Hi @yuweiw , the following will work:
gst-launch-1.0 --gst-debug=v4l2videodec:5 rtspsrc location=$RTSP_STREAM protocols=tcp latency=1000 drop-on-latency=1 timeout=5000000 ! rtph264depay ! h264parse ! nvv4l2decoder cudadec-memtype=2 num-extra-surfaces=1 ! queue leaky=2 max-size-buffers=1 ! nvvideoconvert nvbuf-memory-type=3 output-buffers=1 ! capsfilter caps=video/x-raw,format=RGBA ! fakesink
This the output I have:
0:00:00.066831278 12552 0x5627407b18f0 DEBUG v4l2videodec gstv4l2videodec.c:1740:gst_v4l2_video_dec_sink_getcaps:<nvv4l2decoder0> Returning sink caps image/jpeg, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]; video/x-h264, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], stream-format=(string){ byte-stream }, alignment=(string){ au }; video/x-h265, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], stream-format=(string){ byte-stream }, alignment=(string){ au }; video/mpeg, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], mpegversion=(int)4, systemstream=(boolean)false, parsed=(boolean)true; video/mpeg, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], mpegversion=(int)[ 1, 2 ], systemstream=(boolean)false, parsed=(boolean)true; video/x-divx, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], divxversion=(int)[ 4, 5 ]; video/x-vp8, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]; video/x-vp9, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:00.066910670 12552 0x5627407b18f0 DEBUG v4l2videodec gstv4l2videodec.c:1740:gst_v4l2_video_dec_sink_getcaps:<nvv4l2decoder0> Returning sink caps image/jpeg, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]; video/x-h264, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], stream-format=(string){ byte-stream }, alignment=(string){ au }; video/x-h265, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], stream-format=(string){ byte-stream }, alignment=(string){ au }; video/mpeg, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], mpegversion=(int)4, systemstream=(boolean)false, parsed=(boolean)true; video/mpeg, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], mpegversion=(int)[ 1, 2 ], systemstream=(boolean)false, parsed=(boolean)true; video/x-divx, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], divxversion=(int)[ 4, 5 ]; video/x-vp8, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]; video/x-vp9, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:00.066935338 12552 0x5627407b18f0 DEBUG v4l2videodec gstv4l2videodec.c:1716:gst_v4l2_video_dec_src_query:<nvv4l2decoder0> Returning src caps video/x-raw(memory:NVMM), width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:00.066956286 12552 0x5627407b18f0 DEBUG v4l2videodec gstv4l2videodec.c:1716:gst_v4l2_video_dec_src_query:<nvv4l2decoder0> Returning src caps video/x-raw(memory:NVMM), width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:00.066973847 12552 0x5627407b18f0 DEBUG v4l2videodec gstv4l2videodec.c:1716:gst_v4l2_video_dec_src_query:<nvv4l2decoder0> Returning src caps video/x-raw(memory:NVMM), width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:00.067026633 12552 0x5627407b18f0 DEBUG v4l2videodec gstv4l2videodec.c:1716:gst_v4l2_video_dec_src_query:<nvv4l2decoder0> Returning src caps video/x-raw(memory:NVMM), width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:00.067069773 12552 0x5627407b18f0 DEBUG v4l2videodec gstv4l2videodec.c:1716:gst_v4l2_video_dec_src_query:<nvv4l2decoder0> Returning src caps video/x-raw(memory:NVMM), width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:00.067109192 12552 0x5627407b18f0 DEBUG v4l2videodec gstv4l2videodec.c:1716:gst_v4l2_video_dec_src_query:<nvv4l2decoder0> Returning src caps video/x-raw(memory:NVMM), width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:00.067147533 12552 0x5627407b18f0 DEBUG v4l2videodec gstv4l2videodec.c:1716:gst_v4l2_video_dec_src_query:<nvv4l2decoder0> Returning src caps video/x-raw(memory:NVMM), width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:00.067183587 12552 0x5627407b18f0 DEBUG v4l2videodec gstv4l2videodec.c:1716:gst_v4l2_video_dec_src_query:<nvv4l2decoder0> Returning src caps video/x-raw(memory:NVMM), width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
Setting pipeline to PAUSED ...
0:00:00.067265417 12552 0x5627407b18f0 DEBUG v4l2videodec gstv4l2videodec.c:565:gst_v4l2_video_dec_open:<nvv4l2decoder0> Opening
0:00:00.068350077 12552 0x5627407b18f0 DEBUG v4l2videodec gstv4l2videodec.c:647:gst_v4l2_video_dec_start:<nvv4l2decoder0> Starting
Pipeline is live and does not need PREROLL ...
