when I used GST_DEBUG=2 to run the app, I found the error “Driver bug detected” from nvv4l2decoder element.
0:01:13.764587826 560 0x767f34a0 WARN v4l2 gstv4l2object.c:3033:gst_v4l2_object_get_nearest_size:<nvv4l2decoder21:sink> Unable to try format: Unknown error -1
0:01:13.764633789 560 0x767f34a0 WARN v4l2 gstv4l2object.c:2919:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder21:sink> Could not probe minimum capture size for pixelformat MJPG
0:01:13.764652435 560 0x767f34a0 WARN v4l2 gstv4l2object.c:3033:gst_v4l2_object_get_nearest_size:<nvv4l2decoder21:sink> Unable to try format: Unknown error -1
0:01:13.764668217 560 0x767f34a0 WARN v4l2 gstv4l2object.c:2925:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder21:sink> Could not probe maximum capture size for pixelformat MJPG
0:01:13.764699651 560 0x767f34a0 WARN v4l2 gstv4l2object.c:3033:gst_v4l2_object_get_nearest_size:<nvv4l2decoder21:sink> Unable to try format: Unknown error -1
0:01:13.764714086 560 0x767f34a0 WARN v4l2 gstv4l2object.c:2919:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder21:sink> Could not probe minimum capture size for pixelformat H265
0:01:13.764738560 560 0x767f34a0 WARN v4l2 gstv4l2object.c:3033:gst_v4l2_object_get_nearest_size:<nvv4l2decoder21:sink> Unable to try format: Unknown error -1
0:01:13.764752217 560 0x767f34a0 WARN v4l2 gstv4l2object.c:2925:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder21:sink> Could not probe maximum capture size for pixelformat H265
0:01:13.764780629 560 0x767f34a0 WARN v4l2 gstv4l2object.c:3033:gst_v4l2_object_get_nearest_size:<nvv4l2decoder21:sink> Unable to try format: Unknown error -1
0:01:13.764794620 560 0x767f34a0 WARN v4l2 gstv4l2object.c:2919:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder21:sink> Could not probe minimum capture size for pixelformat H264
0:01:13.764807237 560 0x767f34a0 WARN v4l2 gstv4l2object.c:3033:gst_v4l2_object_get_nearest_size:<nvv4l2decoder21:sink> Unable to try format: Unknown error -1
0:01:13.764820266 560 0x767f34a0 WARN v4l2 gstv4l2object.c:2925:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder21:sink> Could not probe maximum capture size for pixelformat H264
0:01:13.764867444 560 0x767f34a0 WARN v4l2 gstv4l2object.c:3033:gst_v4l2_object_get_nearest_size:<nvv4l2decoder21:src> Unable to try format: Unknown error -1
0:01:13.764885929 560 0x767f34a0 WARN v4l2 gstv4l2object.c:2919:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder21:src> Could not probe minimum capture size for pixelformat NM12
0:01:13.764898661 560 0x767f34a0 WARN v4l2 gstv4l2object.c:3033:gst_v4l2_object_get_nearest_size:<nvv4l2decoder21:src> Unable to try format: Unknown error -1
0:01:13.764912241 560 0x767f34a0 WARN v4l2 gstv4l2object.c:2925:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder21:src> Could not probe maximum capture size for pixelformat NM12
0:01:13.764931329 560 0x767f34a0 WARN v4l2 gstv4l2object.c:2370:gst_v4l2_object_add_interlace_mode:0x7f564406bb90 Failed to determine interlace mode
0:01:13.876598501 560 0x767f34a0 ERROR v4l2 gstv4l2object.c:2072:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:01:13.876645100 560 0x767f34a0 ERROR v4l2 gstv4l2object.c:2072:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:01:13.876712169 560 0x767f34a0 ERROR v4l2 gstv4l2object.c:2072:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:01:13.876730975 560 0x767f34a0 ERROR v4l2 gstv4l2object.c:2072:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:01:13.876797401 560 0x767f34a0 ERROR v4l2 gstv4l2object.c:2072:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:01:13.876814256 560 0x767f34a0 ERROR v4l2 gstv4l2object.c:2072:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:01:13.876866556 560 0x767f34a0 ERROR v4l2 gstv4l2object.c:2072:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:01:13.876885045 560 0x767f34a0 ERROR v4l2 gstv4l2object.c:2072:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:01:13.876939969 560 0x767f34a0 ERROR v4l2 gstv4l2object.c:2072:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:01:13.876956956 560 0x767f34a0 ERROR v4l2 gstv4l2object.c:2072:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
We don’t observe the issue in playing this video. Probably it is specific to certain video files? If yes, please share the video file.
