**• Hardware Platform (Jetson / GPU)**GPU
• DeepStream Version7.1
• TensorRT Version10.3
**• NVIDIA GPU Driver Version (valid for GPU only)**Driver Version: 572.16
The deepstream pipeline is perfectly working on file sources and RTSP live streams, but somehow this is not working on RTMP stream url.
I debug the stream using this command and its working fine:
root@AAM-LAPTOP-027:/opt/nvidia/deepstream/deepstream-7.1/sources/deepstream_python_apps/Backup_Deepstream_Gaze_Prediction# gst-launch-1.0 rtmpsrc location=rtmp://173.208.156.155:1935/live/test ! fakesink
Setting pipeline to PAUSED …
Pipeline is PREROLLING …
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
Redistribute latency…
New clock: GstSystemClock
0:08:02.9 / 99:99:99. -
and when i try to run it in the deepstream pipeline here with this command here:
root@AAM-LAPTOP-027:/opt/nvidia/deepstream/deepstream-7.1/sources/deepstream_python_apps/Backup_Deepstream_Gaze_Prediction# python3 deepstream.py --source rtmp://173.208.156.155:1935/live/test --config-infer-pgie config_infer_primary_yoloV8_face.txt --config-infer-sgie-emotion emotion_classifier_sgie_config.txt --config-infer-sgie-gaze config_infer_secondary_gaze.txt
- the output logs:
DEBUG: Pipeline set to PLAYING
Pipeline started…
DEBUG: Source set to rtmp://173.208.156.155:1935/live/test
DEBUG: PGIE Config File: config_infer_primary_yoloV8_face.txt
DEBUG: SGIE Emotion Config File: emotion_classifier_sgie_config.txt
DEBUG: SGIE Gaze Config File: config_infer_secondary_gaze.txt
DEBUG: StreamMux Batch Size: 1
DEBUG: StreamMux Width: 1920
DEBUG: StreamMux Height: 1080
DEBUG: GPU ID: 0
DEBUG: FPS Measurement Interval: 5 sec
/opt/nvidia/deepstream/deepstream-7.1/sources/deepstream_python_apps/Backup_Deepstream_Gaze_Prediction/deepstream.py:200: DeprecationWarning: Gst.Element.get_request_pad is deprecated
streammux_sink_pad = streammux.get_request_pad(pad_name)
DEBUG: Created uridecodebin for stream 0
Failed to query video capabilities: Inappropriate ioctl for device
0:00:00.094416971 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder-rtsp:sink Unable to try format: Unknown error -1
0:00:00.094448531 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2993:gst_v4l2_object_probe_caps_for_format:encoder-rtsp:sink Could not probe minimum capture size for pixelformat YM12
0:00:00.094452792 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder-rtsp:sink Unable to try format: Unknown error -1
0:00:00.094456264 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2999:gst_v4l2_object_probe_caps_for_format:encoder-rtsp:sink Could not probe maximum capture size for pixelformat YM12
0:00:00.094462921 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder-rtsp:sink Unable to try format: Unknown error -1
0:00:00.094465951 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2993:gst_v4l2_object_probe_caps_for_format:encoder-rtsp:sink Could not probe minimum capture size for pixelformat Y444
0:00:00.094468022 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder-rtsp:sink Unable to try format: Unknown error -1
0:00:00.094470772 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2999:gst_v4l2_object_probe_caps_for_format:encoder-rtsp:sink Could not probe maximum capture size for pixelformat Y444
0:00:00.094476219 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder-rtsp:sink Unable to try format: Unknown error -1
0:00:00.094479463 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2993:gst_v4l2_object_probe_caps_for_format:encoder-rtsp:sink Could not probe minimum capture size for pixelformat P410
0:00:00.094481805 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder-rtsp:sink Unable to try format: Unknown error -1
0:00:00.094484820 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2999:gst_v4l2_object_probe_caps_for_format:encoder-rtsp:sink Could not probe maximum capture size for pixelformat P410
0:00:00.094490804 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder-rtsp:sink Unable to try format: Unknown error -1
0:00:00.094493701 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2993:gst_v4l2_object_probe_caps_for_format:encoder-rtsp:sink Could not probe minimum capture size for pixelformat PM10
0:00:00.094496010 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder-rtsp:sink Unable to try format: Unknown error -1
0:00:00.094498932 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2999:gst_v4l2_object_probe_caps_for_format:encoder-rtsp:sink Could not probe maximum capture size for pixelformat PM10
