 INFO GST_REGISTRY gstregistrybinary.c:621:priv_gst_registry_binary_read_cache: loaded /root/.cache/gstreamer-1.0/registry.aarch64.bin in 0.084890 seconds
0:00:00.089047168 114 0xe562b20 INFO GST_REGISTRY gstregistry.c:1583:scan_and_update_registry: Validating plugins from registry cache: /root/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.094749225 114 0xe562b20 INFO GST_REGISTRY gstregistry.c:1685:scan_and_update_registry: Registry cache has not changed
0:00:00.094848237 114 0xe562b20 INFO GST_REGISTRY gstregistry.c:1762:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.094902352 114 0xe562b20 INFO GST_INIT gst.c:807:init_post: GLib runtime version: 2.56.4
0:00:00.094982259 114 0xe562b20 INFO GST_INIT gst.c:809:init_post: GLib headers version: 2.56.4
0:00:00.095001524 114 0xe562b20 INFO GST_INIT gst.c:810:init_post: initialized GStreamer successfully
Creating Pipeline
Creating Source
0:00:00.099152597 114 0xe562b20 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstcoreelements.so” loaded
0:00:00.099289851 114 0xe562b20 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “filesrc” named “file-source”
0:00:00.100102049 114 0xe562b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSrc@0xe9763f0 adding pad ‘src’
Creating H264Parser
0:00:00.107240812 114 0xe562b20 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideoparsersbad.so” loaded
0:00:00.107329904 114 0xe562b20 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “h264parse” named “h264-parser”
0:00:00.108014575 114 0xe562b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseParse@0xe986120 adding pad ‘sink’
0:00:00.108153046 114 0xe562b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseParse@0xe986120 adding pad ‘src’
0:00:00.108331486 114 0xe562b20 INFO baseparse gstbaseparse.c:3961:gst_base_parse_set_pts_interpolation:GstH264Parse@0xe986120 PTS interpolation: no
Creating Decoder
0:00:00.156591355 114 0xe562b20 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so” loaded
0:00:00.156694432 114 0xe562b20 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvv4l2decoder” named “nvv4l2-decoder”
0:00:00.157655021 114 0xe562b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstVideoDecoder@0xe9dc2b0 adding pad ‘sink’
0:00:00.157756593 114 0xe562b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstVideoDecoder@0xe9dc2b0 adding pad ‘src’
0:00:00.176947915 114 0xe562b20 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so” loaded
0:00:00.177114419 114 0xe562b20 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvstreammux” named “Stream-muxer”
0:00:00.178020157 114 0xe562b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstNvStreamMux@0xea4c250 adding pad ‘src’
0:00:00.280910686 114 0xe562b20 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so” loaded
0:00:00.281020611 114 0xe562b20 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvinfer” named “primary-inference”
0:00:00.281864170 114 0xe562b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0xec264d0 adding pad ‘sink’
0:00:00.281956879 114 0xe562b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0xec264d0 adding pad ‘src’
0:00:00.283613755 114 0xe562b20 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvinfer” named “secondary-nference faceclassifier”
0:00:00.283740769 114 0xe562b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0xec26da0 adding pad ‘sink’
0:00:00.283818085 114 0xe562b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0xec26da0 adding pad ‘src’
0:00:00.288381656 114 0xe562b20 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so” loaded
0:00:00.288452956 114 0xe562b20 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvvideoconvert” named “convertor”
0:00:00.289200990 114 0xe562b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0xec50270 adding pad ‘sink’
0:00:00.289329636 114 0xe562b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0xec50270 adding pad ‘src’
0:00:00.302168632 114 0xe562b20 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so” loaded
0:00:00.302270620 114 0xe562b20 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvdsosd” named “onscreendisplay”
0:00:00.303162406 114 0xe562b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0xec61fd0 adding pad ‘sink’
0:00:00.303256266 114 0xe562b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0xec61fd0 adding pad ‘src’
0:00:00.323991115 114 0xe562b20 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvegltransform.so” loaded
0:00:00.324172948 114 0xe562b20 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvegltransform” named “nvegl-transform”
0:00:00.324877908 114 0xe562b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0xed18150 adding pad ‘sink’
0:00:00.325022203 114 0xe562b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0xed18150 adding pad ‘src’
Creating EGLSink
0:00:00.330312976 114 0xe562b20 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnveglglessink.so” loaded
0:00:00.330429078 114 0xe562b20 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nveglglessink” named “nvvideo-renderer”
0:00:00.331588491 114 0xe562b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0xed1f760 adding pad ‘sink’
Playing file ../../../streams/sample_720p.h264
0:00:00.334967720 114 0xe562b20 INFO filesrc gstfilesrc.c:261:gst_file_src_set_location: filename : ../../../streams/sample_720p.h264
0:00:00.335025291 114 0xe562b20 INFO filesrc gstfilesrc.c:262:gst_file_src_set_location: uri : file:///opt/nvidia/deepstream/deepstream-5.1/samples/streams/sample_720p.h264
Adding elements to Pipeline
Linking elements in the Pipeline
0:00:00.338378694 114 0xe562b20 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element file-source:(any) to element h264-parser:(any)
0:00:00.338695221 114 0xe562b20 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link file-source:src and h264-parser:sink
0:00:00.338869181 114 0xe562b20 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:h264-parser:src pad has no peer
0:00:00.338961185 114 0xe562b20 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: file-source and h264-parser in same bin, no need for ghost pads
0:00:00.339042629 114 0xe562b20 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link file-source:src and h264-parser:sink
0:00:00.339144458 114 0xe562b20 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:h264-parser:src pad has no peer
0:00:00.339265615 114 0xe562b20 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked file-source:src and h264-parser:sink, successful