It also occur with
GST_DEBUG=3 deepstream-app -c deepstream-app/source30_1080p_dec_infer-resnet_tiled_display_int8.txt
In 1080Ti with driver version 418.87.00
Please check if you set up the environment correctly:
[url]NVIDIA DeepStream SDK Developer Guide — DeepStream 6.1.1 Release documentation
It shoudle be something wrong in the environment if you cannot run the sample config file. We have verified all sample config files before releasing DS4.0.1.
I have check the environment, and update the driver to 440.31, but not help at all.
And we checked with DS4.0 and not DS4.0.1
We have tried some examples:
GST_DEBUG=3 gst-launch-1.0 filesrc location=sample_1080p_h264.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! nvvideoconvert ! fakesink
GST_DEBUG=3 gst-launch-1.0 filesrc location=sample_1080p_h264.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! nvvideoconvert ! nveglglessink
GST_DEBUG=3 gst-launch-1.0 filesrc location=sample_1080p_h264.mp4 ! qtdemux ! h264parse ! avdec_h264 ! nvvideoconvert ! fakesink
GST_DEBUG=3 gst-launch-1.0 filesrc location=sample_1080p_h264.mp4 ! qtdemux ! h264parse ! avdec_h264 ! nvvideoconvert ! nveglglessink
1 and 2 (use nvv4l2decoder ) would happen error, 3 and 4 (use avdec_h264 ) would not happen.
0:00:00.029577362 5544 0x55a9a014d190 WARN v4l2 gstv4l2object.c:3033:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: unknow error -1
0:00:00.029590533 5544 0x55a9a014d190 WARN v4l2 gstv4l2object.c:2919:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MJPG
0:00:00.029595662 5544 0x55a9a014d190 WARN v4l2 gstv4l2object.c:3033:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: -1
0:00:00.029599454 5544 0x55a9a014d190 WARN v4l2 gstv4l2object.c:2925:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MJPG
0:00:00.029609091 5544 0x55a9a014d190 WARN v4l2 gstv4l2object.c:3033:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: -1
0:00:00.029612790 5544 0x55a9a014d190 WARN v4l2 gstv4l2object.c:2919:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat H265
0:00:00.029617654 5544 0x55a9a014d190 WARN v4l2 gstv4l2object.c:3033:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: -1
0:00:00.029623207 5544 0x55a9a014d190 WARN v4l2 gstv4l2object.c:2925:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat H265
0:00:00.029632108 5544 0x55a9a014d190 WARN v4l2 gstv4l2object.c:3033:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: -1
0:00:00.029635830 5544 0x55a9a014d190 WARN v4l2 gstv4l2object.c:2919:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat H264
0:00:00.029639036 5544 0x55a9a014d190 WARN v4l2 gstv4l2object.c:3033:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: -1
0:00:00.029642387 5544 0x55a9a014d190 WARN v4l2 gstv4l2object.c:2925:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat H264
0:00:00.029860092 5544 0x55a9a014d190 WARN v4l2 gstv4l2object.c:3033:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: -1
0:00:00.029865883 5544 0x55a9a014d190 WARN v4l2 gstv4l2object.c:2919:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe minimum capture size for pixelformat NM12
0:00:00.029869363 5544 0x55a9a014d190 WARN v4l2 gstv4l2object.c:3033:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: -1
0:00:00.029872869 5544 0x55a9a014d190 WARN v4l2 gstv4l2object.c:2925:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe maximum capture size for pixelformat NM12
0:00:00.029878875 5544 0x55a9a014d190 WARN v4l2 gstv4l2object.c:2370:gst_v4l2_object_add_interlace_mode:0x55a9a00b9770 Failed to determine interlace mode
0:00:00.030047139 5544 0x55a9a014d190 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<filesrc0> pad not activated yet
pipeline is PREROLLING ...
