Hardware Platform (GPU)
• DeepStream Version : 5.1
**• NVIDIA GPU Driver Version (valid for GPU only): Driver Version: 460.39
We are trying to implement the multi model integration using deepstream-python-apps in which we are using trafficcamNet as primary detector and vehicletypeNet as a secondary classifer in which we are getting segamentation fault core )(dumped error).
Error Logs:
pr_sec.py:6: PyGIWarning: GstRtspServer was imported without specifying a version first. Use gi.require_version(‘GstRtspServer’, ‘1.0’) before import to ensure that the right version gets loaded.
from gi.repository import GObject, Gst, GstRtspServer
Creating Pipeline
Creating streamux
Creating source_bin 0
Creating source bin
source-bin-00
Creating Pgie
Creating nvtracker
Creating secondary detector
Creating nvdsanalytics
Creating tiler
Creating nvvidconv
Creating nvosd
Creating H264 Encoder
Creating H264 rtppay
Atleast one of the sources is live
Warning: ‘input-dims’ parameter has been deprecated. Use ‘infer-dims’ instead.
Adding elements to Pipeline
Linking elements in the Pipeline
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8661/ds-test ***
Now playing…
1 : rtsp://10.60.33.147:554/stream2
Starting pipeline
0:00:01.625061378 1999 0x30a3640 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:encoder:sink Unable to try format: Unknown error -1
0:00:01.625115289 1999 0x30a3640 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:encoder:sink Could not probe minimum capture size for pixelformat YM12
0:00:01.625192123 1999 0x30a3640 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:encoder:sink Unable to try format: Unknown error -1
0:00:01.625208945 1999 0x30a3640 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:encoder:sink Could not probe maximum capture size for pixelformat YM12
0:00:01.625244371 1999 0x30a3640 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x308acc0 Failed to determine interlace mode
0:00:01.625294515 1999 0x30a3640 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:encoder:sink Unable to try format: Unknown error -1
0:00:01.625311126 1999 0x30a3640 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:encoder:sink Could not probe minimum capture size for pixelformat NM12
0:00:01.625325834 1999 0x30a3640 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:encoder:sink Unable to try format: Unknown error -1
0:00:01.625341233 1999 0x30a3640 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:encoder:sink Could not probe maximum capture size for pixelformat NM12
0:00:01.625357403 1999 0x30a3640 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x308acc0 Failed to determine interlace mode
0:00:01.625435559 1999 0x30a3640 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:encoder:src Unable to try format: Unknown error -1
0:00:01.625452381 1999 0x30a3640 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:encoder:src Could not probe minimum capture size for pixelformat H264
0:00:01.625466267 1999 0x30a3640 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:encoder:src Unable to try format: Unknown error -1
0:00:01.625487647 1999 0x30a3640 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:encoder:src Could not probe maximum capture size for pixelformat H264
0:00:02.031898737 1999 0x30a3640 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 4]: Trying to create engine from model files
Warning: Flatten layer ignored. TensorRT implicitly flattens input to FullyConnected layers, but in other circumstances this will result in undefined behavior.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Reading Calibration Cache for calibrator: EntropyCalibration2
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Generated calibration scales using calibration cache. Make sure that calibration cache has latest scales.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: To regenerate calibration cache, please delete the existing one. TensorRT will generate a new calibration cache.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Detected 1 inputs and 1 output network tensors.
0:00:31.526787823 1999 0x30a3640 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1749> [UID = 4]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine successfully
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input_1 3x224x224
1 OUTPUT kFLOAT predictions/Softmax 6x1x1
0:00:31.542568805 1999 0x30a3640 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 4]: Load new model:dstest2_sgie3_config.txt sucessfully
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvdcf.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is OFF
[NvDCF][Warning] minTrackingConfidenceDuringInactive is deprecated
[NvDCF] Initialized
0:00:31.825536117 1999 0x30a3640 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 1]: Trying to create engine from model files
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Detected 1 inputs and 2 output network tensors.