0:00:00.339294737 114 0xe562b20 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.339323602 114 0xe562b20 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:file-source:src Received event on flushing pad. Discarding
0:00:00.339501210 114 0xe562b20 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element h264-parser:(any) to element nvv4l2-decoder:(any)
0:00:00.339608383 114 0xe562b20 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link h264-parser:src and nvv4l2-decoder:sink
0:00:00.339811560 114 0xe562b20 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:nvv4l2-decoder:src pad has no peer
0:00:00.340488040 114 0xe562b20 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: h264-parser and nvv4l2-decoder in same bin, no need for ghost pads
0:00:00.340588140 114 0xe562b20 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link h264-parser:src and nvv4l2-decoder:sink
0:00:00.340644879 114 0xe562b20 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:nvv4l2-decoder:src pad has no peer
0:00:00.340916188 114 0xe562b20 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked h264-parser:src and nvv4l2-decoder:sink, successful
0:00:00.340947453 114 0xe562b20 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.341003136 114 0xe562b20 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:h264-parser:src Received event on flushing pad. Discarding
0:00:00.341404178 114 0xe562b20 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘sink_0’ in element “Stream-muxer”
0:00:00.341687039 114 0xe562b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘sink_0’
0:00:00.342675757 114 0xe562b20 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad nvv4l2-decoder:src
0:00:00.343001660 114 0xe562b20 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvv4l2-decoder:src and Stream-muxer:sink_0
0:00:00.343214726 114 0xe562b20 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:Stream-muxer:src pad has no peer
0:00:00.343498195 114 0xe562b20 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvv4l2-decoder:src and Stream-muxer:sink_0, successful
0:00:00.343533141 114 0xe562b20 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.343560438 114 0xe562b20 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:nvv4l2-decoder:src Received event on flushing pad. Discarding
0:00:00.343695261 114 0xe562b20 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element Stream-muxer:(any) to element primary-inference:(any)
0:00:00.343742911 114 0xe562b20 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link Stream-muxer:src and primary-inference:sink
0:00:00.343795969 114 0xe562b20 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:primary-inference:src pad has no peer
0:00:00.343967177 114 0xe562b20 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: Stream-muxer and primary-inference in same bin, no need for ghost pads
0:00:00.344036140 114 0xe562b20 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link Stream-muxer:src and primary-inference:sink
0:00:00.344078414 114 0xe562b20 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:primary-inference:src pad has no peer
0:00:00.344185235 114 0xe562b20 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked Stream-muxer:src and primary-inference:sink, successful
0:00:00.344210068 114 0xe562b20 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.344234485 114 0xe562b20 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:Stream-muxer:src Received event on flushing pad. Discarding
0:00:00.344328442 114 0xe562b20 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element primary-inference:(any) to element secondary-nference faceclassifier:(any)
0:00:00.344369852 114 0xe562b20 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link primary-inference:src and secondary-nference faceclassifier:sink
0:00:00.344551844 114 0xe562b20 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query: pad has no peer
0:00:00.344641896 114 0xe562b20 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: primary-inference and secondary-nference faceclassifier in same bin, no need for ghost pads
0:00:00.344692459 114 0xe562b20 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link primary-inference:src and secondary-nference faceclassifier:sink
0:00:00.344811920 114 0xe562b20 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query: pad has no peer
0:00:00.344902036 114 0xe562b20 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked primary-inference:src and secondary-nference faceclassifier:sink, successful
0:00:00.344924405 114 0xe562b20 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.344947639 114 0xe562b20 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:primary-inference:src Received event on flushing pad. Discarding
0:00:00.345023706 114 0xe562b20 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element secondary-nference faceclassifier:(any) to element convertor:(any)
0:00:00.345061788 114 0xe562b20 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link secondary-nference faceclassifier:src and convertor:sink
0:00:00.345250341 114 0xe562b20 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:convertor:src pad has no peer
0:00:00.345572276 114 0xe562b20 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: secondary-nference faceclassifier and convertor in same bin, no need for ghost pads
0:00:00.345662936 114 0xe562b20 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link secondary-nference faceclassifier:src and convertor:sink
0:00:00.345840864 114 0xe562b20 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:convertor:src pad has no peer
0:00:00.347136956 114 0xe562b20 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked secondary-nference faceclassifier:src and convertor:sink, successful
0:00:00.347204799 114 0xe562b20 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.347237761 114 0xe562b20 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked: Received event on flushing pad. Discarding
0:00:00.347378663 114 0xe562b20 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element convertor:(any) to element onscreendisplay:(any)
0:00:00.347432362 114 0xe562b20 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link convertor:src and onscreendisplay:sink
0:00:00.348448217 114 0xe562b20 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:onscreendisplay:src pad has no peer
0:00:00.348588351 114 0xe562b20 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: convertor and onscreendisplay in same bin, no need for ghost pads
