Hello!
I have just started to learn deep stream. because I have a problem, please help me:
dstest1_pgie_config.txt:
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-file=../../../../samples/models/Primary_Detector/resnet10.caffemodel
proto-file=../../../../samples/models/Primary_Detector/resnet10.prototxt
model-engine-file=../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
labelfile-path=../../../../samples/models/Primary_Detector/labels.txt
int8-calib-file=../../../../samples/models/Primary_Detector/cal_trt.bin
force-implicit-batch-dim=1
batch-size=1
network-mode=1
num-detected-classes=4
interval=0
gie-unique-id=1
output-blob-names=conv2d_bbox;conv2d_cov/Sigmoid
#scaling-filter=0
#scaling-compute-hw=0
cluster-mode=2
[class-attrs-all]
pre-cluster-threshold=0.2
topk=20
nms-iou-threshold=0.5
After I execute the following command:
sudo ./deepstream-test1-app /opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.h264
Output:
pp:2113:gst_nvinfer_submit_input_buffer:<secondary1-nvinference-engine> error: streaming stopped, reason not-negotiated (-4)
ERROR from element secondary3-nvinference-engine: Internal data stream error.
Error details: gstnvinfer.cpp(2113): gst_nvinfer_submit_input_buffer (): /GstPipeline:dstest2-pipeline/GstNvInfer:secondary3-nvinference-engine:
Frame Number = 1 Number of objects = 0 Vehicle Count = 0 Person Count = 0
Returned, stopping playback
Frame Number = 2 Number of objects = 0 Vehicle Count = 0 Person Count = 0
Frame Number = 3 Number of objects = 7 Vehicle Count = 5 Person Count = 2
Frame Number = 4 Number of objects = 7 Vehicle Count = 5 Person Count = 2
So I found the problem on forums, The solution is as follows:
in “deepstream_test1_app.c”:
sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
Modified as:
sink = gst_element_factory_make ("fakesink", "nvvideo-renderer");
make and execute:
output:
ubuntu@os:/opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-test1$ sudo ./deepstream-test1-app /opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.h264
Now playing: /opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.h264
WARNING: [TRT]: CUDA lazy loading is not enabled. Enabling it can significantly reduce device memory usage. See `CUDA_MODULE_LOADING` in https://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#env-vars
0:00:01.731719980 9800 0x558b14aefc10 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:01.787689689 9800 0x558b14aefc10 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:00:01.788619521 9800 0x558b14aefc10 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
Running...
Frame Number = 0 Number of objects = 13 Vehicle Count = 9 Person Count = 4
Frame Number = 1 Number of objects = 11 Vehicle Count = 8 Person Count = 3
Frame Number = 2 Number of objects = 11 Vehicle Count = 7 Person Count = 4
Frame Number = 3 Number of objects = 11 Vehicle Count = 7 Person Count = 4
Frame Number = 1438 Number of objects = 15 Vehicle Count = 14 Person Count = 1
Frame Number = 1439 Number of objects = 14 Vehicle Count = 12 Person Count = 2
Frame Number = 1440 Number of objects = 14 Vehicle Count = 13 Person Count = 1
Frame Number = 1441 Number of objects = 0 Vehicle Count = 0 Person Count = 0
End of stream
Deleting pipeline
According to my understanding, a video should be displayed after execution, but I haven’t seen the video with cases displayed. Is there a problem? If it is not a problem, where is the output (path)?
Please help me!
yingliu
December 2, 2022, 10:50am
2
You may add “GST_DEBUG=3” before ./deepstream-test-app to display more logs.
• DeepStream Version
• TensorRT Version
• The pipeline being used
Version information:
ubuntu@os:~$ deepstream-app --version-all
deepstream-app version 6.0.1
DeepStreamSDK 6.0.1
CUDA Driver Version: 11.6
CUDA Runtime Version: 11.4
TensorRT Version: 8.5
cuDNN Version: 8.2
libNVWarp360 Version: 2.0.1d3
Gpu model:GeForce RTX3070 Laptop GPU
Driver Version: NVIDIA-SMI 510.85.02 Driver Version: 510.85.02
Hardware Platform:Notebook computer (Os version: ubuntu18.04)
I added “GST_DEBUG=3” and executed it. I did not get any useful information. Please help me analyze:
ubuntu@os:/opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-test1$ sudo GST_DEBUG=3 ./deepstream-test1-app /opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.h264
0:00:00.173694910 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.173710799 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat MJPG
0:00:00.173713657 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.173716082 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat MJPG
0:00:00.173727867 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.173730234 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat MPG4
0:00:00.173734945 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.173737152 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat MPG4
0:00:00.173742755 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.173745146 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat MPG2
0:00:00.173747138 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.173749281 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat MPG2
0:00:00.173755372 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.173757744 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat H265
0:00:00.173760918 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.173763003 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat H265
0:00:00.173767483 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.173769758 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat VP90
0:00:00.173772192 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.173774786 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat VP90
0:00:00.173778948 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.173781881 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat VP80
0:00:00.173786309 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.173789372 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat VP80
0:00:00.173794605 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.173797539 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe minimum capture size for pixelformat H264
0:00:00.173799837 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:sink> Unable to try format: Unknown error -1
0:00:00.173802851 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:sink> Could not probe maximum capture size for pixelformat H264
0:00:00.174019420 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:src> Unable to try format: Unknown error -1
0:00:00.174023129 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:src> Could not probe minimum capture size for pixelformat NM12
0:00:00.174025585 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder:src> Unable to try format: Unknown error -1
0:00:00.174027886 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder:src> Could not probe maximum capture size for pixelformat NM12
0:00:00.174032465 13690 0x55a407968070 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x55a406f7ba70 Failed to determine interlace mode
0:00:02.140549450 13690 0x55a407968070 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:00:02.197578930 13690 0x55a407968070 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:00:02.198721262 13690 0x55a407968070 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
0:00:02.198908785 13690 0x55a407968070 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<file-source> pad not activated yet
Running...
0:00:02.309717620 13690 0x55a406f63590 WARN v4l2videodec gstv4l2videodec.c:1685:gst_v4l2_video_dec_decide_allocation:<nvv4l2-decoder> Duration invalid, not setting latency
0:00:02.309744099 13690 0x55a406f63590 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:<nvv4l2-decoder:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:02.310355289 13690 0x7f6f30003230 WARN v4l2bufferpool gstv4l2bufferpool.c:1512:gst_v4l2_buffer_pool_dqbuf:<nvv4l2-decoder:pool:src> Driver should never set v4l2_buffer.field to ANY
Frame Number = 4 Number of objects = 11 Vehicle Count = 8 Person Count = 3
Frame Number = 5 Number of objects = 12 Vehicle Count = 8 Person Count = 4
Frame Number = 6 Number of objects = 11 Vehicle Count = 7 Person Count = 4
Frame Number = 7 Number of objects = 11 Vehicle Count = 7 Person Count = 4
End of stream
Please refer below guide for installation, your driver and CUDA versions are news than DeepStream 6.0.1 required version, you may follow the guide to re-install.
Quickstart Guide — DeepStream 6.0.1 Release documentation (nvidia.com)
Besides, you can also considering install deepstream docker on your laptop: GitHub - NVIDIA/nvidia-docker: Build and run Docker containers leveraging NVIDIA GPUs