0:00:51.267156216 1999 0x30a3640 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1749> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-5.1/sources/dswpark/pri_secondary/resnet18_trafficcamnet_pruned.etlt_b1_gpu0_fp16.engine successfully
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x544x960
1 OUTPUT kFLOAT output_bbox/BiasAdd 16x34x60
2 OUTPUT kFLOAT output_cov/Sigmoid 4x34x60
0:00:51.278325140 1999 0x30a3640 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dsnvanalytics_pgie_config_vehicle.txt sucessfully
Decodebin child added: source
0:00:51.308486207 1999 0x24aa540 FIXME default gstutils.c:3981:gst_pad_create_stream_id_internal:fakesrc0:src Creating random stream-id, consider implementing a deterministic way of creating a stream-id
Decodebin child added: decodebin0
Decodebin child added: rtph264depay0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: nvv4l2decoder0
0:00:51.539527228 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:51.539560851 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MJPG
0:00:51.539577703 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:51.539595747 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MJPG
0:00:51.539644097 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:51.539669024 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MPG4
0:00:51.539887133 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:51.539904225 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MPG4
0:00:51.539932087 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:51.539950291 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MPG2
0:00:51.540007208 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:51.540024491 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MPG2
0:00:51.540078562 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:51.540114589 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H265
0:00:51.540125720 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:51.540169042 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H265
0:00:51.540189490 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:51.540202484 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat VP90
0:00:51.540216010 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:51.540233312 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat VP90
0:00:51.540251205 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:51.540264040 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat VP80
0:00:51.540275531 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:51.540288415 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat VP80
0:00:51.540308834 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:51.540322118 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H264
0:00:51.540335944 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:51.540346615 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H264
0:00:51.540411797 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:51.540425673 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe minimum capture size for pixelformat NM12
0:00:51.540436203 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:51.540446582 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe maximum capture size for pixelformat NM12
0:00:51.540503579 1999 0x24aaf70 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7fd4680b0470 Failed to determine interlace mode
0:00:51.660799023 1999 0x24aaf70 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:51.660844849 1999 0x24aaf70 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:51.660899141 1999 0x24aaf70 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:51.660913127 1999 0x24aaf70 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:51.660957170 1999 0x24aaf70 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:51.660968481 1999 0x24aaf70 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:51.661017754 1999 0x24aaf70 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:51.661029235 1999 0x24aaf70 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:51.661067607 1999 0x24aaf70 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:51.661078808 1999 0x24aaf70 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:51.661118893 1999 0x24aaf70 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:51.661134542 1999 0x24aaf70 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:51.661178054 1999 0x24aaf70 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:51.661194425 1999 0x24aaf70 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:51.661235802 1999 0x24aaf70 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:51.661249889 1999 0x24aaf70 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
