• Hardware Platform (GPU) • DeepStream Version (docker 6.1-triton) • NVIDIA GPU Driver Version 555.48.07 (valid for GPU only) • Issue Type(bugs)
**• How to reproduce the issue ? **
Use the command:
gst-launch-1.0 uridecodebin uri=rtsp://admin:123456@192.168.1.25:554 ! fakesink
• Requirement details
The log:
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://admin:123456@192.168.1.25:554
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
Progress: (open) Opened Stream
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Progress: (request) Sending PLAY request
Progress: (request) Sent PLAY request
Missing element: H.264 (Main Profile) decoder
WARNING: from element /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0: No decoder available for type 'video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)4, profile=(string)main, width=(int)1920, height=(int)1080, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true'.
Additional debug info:
gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0
ERROR: from element /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0: Your GStreamer installation is missing a plug-in.
gsturidecodebin.c(987): no_more_pads_full (): /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0:
no suitable plugins found:
gstdecodebin2.c(4678): gst_decode_bin_expose (): /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0:
Couldn't set nvv4l2decoder0 to PAUSED:
GStreamer encountered a general resource error.
Device '/dev/nvidia0' failed during initialization
gstv4l2object.c(4114): gst_v4l2_object_set_format_full (): /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/nvv4l2decoder:nvv4l2decoder0:
Call to S_FMT failed for H264 @ 1920x1080: Unknown error -1
Execution ended after 0:00:04.147290883
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
I have three 3080 machines, I use docker pull nvcr.io/nvidia/deepstream:6.1.1-triton - download the image and use the ‘docker run --gpus all --net=host -itd --cap-add sys_ptrace --name deepstream_triton deepstream6.1’ startup. One machine is working normally all the time, one started to work after power failure and restart, and the other machine is not working. The two machines with the problem report the same error.
It is under directory /opt/nvidia/deepstream/deepstream-6.1, please execute this command and then test again, you can add " GST_DEBUG=3 " before you gst-launch-1.0 command for extra debug info.
I don’t have in the/opt/nvidia/deepstream/deepstream/ found user_additional_install.sh scripts
This is what my directory contains:
root@localhost:/opt/nvidia/deepstream/deepstream-6.1# ls
LICENSE.txt LicenseAgreement.pdf LicenseAgreementContainer.pdf README README.rhel bin entrypoint.sh install.sh lib samples sources uninstall.sh version
Seems it is introduced in DeepStream 6.1.1 container, my local 6.1.1 version has this file, just downloaded a DS6.1-triton container and there is no such file as you listed.
So you have 3 PC, now 2 of them can work, only one PC has such issue, correct? What’s the difference between the working and non-working PC&config? What’s the output of runnling localfile(gst-launch-1.0 uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4 ! fakesink) ?
All I know is that these three machines have 3080 graphics cards and use the same docker.
this is result:
root@localhost:/home/# gst-launch-1.0 uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4 ! fakesink
Pipeline is PREROLLING ...
Missing element: H.264 (High Profile) decoder
WARNING: from element /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0: No decoder available for type 'video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)1280, height=(int)720, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true'.
Pipeline is PREROLLED ...
Got EOS from element "pipeline0".
Execution ended after 0:00:00.157070746
Just look at the environment and plugin everything works, but execute gst-launch-1.0 uridecodebin uri=***! fakesink command can not find decoder, how to explain this.
It is just a warning in early stage when uridecodebin try to look for decoder, it finally found the correct decoder and the pipeline play and got EOS successfully. No error happened.
This is when I set GST_DEBUG=3 to execute gst-launch-1.0 uridecodebin in both normal and abnormal environments uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4 ! Detailed printing of fakesink.Obviously there was an error printed.
Execution ended after 0:00:00.905707455
root@localhost:/opt/nvidia/deepstream/deepstream-6.1# export GST_DEBUG=3
root@localhost:/opt/nvidia/deepstream/deepstream-6.1# gst-launch-1.0 uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4 ! fakesink
0:00:00.032882189 67872 0x563ae2583a70 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete:<source> pad not activated yet
0:00:00.033668809 67872 0x563ae2583a70 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete:<source> pad not activated yet
0:00:00.043699067 67872 0x563ae2598700 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type sgpd
0:00:00.043770894 67872 0x563ae2598700 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type sbgp
0:00:00.043876017 67872 0x563ae2598700 WARN qtdemux qtdemux.c:3237:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 1
0:00:00.044111543 67872 0x563ae2598700 WARN qtdemux qtdemux.c:3237:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 2
0:00:00.076799782 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: 未知的错误 -1
0:00:00.076858651 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:2941:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MJPG
0:00:00.076885618 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: 未知的错误 -1
0:00:00.076947043 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:2947:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MJPG
0:00:00.076996450 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: 未知的错误 -1
0:00:00.077022636 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:2941:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat DVX5
0:00:00.077045921 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: 未知的错误 -1
0:00:00.077071430 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:2947:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat DVX5
0:00:00.077103066 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: 未知的错误 -1
0:00:00.077127657 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:2941:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat DVX4
0:00:00.077154522 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: 未知的错误 -1
0:00:00.077178589 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:2947:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat DVX4
0:00:00.077233460 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: 未知的错误 -1
0:00:00.077258954 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:2941:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MPG4
0:00:00.077281656 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: 未知的错误 -1
0:00:00.077325927 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:2947:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MPG4
0:00:00.077357942 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: 未知的错误 -1
0:00:00.077384793 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:2941:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MPG2
0:00:00.077427685 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: 未知的错误 -1
0:00:00.077466895 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:2947:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MPG2
0:00:00.077501813 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: 未知的错误 -1
0:00:00.077526652 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:2941:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat H265
0:00:00.077549912 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: 未知的错误 -1
0:00:00.077573632 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:2947:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat H265
0:00:00.077620936 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: 未知的错误 -1
0:00:00.077647278 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:2941:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat VP90
0:00:00.077670128 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: 未知的错误 -1
0:00:00.077694297 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:2947:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat VP90