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://......................
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
Progress: (open) Opened Stream
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Progress: (request) Sending PLAY request
Progress: (request) Sent PLAY request
0:00:01.391966005 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1740:gst_v4l2_video_dec_sink_getcaps:<nvv4l2decoder0> Returning sink caps video/x-h264, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ], framerate=(fraction)[ 0/1, 2147483647/1 ], stream-format=(string)byte-stream, alignment=(string)au, parsed=(boolean)true
0:00:01.392131583 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1740:gst_v4l2_video_dec_sink_getcaps:<nvv4l2decoder0> Returning sink caps video/x-h264, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ], framerate=(fraction)[ 0/1, 2147483647/1 ], stream-format=(string)byte-stream, alignment=(string)au, parsed=(boolean)true
0:00:01.392273472 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1740:gst_v4l2_video_dec_sink_getcaps:<nvv4l2decoder0> Returning sink caps video/x-h264, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ], framerate=(fraction)[ 0/1, 2147483647/1 ], stream-format=(string)byte-stream, alignment=(string)au, parsed=(boolean)true
0:00:01.392325174 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:704:gst_v4l2_video_dec_set_format:<nvv4l2decoder0> Setting format: video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, parsed=(boolean)true
0:00:01.393229369 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1740:gst_v4l2_video_dec_sink_getcaps:<nvv4l2decoder0> Returning sink caps video/x-h264, width=(int)800, height=(int)600, framerate=(fraction)13500000/465517, stream-format=(string)byte-stream, alignment=(string)au, parsed=(boolean)true, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, profile=(string)high, level=(string)3.1
0:00:01.393260420 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:704:gst_v4l2_video_dec_set_format:<nvv4l2decoder0> Setting format: video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)800, height=(int)600, framerate=(fraction)13500000/465517, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, profile=(string)high, level=(string)3.1
0:00:01.393883495 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 0
0:00:01.393895854 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1389:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Sending header
0:00:01.619232787 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1482:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Acquired caps: video/x-raw, format=(string)NV12, width=(int)800, height=(int)600, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)1:3:5:1, framerate=(fraction)0/1
0:00:01.619419480 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1489:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Available caps: image/jpeg, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)800, height=(int)608, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }; video/x-raw, format=(string)NV12, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)800, height=(int)608, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }; video/mpeg, mpegversion=(int)4, systemstream=(boolean)false, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)800, height=(int)608, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }; video/mpeg, mpegversion=(int)2, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)800, height=(int)608, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }; video/x-vp9, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)800, height=(int)608, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }; video/x-vp8, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)800, height=(int)608, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }; video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)800, height=(int)608, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }; video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)800, height=(int)608, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }
0:00:01.619459139 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1497:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Filtered caps: EMPTY
0:00:01.619554930 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1514:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Possible decoded caps: video/x-raw(memory:NVMM), width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], format=(string){ I420, NV12, P010_10LE, BGRx, RGBA, GRAY8, GBR }
0:00:01.619570253 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1523:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Chosen decoded caps: video/x-raw(memory:NVMM), width=(int)1, height=(int)1, framerate=(fraction)0/1, format=(string)I420
0:00:01.619959132 12552 0x7f8934037190 WARN v4l2videodec gstv4l2videodec.c:1685:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder0> Duration invalid, not setting latency
0:00:01.620303087 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1576:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Starting decoding thread
0:00:01.620413833 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 1
0:00:01.620470077 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 2
0:00:01.620515588 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 3
0:00:01.620575964 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 4
0:00:01.620616567 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 5
0:00:01.620657608 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 6
0:00:01.620694136 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 7
0:00:01.620735514 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 8
0:00:01.620788366 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 9
0:00:01.620835270 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 10
0:00:01.620879750 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 11
0:00:01.620918937 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 12
0:00:01.620956976 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 13
0:00:01.620995358 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 14
0:00:01.621032922 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 15
0:00:01.621071502 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 16
0:00:01.621109258 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 17
0:00:01.621149378 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 18
0:00:01.621194887 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 19
0:00:01.621240832 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 20
0:00:01.621279026 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 21
0:00:01.621317116 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 22
0:00:01.621354811 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 23
0:00:01.621401401 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 24
0:00:01.621439960 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 25
0:00:01.621485130 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 26
0:00:01.621523280 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 27
0:00:01.621562277 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 28
0:00:01.621680045 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 29
0:00:01.621753093 12552 0x7f8934037190 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 30
