Nvv4l2decoder got stuck in Deepstream6.1.1
• Hardware Platform ( GPU): A30X
• DeepStream Version: 6.1.1
• TensorRT Version: 8.4.1.5
**• NVIDIA GPU Driver Version: 515.65.01 **
• Issue Type: questions
I started the DeepStream docker container (nvcr.io/nvidia/deepstream: 6.1.1-devel) and ran the following pipeline:
gst-launch-1.0 -e filesrc location=./xxx.mp4 !
qtdemux !
h264parse !
nvv4l2decoder !
fakesink dump=True
However, nvv4l2decoder got stuck in Deepstream6.1.1.
Do you know why nvv4l2decoder stucks?
Is there a problem with the execution environment?
The environment is:
Hardware Platform(GPU):A30X
docker image:nvcr.io/nvidia/deepstream:6.1.1-devel
OS:ubuntu20.04
cuda:11.7.1
GPU Driver:515.65.01
TensorRT Version:8.4.1.5
Is there any output after executing the command? You can add "GST_DEBUG=3 " before gst-launch-1.0 to enable more log to find more clues.
The following log was output:.
Do you know why nvv4l2decoder got stuck?
GST_DEBUG=3 gst-launch-1.0 -e filesrc location=/opt/nvidia/deepstream/deepstream-6.1/samples/streams/sample_1080p_h264.mp4 !
qtdemux ! h264parse ! nvv4l2decoder ! fakesink dump=True
Setting pipeline to PAUSED …
0:00:00.133263795 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.133291428 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MJPG
0:00:00.133296217 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.133300716 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MJPG
0:00:00.133312999 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.133317348 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat AV10
0:00:00.133324431 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.133328679 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat AV10
0:00:00.133337637 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.133343007 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat DVX5
0:00:00.133347335 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.133352405 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat DVX5
0:00:00.133360180 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.133364899 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat DVX4
0:00:00.133369127 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.133374157 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat DVX4
0:00:00.133383034 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.133389286 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MPG4
0:00:00.133395007 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.133401088 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MPG4
0:00:00.133412911 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.133418632 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MPG2
0:00:00.133422349 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.133427188 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MPG2
0:00:00.133436095 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.133441987 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H265
0:00:00.133447417 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.133452827 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H265
0:00:00.133459931 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.133465532 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat VP90
0:00:00.133470582 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.133475591 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat VP90
0:00:00.133485590 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.133492403 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat VP80
0:00:00.133498064 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.133502713 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat VP80
0:00:00.133554352 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.133560544 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H264
0:00:00.133566025 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.133571926 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H264
0:00:00.133934732 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:00.133942226 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe minimum capture size for pixelformat NM12
0:00:00.133947446 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:00.133952366 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe maximum capture size for pixelformat NM12
0:00:00.133960461 70 0x55a64cc0f8c0 WARN v4l2 gstv4l2object.c:2395:gst_v4l2_object_add_interlace_mode:0x55a64cc0eaf0 Failed to determine interlace mode
0:00:00.134204580 70 0x55a64cc0f8c0 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete: pad not activated yet
Pipeline is PREROLLING …
0:00:00.134566313 70 0x55a64cbe06a0 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:00.134684620 70 0x55a64cbe06a0 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex: failed to find fragment defaults for stream 2
I have exactly the same problem with 2 A30 GPUs on the same server.
The kind of deadlock happens with driver 515.65.01 and also 515.48.07.
In my case I tried it with a h265 stream, but I guess it would happen with h264 too.
We are running DeepStream 6.0.1, but the same happens with the docker image of 6.1 and 5.1-21.02.
Using CPU decoder make my pipeline works, and of course it’s not an option.
We have another server with the same A30 GPU that is working fine with driver 510.47.03.
We haven’t tested yet to downgrade the driver version on the server running with 515.
gst-launch output gives me:
0:00:01.728621898   145 0x7f2a3c0084a0 DEBUG           v4l2videodec gstv4l2videodec.c:1740:gst_v4l2_video_dec_sink_getcaps:<nvv4l2decoder0> Returning sink caps video/x-h265, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ], framerate=(fraction)[ 0/1, 2147483647/1 ], stream-format=(string)byte-stream, alignment=(string)au, parsed=(boolean)true
0:00:01.728800158   145 0x7f2a3c0084a0 DEBUG           v4l2videodec gstv4l2videodec.c:1740:gst_v4l2_video_dec_sink_getcaps:<nvv4l2decoder0> Returning sink caps video/x-h265, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ], framerate=(fraction)[ 0/1, 2147483647/1 ], stream-format=(string)byte-stream, alignment=(string)au, parsed=(boolean)true
0:00:01.733844059   145 0x7f2a3c0084a0 DEBUG           v4l2videodec gstv4l2videodec.c:1740:gst_v4l2_video_dec_sink_getcaps:<nvv4l2decoder0> Returning sink caps video/x-h265, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ], framerate=(fraction)[ 0/1, 2147483647/1 ], stream-format=(string)byte-stream, alignment=(string)au, parsed=(boolean)true
0:00:01.734314872   145 0x7f2a3c0084a0 DEBUG           v4l2videodec gstv4l2videodec.c:1740:gst_v4l2_video_dec_sink_getcaps:<nvv4l2decoder0> Returning sink caps video/x-h265, width=(int)2592, height=(int)1944, framerate=(fraction)25/1, stream-format=(string)byte-stream, alignment=(string)au, parsed=(boolean)true, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, profile=(string)main, tier=(string)main, level=(string)5
0:00:01.734414035   145 0x7f2a3c0084a0 DEBUG           v4l2videodec gstv4l2videodec.c:704:gst_v4l2_video_dec_set_format:<nvv4l2decoder0> Setting format: video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, width=(int)2592, height=(int)1944, framerate=(fraction)25/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, profile=(string)main, tier=(string)main, level=(string)5
0:00:01.737964417   145 0x7f2a3c0084a0 DEBUG           v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 0
0:00:01.737994678   145 0x7f2a3c0084a0 DEBUG           v4l2videodec gstv4l2videodec.c:1389:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Sending header
Then nothing happens.
Downgrading to 510.85.02 made my pipeline work!
Something is bad with 515 and A30. (I have 515 with A100 and other GPUs working fine).
The issue specific to A30 card. internal bug filed to track this issue.
Thanks @Amycao, will you post here news when it’s fixed? just to know when we can update safely the drivers.
Yes.