In cb_newpad
gstname= video/x-raw
features= <Gst.CapsFeatures object at 0x7fd61eb14be8 (GstCapsFeatures at 0x7fd4680adb40)>
0:00:51.666281664 1999 0x24aaf70 FIXME basesink gstbasesink.c:3145:gst_base_sink_default_event: stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:51.719763091 1999 0x24aaf70 WARN v4l2bufferpool gstv4l2bufferpool.c:1066:gst_v4l2_buffer_pool_start:encoder:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:51.722712912 1999 0x24aaf70 WARN v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:51.722759900 1999 0x24aaf70 WARN v4l2bufferpool gstv4l2bufferpool.c:1066:gst_v4l2_buffer_pool_start:nvv4l2decoder0:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:52.711487163 1999 0x7fd4680d1cf0 WARN v4l2bufferpool gstv4l2bufferpool.c:1513:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder0:pool:src Driver should never set v4l2_buffer.field to ANY
Frame Number= 0 stream id= 0 Number of Objects= 0 CARS= 0
0:00:52.840566068 1999 0x24a9720 WARN v4l2bufferpool gstv4l2bufferpool.c:1513:gst_v4l2_buffer_pool_dqbuf:encoder:pool:src Driver should never set v4l2_buffer.field to ANY
Frame Number= 1 stream id= 0 Number of Objects= 0 CARS= 0
Frame Number= 2 stream id= 0 Number of Objects= 0 CARS= 0
Frame Number= 3 stream id= 0 Number of Objects= 1 CARS= 1
Fatal Python error: Segmentation fault
Thread 0x00007fd6c82c7740 (most recent call first):
File “/usr/lib/python3/dist-packages/gi/overrides/GLib.py”, line 585 in run
File “pr_sec.py”, line 661 in main
File “pr_sec.py”, line 669 in
Output of Nvidia-smi:
| NVIDIA-SMI 460.39 Driver Version: 460.39 CUDA Version: 11.2 |
| | | MIG M. |
| 0 Tesla T4 Off | 00000000:27:00.0 Off | 0 |
| N/A 48C P0 28W / 70W | 0MiB / 15109MiB | 0% Default |
| | | N/A |
| 1 Tesla T4 Off | 00000000:83:00.0 Off | 0 |
| N/A 53C P0 29W / 70W | 310MiB / 15109MiB | 8% Default |
| | | N/A |
| 2 Tesla T4 Off | 00000000:A3:00.0 Off | 0 |
| N/A 72C P0 45W / 70W | 2669MiB / 15109MiB | 37% Default |
| | | N/A |
| 3 Tesla T4 Off | 00000000:C3:00.0 Off | 0 |
| N/A 54C P0 29W / 70W | 0MiB / 15109MiB | 6% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
Docker command for creating a container:
docker run -it -d --name -p p1:p2 --gpus all bash
Logging into already created container:
docker exec -it bash
To run deepstream file:
python3
Here is the python file:
import sys
sys.path.append(‘…/’)
import gi
import configparser
gi.require_version(‘Gst’, ‘1.0’)
from gi.repository import GLib
from ctypes import *
import time
import sys
import math
import platform
from common.is_aarch_64 import is_aarch64
from common.bus_call import bus_call
from common.FPS import GETFPS
import numpy as np
import pyds
import datetime
from timeit import time
from datetime import datetime
import cv2
import faulthandler
faulthandler.enable()
codec=“H264”
bitrate=4000000
fps_streams={}
MAX_DISPLAY_LEN=64
PGIE_CLASS_ID_CARS = 0
PGIE_CLASS_ID_PEOPLE = 1
PGIE_CLASS_ID_ROADSIGN = 2
PGIE_CLASS_ID_TWO_WHEELERS = 3
MUXER_OUTPUT_WIDTH=1920
MUXER_OUTPUT_HEIGHT=1080
MUXER_BATCH_TIMEOUT_USEC=4000000
TILED_OUTPUT_WIDTH=1280
TILED_OUTPUT_HEIGHT=720
GST_CAPS_FEATURES_NVMM=“memory:NVMM”
OSD_PROCESS_MODE= 0
OSD_DISPLAY_TEXT= 1
pgie_classes_str= [“cars”,“people”,“road signs”, “two-wheelers”]
thres_time = 20
for chcking the id with time
first_appearence_dict = {}
for checking the postion
dict_pos = {}
nvanlytics_src_pad_buffer_probe will extract metadata received on nvtiler sink pad
and update params for drawing rectangle, object information etc.
def nvanalytics_src_pad_buffer_probe(pad,info,u_data):
frame_number=0
num_rects=0
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
# Retrieve batch metadata from the gst_buffer
# Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
# C address of gst_buffer as input, which is obtained with hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
#dict_pos = {}
while l_frame:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.NvDsFrameMeta.cast()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garTWO_WHEELERSe collector will leave