0:00:00.094503196 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder-rtsp:sink Unable to try format: Unknown error -1
0:00:00.094506349 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2993:gst_v4l2_object_probe_caps_for_format:encoder-rtsp:sink Could not probe minimum capture size for pixelformat NM12
0:00:00.094508428 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder-rtsp:sink Unable to try format: Unknown error -1
0:00:00.094510862 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2999:gst_v4l2_object_probe_caps_for_format:encoder-rtsp:sink Could not probe maximum capture size for pixelformat NM12
0:00:00.094536318 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder-rtsp:src Unable to try format: Unknown error -1
0:00:00.094539622 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2993:gst_v4l2_object_probe_caps_for_format:encoder-rtsp:src Could not probe minimum capture size for pixelformat H264
0:00:00.094542139 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder-rtsp:src Unable to try format: Unknown error -1
0:00:00.094545333 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2999:gst_v4l2_object_probe_caps_for_format:encoder-rtsp:src Could not probe maximum capture size for pixelformat H264
0:00:00.094855300 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder:sink Unable to try format: Unknown error -1
0:00:00.094877011 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2993:gst_v4l2_object_probe_caps_for_format:encoder:sink Could not probe minimum capture size for pixelformat YM12
0:00:00.094881295 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder:sink Unable to try format: Unknown error -1
0:00:00.094884457 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2999:gst_v4l2_object_probe_caps_for_format:encoder:sink Could not probe maximum capture size for pixelformat YM12
0:00:00.094908816 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder:sink Unable to try format: Unknown error -1
0:00:00.094922402 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2993:gst_v4l2_object_probe_caps_for_format:encoder:sink Could not probe minimum capture size for pixelformat Y444
0:00:00.094926871 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder:sink Unable to try format: Unknown error -1
0:00:00.094930334 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2999:gst_v4l2_object_probe_caps_for_format:encoder:sink Could not probe maximum capture size for pixelformat Y444
0:00:00.094938329 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder:sink Unable to try format: Unknown error -1
0:00:00.094941345 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2993:gst_v4l2_object_probe_caps_for_format:encoder:sink Could not probe minimum capture size for pixelformat P410
0:00:00.094943784 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder:sink Unable to try format: Unknown error -1
0:00:00.094946655 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2999:gst_v4l2_object_probe_caps_for_format:encoder:sink Could not probe maximum capture size for pixelformat P410
0:00:00.094951881 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder:sink Unable to try format: Unknown error -1
0:00:00.094954856 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2993:gst_v4l2_object_probe_caps_for_format:encoder:sink Could not probe minimum capture size for pixelformat PM10
0:00:00.094957078 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder:sink Unable to try format: Unknown error -1
0:00:00.094959686 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2999:gst_v4l2_object_probe_caps_for_format:encoder:sink Could not probe maximum capture size for pixelformat PM10
0:00:00.094964363 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder:sink Unable to try format: Unknown error -1
0:00:00.094967345 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2993:gst_v4l2_object_probe_caps_for_format:encoder:sink Could not probe minimum capture size for pixelformat NM12
0:00:00.094969621 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder:sink Unable to try format: Unknown error -1
0:00:00.094972398 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2999:gst_v4l2_object_probe_caps_for_format:encoder:sink Could not probe maximum capture size for pixelformat NM12
0:00:00.094999953 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder:src Unable to try format: Unknown error -1
