Nvv4l2decoder Unable to try format: Unknown error -1
nvv4l2decoder throw errors within docker
  1. attach to docker with flowing command
    nvidia-docker run -it nvcr.io/nvidia/deepstream:5.0.1-20.09-devel bash
  2. execute flowing gstreamer pipline, and throw error
    GST_DEBUG=2 gst-launch-1.0 filesrc location=/opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h265.mp4 ! qtdemux name=c c.video_0 ! h265parse ! nvv4l2decoder ! fakesink
0:00:00.078927064 12 0x5618f47f4470 WARN ladspa gstladspa.c:507:plugin_init: no LADSPA plugins found, check LADSPA_PATH
0:00:00.198730335 12 0x5618f47f4470 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x120000: ‘AVR (Audio Visual Research)’ is not mapped
0:00:00.198754720 12 0x5618f47f4470 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x180000: ‘CAF (Apple Core Audio File)’ is not mapped
0:00:00.198762816 12 0x5618f47f4470 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x100000: ‘HTK (HMM Tool Kit)’ is not mapped
0:00:00.198773135 12 0x5618f47f4470 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0xc0000: ‘MAT4 (GNU Octave 2.0 / Matlab 4.2)’ is not mapped
0:00:00.198780689 12 0x5618f47f4470 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0xd0000: ‘MAT5 (GNU Octave 2.1 / Matlab 5.0)’ is not mapped
0:00:00.198789195 12 0x5618f47f4470 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x210000: ‘MPC (Akai MPC 2k)’ is not mapped
0:00:00.198797431 12 0x5618f47f4470 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0xe0000: ‘PVF (Portable Voice Format)’ is not mapped
0:00:00.198804795 12 0x5618f47f4470 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x160000: ‘SD2 (Sound Designer II)’ is not mapped
0:00:00.198814062 12 0x5618f47f4470 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x190000: ‘WVE (Psion Series 3)’ is not mapped
0:00:00.403004227 12 0x5618f47f4470 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libtrtserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:12): GStreamer-WARNING **: 14:14:03.843: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtrtserver.so: cannot open shared object file: No such file or directory
Setting pipeline to PAUSED ...
0:00:00.690651830    11 0x5637743b2210 WARN                    v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:00.690696143    11 0x5637743b2210 WARN                    v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MJPG
0:00:00.690706012    11 0x5637743b2210 WARN                    v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:00.690714518    11 0x5637743b2210 WARN                    v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MJPG
0:00:00.690745746    11 0x5637743b2210 WARN                    v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:00.690754393    11 0x5637743b2210 WARN                    v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MPG4
0:00:00.690761376    11 0x5637743b2210 WARN                    v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:00.690769942    11 0x5637743b2210 WARN                    v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MPG4
0:00:00.690788146    11 0x5637743b2210 WARN                    v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:00.690797113    11 0x5637743b2210 WARN                    v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat H265
0:00:00.690804747    11 0x5637743b2210 WARN                    v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:00.690812612    11 0x5637743b2210 WARN                    v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat H265
0:00:00.690830245    11 0x5637743b2210 WARN                    v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:00.690837699    11 0x5637743b2210 WARN                    v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat H264
0:00:00.690844412    11 0x5637743b2210 WARN                    v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:00.690851655    11 0x5637743b2210 WARN                    v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat H264
0:00:00.691302182    11 0x5637743b2210 WARN                    v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
0:00:00.691311860    11 0x5637743b2210 WARN                    v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe minimum capture size for pixelformat NM12
0:00:00.691318813    11 0x5637743b2210 WARN                    v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
0:00:00.691325947    11 0x5637743b2210 WARN                    v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe maximum capture size for pixelformat NM12
0:00:00.691339392    11 0x5637743b2210 WARN                    v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x563774429200 Failed to determine interlace mode
0:00:00.691903422    11 0x5637743b2210 WARN                 basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<filesrc0> pad not activated yet
Pipeline is PREROLLING ...
0:00:00.692681224    11 0x56377443f320 WARN                 qtdemux qtdemux.c:3031:qtdemux_parse_trex:<c> failed to find fragment defaults for stream 1
0:00:00.692942474    11 0x56377443f320 WARN                 qtdemux qtdemux.c:3031:qtdemux_parse_trex:<c> failed to find fragment defaults for stream 2
0:00:00.922996905    11 0x56377443f320 ERROR                   v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.923038243    11 0x56377443f320 ERROR                   v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.923080632    11 0x56377443f320 ERROR                   v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.923089589    11 0x56377443f320 ERROR                   v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.923121509    11 0x56377443f320 ERROR                   v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.923129504    11 0x56377443f320 ERROR                   v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.923156775    11 0x56377443f320 ERROR                   v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.923164770    11 0x56377443f320 ERROR                   v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.923191681    11 0x56377443f320 ERROR                   v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.923198794    11 0x56377443f320 ERROR                   v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.923228049    11 0x56377443f320 ERROR                   v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.923235163    11 0x56377443f320 ERROR                   v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.923611009    11 0x56377443f320 WARN            v4l2videodec gstv4l2videodec.c:1614:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder0> Duration invalid, not setting latency
0:00:00.923639623    11 0x56377443f320 WARN          v4l2bufferpool gstv4l2bufferpool.c:1057:gst_v4l2_buffer_pool_start:<nvv4l2decoder0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:00.924657075    11 0x7f5e880126d0 WARN          v4l2bufferpool gstv4l2bufferpool.c:1503:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:src> Driver should never set v4l2_buffer.field to ANY
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Got EOS from element "pipeline0".
Blockquote
Execution ended after 0:00:01.243886687
Setting pipeline to PAUSED …
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
Hardware information
root@d85556ffce6d:/opt/nvidia/deepstream/deepstream-5.0# nvidia-smi
Sat Nov 7 14:19:55 2020
| NVIDIA-SMI 450.80.02 Driver Version: 450.80.02 CUDA Version: 11.0 |
| | | MIG M. |
| 0 Tesla P4 Off | 00000000:21:00.0 Off | 0 |
| N/A 35C P8 6W / 75W | 0MiB / 7611MiB | 0% Default |
| | | N/A |
| 1 Tesla T4 Off | 00000000:41:00.0 Off | 0 |
| N/A 35C P8 9W / 70W | 0MiB / 15109MiB | 0% Default |
| | | N/A |
| 2 Tesla T4 Off | 00000000:61:00.0 Off | 0 |
| N/A 36C P8 9W / 70W | 0MiB / 15109MiB | 0% Default |
| | | N/A |
| 3 Tesla T4 Off | 00000000:C1:00.0 Off | 0 |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
r
The log is OK. What is your problem?
你看不到错误日志吗? Chen
0:00:00.690651830 11 0x5637743b2210 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
This warning. Not error. Please ignore it. It will not impact decoding.
This is error
0:00:00.923191681 11 0x56377443f320 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
I guess the warning maybe cause the error.
No. The log is OK.It is no harm. Please ignore it.
But this is truly Error log. I will try again.
0:00:00.923235163 11 0x56377443f320 ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from Making sure you're not a bot!
We know this log, and we know the reason it print out. It is OK. It will not impact decoding.
