Failed to allocate buffer
• Hardware Platform (Jetson)
• DeepStream Version - 7
• JetPack Version (valid for Jetson only) - 6.0-b52
• TensorRT Version - 8.6.2.3
We are running a deepstream code refer from the repo DeepStream-Yolo-Face on a Jetson Orion Nano Module.
When we run the code using the model yolov8n-face.pt, the code run successfully. But when I choose an another onnx model which I trained manually, I’m facing some error like,
(base) jetson@ubuntu:~/Downloads/DeepStream-Yolo-Face-master$ sudo python3 deepstream.py -s file:///home/jetson/Downloads/DeepStream-Yolo-Face-master/f617d41f3a0e484d857cb8cf65d21ecd.mp4 -c config_infer_primary_yoloV8_face.txt
/home/jetson/Downloads/DeepStream-Yolo-Face-master/deepstream.py:201: DeprecationWarning: Gst.Element.get_request_pad is deprecated
  streammux_sink_pad = streammux.get_request_pad(pad_name)
SOURCE: file:///home/jetson/Downloads/DeepStream-Yolo-Face-master/f617d41f3a0e484d857cb8cf65d21ecd.mp4
CONFIG_INFER: config_infer_primary_yoloV8_face.txt
STREAMMUX_BATCH_SIZE: 1
STREAMMUX_WIDTH: 1920
STREAMMUX_HEIGHT: 1080
GPU_ID: 0
PERF_MEASUREMENT_INTERVAL_SEC: 5
JETSON: TRUE
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-7.0/lib/libnvds_nvmultiobjecttracker.so
[NvMultiObjectTracker] Initialized
Setting min object dimensions as 16x16 instead of 1x1 to support VIC compute mode.
0:00:07.273003161 39599 0xaaab5b715870 INFO                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<pgie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2095> [UID = 1]: deserialized trt engine from :/home/jetson/Downloads/DeepStream-Yolo-Face-master/best.onnx_b1_gpu0_fp32.engine
WARNING: [TRT]: The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
INFO: [Implicit Engine Info]: layers num: 4
0   INPUT  kFLOAT input           3x640x640
1   OUTPUT kFLOAT boxes           8400x4
2   OUTPUT kFLOAT scores          8400x1
3   OUTPUT kFLOAT landmarks       8400x0
0:00:07.686870097 39599 0xaaab5b715870 INFO                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<pgie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2198> [UID = 1]: Use deserialized engine model: /home/jetson/Downloads/DeepStream-Yolo-Face-master/best.onnx_b1_gpu0_fp32.engine
0:00:07.694737548 39599 0xaaab5b715870 ERROR                nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger:<pgie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::resizeOutputBufferpool() <nvdsinfer_context_impl.cpp:1463> [UID = 1]: Failed to allocate cuda output buffer during context initialization
0:00:07.694794735 39599 0xaaab5b715870 ERROR                nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger:<pgie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::allocateBuffers() <nvdsinfer_context_impl.cpp:1595> [UID = 1]: Failed to allocate output bufferpool
0:00:07.694819728 39599 0xaaab5b715870 ERROR                nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger:<pgie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1375> [UID = 1]: Failed to allocate buffers
Segmentation fault
How to resolve this?
How do you generate the engine file? Could you attach your config file?
this is my config file
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-color-format=0
onnx-file=yolov8n-face.onnx
model-engine-file=yolov8n-face.onnx_b1_gpu0_fp32.engine
#int8-calib-file=calib.table
labelfile-path=labels.txt
batch-size=1
network-mode=0
num-detected-classes=1
interval=0
gie-unique-id=1
process-mode=1
network-type=3
cluster-mode=4
maintain-aspect-ratio=1
symmetric-padding=1
#workspace-size=2000
parse-bbox-instance-mask-func-name=NvDsInferParseYoloFace
custom-lib-path=nvdsinfer_custom_impl_Yolo_face/libnvdsinfer_custom_impl_Yolo_face.so
output-instance-mask=1
[class-attrs-all]
pre-cluster-threshold=0.25
topk=300
Please double check your config file when you run DeepStream. From the log you attached, the model is /home/jetson/Downloads/DeepStream-Yolo-Face-master/best.onnx_b1_gpu0_fp32.engine. You can look into this mismatch issue first.
Sorry, My mistake.