# it alone.
except StopIteration:
break
#old_time = datetime.datetime.now()
# thres_time = 0.005
# first_appearence_dict = {}
"""DS PROBE LOGIC"""
# if obj_meta.object_id in first_appearence_dict.keys():
# time_diff = first_appearence_dict[obj_meta.object_id] - datetime.now()
# if time_diff > thres_time:
# print("RAISE FLAG")
# else:
# first_appearence_dict[obj_meta.object_id] = datetime.now()
frame_number=frame_meta.frame_num
l_obj=frame_meta.obj_meta_list
num_rects = frame_meta.num_obj_meta
obj_counter = {
PGIE_CLASS_ID_CARS:0,
PGIE_CLASS_ID_PEOPLE:0,
PGIE_CLASS_ID_ROADSIGN:0,
PGIE_CLASS_ID_TWO_WHEELERS:0
print("#"*50)
counter = 0
vehicle_meta_status= "" #entry/exit status
#vehicle_id_list = [""]
# dict_pos={}
while l_obj:
# dict_pos={}
try:
# Note that l_obj.data needs a cast to pyds.NvDsObjectMeta
# The casting is done by pyds.NvDsObjectMeta.cast()
obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
break
obj_counter[obj_meta.class_id] += 1
l_user_meta = obj_meta.obj_user_meta_list
# Extract object level meta data from NvDsAnalyticsObjInfo
while l_user_meta:
try:
user_meta = pyds.NvDsUserMeta.cast(l_user_meta.data)
if user_meta.base_meta.meta_type == pyds.nvds_get_user_meta_type("NVIDIA.DSANALYTICSOBJ.USER_META"):
user_meta_data = pyds.NvDsAnalyticsObjInfo.cast(user_meta.user_meta_data)
#if user_meta_data.dirStatus: print("Object {0} moving in direction: {1}".format(obj_meta.object_id, user_meta_data.dirStatus))
if user_meta_data.lcStatus:
# print("=================Object {0} line crossing status: {1}".format(obj_meta.object_id, user_meta_data.lcStatus))
pass
if user_meta_data.ocStatus: print("Object {0} overcrowding status: {1}".format(obj_meta.object_id, user_meta_data.ocStatus))
# if user_meta_data.roiStatus: print("Object {0} roi status: {1}".format(obj_meta.object_id, user_meta_data.roiStatus))
if user_meta_data.roiStatus: print("Object {0} roi ROI: {1}".format(obj_meta.object_id, user_meta_data.roiStatus))
roi_status= user_meta_data.roiStatus
#print("HEYYYYYYYYY**********user_meta_data.roiStatus",user_meta_data.roiStatus)
vehicle_id = obj_meta.object_id
#dict_pos = {}
if obj_meta.object_id not in first_appearence_dict.keys():
#dict_pos={}
first_appearence_dict[obj_meta.object_id]=datetime.now()
dict_pos[obj_meta.object_id]=obj_meta.rect_params.top
print(first_appearence_dict)
print("oldtop",obj_meta.rect_params.top)
else:
#print(first_appearence_dict[obj_meta.object_id])
#print(datetime.now())
print("newtop",obj_meta.rect_params.top)
print("oldtop",dict_pos[obj_meta.object_id])
posdiff = obj_meta.rect_params.top - dict_pos[obj_meta.object_id]
# print("newtop",obj_meta.rect_params.top)
# print("oldtop",dict_pos[obj_meta.object_id])
timediff = datetime.now() - first_appearence_dict[obj_meta.object_id]
timediff1 = (timediff.hour3600)+(timediff.minute60)+timediff.second
timediff1 = timediff.seconds
#print(timediff)
# print(timediff1)
print(posdiff)
if posdiff < 1 and timediff1 > thres_time:
counter +=1
#print("Wrongly Parked")
text = "{}|{}secs.".format('wrongly parked', str(np.round(timediff1,1)))
vehicle_meta_status = "Wrongly Parked"
# cv2.putText(frame_meta, text,(int(bbox[0]-50), int(bbox[1] -40)),0, 5e-3 * 100, (0,0,255),2)
#cv2.putText(frame_meta.base_meta, text,0, 5e-3 * 100, (0,0,255),2)
#if obj_meta.object_id in first_appearence_dict.keys():
# print(time_diff)
# print("time_diff")
# print("WRONGLY PARKED")
#else:
# print(first_appearence_dict)
# if time_diff_final>.005:
# vehicle_meta_status = "Wrongly Parked"
# else: print('Correct!')
break
try:
l_user_meta = l_user_meta.next
break
try:
l_obj=l_obj.next
break
print(‘=========object metadat***====’,obj_meta.text_params.display_text)
# Get meta data from NvDsAnalyticsFrameMeta
l_user = frame_meta.frame_user_meta_list
while l_user:
try:
user_meta = pyds.NvDsUserMeta.cast(l_user.data)
if user_meta.base_meta.meta_type == pyds.nvds_get_user_meta_type("NVIDIA.DSANALYTICSFRAME.USER_META"):
user_meta_data = pyds.NvDsAnalyticsFrameMeta.cast(user_meta.user_meta_data)
if user_meta_data.objInROIcnt: print("Objs in ROI: {0}".format(user_meta_data.objInROIcnt))
if user_meta_data.objLCCumCnt:
print("Linecrossing Cumulative: {0}".format(user_meta_data.objLCCumCnt))
user_meta_status= str(user_meta_data.objLCCumCnt)
if user_meta_data.objLCCurrCnt:
print("Linecrossing Current Frame: {0}".format(user_meta_data.objLCCurrCnt))
if user_meta_data.ocStatus: print("Overcrowding status: {0}".format(user_meta_data.ocStatus))
break
try:
l_user = l_user.next
break
#print(“Frame Number=”, frame_number, “stream id=”, frame_meta.pad_index, “Number of Objects=”,num_rects,“Vehicle_count=”,obj_counter[PGIE_CLASS_ID_VEHICLE],“CARS_count=”,obj_counter[PGIE_CLASS_ID_CARS])
print(“Frame Number=”, frame_number, “stream id=”, frame_meta.pad_index, “Number of Objects=”,num_rects,“CARS=”,obj_counter[PGIE_CLASS_ID_CARS])
# Get frame rate through this probe
fps_streams[“stream{0}”.format(frame_meta.pad_index)].get_fps()
#for displaying frames on OSD
display_meta=pyds.nvds_acquire_display_meta_from_pool(batch_meta)
display_meta.num_labels = 1
py_nvosd_text_params = display_meta.text_params[0]
# text = "{}|{}secs.".format('wrongly parked', str(np.round(time1,1)))
# py_nvosd_text_params.display_text = "Timer = {}".format(text)
py_nvosd_text_params.display_text = "Frame Number={} Parking Status:{} Count of Wrongly Parked Vehicles:{}".format(frame_number,vehicle_meta_status,counter)
py_nvosd_text_params.x_offset = 70;
py_nvosd_text_params.y_offset = 16;
py_nvosd_text_params.font_params.font_name = "Serif"
py_nvosd_text_params.font_params.font_size = 14
py_nvosd_text_params.font_params.font_color.red = 1.0
py_nvosd_text_params.font_params.font_color.green = 1.0
py_nvosd_text_params.font_params.font_color.blue = 1.0
py_nvosd_text_params.font_params.font_color.alpha = 1.0
py_nvosd_text_params.set_bg_clr = 1
py_nvosd_text_params.text_bg_clr.red = 0.0
py_nvosd_text_params.text_bg_clr.green = 0.0
py_nvosd_text_params.text_bg_clr.blue = 0.0
py_nvosd_text_params.text_bg_clr.alpha = 1.0
#print("============================DISPLAY META===========================",display_meta)
#for i in display_meta.items():
# print(i)
pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
#py_nvosd_text_params.display_text = "Frame Number={} Number of Objects={} Vehicle_count={} CARS_count={}". \
# format(frame_number, num_rects, obj_counter[PGIE_CLASS_ID_VEHICLE], obj_counter[PGIE_CLASS_ID_CARS])
try:
l_frame=l_frame.next
break
print("#"*50)
return Gst.PadProbeReturn.OK
def cb_newpad(decodebin, decoder_src_pad,data):
print(“In cb_newpad\n”)
caps=decoder_src_pad.get_current_caps()
gststruct=caps.get_structure(0)
gstname=gststruct.get_name()
source_bin=data
features=caps.get_features(0)
# Need to check if the pad created by the decodebin is for video and not
# audio.
print("gstname=",gstname)
if(gstname.find("video")!=-1):
# Link the decodebin pad only if decodebin has picked nvidia
# decoder plugin nvdec_*. We do this by checking if the pad caps contain
# NVMM memory features.
print("features=",features)
if features.contains("memory:NVMM"):
# Get the source bin ghost pad
bin_ghost_pad=source_bin.get_static_pad("src")
if not bin_ghost_pad.set_target(decoder_src_pad):
sys.stderr.write("Failed to link decoder src pad to source bin ghost pad\n")
else:
sys.stderr.write(" Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy,Object,name,user_data):
print(“Decodebin child added:”, name, “\n”)
if(name.find(“decodebin”) != -1):
Object.connect(“child-added”,decodebin_child_added,user_data)
if(is_aarch64() and name.find(“nvv4l2decoder”) != -1):
print(“Seting bufapi_version\n”)
Object.set_property(“bufapi-version”,True)
def create_source_bin(index,uri):
print(“Creating source bin”)
# Create a source GstBin to abstract this bin's content from the rest of the
# pipeline
bin_name="source-bin-%02d" %index
print(bin_name)
nbin=Gst.Bin.new(bin_name)
if not nbin:
sys.stderr.write(" Unable to create source bin \n")
# Source element for reading from the uri.
# We will use decodebin and let it figure out the container format of the
# stream and the codec and plug the appropriate demux and decode plugins.
uri_decode_bin=Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
if not uri_decode_bin:
sys.stderr.write(" Unable to create uri decode bin \n")
# We set the input uri to the source element
uri_decode_bin.set_property("uri",uri)
# Connect to the "pad-added" signal of the decodebin which generates a
# callback once a new pad for raw data has beed created by the decodebin
uri_decode_bin.connect("pad-added",cb_newpad,nbin)
uri_decode_bin.connect("child-added",decodebin_child_added,nbin)