0:00:00.348663139 114 0xe562b20 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link convertor:src and onscreendisplay:sink
0:00:00.349718772 114 0xe562b20 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:onscreendisplay:src pad has no peer
0:00:00.349849018 114 0xe562b20 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked convertor:src and onscreendisplay:sink, successful
0:00:00.349896604 114 0xe562b20 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.349993344 114 0xe562b20 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:convertor:src Received event on flushing pad. Discarding
0:00:00.350136615 114 0xe562b20 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element onscreendisplay:(any) to element nvegl-transform:(any)
0:00:00.350187689 114 0xe562b20 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link onscreendisplay:src and nvegl-transform:sink
0:00:00.350682592 114 0xe562b20 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:nvegl-transform:src pad has no peer
0:00:00.350916715 114 0xe562b20 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: onscreendisplay and nvegl-transform in same bin, no need for ghost pads
0:00:00.350974510 114 0xe562b20 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link onscreendisplay:src and nvegl-transform:sink
0:00:00.351982397 114 0xe562b20 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:nvegl-transform:src pad has no peer
0:00:00.352182374 114 0xe562b20 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked onscreendisplay:src and nvegl-transform:sink, successful
0:00:00.352269418 114 0xe562b20 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.352307852 114 0xe562b20 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:onscreendisplay:src Received event on flushing pad. Discarding
0:00:00.352474355 114 0xe562b20 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element nvegl-transform:(any) to element nvvideo-renderer:(any)
0:00:00.352522550 114 0xe562b20 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link nvegl-transform:src and nvvideo-renderer:sink
0:00:00.354389740 114 0xe562b20 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: nvegl-transform and nvvideo-renderer in same bin, no need for ghost pads
0:00:00.354455087 114 0xe562b20 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvegl-transform:src and nvvideo-renderer:sink
0:00:00.355149359 114 0xe562b20 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvegl-transform:src and nvvideo-renderer:sink, successful
0:00:00.355186929 114 0xe562b20 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.355221331 114 0xe562b20 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:nvegl-transform:src Received event on flushing pad. Discarding
0:00:00.360973949 114 0xe562b20 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad onscreendisplay:sink
Starting pipeline
0:00:00.362010702 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
Using winsys: x11
0:00:00.362545286 114 0xe562b20 INFO egladaption gstegladaptation_egl.c:186:gst_egl_adaptation_init_display: System reports supported EGL version v1.5
0:00:00.363440240 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.363487986 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.363552149 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvvideo-renderer’ changed state to 2(READY) successfully
0:00:00.363607768 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.363640985 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.363679931 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.363740158 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvegl-transform’ changed state to 2(READY) successfully
0:00:00.363802561 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.363837090 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.363870404 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.364030187 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘onscreendisplay’ changed state to 2(READY) successfully
0:00:00.364077069 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.364122863 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.364168882 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.364230708 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘convertor’ changed state to 2(READY) successfully
0:00:00.364278231 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.364313144 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.364344890 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.364389532 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘secondary-nference faceclassifier’ changed state to 2(READY) successfully
0:00:00.364532002 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.364571620 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.364597829 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.364653192 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘primary-inference’ changed state to 2(READY) successfully
0:00:00.364709867 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.468811716 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.468914601 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.469049167 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘Stream-muxer’ changed state to 2(READY) successfully
0:00:00.469122451 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
Opening in BLOCKING MODE
0:00:00.529394813 114 0xe562b20 INFO v4l2 v4l2_calls.c:619:gst_v4l2_open:nvv4l2-decoder:sink Opened device ‘’ (/dev/nvhost-nvdec) successfully
0:00:00.529502818 114 0xe562b20 INFO v4l2 v4l2_calls.c:720:gst_v4l2_dup:nvv4l2-decoder:src Cloned device ‘’ (/dev/nvhost-nvdec) successfully
0:00:00.529621351 114 0xe562b20 INFO v4l2 gstv4l2object.c:1284:gst_v4l2_object_fill_format_list:nvv4l2-decoder:sink got 13 format(s):
0:00:00.529654633 114 0xe562b20 INFO v4l2 gstv4l2object.c:1290:gst_v4l2_object_fill_format_list:nvv4l2-decoder:sink JPEG
0:00:00.529681802 114 0xe562b20 INFO v4l2 gstv4l2object.c:1290:gst_v4l2_object_fill_format_list:nvv4l2-decoder:sink MJPG
0:00:00.529707243 114 0xe562b20 INFO v4l2 gstv4l2object.c:1290:gst_v4l2_object_fill_format_list:nvv4l2-decoder:sink DVX5
0:00:00.529731404 114 0xe562b20 INFO v4l2 gstv4l2object.c:1290:gst_v4l2_object_fill_format_list:nvv4l2-decoder:sink DVX4
0:00:00.529756109 114 0xe562b20 INFO v4l2 gstv4l2object.c:1290:gst_v4l2_object_fill_format_list:nvv4l2-decoder:sink MPG4
0:00:00.529781199 114 0xe562b20 INFO v4l2 gstv4l2object.c:1290:gst_v4l2_object_fill_format_list:nvv4l2-decoder:sink MPG2