This is my config file ,
[property]
gpu-id=0
onnx-file=/home/jetson/Downloads/DeepStream-Yolo-Face-master/utils/best.onnx
model-engine-file=/home/jetson/Downloads/DeepStream-Yolo-Face-master/utils/best.onnx_b1_gpu0_fp32.engine
#onnx-file=/home/jetson/Downloads/DeepStream-Yolo-Face-master/yolov8n-face.onnx
#model-engine-file=/home/jetson/Downloads/DeepStream-Yolo-Face-master/yolov8n-face.onnx_b1_gpu0_fp32.engine
labelfile-path=/home/jetson/Downloads/DeepStream-Yolo-Face-master/labels.txt
batch-size=1
network-mode=0
interval=0
gie-unique-id=1
process-mode=1
network-type=3
cluster-mode=4
symmetric-padding=1
custom-lib-path=/home/jetson/Downloads/DeepStream-Yolo-Face-master/nvdsinfer_custom_impl_Yolo_face/libnvdsinfer_custom_impl_Yolo_face.so
[class-attrs-all]
topk=300
Just from the log attached, this output layer is suspicious. Could you add some log in the source code for preliminary analysis?
sources\libs\nvdsinfer\nvdsinfer_context_impl.cpp
+printf(" layer name %s size %d\n", layerInfo.layerName, size);
/* Allocate device memory for output layers here. */
auto outputBuf = std::make_unique<CudaDeviceBuffer>(size);
Thanks, That error solved.
i am working on the deepstream python yolov8 (GitHub - marcoslucianops/DeepStream-Yolo-Face: NVIDIA DeepStream SDK 6.3 / 6.2 / 6.1.1 / 6.1 / 6.0.1 / 6.0 application for YOLO-Face models) code to detect moving object. i am using following model
(yolov8n-face.pt - Google Drive)
the problem is the code detect only persons. i also share my python scripts and config file.
i never edit the deepstream.py file. i want to know any change in python and config file.
import gi
gi.require_version('Gst', '1.0')
from gi.repository import Gst, GLib
import os
import sys
import time
import argparse
import platform
from ctypes import *
sys.path.append('/opt/nvidia/deepstream/deepstream-7.0/lib')
import pyds
MAX_ELEMENTS_IN_DISPLAY_META = 16
SOURCE = ''
CONFIG_INFER = ''
STREAMMUX_BATCH_SIZE = 1
STREAMMUX_WIDTH = 1920
STREAMMUX_HEIGHT = 1080
GPU_ID = 0
PERF_MEASUREMENT_INTERVAL_SEC = 5
skeleton = [[16, 14], [14, 12], [17, 15], [15, 13], [12, 13], [6, 12], [7, 13], [6, 7], [6, 8], [7, 9], [8, 10], [9, 11],
            [2, 3], [1, 2], [1, 3], [2, 4], [3, 5], [4, 6], [5, 7]]
start_time = time.time()
fps_streams = {}
class GETFPS:
    def __init__(self, stream_id):
        global start_time
        self.start_time = start_time
        self.is_first = True
        self.frame_count = 0
        self.stream_id = stream_id
        self.total_fps_time = 0
        self.total_frame_count = 0
    def get_fps(self):
        end_time = time.time()
        if self.is_first:
            self.start_time = end_time
            self.is_first = False
        current_time = end_time - self.start_time
        if current_time > PERF_MEASUREMENT_INTERVAL_SEC:
            self.total_fps_time = self.total_fps_time + current_time
            self.total_frame_count = self.total_frame_count + self.frame_count
            current_fps = float(self.frame_count) / current_time
            avg_fps = float(self.total_frame_count) / self.total_fps_time
            sys.stdout.write('DEBUG: FPS of stream %d: %.2f (%.2f)\n' % (self.stream_id + 1, current_fps, avg_fps))
        else:
            self.frame_count = self.frame_count + 1
def set_custom_bbox(obj_meta):
    border_width = 6
    font_size = 18
    x_offset = int(min(STREAMMUX_WIDTH - 1, max(0, obj_meta.rect_params.left - (border_width / 2))))
    y_offset = int(min(STREAMMUX_HEIGHT - 1, max(0, obj_meta.rect_params.top - (font_size * 2) + 1)))
    obj_meta.rect_params.border_width = border_width
    obj_meta.rect_params.border_color.red = 0.0
    obj_meta.rect_params.border_color.green = 0.0
    obj_meta.rect_params.border_color.blue = 1.0
    obj_meta.rect_params.border_color.alpha = 1.0
    obj_meta.text_params.font_params.font_name = 'Ubuntu'