# We need to create a ghost pad for the source bin which will act as a proxy
# for the video decoder src pad. The ghost pad will not have a target right
# now. Once the decode bin creates the video decoder and generates the
# cb_newpad callback, we will set the ghost pad target to the video decoder
# src pad.
Gst.Bin.add(nbin,uri_decode_bin)
bin_pad=nbin.add_pad(Gst.GhostPad.new_no_target("src",Gst.PadDirection.SRC))
if not bin_pad:
sys.stderr.write(" Failed to add ghost pad in source bin \n")
return None
return nbin
def main(args):
# Check input arguments
if len(args) < 2:
sys.stderr.write(“usage: %s [uri2] … [uriN]\n” % args[0])
sys.exit(1)
for i in range(0,len(args)-1):
fps_streams["stream{0}".format(i)]=GETFPS(i)
number_sources=len(args)-1
# Standard GStreamer initialization
GObject.threads_init()
Gst.init(None)
# Create gstreamer elements */
# Create Pipeline element that will form a connection of other elements
print("Creating Pipeline \n ")
pipeline = Gst.Pipeline()
is_live = False
if not pipeline:
sys.stderr.write(" Unable to create Pipeline \n")
print("Creating streamux \n ")
# Create nvstreammux instance to form batches from one or more sources.
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
if not streammux:
sys.stderr.write(" Unable to create NvStreamMux \n")
pipeline.add(streammux)
for i in range(number_sources):
print("Creating source_bin ",i," \n ")
uri_name=args[i+1]
if uri_name.find("rtsp://") == 0 :
is_live = True
source_bin=create_source_bin(i, uri_name)
if not source_bin:
sys.stderr.write("Unable to create source bin \n")
pipeline.add(source_bin)
padname="sink_%u" %i
sinkpad= streammux.get_request_pad(padname)
if not sinkpad:
sys.stderr.write("Unable to create sink pad bin \n")
srcpad=source_bin.get_static_pad("src")
if not srcpad:
sys.stderr.write("Unable to create src pad bin \n")
srcpad.link(sinkpad)
queue1=Gst.ElementFactory.make("queue","queue1")
queue2=Gst.ElementFactory.make("queue","queue2")
queue3=Gst.ElementFactory.make("queue","queue3")
queue4=Gst.ElementFactory.make("queue","queue4")
queue5=Gst.ElementFactory.make("queue","queue5")
queue6=Gst.ElementFactory.make("queue","queue6")
queue7=Gst.ElementFactory.make("queue","queue7")
pipeline.add(queue1)
pipeline.add(queue2)
pipeline.add(queue3)
pipeline.add(queue4)
pipeline.add(queue5)
pipeline.add(queue6)
pipeline.add(queue7)
print("Creating Pgie \n ")
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
if not pgie:
sys.stderr.write(" Unable to create pgie \n")
print("Creating nvtracker \n ")
tracker = Gst.ElementFactory.make("nvtracker", "tracker")
if not tracker:
sys.stderr.write(" Unable to create tracker \n")
print("Creating secondary detector \n ")
sgie3 = Gst.ElementFactory.make("nvinfer", "secondary3-nvinference-engine")
if not sgie3:
sys.stderr.write(" Unable to make sgie3 \n")
print("Creating nvdsanalytics \n ")
nvanalytics = Gst.ElementFactory.make("nvdsanalytics", "analytics")
if not nvanalytics:
sys.stderr.write(" Unable to create nvanalytics \n")
nvanalytics.set_property("config-file", "config_nvdsanalytics.txt")
print("Creating tiler \n ")
tiler=Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
if not tiler:
sys.stderr.write(" Unable to create tiler \n")
print("Creating nvvidconv \n ")
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
if not nvvidconv:
sys.stderr.write(" Unable to create nvvidconv \n")
print("Creating nvosd \n ")
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
if not nvosd:
sys.stderr.write(" Unable to create nvosd \n")
nvosd.set_property('process-mode',OSD_PROCESS_MODE)
nvosd.set_property('display-text',OSD_DISPLAY_TEXT)
#nvosd.set_property('display_text',0)
if(is_aarch64()):
print("Creating transform \n ")
transform=Gst.ElementFactory.make("nvegltransform", "nvegl-transform")
if not transform:
sys.stderr.write(" Unable to create transform \n")
# Create OSD to draw on the converted RGBA buffer
#nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
if not nvosd:
nvvidconv_postosd = Gst.ElementFactory.make("nvvideoconvert", "convertor_postosd")
if not nvvidconv_postosd:
sys.stderr.write(" Unable to create nvvidconv_postosd \n")