0:00:00.095003676 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2993:gst_v4l2_object_probe_caps_for_format:encoder:src Could not probe minimum capture size for pixelformat H264
0:00:00.095006283 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:3108:gst_v4l2_object_get_nearest_size:encoder:src Unable to try format: Unknown error -1
0:00:00.095009287 638 0x55fb59fc48e0 WARN v4l2 gstv4l2object.c:2999:gst_v4l2_object_probe_caps_for_format:encoder:src Could not probe maximum capture size for pixelformat H264
0:00:00.237208177 638 0x55fb59fc48e0 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger: NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 3]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-7.1/sources/deepstream_python_apps/Backup_Deepstream_Gaze_Prediction/gaze_estimation.onnx_b1_gpu0_fp16.engine
Implicit layer support has been deprecated
INFO: [Implicit Engine Info]: layers num: 0
0:00:00.237282096 638 0x55fb59fc48e0 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger: NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 3]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-7.1/sources/deepstream_python_apps/Backup_Deepstream_Gaze_Prediction/gaze_estimation.onnx_b1_gpu0_fp16.engine
0:00:00.249474415 638 0x55fb59fc48e0 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus: [UID 3]: Load new model:config_infer_secondary_gaze.txt sucessfully
0:00:00.253930802 638 0x55fb59fc48e0 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger: NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 2]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-7.1/sources/deepstream_python_apps/Backup_Deepstream_Gaze_Prediction/emotion_classifier_transposed.onnx_b1_gpu0_fp16.engine
0:00:00.253991939 638 0x55fb59fc48e0 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger: NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 2]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-7.1/sources/deepstream_python_apps/Backup_Deepstream_Gaze_Prediction/emotion_classifier_transposed.onnx_b1_gpu0_fp16.engine
0:00:00.255380110 638 0x55fb59fc48e0 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus: [UID 2]: Load new model:emotion_classifier_sgie_config.txt sucessfully
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
[NvMultiObjectTracker] Initialized
0:00:00.299675408 638 0x55fb59fc48e0 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-7.1/sources/deepstream_python_apps/Backup_Deepstream_Gaze_Prediction/yolov8n-face.onnx_b1_gpu0_fp32.engine
0:00:00.299742700 638 0x55fb59fc48e0 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-7.1/sources/deepstream_python_apps/Backup_Deepstream_Gaze_Prediction/yolov8n-face.onnx_b1_gpu0_fp32.engine
0:00:00.302419237 638 0x55fb59fc48e0 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus: [UID 1]: Load new model:config_infer_primary_yoloV8_face.txt sucessfully
Pipeline started…
0:00:01.830544466 638 0x7f55dc001e80 FIXME rtmpconnection rtmpconnection.c:869:gst_rtmp_connection_handle_protocol_control:GstRtmpConnection@0x7f5590011100 set peer bandwidth: 5000000, 2
0:00:02.871027582 638 0x7f55dc002b70 WARN uridecodebin gsturidecodebin.c:960:unknown_type_cb: warning: No decoder available for type ‘audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, rate=(int)44100, channels=(int)2, codec_data=(buffer)1210, level=(string)2, base-profile=(string)lc, profile=(string)lc’.
WARNING: gst-stream-error-quark: No decoder available for type ‘audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, rate=(int)44100, channels=(int)2, codec_data=(buffer)1210, level=(string)2, base-profile=(string)lc, profile=(string)lc’. (6): …/gst/playback/gsturidecodebin.c(960): unknown_type_cb (): /GstPipeline:deepstream-combined-pipeline/GstURIDecodeBin:source-bin-0000
0:00:03.163165991 638 0x7f55dc0022d0 WARN basesrc gstbasesrc.c:3127:gst_base_src_loop:
0:00:03.163228065 638 0x7f55dc0022d0 WARN basesrc gstbasesrc.c:3127:gst_base_src_loop:
ERROR: gst-stream-error-quark: Internal data stream error. (1): …/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:deepstream-combined-pipeline/GstURIDecodeBin:source-bin-0000/GstRtmp2Src:source:
streaming stopped, reason not-linked (-1)
DEBUG: EOS sent, waiting for finalization…
- here is the pipeline code:
deepstream.txt (40.4 KB)
- i would really appreciate you to kindly help me out why this is not working with RTMP streams and how can we make it work with them.
Thanks in advance.