0:00:00.077724065 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: 未知的错误 -1
0:00:00.077749243 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:2941:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat VP80
0:00:00.077772352 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: 未知的错误 -1
0:00:00.077796094 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:2947:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat VP80
0:00:00.077828326 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: 未知的错误 -1
0:00:00.077857081 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:2941:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat H264
0:00:00.077880404 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: 未知的错误 -1
0:00:00.077904315 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:2947:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat H264
0:00:00.078742871 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: 未知的错误 -1
0:00:00.078776383 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:2941:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe minimum capture size for pixelformat NM12
0:00:00.078801307 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: 未知的错误 -1
0:00:00.078826961 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:2947:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe maximum capture size for pixelformat NM12
0:00:00.078856386 67872 0x7f2540052460 WARN v4l2 gstv4l2object.c:2394:gst_v4l2_object_add_interlace_mode:0x7f253003a020 Failed to determine interlace mode
0:00:00.335538465 67872 0x7f2540052460 WARN v4l2videodec gstv4l2videodec.c:1779:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder0> Duration invalid, not setting latency
0:00:00.335598123 67872 0x7f2540052460 WARN v4l2bufferpool gstv4l2bufferpool.c:1049:gst_v4l2_buffer_pool_start:<nvv4l2decoder0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:00.337237857 67872 0x7f253c00cf60 WARN v4l2bufferpool gstv4l2bufferpool.c:1499:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:src> Driver should never set v4l2_buffer.field to ANY
0:00:01.244957438 67872 0x7f25400525e0 WARN audiodecoder gstaudiodecoder.c:1753:gst_audio_decoder_drain:<faad0> still 1 frames left after draining
Execution ended after 0:00:00.908607087
0:00:00.022992002 8834 0x557f029a8a70 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete:<source> pad not activated yet
0:00:00.023430134 8834 0x557f029a8a70 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete:<source> pad not activated yet
0:00:00.032574051 8834 0x557f029b4b00 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type sgpd
0:00:00.032653402 8834 0x557f029b4b00 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type sbgp
0:00:00.032764083 8834 0x557f029b4b00 WARN qtdemux qtdemux.c:3237:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 1
0:00:00.033023382 8834 0x557f029b4b00 WARN qtdemux qtdemux.c:3237:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 2
0:00:02.085113171 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:02.085191364 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:2941:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MJPG
0:00:02.085226704 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:02.085265210 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:2947:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MJPG
0:00:02.085368305 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:02.085401343 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:2941:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat DVX5
0:00:02.085430574 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:02.085462636 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:2947:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat DVX5
0:00:02.085510618 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:02.085555081 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:2941:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat DVX4
0:00:02.085584595 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:02.085614787 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:2947:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat DVX4
0:00:02.085657681 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:02.085725251 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:2941:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MPG4
0:00:02.085773898 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:02.085806966 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:2947:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MPG4
0:00:02.085863181 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:02.085895368 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:2941:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MPG2
0:00:02.085924787 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:02.085984769 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:2947:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MPG2
0:00:02.086035636 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:02.086067519 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:2941:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat H265
0:00:02.086098747 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:02.086130797 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:2947:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat H265
0:00:02.086173159 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:02.086206450 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:2941:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat VP90
0:00:02.086237698 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:02.086268114 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:2947:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat VP90
0:00:02.086310667 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:02.086342538 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:2941:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat VP80
0:00:02.086392210 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:02.086439994 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:2947:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat VP80
0:00:02.086491514 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:02.086522621 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:2941:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat H264
0:00:02.086555740 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:02.086587797 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:2947:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat H264
0:00:02.087684083 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
0:00:02.087729916 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:2941:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe minimum capture size for pixelformat NM12
0:00:02.087760766 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:3056:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
0:00:02.087794260 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:2947:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe maximum capture size for pixelformat NM12
0:00:02.087852539 8834 0x7fbe24052c60 WARN v4l2 gstv4l2object.c:2394:gst_v4l2_object_add_interlace_mode:0x7fbe1403a020 Failed to determine interlace mode
0:00:02.088790825 8834 0x7fbe24052c60 WARN default v4l2-utils.c:189:gst_v4l2_error:<nvv4l2decoder0> error: Device '/dev/nvidia0' failed during initialization
0:00:02.088852206 8834 0x7fbe24052c60 WARN default v4l2-utils.c:192:gst_v4l2_error:<nvv4l2decoder0> error: Call to S_FMT failed for H264 @ 1280x720: Unknown error -1
0:00:02.088958115 8834 0x7fbe24052c60 WARN videodecoder gstvideodecoder.c:743:gst_video_decoder_setcaps:<nvv4l2decoder0> Subclass refused caps
0:00:02.088996660 8834 0x7fbe24052c60 WARN decodebin gstdecodebin2.c:2523:connect_pad:<decodebin0> Couldn't set nvv4l2decoder0 to PAUSED
0:00:02.089793643 8834 0x7fbe24052c60 WARN uridecodebin gsturidecodebin.c:920:unknown_type_cb:<uridecodebin0> warning: No decoder available for type 'video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)1280, height=(int)720, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true'.
0:00:02.256278316 8834 0x7fbe24052de0 WARN audiodecoder gstaudiodecoder.c:1753:gst_audio_decoder_drain:<faad0> still 1 frames left after draining
Execution ended after 0:00:00.164331371
