**• Hardware Platform (Jetson / GPU) RTX2070
**• DeepStream Version5.1
**• JetPack Version (valid for Jetson only)None
**• TensorRT Version7.2.2
**• NVIDIA GPU Driver Version (valid for GPU only)470
I build an app based deepstream-test2. It follow some steps: detect personal face → classify emotion.
The application always report an error when it enable tracker. If i disable tracker, there is not this problem. I can’t find what occur this issue. Please help me to slove this issue.
Enable tracker code :
Disable tracker code:
Tha application error appearance:
I try set second gie config parameter:
[property]
gpu-id=0
net-scale-factor=1
# model-file=../../../../samples/models/Secondary_CarColor/resnet18.caffemodel
# proto-file=../../../../samples/models/Secondary_CarColor/resnet18.prototxt
# model-engine-file=../../../../samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
# mean-file=../../../../samples/models/Secondary_CarColor/mean.ppm
# labelfile-path=../../../../samples/models/Secondary_CarColor/labels.txt
# int8-calib-file=../../../../samples/models/Secondary_CarColor/cal_trt.bin
model-engine-file=./models/EmotionNet/emotion-ferplus-8.engine
labelfile-path=./models/EmotionNet/labels.txt
force-implicit-batch-dim=1
batch-size=1
# 0=FP32 and 1=INT8 mode
network-mode=1
input-object-min-width=64
input-object-min-height=64
process-mode=2
model-color-format=2
gpu-id=0
gie-unique-id=2
operate-on-gie-id=1
operate-on-class-ids=0
classifier-async-mode=0
classifier-threshold=0.51
process-mode=2
secondary-reinfer-interval=0
num-detected-classes=8
network-type=1
output-tensor-meta=1
model information:
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x416x736
1 OUTPUT kFLOAT output_bbox/BiasAdd 4x26x46
2 OUTPUT kFLOAT output_cov/Sigmoid 1x26x46
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT Input3 1x64x64
1 OUTPUT kFLOAT Plus692_Output_0 8
deepstream_mytest.py (17.7 KB)
my_sgie1_config.txt (3.7 KB)
my_tracker_config.txt (1.8 KB)
myconfig.txt (4.0 KB)
tracker_config.yml (6.6 KB)
Can you enable debug message with “export GST_DEBUG=3” to get more log?
error log:
0:00:01.452936693 168915 0x21610d0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1806> [UID = 2]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.1/sources/python/apps/deepstream-mytest/models/EmotionNet/emotion-ferplus-8.engine
0:00:01.453471087 168915 0x21610d0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary1-nvinference-engine> [UID 2]: Load new model:my_sgie1_config.txt sucessfully
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvdcf.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is ON
[NvDCF] Initialized
0:00:01.702376624 168915 0x21610d0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1702> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.1/sources/python/apps/deepstream-mytest/models/FaceDetect/model.etlt_b16_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0:00:01.702443770 168915 0x21610d0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1806> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.1/sources/python/apps/deepstream-mytest/models/FaceDetect/model.etlt_b16_gpu0_int8.engine
0:00:01.704260494 168915 0x21610d0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:myconfig.txt sucessfully
0:00:01.704852506 168915 0x21610d0 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source> pad not activated yet
Decodebin child added: source
Decodebin child added: decodebin0
0:00:01.705638193 168915 0x21610d0 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source> pad not activated yet
Decodebin child added: qtdemux0
0:00:01.712004546 168915 0x7efe54070230 WARN qtdemux qtdemux_types.c:233:qtdemux_type_get: unknown QuickTime node type pasp
0:00:01.712039462 168915 0x7efe54070230 WARN qtdemux qtdemux_types.c:233:qtdemux_type_get: unknown QuickTime node type sgpd
0:00:01.712052917 168915 0x7efe54070230 WARN qtdemux qtdemux_types.c:233:qtdemux_type_get: unknown QuickTime node type sbgp
0:00:01.712079838 168915 0x7efe54070230 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 1
0:00:01.712156311 168915 0x7efe54070230 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 2
Decodebin child added: multiqueue0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: aacparse0
Decodebin child added: avdec_aac0
Decodebin child added: nvv4l2decoder0
0:00:01.732756964 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.732786860 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MJPG
0:00:01.732803681 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.732834980 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MJPG
0:00:01.733014708 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.733044233 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MPG4
0:00:01.733055174 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.733112191 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MPG4
0:00:01.733196119 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.733253206 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MPG2
0:00:01.733433565 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.733580661 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MPG2
0:00:01.733631196 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.733733318 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat H265
0:00:01.733833066 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.733912555 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat H265
0:00:01.733992946 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.734087824 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat VP90
0:00:01.734114975 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.734207209 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat VP90
0:00:01.734279986 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.734338996 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat VP80
0:00:01.734399540 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.734468109 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat VP80
0:00:01.734547799 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.734592152 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat H264
0:00:01.734605297 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:01.734683925 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat H264
0:00:01.735103263 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
0:00:01.735114033 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe minimum capture size for pixelformat NM12
0:00:01.735127869 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
0:00:01.735133760 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe maximum capture size for pixelformat NM12
0:00:01.735141174 168915 0x7efe5803ce80 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7efe4c0194e0 Failed to determine interlace mode
0:00:01.845143239 168915 0x7efe5803ce80 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.845182723 168915 0x7efe5803ce80 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.845217598 168915 0x7efe5803ce80 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.845224612 168915 0x7efe5803ce80 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.845253436 168915 0x7efe5803ce80 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.845260659 168915 0x7efe5803ce80 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.845286899 168915 0x7efe5803ce80 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.845294904 168915 0x7efe5803ce80 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.845316604 168915 0x7efe5803ce80 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.845322796 168915 0x7efe5803ce80 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.845344497 168915 0x7efe5803ce80 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.845350338 168915 0x7efe5803ce80 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.845375275 168915 0x7efe5803ce80 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.845382528 168915 0x7efe5803ce80 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.845421522 168915 0x7efe5803ce80 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:01.845429066 168915 0x7efe5803ce80 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
In cb_newpad
In cb_newpad
0:00:01.986123895 168915 0x7efe5803ce80 WARN v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder0> Duration invalid, not setting latency
0:00:01.986327477 168915 0x7efe5803ce80 WARN v4l2bufferpool gstv4l2bufferpool.c:1066:gst_v4l2_buffer_pool_start:<nvv4l2decoder0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:01.986943785 168915 0x7efe4c31de30 WARN v4l2bufferpool gstv4l2bufferpool.c:1513:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:src> Driver should never set v4l2_buffer.field to ANY