0:00:00.030221338 5544 0x55a9a0091e80 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 1
0:00:00.030286381 5544 0x55a9a0091e80 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 2
0:00:00.179700517 5544 0x55a9a0091e80 ERROR v4l2 gstv4l2object.c:2072:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.179761673 5544 0x55a9a0091e80 ERROR v4l2 gstv4l2object.c:2072:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.179871413 5544 0x55a9a0091e80 ERROR v4l2 gstv4l2object.c:2072:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.179916605 5544 0x55a9a0091e80 ERROR v4l2 gstv4l2object.c:2072:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.180035308 5544 0x55a9a0091e80 ERROR v4l2 gstv4l2object.c:2072:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.180068336 5544 0x55a9a0091e80 ERROR v4l2 gstv4l2object.c:2072:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.180143997 5544 0x55a9a0091e80 ERROR v4l2 gstv4l2object.c:2072:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.180174760 5544 0x55a9a0091e80 ERROR v4l2 gstv4l2object.c:2072:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.180272863 5544 0x55a9a0091e80 ERROR v4l2 gstv4l2object.c:2072:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.180306214 5544 0x55a9a0091e80 ERROR v4l2 gstv4l2object.c:2072:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.181245757 5544 0x55a9a0091e80 WARN v4l2videodec gstv4l2videodec.c:1433:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder0> Duration invalid, not setting latency
0:00:00.181313391 5544 0x55a9a0091e80 WARN v4l2bufferpool gstv4l2bufferpool.c:1054:gst_v4l2_buffer_pool_start:<nvv4l2decoder0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:00.182739479 5544 0x7f867c0145e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1518:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:src> Driver should never set v4l2_buffer.field to ANY
If my GPU has some error or driver not compatible ?
NVIDIA® GeForce® GTX 1080 is listed. 1080Ti should also work well.
Could you clean cache and try again?
If the application encounters errors and cannot create Gst elements, remove the GStreamer cache, then try again. To remove the GStreamer cache, enter this command:
$ rm ${HOME}/.cache/gstreamer-1.0/registry.x86_64.bin
It doesn’t help. and I checked it in docker nvcr.io/nvidia/deepstream:4.0-19.07 also happen. And we checked it in tesla P4 also happen.
Now we will try in ubuntu 16.04 with docker 18.04 to exclude the OS error.
Hi ClancyLian,
Is this issue resolved? I am facing the same problem with the driver version 418.87.00, on my RTX 2070
Hi Clancy - Did moving to ubuntu 16.04 solve the driver problem for you?
fanis
May 29, 2020, 11:58am
12
Same problem for videos from deepstream samples:
GST_DEBUG=nvv4l2decoder,3 gst-launch-1.0 filesrc location=/opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_720p.h264 ! h264parse ! nvv4l2decoder ! fakesink
Setting pipeline to PAUSED …
0:00:00.029801169 22467 0x55b2d7acc040 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.029818111 22467 0x55b2d7acc040 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MJPG
kayccc
June 2, 2020, 5:27am
13
Hi fanis,
Please open a new topic for this issue. Thanks
I’m getting this same issue. Using:
Ubuntu Desktop x64 18.04.03 with 5+ kernel (Tested using server version with 4.15 kernel and got same result)
cuda_10.2.89_440.33.01_linux.run - to install cuda and the 440 driver
Using cudnn 7.6.5 (Test script works)
Installed the cuda-toolkit-10-2 using the apt .deb
TensorRt 7.0.0.11-ga-20191216
Using deepstream-5.0_5.0.0-1_amd64.deb
I’ve followed the steps correctly and nvv4l2decoder still throws the driver error:
0:00:00.288042600 27032 0x5605a579a0a0 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
GST_DEBUG=4 gst-inspect-1.0 nvv4l2decoder shows no errors.
But
Fails with the driver error.
ZZBB
February 2, 2021, 12:33pm
15
Any updates on this issue? I get the same result and have the same setup as Santiago.
any updates? I’m facing same issue on deepstream 5.1
kayccc
July 27, 2021, 4:03am
17