0:00:00.529874995 114 0xe562b20 INFO v4l2 gstv4l2object.c:1290:gst_v4l2_object_fill_format_list:nvv4l2-decoder:sink MPG1
0:00:00.529906132 114 0xe562b20 INFO v4l2 gstv4l2object.c:1290:gst_v4l2_object_fill_format_list:nvv4l2-decoder:sink VP90
0:00:00.529929941 114 0xe562b20 INFO v4l2 gstv4l2object.c:1290:gst_v4l2_object_fill_format_list:nvv4l2-decoder:sink VP80
0:00:00.529954071 114 0xe562b20 INFO v4l2 gstv4l2object.c:1290:gst_v4l2_object_fill_format_list:nvv4l2-decoder:sink H265
0:00:00.530016025 114 0xe562b20 INFO v4l2 gstv4l2object.c:1290:gst_v4l2_object_fill_format_list:nvv4l2-decoder:sink H264
0:00:00.530041275 114 0xe562b20 INFO v4l2 gstv4l2object.c:1290:gst_v4l2_object_fill_format_list:nvv4l2-decoder:sink VP8F
0:00:00.530064028 114 0xe562b20 INFO v4l2 gstv4l2object.c:1290:gst_v4l2_object_fill_format_list:nvv4l2-decoder:sink S264
0:00:00.530914371 114 0xe562b20 INFO v4l2 gstv4l2object.c:4490:gst_v4l2_object_probe_caps:nvv4l2-decoder:sink probed caps: image/jpeg, width=(int)[ 48, 7680 ], height=(int)[ 48, 7680 ], parsed=(boolean)true; video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)[ 48, 4096 ], height=(int)[ 48, 4096 ], parsed=(boolean)true; video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, width=(int)[ 180, 7680 ], height=(int)[ 180, 7680 ], parsed=(boolean)true; video/mpeg, mpegversion=(int)4, systemstream=(boolean)false, parsed=(boolean)true, width=(int)[ 48, 1920 ], height=(int)[ 48, 1920 ]; video/mpeg, mpegversion=(int)2, systemstream=(boolean)false, parsed=(boolean)true, width=(int)[ 48, 4096 ], height=(int)[ 48, 4096 ]; video/mpeg, mpegversion=(int)1, systemstream=(boolean)false, parsed=(boolean)true, width=(int)[ 48, 4096 ], height=(int)[ 48, 4096 ]; video/x-divx, divxversion=(int)5, width=(int)[ 48, 1920 ], height=(int)[ 48, 1920 ], systemstream=(boolean)false; video/x-divx, divxversion=(int)4, width=(int)[ 48, 1920 ], height=(int)[ 48, 1920 ], systemstream=(boolean)false; video/x-vp8, width=(int)[ 48, 4096 ], height=(int)[ 48, 4096 ]; video/x-vp9, width=(int)[ 48, 4096 ], height=(int)[ 48, 4096 ]
0:00:00.534211644 114 0xe562b20 INFO v4l2 gstv4l2object.c:1284:gst_v4l2_object_fill_format_list:nvv4l2-decoder:src got 2 format(s):
0:00:00.534310241 114 0xe562b20 INFO v4l2 gstv4l2object.c:1290:gst_v4l2_object_fill_format_list:nvv4l2-decoder:src NM12
0:00:00.534491433 114 0xe562b20 INFO v4l2 gstv4l2object.c:1290:gst_v4l2_object_fill_format_list:nvv4l2-decoder:src YM16
0:00:00.534723444 114 0xe562b20 WARN v4l2 gstv4l2object.c:4434:gst_v4l2_object_probe_caps:nvv4l2-decoder:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:00.534842233 114 0xe562b20 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0xe9deac0 Failed to determine interlace mode
0:00:00.534925597 114 0xe562b20 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0xe9deac0 Failed to determine interlace mode
0:00:00.535128614 114 0xe562b20 INFO v4l2 gstv4l2object.c:4490:gst_v4l2_object_probe_caps:nvv4l2-decoder:src probed caps: video/x-raw, format=(string)NV12, width=(int)[ 48, 4096 ], height=(int)[ 48, 4096 ], framerate=(fraction)[ 0/1, 2147483647/1 ]; video/x-raw, format=(string)Y42B, width=(int)[ 48, 4096 ], height=(int)[ 48, 4096 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:00.535171752 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.535203402 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.535300590 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvv4l2-decoder’ changed state to 2(READY) successfully
0:00:00.535428372 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.535464630 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.535489527 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.535525753 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘h264-parser’ changed state to 2(READY) successfully
0:00:00.535560442 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.535586972 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.535612285 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.535644350 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘file-source’ changed state to 2(READY) successfully
0:00:00.535719682 114 0xe562b20 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PLAYING, next PAUSED
0:00:00.535759012 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PLAYING pending)
0:00:00.535793285 114 0xe562b20 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PLAYING
0:00:00.535998479 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.537748800 114 0xe562b20 INFO GST_STATES gstbin.c:2960:gst_bin_change_state_func: child ‘nvvideo-renderer’ is changing state asynchronously to PAUSED
0:00:00.537835140 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.538134610 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.538177716 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.538233046 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvegl-transform’ changed state to 3(PAUSED) successfully
0:00:00.538283865 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.552371590 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.552475403 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.552577999 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘onscreendisplay’ changed state to 3(PAUSED) successfully
0:00:00.552662291 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.552753111 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.552833627 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.553014564 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘convertor’ changed state to 3(PAUSED) successfully
0:00:00.553088903 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:05.485528751 114 0xe562b20 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1702> [UID = 2]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.1/samples/deepstream_python_apps/apps/deepstream-test1/facenet/facenet.onnx_b1_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input:0 3x160x160
1 OUTPUT kFLOAT Bottleneck/BatchNorm/batchnorm/add_1:0 128
0:00:05.485828445 114 0xe562b20 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1806> [UID = 2]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.1/samples/deepstream_python_apps/apps/deepstream-test1/facenet/facenet.onnx_b1_gpu0_fp16.engine
0:00:05.495734087 114 0xe562b20 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 2]: Load new model:facenet/facenet_config.txt sucessfully
0:00:05.495856493 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:05.496129530 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:05.496213117 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘secondary-nference faceclassifier’ changed state to 3(PAUSED) successfully