    obj_meta.text_params.font_params.font_size = font_size
    obj_meta.text_params.x_offset = x_offset
    obj_meta.text_params.y_offset = y_offset
    obj_meta.text_params.font_params.font_color.red = 1.0
    obj_meta.text_params.font_params.font_color.green = 1.0
    obj_meta.text_params.font_params.font_color.blue = 1.0
    obj_meta.text_params.font_params.font_color.alpha = 1.0
    obj_meta.text_params.set_bg_clr = 1
    obj_meta.text_params.text_bg_clr.red = 0.0
    obj_meta.text_params.text_bg_clr.green = 0.0
    obj_meta.text_params.text_bg_clr.blue = 1.0
    obj_meta.text_params.text_bg_clr.alpha = 1.0
def parse_face_from_meta(frame_meta, obj_meta):
    num_joints = int(obj_meta.mask_params.size / (sizeof(c_float) * 3))
    gain = min(obj_meta.mask_params.width / STREAMMUX_WIDTH,
               obj_meta.mask_params.height / STREAMMUX_HEIGHT)
    pad_x = (obj_meta.mask_params.width - STREAMMUX_WIDTH * gain) / 2.0
    pad_y = (obj_meta.mask_params.height - STREAMMUX_HEIGHT * gain) / 2.0
    batch_meta = frame_meta.base_meta.batch_meta
    display_meta = pyds.nvds_acquire_display_meta_from_pool(batch_meta)
    pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
    for i in range(num_joints):
        data = obj_meta.mask_params.get_mask_array()
        xc = int((data[i * 3 + 0] - pad_x) / gain)
        yc = int((data[i * 3 + 1] - pad_y) / gain)
        confidence = data[i * 3 + 2]
        if confidence < 0.5:
            continue
        if display_meta.num_circles == MAX_ELEMENTS_IN_DISPLAY_META:
        circle_params = display_meta.circle_params[display_meta.num_circles]
        circle_params.xc = xc
        circle_params.yc = yc
        circle_params.radius = 6
        circle_params.circle_color.red = 1.0
        circle_params.circle_color.green = 1.0
        circle_params.circle_color.blue = 1.0
        circle_params.circle_color.alpha = 1.0
        circle_params.has_bg_color = 1
        circle_params.bg_color.red = 0.0
        circle_params.bg_color.green = 0.0
        circle_params.bg_color.blue = 1.0
        circle_params.bg_color.alpha = 1.0
        display_meta.num_circles += 1
def tracker_src_pad_buffer_probe(pad, info, user_data):
    buf = info.get_buffer()
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(buf))
    l_frame = batch_meta.frame_meta_list
    while l_frame:
        try:
        except StopIteration:
            break
        current_index = frame_meta.source_id
        l_obj = frame_meta.obj_meta_list
        while l_obj:
            try:
                obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
                break
            try:
                l_obj = l_obj.next
                break
        fps_streams['stream{0}'.format(current_index)].get_fps()
        try:
            l_frame = l_frame.next
            break
    return Gst.PadProbeReturn.OK
def decodebin_child_added(child_proxy, Object, name, user_data):
    if name.find('decodebin') != -1:
        Object.connect('child-added', decodebin_child_added, user_data)
    if name.find('nvv4l2decoder') != -1:
        Object.set_property('drop-frame-interval', 0)
        Object.set_property('num-extra-surfaces', 1)
        if is_aarch64():
            Object.set_property('enable-max-performance', 1)
        else:
            Object.set_property('cudadec-memtype', 0)
            Object.set_property('gpu-id', GPU_ID)
def cb_newpad(decodebin, pad, user_data):
    streammux_sink_pad = user_data
    caps = pad.get_current_caps()
    if not caps:
        caps = pad.query_caps()
    structure = caps.get_structure(0)
    name = structure.get_name()
    features = caps.get_features(0)
    if name.find('video') != -1:
        if features.contains('memory:NVMM'):
            if pad.link(streammux_sink_pad) != Gst.PadLinkReturn.OK:
                sys.stderr.write('ERROR: Failed to link source to streammux sink pad\n')
        else:
            sys.stderr.write('ERROR: decodebin did not pick NVIDIA decoder plugin')
def create_uridecode_bin(stream_id, uri, streammux):
    bin_name = 'source-bin-%04d' % stream_id
    bin = Gst.ElementFactory.make('uridecodebin', bin_name)
    if 'rtsp://' in uri:
        pyds.configure_source_for_ntp_sync(bin)
    bin.set_property('uri', uri)
    pad_name = 'sink_%u' % stream_id
    bin.connect('pad-added', cb_newpad, streammux_sink_pad)
    bin.connect('child-added', decodebin_child_added, 0)
    fps_streams['stream{0}'.format(stream_id)] = GETFPS(stream_id)
    return bin
def bus_call(bus, message, user_data):
    loop = user_data
    t = message.type
    if t == Gst.MessageType.EOS:
        sys.stdout.write('DEBUG: EOS\n')
        loop.quit()
    elif t == Gst.MessageType.WARNING:
        err, debug = message.parse_warning()
        sys.stderr.write('WARNING: %s: %s\n' % (err, debug))
    elif t == Gst.MessageType.ERROR:
        err, debug = message.parse_error()
        sys.stderr.write('ERROR: %s: %s\n' % (err, debug))
        loop.quit()
    return True
def is_aarch64():
    return platform.uname()[4] == 'aarch64'
def main():
    Gst.init(None)
    loop = GLib.MainLoop()
    pipeline = Gst.Pipeline()
    if not pipeline:
        sys.stderr.write('ERROR: Failed to create pipeline\n')
        sys.exit(1)
    streammux = Gst.ElementFactory.make('nvstreammux', 'nvstreammux')
    if not streammux:
        sys.stderr.write('ERROR: Failed to create nvstreammux\n')
        sys.exit(1)
    pipeline.add(streammux)
    source_bin = create_uridecode_bin(0, SOURCE, streammux)
    if not source_bin:
        sys.stderr.write('ERROR: Failed to create source_bin\n')
        sys.exit(1)
    pipeline.add(source_bin)
    pgie = Gst.ElementFactory.make('nvinfer', 'pgie')
    if not pgie:
        sys.stderr.write('ERROR: Failed to create nvinfer\n')
        sys.exit(1)
    tracker = Gst.ElementFactory.make('nvtracker', 'nvtracker')
    if not tracker:
        sys.stderr.write('ERROR: Failed to create nvtracker\n')
        sys.exit(1)
    converter = Gst.ElementFactory.make('nvvideoconvert', 'nvvideoconvert')
    if not converter:
        sys.stderr.write('ERROR: Failed to create nvvideoconvert\n')
        sys.exit(1)
    osd = Gst.ElementFactory.make('nvdsosd', 'nvdsosd')
    if not osd:
        sys.stderr.write('ERROR: Failed to create nvdsosd\n')
        sys.exit(1)
    sink = None
    if is_aarch64():
        sink = Gst.ElementFactory.make('nv3dsink', 'nv3dsink')
        if not sink:
            sys.stderr.write('ERROR: Failed to create nv3dsink\n')
            sys.exit(1)
    else:
        sink = Gst.ElementFactory.make('nveglglessink', 'nveglglessink')
        if not sink:
            sys.stderr.write('ERROR: Failed to create nveglglessink\n')
            sys.exit(1)
    sys.stdout.write('\n')
    sys.stdout.write('SOURCE: %s\n' % SOURCE)
    sys.stdout.write('CONFIG_INFER: %s\n' % CONFIG_INFER)
    sys.stdout.write('STREAMMUX_BATCH_SIZE: %d\n' % STREAMMUX_BATCH_SIZE)
    sys.stdout.write('STREAMMUX_WIDTH: %d\n' % STREAMMUX_WIDTH)
    sys.stdout.write('STREAMMUX_HEIGHT: %d\n' % STREAMMUX_HEIGHT)
    sys.stdout.write('GPU_ID: %d\n' % GPU_ID)
    sys.stdout.write('PERF_MEASUREMENT_INTERVAL_SEC: %d\n' % PERF_MEASUREMENT_INTERVAL_SEC)
    sys.stdout.write('JETSON: %s\n' % ('TRUE' if is_aarch64() else 'FALSE'))
    streammux.set_property('batch-size', STREAMMUX_BATCH_SIZE)
    streammux.set_property('batched-push-timeout', 25000)
    streammux.set_property('width', STREAMMUX_WIDTH)
    streammux.set_property('height', STREAMMUX_HEIGHT)
    streammux.set_property('enable-padding', 0)
    streammux.set_property('live-source', 1)
    streammux.set_property('attach-sys-ts', 1)