# Create a caps filter
caps = Gst.ElementFactory.make("capsfilter", "filter")
caps.set_property("caps", Gst.Caps.from_string("video/x-raw(memory:NVMM), format=I420"))
# Make the encoder
if codec == "H264":
encoder = Gst.ElementFactory.make("nvv4l2h264enc", "encoder")
print("Creating H264 Encoder")
elif codec == "H265":
encoder = Gst.ElementFactory.make("nvv4l2h265enc", "encoder")
print("Creating H265 Encoder")
if not encoder:
sys.stderr.write(" Unable to create encoder")
encoder.set_property('bitrate', bitrate)
if is_aarch64():
encoder.set_property('preset-level', 1)
encoder.set_property('insert-sps-pps', 1)
encoder.set_property('bufapi-version', 1)
# Make the payload-encode video into RTP packets
if codec == "H264":
rtppay = Gst.ElementFactory.make("rtph264pay", "rtppay")
print("Creating H264 rtppay")
rtppay = Gst.ElementFactory.make("rtph265pay", "rtppay")
print("Creating H265 rtppay")
if not rtppay:
sys.stderr.write(" Unable to create rtppay")
#print("Creating EGLSink \n")
#sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
#sink = Gst.ElementFactory.make("fakesink", "fakesink")
#if not sink:
# sys.stderr.write(" Unable to create egl sink \n")
# Make the UDP sink
updsink_port_num = 250
sink = Gst.ElementFactory.make("udpsink", "udpsink")
if not sink:
sys.stderr.write(" Unable to create udpsink")
sink.set_property('host', '224.224.255.255')
sink.set_property('port', updsink_port_num)
sink.set_property('async', False)
sink.set_property('sync', 1)
if is_live:
print("Atleast one of the sources is live")
streammux.set_property('live-source', 1)
streammux.set_property('width', 1920)
streammux.set_property('height', 1080)
streammux.set_property('batch-size', number_sources)
streammux.set_property('batched-push-timeout', 4000000)
#pgie.set_property('config-file-path', "dsnvanalytics_pgie_config.txt")
pgie.set_property('config-file-path', "dsnvanalytics_pgie_config_vehicle.txt")
####Set properties of sgie
sgie3.set_property('config-file-path', "dstest2_sgie3_config.txt")
pgie_batch_size=pgie.get_property("batch-size")
if(pgie_batch_size != number_sources):
print("WARNING: Overriding infer-config batch-size",pgie_batch_size," with number of sources ", number_sources," \n")
pgie.set_property("batch-size",number_sources)
tiler_rows=int(math.sqrt(number_sources))
tiler_columns=int(math.ceil((1.0*number_sources)/tiler_rows))
tiler.set_property("rows",tiler_rows)
tiler.set_property("columns",tiler_columns)
tiler.set_property("width", TILED_OUTPUT_WIDTH)
tiler.set_property("height", TILED_OUTPUT_HEIGHT)
sink.set_property("qos",0)
#Set properties of tracker
config = configparser.ConfigParser()
config.read('dsnvanalytics_tracker_config.txt')
config.sections()
for key in config['tracker']:
if key == 'tracker-width' :
tracker_width = config.getint('tracker', key)
tracker.set_property('tracker-width', tracker_width)
if key == 'tracker-height' :
tracker_height = config.getint('tracker', key)
tracker.set_property('tracker-height', tracker_height)
if key == 'gpu-id' :
tracker_gpu_id = config.getint('tracker', key)
tracker.set_property('gpu_id', tracker_gpu_id)
if key == 'll-lib-file' :
tracker_ll_lib_file = config.get('tracker', key)
tracker.set_property('ll-lib-file', tracker_ll_lib_file)
if key == 'll-config-file' :
tracker_ll_config_file = config.get('tracker', key)
tracker.set_property('ll-config-file', tracker_ll_config_file)
if key == 'enable-batch-process' :
tracker_enable_batch_process = config.getint('tracker', key)
tracker.set_property('enable_batch_process', tracker_enable_batch_process)
if key == 'enable-past-frame' :
tracker_enable_past_frame = config.getint('tracker', key)
tracker.set_property('enable_past_frame', tracker_enable_past_frame)
if key == 'display-tracking-id' :
tracker_display_tracking_id = config.getint('tracker', key)
tracker.set_property('display_tracking_id', tracker_display_tracking_id)
print("Adding elements to Pipeline \n")
pipeline.add(pgie)
pipeline.add(tracker)
pipeline.add(sgie3)
pipeline.add(nvanalytics)
pipeline.add(tiler)
pipeline.add(nvvidconv)
pipeline.add(nvosd)
pipeline.add(nvvidconv_postosd)