0:00:05.496286081 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:05.556417665 114 0xe562b20 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1702> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.1/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:05.556712175 114 0xe562b20 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1806> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:00:05.559835872 114 0xe562b20 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
0:00:05.560109900 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:05.560210257 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:05.560352920 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘primary-inference’ changed state to 3(PAUSED) successfully
0:00:05.560462685 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:05.560614020 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:05.560664774 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:05.560730889 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘Stream-muxer’ changed state to 3(PAUSED) successfully
0:00:05.560804524 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:05.560886448 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:05.560941331 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:05.561047992 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvv4l2-decoder’ changed state to 3(PAUSED) successfully
0:00:05.561136668 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:05.561522862 114 0xe562b20 INFO filesrc gstfilesrc.c:468:gst_file_src_start: opening file ../../../streams/sample_720p.h264
0:00:05.561657716 114 0xe562b20 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:05.561748504 114 0xe562b20 INFO filesrc gstfilesrc.c:468:gst_file_src_start: opening file ../../../streams/sample_720p.h264
0:00:05.562003460 114 0xe562b20 INFO GST_EVENT gstevent.c:895:gst_event_new_segment: creating segment event time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:05.562100456 114 0xe562b20 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0xe978390 on task 0xe988710
0:00:05.562130986 114 0xe562b20 INFO GST_PADS gstpad.c:6154:gst_pad_start_task:h264-parser:sink created task 0xe988710
0:00:05.562766695 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:05.562879725 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:05.562945040 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘h264-parser’ changed state to 3(PAUSED) successfully
0:00:05.563002546 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:05.563053269 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:05.563085750 114 0xe69ca80 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad h264-parser:sink
0:00:05.563224220 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:05.563366499 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘file-source’ changed state to 3(PAUSED) successfully
0:00:05.567615240 114 0xe69ca80 INFO h264parse gsth264parse.c:1793:gst_h264_parse_update_src_caps: resolution changed 1280x720
0:00:05.567731981 114 0xe69ca80 INFO baseparse gstbaseparse.c:4004:gst_base_parse_set_latency: min/max latency 0:00:00.033333333, 0:00:00.033333333
0:00:05.569913106 114 0xe69ca80 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-h264, width=(int)1280, height=(int)720, framerate=(fraction)30/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)high, level=(string)3.1
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
0:00:05.580702790 114 0xe69ca80 INFO v4l2 gstv4l2object.c:3152:gst_v4l2_object_setup_pool:nvv4l2-decoder:sink accessing buffers via mode 3
0:00:05.581359972 114 0xe69ca80 INFO v4l2bufferpool gstv4l2bufferpool.c:825:gst_v4l2_buffer_pool_set_config:nvv4l2-decoder:pool:sink increasing minimum buffers to 2
0:00:05.581411239 114 0xe69ca80 INFO v4l2bufferpool gstv4l2bufferpool.c:832:gst_v4l2_buffer_pool_set_config:nvv4l2-decoder:pool:sink increasing minimum buffers to 10
0:00:05.581454825 114 0xe69ca80 INFO v4l2bufferpool gstv4l2bufferpool.c:838:gst_v4l2_buffer_pool_set_config:nvv4l2-decoder:pool:sink reducing maximum buffers to 32
0:00:05.581489386 114 0xe69ca80 INFO v4l2bufferpool gstv4l2bufferpool.c:849:gst_v4l2_buffer_pool_set_config:nvv4l2-decoder:pool:sink can’t allocate, setting maximum to minimum
0:00:05.582161737 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”;
0:00:05.683448092 114 0xe69ca80 WARN v4l2 gstv4l2object.c:4434:gst_v4l2_object_probe_caps:nvv4l2-decoder:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:05.683587490 114 0xe69ca80 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0xe9deac0 Failed to determine interlace mode
0:00:05.683672102 114 0xe69ca80 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0xe9deac0 Failed to determine interlace mode
0:00:05.683846606 114 0xe69ca80 INFO v4l2 gstv4l2object.c:4490:gst_v4l2_object_probe_caps:nvv4l2-decoder:src probed caps: video/x-raw, format=(string)NV12, width=(int)[ 48, 4096 ], height=(int)[ 48, 4096 ], framerate=(fraction)[ 0/1, 2147483647/1 ]; video/x-raw, format=(string)Y42B, width=(int)[ 48, 4096 ], height=(int)[ 48, 4096 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:05.685938863 114 0xe69ca80 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)30/1
0:00:05.686597390 114 0xe69ca80 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, framerate=(fraction)30/1, batch-size=(int)1, num-surfaces-per-frame=(int)1
0:00:05.687015969 114 0xe69ca80 INFO basetransform gstbasetransform.c:1308:gst_base_transform_setcaps: reuse caps
0:00:05.687101157 114 0xe69ca80 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, framerate=(fraction)30/1, batch-size=(int)1, num-surfaces-per-frame=(int)1
0:00:05.687431924 114 0xe69ca80 INFO basetransform gstbasetransform.c:1308:gst_base_transform_setcaps: reuse caps
0:00:05.687675583 114 0xe69ca80 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, framerate=(fraction)30/1, batch-size=(int)1, num-surfaces-per-frame=(int)1
0:00:05.689394927 114 0xe69ca80 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, framerate=(fraction)30/1, batch-size=(int)1, num-surfaces-per-frame=(int)1, format=(string)RGBA
0:00:05.689592984 114 0xe69ca80 INFO basetransform gstbasetransform.c:1308:gst_base_transform_setcaps: reuse caps
0:00:05.690651177 114 0xe69ca80 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, framerate=(fraction)30/1, batch-size=(int)1, num-surfaces-per-frame=(int)1, format=(string)RGBA