    pgie.set_property('config-file-path', CONFIG_INFER)
    pgie.set_property('qos', 0)
    tracker.set_property('tracker-width', 640)
    tracker.set_property('tracker-height', 384)
    tracker.set_property('ll-lib-file', '/opt/nvidia/deepstream/deepstream-7.0/lib/libnvds_nvmultiobjecttracker.so')
    tracker.set_property('ll-config-file',
                         '/opt/nvidia/deepstream/deepstream-7.0/samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml')
    tracker.set_property('display-tracking-id', 1)
    tracker.set_property('qos', 0)
    osd.set_property('process-mode', int(pyds.MODE_GPU))
    osd.set_property('qos', 0)
    sink.set_property('async', 0)
    sink.set_property('sync', 0)
    sink.set_property('qos', 0)
    if 'file://' in SOURCE:
        streammux.set_property('live-source', 0)
    if tracker.find_property('enable_batch_process') is not None:
        tracker.set_property('enable_batch_process', 1)
    if tracker.find_property('enable_past_frame') is not None:
        tracker.set_property('enable_past_frame', 1)
    if not is_aarch64():
        streammux.set_property('nvbuf-memory-type', 0)
        streammux.set_property('gpu_id', GPU_ID)
        pgie.set_property('gpu_id', GPU_ID)
        tracker.set_property('gpu_id', GPU_ID)
        converter.set_property('nvbuf-memory-type', 0)
        converter.set_property('gpu_id', GPU_ID)
        osd.set_property('gpu_id', GPU_ID)
    pipeline.add(pgie)
    pipeline.add(tracker)
    pipeline.add(converter)
    pipeline.add(osd)
    pipeline.add(sink)
    streammux.link(pgie)
    pgie.link(tracker)
    tracker.link(converter)
    converter.link(osd)
    osd.link(sink)
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect('message', bus_call, loop)
    tracker_src_pad = tracker.get_static_pad('src')
    if not tracker_src_pad:
        sys.stderr.write('ERROR: Failed to get tracker src pad\n')
        sys.exit(1)
    else:
        tracker_src_pad.add_probe(Gst.PadProbeType.BUFFER, tracker_src_pad_buffer_probe, 0)
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
    except:
        pass
    pipeline.set_state(Gst.State.NULL)
def parse_args():
    global SOURCE, CONFIG_INFER, STREAMMUX_BATCH_SIZE, STREAMMUX_WIDTH, STREAMMUX_HEIGHT, GPU_ID, \
    parser = argparse.ArgumentParser(description='DeepStream')
    parser.add_argument('-s', '--source', required=True, help='Source stream/file')
    parser.add_argument('-c', '--config-infer', required=True, help='Config infer file')
    parser.add_argument('-b', '--streammux-batch-size', type=int, default=1, help='Streammux batch-size (default: 1)')
    parser.add_argument('-w', '--streammux-width', type=int, default=1920, help='Streammux width (default: 1920)')
    parser.add_argument('-e', '--streammux-height', type=int, default=1080, help='Streammux height (default: 1080)')
    parser.add_argument('-g', '--gpu-id', type=int, default=0, help='GPU id (default: 0)')
    parser.add_argument('-f', '--fps-interval', type=int, default=5, help='FPS measurement interval (default: 5)')
    args = parser.parse_args()
    if args.source == '':
        sys.stderr.write('ERROR: Source not found\n')
        sys.exit(1)
    if args.config_infer == '' or not os.path.isfile(args.config_infer):
        sys.stderr.write('ERROR: Config infer not found\n')
        sys.exit(1)
    SOURCE = args.source
    CONFIG_INFER = args.config_infer
    STREAMMUX_BATCH_SIZE = args.streammux_batch_size
    STREAMMUX_WIDTH = args.streammux_width
    STREAMMUX_HEIGHT = args.streammux_height
    GPU_ID = args.gpu_id
    PERF_MEASUREMENT_INTERVAL_SEC = args.fps_interval
if __name__ == '__main__':
    parse_args()
    sys.exit(main())
config_infer_primary_yoloV8_face.txt (793 Bytes)
Since you are using the original source code and model, could you check this with the project owner DeepStream-Yolo-Face?