pipeline.add(caps)
pipeline.add(encoder)
pipeline.add(rtppay)
#if is_aarch64():
# pipeline.add(transform)
pipeline.add(sink)
print("Linking elements in the Pipeline \n")
streammux.link(pgie)
pgie.link(tracker)
tracker.link(sgie3)
sgie3.link(nvanalytics)
nvanalytics.link(tiler)
tiler.link(nvvidconv)
nvvidconv.link(nvosd)
nvosd.link(nvvidconv_postosd)
nvvidconv_postosd.link(caps)
caps.link(encoder)
encoder.link(rtppay)
rtppay.link(sink)
# We link elements in the following order:
# sourcebin -> streammux -> nvinfer -> nvtracker -> nvdsanalytics ->
# nvtiler -> nvvideoconvert -> nvdsosd -> sink
#print("Linking elements in the Pipeline \n")
#streammux.link(queue1)
queue1.link(pgie)
pgie.link(queue2)
queue2.link(tracker)
tracker.link(queue3)
queue3.link(nvanalytics)
nvanalytics.link(queue4)
queue4.link(tiler)
tiler.link(queue5)
queue5.link(nvvidconv)
nvvidconv.link(queue6)
queue6.link(nvosd)
if is_aarch64():
nvosd.link(queue7)
queue7.link(transform)
transform.link(sink)
else:
nvosd.link(queue7)
queue7.link(sink)
# create an event loop and feed gstreamer bus mesages to it
loop = GObject.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect ("message", bus_call, loop)
# Start streaming
rtsp_port_num = 8661
server = GstRtspServer.RTSPServer.new()
server.props.service = "%d" % rtsp_port_num
server.attach(None)
factory = GstRtspServer.RTSPMediaFactory.new()
factory.set_launch( "( udpsrc name=pay0 port=%d buffer-size=524288 caps=\"application/x-rtp, media=video, clock-rate=90000, encoding-name=(string)%s, payload=96 \" )" % (updsink_port_num, codec))
factory.set_shared(True)
server.get_mount_points().add_factory("/ds-test", factory)
print("\n *** DeepStream: Launched RTSP Streaming at rtsp://localhost:%d/ds-test ***\n\n" % rtsp_port_num)
nvanalytics_src_pad=nvanalytics.get_static_pad("src")
if not nvanalytics_src_pad:
sys.stderr.write(" Unable to get src pad \n")
else:
nvanalytics_src_pad.add_probe(Gst.PadProbeType.BUFFER, nvanalytics_src_pad_buffer_probe, 0)
# List the sources
print("Now playing...")
for i, source in enumerate(args):
if (i != 0):
print(i, ": ", source)
print("Starting pipeline \n")
# start play back and listed to events
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
# cleanup
print("Exiting app\n")
pipeline.set_state(Gst.State.NULL)
if name == ‘main’:
sys.exit(main(sys.argv))
Primary Config file:
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
tlt-model-key=tlt_encode
tlt-encoded-model=resnet18_trafficcamnet_pruned.etlt
input-dims=3;544;960;0
labelfile-path=label_vehicle.txt
force-implicit-batch-dim=1
batch-size=1
process-mode=1
model-color-format=0
network-mode=2
num-detected-classes=4
interval=0
gie-unique-id=1
uff-input-blob-name=input_1
output-blob-names=output_bbox/BiasAdd;output_cov/Sigmoid
0=Group Rectangles, 1=DBSCAN, 2=NMS, 3= DBSCAN+NMS Hybrid, 4 = None(No clustering)
cluster-mode=1
[class-attrs-all]
pre-cluster-threshold=0.35
eps=0.7
minBoxes=1
#Use the config params below for dbscan clustering mode
[class-attrs-all]
detected-min-w=4
detected-min-h=4
minBoxes=3
Per class configurations
[class-attrs-0]
eps=0.7
dbscan-min-score=0.95
[class-attrs-1]
pre-cluster-threshold=0.95
eps=0.7
dbscan-min-score=0.5
[class-attrs-2]
eps=0.6
[class-attrs-3]
eps=0.6
Secondary config file:
[property]
gpu-id=0
net-scale-factor=1
model-file=…/…/…/…/samples/models/Secondary_VehicleTypes/resnet18.caffemodel
proto-file=…/…/…/…/samples/models/Secondary_VehicleTypes/resnet18.prototxt
model-engine-file=…/…/…/…/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
mean-file=…/…/…/…/samples/models/Secondary_VehicleTypes/mean.ppm
labelfile-path=…/…/…/…/samples/models/Secondary_VehicleTypes/labels.txt
int8-calib-file=…/…/…/…/samples/models/Secondary_VehicleTypes/cal_trt.bin
batch-size=16
0=FP32 and 1=INT8 mode
network-mode=1
input-object-min-width=64
input-object-min-height=64
model-color-format=1
process-mode=2
gpu-id=0
gie-unique-id=4
operate-on-gie-id=1
operate-on-class-ids=0
is-classifier=1
output-blob-names=predictions/Softmax
classifier-async-mode=1
classifier-threshold=0.51
process-mode=2
#scaling-filter=0
#scaling-compute-hw=0