0:00:05.691133088 114 0xe69ca80 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw(memory:EGLImage), width=(int)1920, height=(int)1080, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, framerate=(fraction)30/1, batch-size=(int)1, num-surfaces-per-frame=(int)1, format=(string)RGBA
0:00:05.700021371 114 0xe69ccf0 INFO nveglglessink gsteglglessink.c:2685:gst_eglglessink_configure_caps: No window. Will attempt internal window creation
0:00:05.700114879 114 0xe69ccf0 INFO nveglglessink gsteglglessink.c:937:gst_eglglessink_create_window: Attempting internal window creation
0:00:05.761376980 114 0xe69ccf0 INFO egladaption gstegladaptation_egl.c:254:gst_egl_adaptation_update_surface_dimensions: Got surface of 1920x1080 pixels
0:00:05.764840917 114 0xe69ccf0 INFO egladaption gstegladaptation.c:611:gst_egl_adaptation_init_surface: Performing initial texture setup
0:00:05.765020637 114 0xe69ccf0 INFO nveglglessink gsteglglessink.c:2726:gst_eglglessink_configure_caps: Configured caps successfully
0:00:05.766856818 114 0xe69ca80 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0xe978cd0 on task 0xe988cb0
0:00:05.766918005 114 0xe69ca80 INFO GST_PADS gstpad.c:6154:gst_pad_start_task:Stream-muxer:src created task 0xe988cb0
0:00:05.767697849 114 0xe69ca80 INFO nvstreammux gstnvstreammux.c:1129:gst_nvstreammux_sink_event: Conversion enabled for source 0
0:00:05.767993895 114 0xe69ca80 INFO v4l2 gstv4l2object.c:3152:gst_v4l2_object_setup_pool:nvv4l2-decoder:src accessing buffers via mode 2
0:00:05.768249683 114 0xe69ca80 INFO v4l2bufferpool gstv4l2bufferpool.c:825:gst_v4l2_buffer_pool_set_config:nvv4l2-decoder:pool:src increasing minimum buffers to 2
0:00:05.768286516 114 0xe69ca80 INFO v4l2bufferpool gstv4l2bufferpool.c:832:gst_v4l2_buffer_pool_set_config:nvv4l2-decoder:pool:src increasing minimum buffers to 9
0:00:05.768310037 114 0xe69ca80 INFO v4l2bufferpool gstv4l2bufferpool.c:838:gst_v4l2_buffer_pool_set_config:nvv4l2-decoder:pool:src reducing maximum buffers to 32
0:00:05.768328246 114 0xe69ca80 INFO v4l2bufferpool gstv4l2bufferpool.c:849:gst_v4l2_buffer_pool_set_config:nvv4l2-decoder:pool:src can’t allocate, setting maximum to minimum
0:00:05.768345207 114 0xe69ca80 INFO v4l2bufferpool gstv4l2bufferpool.c:854:gst_v4l2_buffer_pool_set_config:nvv4l2-decoder:pool:src adding needed video meta
0:00:05.768401914 114 0xe69e140 INFO GST_EVENT gstevent.c:895:gst_event_new_segment: creating segment event time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:05.768482557 114 0xe69ca80 INFO v4l2bufferpool gstv4l2bufferpool.c:838:gst_v4l2_buffer_pool_set_config:nvv4l2-decoder:pool:src reducing maximum buffers to 32
0:00:05.768513055 114 0xe69ca80 INFO v4l2bufferpool gstv4l2bufferpool.c:849:gst_v4l2_buffer_pool_set_config:nvv4l2-decoder:pool:src can’t allocate, setting maximum to minimum
0:00:05.768784523 114 0xe69ca80 WARN v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:05.769386375 114 0xe69ca80 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:nvv4l2-decoder:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:05.770007460 114 0xe69ca80 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0xe978a80 on task 0xe988dd0
0:00:05.770052646 114 0xe69ca80 INFO GST_PADS gstpad.c:6154:gst_pad_start_task:nvv4l2-decoder:src created task 0xe988dd0
0:00:05.772843463 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)7063680, maximum-bitrate=(uint)7063680, bitrate=(uint)5270448;
0:00:05.779154700 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)3431520, maximum-bitrate=(uint)7063680, bitrate=(uint)5103272;
0:00:05.783771521 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)2376240, maximum-bitrate=(uint)7063680, bitrate=(uint)4876020;
0:00:05.783796291 114 0xe69e2d0 WARN v4l2bufferpool gstv4l2bufferpool.c:1512:gst_v4l2_buffer_pool_dqbuf:nvv4l2-decoder:pool:src Driver should never set v4l2_buffer.field to ANY
0:00:05.784342428 114 0xe69e2d0 INFO videodecoder gstvideodecoder.c:3201:gst_video_decoder_clip_and_push_buf: First buffer since flush took 0:00:00.223462828 to produce
Frame Number=0 Number of Objects=5 Vehicle_count=3 Person_count=2
0:00:06.004193984 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)2376240, maximum-bitrate=(uint)7063680, bitrate=(uint)4689378;
0:00:06.062762295 114 0xe69ccf0 INFO nveglglessink gsteglglessink.c:980:gst_eglglessink_setup_vbo: VBO setup. have_vbo:0
0:00:06.067676251 114 0xe69cd40 INFO GST_STATES gstbin.c:3424:bin_handle_async_done: committing state from READY to PAUSED, old pending PLAYING
0:00:06.067735262 114 0xe69cd40 INFO GST_STATES gstbin.c:3453:bin_handle_async_done: continue state change, pending PLAYING
0:00:06.067771647 114 0xe69cd40 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (PLAYING pending)
0:00:06.068300632 114 0xe69f590 INFO GST_STATES gstbin.c:3250:gst_bin_continue_func: continue state change PAUSED to PLAYING, final PLAYING
0:00:06.069076540 114 0xe69f590 INFO GST_EVENT gstevent.c:1388:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:06.069313223 114 0xe69f590 INFO bin gstbin.c:2783:gst_bin_do_latency_func: configured latency of 0:00:00.000000000
0:00:06.069446701 114 0xe69f590 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:06.069510256 114 0xe69f590 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:06.069566098 114 0xe69f590 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:06.070085194 114 0xe69f590 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvvideo-renderer’ changed state to 4(PLAYING) successfully
0:00:06.071225663 114 0xe69f590 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:06.071280930 114 0xe69f590 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:06.071319972 114 0xe69f590 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:06.071717398 114 0xe69f590 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvegl-transform’ changed state to 4(PLAYING) successfully
0:00:06.071775225 114 0xe69f590 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:06.071846108 114 0xe69f590 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:06.071950305 114 0xe69f590 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:06.072231470 114 0xe69f590 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘onscreendisplay’ changed state to 4(PLAYING) successfully
0:00:06.072292689 114 0xe69f590 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:06.072340019 114 0xe69f590 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:06.072370932 114 0xe69f590 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:06.072650657 114 0xe69f590 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘convertor’ changed state to 4(PLAYING) successfully
0:00:06.072707396 114 0xe69f590 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:06.072742565 114 0xe69f590 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:06.072773415 114 0xe69f590 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:06.072843594 114 0xe69f590 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘secondary-nference faceclassifier’ changed state to 4(PLAYING) successfully
0:00:06.072892460 114 0xe69f590 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:06.072922222 114 0xe69f590 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:06.072983025 114 0xe69f590 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:06.073077493 114 0xe69f590 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘primary-inference’ changed state to 4(PLAYING) successfully
0:00:06.073123191 114 0xe69f590 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:06.073295647 114 0xe69f590 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:06.073338209 114 0xe69f590 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:06.073411908 114 0xe69f590 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘Stream-muxer’ changed state to 4(PLAYING) successfully
0:00:06.073459335 114 0xe69f590 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:06.073495528 114 0xe69f590 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:06.073530858 114 0xe69f590 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:06.073581164 114 0xe69f590 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvv4l2-decoder’ changed state to 4(PLAYING) successfully
0:00:06.073625742 114 0xe69f590 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:06.073667120 114 0xe69f590 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:06.073698066 114 0xe69f590 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:06.073746804 114 0xe69f590 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘h264-parser’ changed state to 4(PLAYING) successfully
0:00:06.073788790 114 0xe69f590 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:06.073821815 114 0xe69f590 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:06.073854169 114 0xe69f590 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:06.073901947 114 0xe69f590 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘file-source’ changed state to 4(PLAYING) successfully
0:00:06.073960478 114 0xe69f590 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:06.073992095 114 0xe69f590 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
Frame Number=1 Number of Objects=5 Vehicle_count=3 Person_count=2
0:00:06.088627109 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)2376240, maximum-bitrate=(uint)7063680, bitrate=(uint)4819457;
0:00:06.089269091 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)2376240, maximum-bitrate=(uint)7063680, bitrate=(uint)4707984;
0:00:06.089583857 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)2376240, maximum-bitrate=(uint)7063680, bitrate=(uint)4568250;
0:00:06.089877855 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)2337600, maximum-bitrate=(uint)7063680, bitrate=(uint)4437035;
0:00:06.090254928 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)2337600, maximum-bitrate=(uint)7063680, bitrate=(uint)4564560;
0:00:06.090928943 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)2262960, maximum-bitrate=(uint)7063680, bitrate=(uint)4379400;
Frame Number=2 Number of Objects=5 Vehicle_count=3 Person_count=2
0:00:06.114181188 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)2195040, maximum-bitrate=(uint)7063680, bitrate=(uint)4275382;
0:00:06.114711869 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)2165520, maximum-bitrate=(uint)7063680, bitrate=(uint)4179480;
Frame Number=3 Number of Objects=7 Vehicle_count=4 Person_count=3
0:00:06.147869500 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)1884960, maximum-bitrate=(uint)7063680, bitrate=(uint)4079718;
Frame Number=4 Number of Objects=6 Vehicle_count=4 Person_count=2
0:00:06.180385213 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)1809840, maximum-bitrate=(uint)7063680, bitrate=(uint)3985140;
0:00:06.181100254 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)1108080, maximum-bitrate=(uint)7063680, bitrate=(uint)3870057;
Frame Number=5 Number of Objects=5 Vehicle_count=3 Person_count=2
Frame Number=6 Number of Objects=5 Vehicle_count=3 Person_count=2
Frame Number=7 Number of Objects=6 Vehicle_count=4 Person_count=2
0:00:06.309122086 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)1108080, maximum-bitrate=(uint)7063680, bitrate=(uint)3758773;
Frame Number=8 Number of Objects=6 Vehicle_count=4 Person_count=2
Frame Number=9 Number of Objects=6 Vehicle_count=4 Person_count=2
Frame Number=10 Number of Objects=6 Vehicle_count=4 Person_count=2
0:00:06.383485369 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)836400, maximum-bitrate=(uint)7063680, bitrate=(uint)3654402;
Frame Number=11 Number of Objects=7 Vehicle_count=5 Person_count=2
Frame Number=12 Number of Objects=6 Vehicle_count=4 Person_count=2
Frame Number=13 Number of Objects=6 Vehicle_count=4 Person_count=2
0:00:06.508634843 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)836400, maximum-bitrate=(uint)7063680, bitrate=(uint)3559746;
Frame Number=14 Number of Objects=7 Vehicle_count=5 Person_count=2
Frame Number=15 Number of Objects=7 Vehicle_count=5 Person_count=2
0:00:06.566039005 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)836400, maximum-bitrate=(uint)8223360, bitrate=(uint)3715200;
Frame Number=16 Number of Objects=6 Vehicle_count=4 Person_count=2
Frame Number=17 Number of Objects=7 Vehicle_count=5 Person_count=2
Frame Number=18 Number of Objects=6 Vehicle_count=4 Person_count=2
0:00:06.662790908 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)836400, maximum-bitrate=(uint)8223360, bitrate=(uint)3559207;
0:00:06.663245937 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)836400, maximum-bitrate=(uint)8223360, bitrate=(uint)3476756;
0:00:06.663667365 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)836400, maximum-bitrate=(uint)8223360, bitrate=(uint)3613235;
Frame Number=19 Number of Objects=6 Vehicle_count=4 Person_count=2
0:00:06.711793977 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)836400, maximum-bitrate=(uint)8223360, bitrate=(uint)3536386;
Frame Number=20 Number of Objects=7 Vehicle_count=5 Person_count=2
0:00:06.749619344 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)497520, maximum-bitrate=(uint)8223360, bitrate=(uint)3451973;
Frame Number=21 Number of Objects=7 Vehicle_count=5 Person_count=2
Frame Number=22 Number of Objects=7 Vehicle_count=5 Person_count=2
Frame Number=23 Number of Objects=8 Vehicle_count=6 Person_count=2
Frame Number=24 Number of Objects=8 Vehicle_count=6 Person_count=2
Frame Number=25 Number of Objects=8 Vehicle_count=6 Person_count=2
Frame Number=26 Number of Objects=8 Vehicle_count=6 Person_count=2
Frame Number=27 Number of Objects=8 Vehicle_count=6 Person_count=2
0:00:07.032204522 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)430800, maximum-bitrate=(uint)8223360, bitrate=(uint)3322535;
Frame Number=28 Number of Objects=8 Vehicle_count=6 Person_count=2
Frame Number=29 Number of Objects=8 Vehicle_count=6 Person_count=2
0:00:07.118601418 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)430800, maximum-bitrate=(uint)8223360, bitrate=(uint)3250788;
0:00:07.119276745 114 0xe69ca80 INFO videodecoder gstvideodecoder.c:1330:gst_video_decoder_sink_event_default: upstream tags: taglist, video-codec=(string)“H.264\ (High\ Profile)”, minimum-bitrate=(uint)430800, maximum-bitrate=(uint)8223360, bitrate=(uint)3166788;
^C0:05:41.758234127 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:05:41.758356534 114 0xe562b20 INFO GST_STATES gstbin.c:2960:gst_bin_change_state_func: child ‘nvvideo-renderer’ is changing state asynchronously to PAUSED
0:05:41.758430682 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:05:41.758526624 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:05:41.758629413 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:05:41.758782350 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvegl-transform’ changed state to 3(PAUSED) successfully
0:05:41.758840466 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:05:41.758876564 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:05:41.758912566 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:05:41.758963577 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘onscreendisplay’ changed state to 3(PAUSED) successfully
0:05:41.759012699 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:05:41.759051550 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:05:41.759110177 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:05:41.759158660 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘convertor’ changed state to 3(PAUSED) successfully
0:05:41.759240201 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:05:41.759272394 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:05:41.759305708 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:05:41.759354447 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘secondary-nference faceclassifier’ changed state to 3(PAUSED) successfully
0:05:41.759443188 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:05:41.759473782 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:05:41.759508024 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:05:41.759558427 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘primary-inference’ changed state to 3(PAUSED) successfully
0:05:41.759603613 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:05:41.759839691 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:05:41.760001460 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:05:41.760060344 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘Stream-muxer’ changed state to 3(PAUSED) successfully
0:05:41.760116315 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:05:41.760153565 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:05:41.760197312 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:05:41.760243650 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvv4l2-decoder’ changed state to 3(PAUSED) successfully
0:05:41.760288389 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:05:41.760363529 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:05:41.760393419 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:05:41.760518354 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘h264-parser’ changed state to 3(PAUSED) successfully
0:05:41.760565653 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:05:41.760598487 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:05:41.760672283 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:05:41.760721502 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘file-source’ changed state to 3(PAUSED) successfully
0:05:41.760774785 114 0xe562b20 INFO GST_STATES gstelement.c:2981:gst_element_change_state: forcing commit state NULL <= READY
0:05:41.760804994 114 0xe562b20 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from PLAYING to PAUSED, pending NULL, next READY
0:05:41.760829636 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (NULL pending)
0:05:41.760866758 114 0xe562b20 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change PAUSED to READY, final NULL
0:05:41.760971660 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PLAYING pending PAUSED, desired next READY
0:05:41.761223803 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:05:41.761257660 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PLAYING to READY (VOID_PENDING pending)
0:05:41.761298175 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvvideo-renderer’ changed state to 2(READY) successfully
0:05:41.761339233 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next READY
0:05:41.780427946 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:05:41.780532816 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:05:41.780627957 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvegl-transform’ changed state to 2(READY) successfully
0:05:41.780816800 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next READY
0:05:41.784733761 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:05:41.784895115 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:05:41.784990704 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘onscreendisplay’ changed state to 2(READY) successfully
0:05:41.785065076 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next READY
0:05:41.790291265 114 0xe562b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:05:41.790391686 114 0xe562b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:05:41.790489164 114 0xe562b20 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘convertor’ changed state to 2(READY) successfully
0:05:41.790570257 114 0xe562b20 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next READY
^C^C^C^C^C^C^C^C^C
